» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 89 online users.
» 0 Member(s) | 72 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot, owler
kc868-a6 analog input
11 hours ago
F24 ESPHome yaml for home...
Forum: F24
Today, 07:25 AM
Forum: F24
Today, 05:35 AM
Forum: F24
Today, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Today, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  A16v3 help needed ifttt
Posted by: OliverMkp - 03-19-2025, 11:00 AM - Forum: DIY Project - Replies (2)
I am trying to trigger a webhook but it dont work.
How do I have to setup ifttt?
HTTP Server is enabled
my webhook adress is: https://hook.eu1.make.com/6yyjeeeopcdlru...u70zc4jt8v
I put this Url in custom protocol and activated HTTP GET and HTTP Post.
I have chosen this protocol in ifttt an can run this succesfully, but my webhook do not work.
Can anybody help me, to setup a trigger for webhooks?
Thank you in advance
Oliver
  Feature Request: MQTT with HA auto discovery - please pass through Input/Output names
Posted by: useful21 - 03-18-2025, 07:15 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Thanks for the an awesome product and the MQTT auto discover feature for Home Assistant (HA).
However, I discovered that after carefully naming my Digital Inputs and Digital Outputs inside the KinCony, via MQTT for HA and auto discover, only the generic names are published.
It would make using Home Assistant and keeping the names of each Input and Output in sync so much easier if the actual named value of the Inputs/Outputs as set in the KinCony were passed through to HA.
Feature Request
Use the actual names as set inside KinCony for sensor names for Home Assistant MQTT auto discover.
A16V3, v3.8.0, setting Input & Output names:
Home Assistant, showing KinCony sensors as created by MQTT HA auto discover:
  KC868-E16T added Tuya module and input toggle output yaml file for ESPHome
Posted by: admin - 03-18-2025, 10:05 AM - Forum: KC868-E16T - Replies (6)
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
  - source:
      type: git
      ref: v1.1.0
  tx_pin: 33
  rx_pin: 14
  baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: tfj1dtlneyxp5uya
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 5
  wifi_led_pin: 12
  sda: 16
  scl: 15
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x21
    address: 0x25
# Individual outputs
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "e16t_output1"
    dp_id: 2
    internal: true
    bind_switch_id: "e16t_output2"
    dp_id: 3
    internal: true
    bind_switch_id: "e16t_output3"
    dp_id: 4
    internal: true
    bind_switch_id: "e16t_output4"
    dp_id: 5
    internal: true
    bind_switch_id: "e16t_output5"
    dp_id: 6
    internal: true
    bind_switch_id: "e16t_output6"
    dp_id: 101
    internal: true
    bind_switch_id: "e16t_output7"
    dp_id: 102
    internal: true
    bind_switch_id: "e16t_output8"
      pcf8574: pcf8574_hub_out_2
    dp_id: 103
    internal: true
    bind_switch_id: "e16t_output9"
    dp_id: 104
    internal: true
    bind_switch_id: "e16t_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "e16t_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "e16t_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "e16t_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "e16t_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "e16t_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "e16t_output16"
    on_press:
      then:
        - switch.toggle: e16t_output1
    name: e16t DI01 Tuya
    dp_id: 111
    bind_binary_sensor_id: e16t_input1
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output2
    name: e16t DI02 Tuya
    dp_id: 112
    bind_binary_sensor_id: e16t_input2
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output3
    name: e16t DI03 Tuya
    dp_id: 113
    bind_binary_sensor_id: e16t_input3
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output4
    name: e16t DI04 Tuya
    dp_id: 114
    bind_binary_sensor_id: e16t_input4
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output5
    name: e16t DI05 Tuya
    dp_id: 115
    bind_binary_sensor_id: e16t_input5
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output6
    name: e16t DI06 Tuya
    dp_id: 116
    bind_binary_sensor_id: e16t_input6
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output7
    name: e16t DI07 Tuya
    dp_id: 117
    bind_binary_sensor_id: e16t_input7
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output8
    name: e16t DI08 Tuya
    dp_id: 118
    bind_binary_sensor_id: e16t_input8
    internal: true
      pcf8574: pcf8574_hub_in_2
    on_press:
      then:
        - switch.toggle: e16t_output9
    name: e16t DI09 Tuya
    dp_id: 119
    bind_binary_sensor_id: e16t_input9
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output10
    name: e16t DI10 Tuya
    dp_id: 120
    bind_binary_sensor_id: e16t_input10
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output11
    name: e16t DI11 Tuya
    dp_id: 121
    bind_binary_sensor_id: e16t_input11
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output12
    name: e16t DI12 Tuya
    dp_id: 122
    bind_binary_sensor_id: e16t_input12
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output13
    name: e16t DI13 Tuya
    dp_id: 123
    bind_binary_sensor_id: e16t_input13
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output14
    name: e16t DI14 Tuya
    dp_id: 124
    bind_binary_sensor_id: e16t_input14
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output15
    name: e16t DI15 Tuya
    dp_id: 125
    bind_binary_sensor_id: e16t_input15
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output16
    name: e16t DI16 Tuya
    dp_id: 126
    bind_binary_sensor_id: e16t_input16
    internal: true
firmware BIN file download:
.zip   e16t.factory_tuya.zip (Size: 372.83 KB / Downloads: 803)
  Presence Sensor Remote Control User Manual
Posted by: admin - 03-18-2025, 12:39 AM - Forum: Extender module - No Replies
Presence Sensor Remote Control User Manual PDF
.pdf   Presence-Sensor-Remote-Control-User-Manual.pdf (Size: 558.23 KB / Downloads: 807)
  KC868-AIO question
Posted by: pallermo - 03-17-2025, 11:12 PM - Forum: KC868-A series and Uair Smart Controller - Replies (6)
Hello to all,
I have one question regarding this device or any other with RS485 interface.
Can I control some device with rs485 or to receive some commands or information from another device? I want to be able to control heat pump (it has rs485) and my power generator (modbus). Also, my ATS (automatic transfer switch) has modbus option. I want to be able to do some controlling from KC868 devices to mentioned devices, receive some status etc...
Like for power generator - load, temperature, fuel etc...For heat pump, there are many things to receive or to control it. Remotely I can start heat pump with RS485. Is he able to send commands to any of mentioned devices with commands and also to receive feedback from devices to know the status of it?
With heat pump, remote controllers (in the room) are sending info about temps in the rooms to main outdoor device. Main device can provide those temps to KC868 via RS485 but the question is - how to program it to be able to read those messages and display temperatures inside the rooms. Is this possible at all?
Also, what is the proper way for expanding number of i/o for this device? How it can be achieved? thanks
  Using SPI connectors labeled for nRF24L01/LoRA on KC868-A6v3
Posted by: dereknet - 03-17-2025, 06:32 PM - Forum: Development - Replies (1)
Can the SPI connectors labeled for nRF24L01 and LoRA on the KC868-A6v3 board be safely used to connect other SPI-based modules, such as a CC1101 RF433 transceiver?
Are there any limitations or conflicts with other board functions when using these SPI connectors (e.g. relays)?
  A32PRO - multiple 1-wire
Posted by: RichieNa - 03-17-2025, 02:49 PM - Forum: KC868-A32/A32 Pro - Replies (1)
I use A32PRO with software version v3.4.0 only via KCS web page and then to Loxone. I also bought several DS18B20 sensors with A32PRO, but only later I found out that I can only connect 1+1 piece to W1 and W2. I found a few posts here that solve this via ESP HOME, but I never used them.. How to get support for multiple sensors at once into an already running A32PRO without disrupting my existing settings? Or how can I make a backup of my program in A32PRO, in case something gets disrupted.
Sorry for the noob question, but I have never worked with ESP HOME and I am afraid that I will ruin the existing installation, on which part of my house is already running.
I found these threads here on the forum:
https://www.kincony.com/forum/showthread.php?tid=2290
https://www.kincony.com/forum/showthread...ht=DS18B20
https://www.kincony.com/forum/showthread...ight=1wire
Can I use one of them to get support for multiple DS18B20 sensors into the KCS firmware and subsequently into Loxone?
Thank you
  KC868-A6-V3
Posted by: yuchris - 03-17-2025, 02:42 PM - Forum: "KCS" v3 firmware - Replies (7)
I follow the website to download v3 firmware.
Download success, then i power cycle it.
but it didnt boot...i have LCD panel.
please share how to complete firmware loading procedure
  DHT22 and SCD40 Sensors
Posted by: esskay - 03-17-2025, 01:48 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Greetings, Please advise as to what pins to use for a DHT22 Temp/Humidity sensor as well as an SCD40 Temp/Humidity/CO2 sensor.
Appreciated.
  SD-Card in KC868-A16v3
Posted by: classiccars - 03-17-2025, 11:13 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
I find no infos how the SD card works.
Is it just to safe log files?
To read the log files I must remove the card or is there any other way to access the datas?
