» Members: 10,405
» Latest member: ll88tvcom
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 466 online users.
» 1 Member(s) | 443 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Sogou web, bot, ll88tvcom
Today, 03:04 AM
Today, 01:34 AM
Today, 12:15 AM
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  B16 ESPHome yaml for home assistant with tuya
Posted by: admin - 02-22-2025, 01:53 AM - Forum: B16 - Replies (7)
  friendly_name: b16
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
# logger:
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: byxtsco8rwt4x8km
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b16_output01"
    dp_id: 2
    internal: true
    bind_switch_id: "b16_output02"
    dp_id: 3
    internal: true
    bind_switch_id: "b16_output03"
    dp_id: 4
    internal: true
    bind_switch_id: "b16_output04"
    dp_id: 5
    internal: true
    bind_switch_id: "b16_output05"
    dp_id: 6
    internal: true
    bind_switch_id: "b16_output06"
    dp_id: 101
    internal: true
    bind_switch_id: "b16_output07"
    dp_id: 102
    internal: true
    bind_switch_id: "b16_output08"
      number: 8
    dp_id: 103
    internal: true
    bind_switch_id: "b16_output09"
      number: 9
    dp_id: 104
    internal: true
    bind_switch_id: "b16_output10"
      number: 10
    dp_id: 105
    internal: true
    bind_switch_id: "b16_output11"
      number: 11
    dp_id: 106
    internal: true
    bind_switch_id: "b16_output12"
      number: 12
    dp_id: 107
    internal: true
    bind_switch_id: "b16_output13"
      number: 13
    dp_id: 108
    internal: true
    bind_switch_id: "b16_output14"
      number: 14
    dp_id: 109
    internal: true
    bind_switch_id: "b16_output15"
      number: 15
    dp_id: 110
    internal: true
    bind_switch_id: "b16_output16"
    dp_id: 111
    bind_binary_sensor_id: b16_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: b16_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: b16_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: b16_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: b16_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: b16_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: b16_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: b16_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: b16_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: b16_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: b16_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: b16_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: b16_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: b16_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: b16_input15
    internal: true
      number: 15
    dp_id: 126
    bind_binary_sensor_id: b16_input16
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B16");
download yaml file:
.txt   B16-HA.txt (Size: 13.84 KB / Downloads: 671)
  B16 ESP32-S3 IO pins define
Posted by: admin - 02-22-2025, 01:52 AM - Forum: B16 - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575Sadrelay1-16): i2c address:0x22
PCF8575Sadinput1-16): i2c address:0x24
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
Analog input (A1Big GrinC 0-5v)
Analog input (A2Big GrinC 0-5v)
Analog input (A3Big GrinC 4-20mA)
Analog input (A4Big GrinC 4-20mA)
GPIO13
GPIO14
GPIO21
free GPIOs (with pull-up resistance on PCB):
GPIO40
GPIO48
GPIO47
GPIO7
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
  KinCony controller to Mushroom farm
Posted by: intelligsystems - 02-21-2025, 11:30 PM - Forum: DIY Project - Replies (10)
Hi everyone,
I'm new to this forum and new to ESP/Home Assistant.
I have a mushroom cultivation tent where I use a humidifier, blower motors, LED lights, sensors, and an electric heater.
Currently, I control the climate using WiFi-connected sensors, but I would like to fully automate all devices and manage them using Home Assistant (I already have a server and WiFi infrastructure set up).
I'm unsure which Kincony controller would be the best choice, so I’d appreciate your advice. I've attached a diagram showing the devices I want to connect to the controller.
List of devices and required functions in Home Assistant:
  • Electric Heater (PTC 1.5 kW): Turn on/off based on the temperature sensor.
  • Humidity, Temperature, and CO2 Sensor: Read and monitor sensor data.
  • UV Lamp (in humidifier water container): Activate for short intervals (e.g., every 10 seconds).
  • Blower Motor: Adjust fan speed based on CO2 sensor readings.
  • LED Lights: Run for 12 hours daily with adjustable intensity.
  • Humidifier: Turn on/off based on the humidity sensor.
Thanks in advance for your help!
Krzysztof
  Free GPIO pins
Posted by: dionamket - 02-21-2025, 10:37 PM - Forum: KC868-A16 - Replies (1)
Just received the board, no problem setting up!
Is it possible to add a Neopixel light strip for a self made indicator of the input pins status? (green/red for on/off). That would require just one free GPIO. From what I understand there are no free GPIO pins on V2 of the board, just the new V3.
Are the 3 HT pin inputs only for temperature/humidity?
Thanks for your time!
  COM problem on A32 Pro
Posted by: alamiran - 02-21-2025, 06:41 PM - Forum: KC868-A32/A32 Pro - Replies (1)
Hello everyone,
I recently installed 2 cards module A32 Pro into my electric cabinet, and they come as usual without firmware, when I turn on the card the dispay shows A32 Pro
I tried to connect via USBC-USBC cable to my laptop, but the port is not reconginzed on my windows device manager, and since the port is not physical viable, I won't be able to load the firmware app to load the software.
I turned off the card, press on the DL button, and Turn on the card and then released the DL botton in order to boot the card in bootloader mode, Yet this couldn't help in finding the COM port on my device.
My Computer is fine, and so is the Cable, i used same cable and same computer on F16 card, and i's worked smoothly without any issues.
Please advice I need help.
Thank you,
Rani
  Operation log
Posted by: Yosemite - 02-21-2025, 09:17 AM - Forum: "KCS" v2 firmware system - Replies (4)
For the next revision of KCS firmware V2, would Kincony consider adding an operation log of input and output states? This would be very helpful for troubleshooting.
  Alarm system wiring
Posted by: rubenroucourt - 02-21-2025, 07:35 AM - Forum: KC868-A series and Uair Smart Controller - Replies (6)
Can I use the Bosch isc-bpr2-wp12 motion sensor with a NC contact with the KC868-A16 board?
I guess I need to give it the 12V input on +/- and wire the NC contact to GND and a dry contact input?
  access control panel input number control OUTPUT by wiegand yaml for ESPhome
Posted by: admin - 02-21-2025, 05:47 AM - Forum: KC868-AIO - No Replies
here is demo config file for access control panel. control OUTPUT1 or OUTPUT3 by INPUT NUMBER "101#" and "102#" by touch panel.
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
   - id: bus_a
     sda: 4
     scl: 16
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_in_3'  # for output channel 33-38  + (input 49-58)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
# Individual outputs
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_2
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_in_3
      number: 12
      number: 13
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0:
      number: 8
    pin_s1:
      number: 9
    pin_s2:
      number: 10
    pin_s3:
      number: 11
  - platform: adc
    pin: 36
    update_interval: never
    attenuation: 11db
  - platform: adc
    pin: 39
    update_interval: 50s
    attenuation: 11db
  - platform: adc
    pin: 34
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
  - platform: cd74hc4067
    sensor: adc36
    sensor: adc36
    sensor: adc36
    sensor: adc36
    sensor: adc36
    sensor: adc36
    sensor: adc36
    sensor: adc36
    number: 8
    sensor: adc36
    number: 9
    sensor: adc36
    number: 10
    sensor: adc36
    number: 11
    sensor: adc36
    number: 12
    sensor: adc36
    number: 13
    sensor: adc36
    number: 14
    sensor: adc36
    number: 15
    sensor: adc36
# Individual inputs
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_2
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 14
      number: 15
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
wiegand:
  - id: mykeypad
    d0: GPIO14
    d1: GPIO5
    on_key:
      - lambda: ESP_LOGI("KEY", "received key %d", x);
    on_tag:
      - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
    on_raw:
      - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
key_collector:
  - id: pincode_reader
    source_id: mykeypad
    min_length: 3
    max_length: 3
    end_keys: "#"
    end_key_required: true
    back_keys: "*"
    clear_keys: "C"
#    allowed_keys: "0123456789"
    timeout: 5s
    on_progress:
      - logger.log:
          format: "input progress: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
    on_result:
      - logger.log:
          format: "input result: '%s', started by '%c', ended by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
      - if:
          condition:
            lambda: |-
              return x=="101";
          then:
            switch.toggle: aio_light1
      - if:
          condition:
            lambda: |-
              return x=="102";
          then:
            switch.toggle: aio_light2
    on_timeout:
      - logger.log:
          format: "input timeout: '%s', started by '%c'"
ESPHome yaml file download:
.txt   KC868-AIO-ESPHome-wiegand.txt (Size: 21.93 KB / Downloads: 487)
  Newbie question
Posted by: DK5EW - 02-20-2025, 03:05 PM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Hi all,
first I`m not a programmer or software guy I just want to use my KinCony A16S 16 Channel ESP32 for switching the relay outputs.
First problem is how do I connect the board with LAN ? I connected it to PC and I see a ethernet but I can`t get access to the IP 192.168.1.200
Second I want to use Tuya I leard that I have put in the purchased code but first I have to connect but this failed.
So any help hwo to connect to the board with PC over LAN are very welcome. I searched for document or video but did not find anything.
regards
  Auxiliary memory in IFTTT
Posted by: Yosemite - 02-20-2025, 10:19 AM - Forum: "KCS" v2 firmware system - Replies (11)
It would be very useful if you could add more feature like auxiliary memory (internal registers), or similar functionality, to IFTTT's inputs and outputs this will be significantly enhanced its capabilities. Just as auxiliary memory is crucial in PLCs for temporarily storing data and managing conditional logic during program execution, it could bring similar benefits to IFTTT. This would allow for more complex and nuanced automations based on stored states and data.
By the way, from my understanding the IFTTT function you have provided can work without internet connection, right?
