» Members: 10,405
» Latest member: ll88tvcom
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 481 online users.
» 0 Member(s) | 462 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
Today, 03:04 AM
Today, 01:34 AM
Today, 12:15 AM
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  Ethernet and Bluetooth both enabled in ESP Home at the same time
Posted by: kennedyed - 02-06-2025, 08:26 PM - Forum: KC868-A16 - Replies (1)
Hi There,
I have recently started using the KC868-A16 board and it is an excellent board.
I have loaded it with ESP Home and it is working well.
It is connected to my network via Ethernet for reliability and I also wish to enable Bluetooth on the board so as to use it as a gateway for BLE sensors in ESP Home and Home Assistant.
Do you know is it possible to use Bluetooth and Ethernet in the same ESP Home configuration on the KC868-A16 board?
I know W-Fi and Bluetooth  can work at the same time but I want use Ethernet as Wi-Fi coverage is poor at the location.
If I can use Ethernet and Bluetooth would you have an example ESP Home configuration for Bluetooth?
Thanks,
Ed.
  KC868-H32BS connecting with external relays / switches
Posted by: fernandobandeira - 02-06-2025, 04:24 AM - Forum: KC868-HxB series Smart Controller - Replies (5)
I currently have 2 panels with some 16a Finder (20.21.9.024.4000) 24v dc relays, these relays controls some lights and blinds, the blinds have a sequencing to it (open, pause, close, pause, open) currently they are being toggled by a switch/interruptor.
I've watched some videos from kincony and looks like I could use the kc868-h32bs, I guess my question is if this is the best option, I basically want to make these relays available on alexa, and it feels like I'd connect the existing switches to the inputs from the kc868-h32bs and then the output would go to the finder relay. is there another way of achieving this? My concern is making sure that the board knows when the relay is on/off as it needs to know if the lights are turned on / off to work properly.
the problem though is that connecting the switch to the board directly would leave it without a backup in case the board has any issues, so it wouldnt be possible to control the lights directly in that case, I wanted to have a backup if possible, I'm not sure if theres a way of the board detecting the relay state otherwise
(Im a software engineer, so not too familliar with hardware, any help is appreciated, I wanna make sure I order the right products for the setup)
Attaching a photo of one of my panels.
Wink KC868-A8M reading Ethernet data
Posted by: MWDH - 02-05-2025, 09:27 PM - Forum: KC868-A8M - Replies (10)
Hello Community,
I want to use the KC868-A8M to do the following:
  • use it as Wifi AP (Which is easy and I have accomplished) to have access with my phone
  • read data with the KC868-A8M from a web server from another device via Ethernet (Ethernet is connected to another device which creates the web server)
  • red data via http get requests
Now the question: Am I able to configure all the get requests in the KCS software and use the answers / data in the IFTTT section? This would make it very easy to program logic to the KC868-A8M.
Or do I need to program my own code in the Arduino IDE to create get requests and react accordingly?
If there is a simple solution, I would be very happy to learn about it, since this will be super helpful in one of my projects.
Thank you very much![Image: smile.png]
Best wishes
Max
  A24 Where DAC?
Posted by: skench - 02-05-2025, 08:52 PM - Forum: KinCony A24 - Replies (6)
Good day, admin, please tell me, do you have a video https://www.youtube.com/watch?v=kLUGJtZg1aQ, the description says the following "how to slove A32 Pro/A24 DAC dimmer"
However, I do not see the inscription on the case as for the A32 PRO DA1 and DA2 in the lower right corner of the case is located on the A32 Pro
So does the KinCony A24 https://aliexpress.ru/item/1005006364867...757axPMWYQ
have dimmer control? If so, where are the inscriptions?
  Etgernet + wifi
Posted by: kulibin - 02-05-2025, 08:19 PM - Forum: KC868-A series and Uair Smart Controller - Replies (34)
My module (KC868-A) is connected via ethernet and I want it to be an access point via WiFi. How to set up a configuration file in esp home in home assistance ?
  KC868A6
Posted by: Chris89 - 02-04-2025, 07:37 PM - Forum: "KCS" v2 firmware system - Replies (1)
I have bought a kincony 868A6. The first time, red led power in on and 6 other red leds are blinking and clicking. I have a 12V power. But now only the red led power is on. No blinking and no clicking for the 6 red leds.
Unpossible to use flashtools. The board is recognized whan i put the usb. But nothing other. Is the board out of order? I try to reset it with the button. Nothing.
What can i do? Send to the seller? thanks for your answer
Christian (France)
  M16 Warning: Component <unknown> took a long time for an operation
Posted by: linuxeux - 02-04-2025, 02:42 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (3)
I just received my M16 and I flash it with ESPHome. Everything seems to work properly but the logs are flooded by a Warning that I don't know how to solve. I saw a post similar and putting the frequency at 400kHz solved the problem but not for me. Here is a snapshot of thoses warnings:
[09:09:52][W][component:238]: Components should block for at most 30 ms.
[09:09:52][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:09:59][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:09:59][W][component:238]: Components should block for at most 30 ms.
[09:10:07][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:07][W][component:238]: Components should block for at most 30 ms.
[09:10:09][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:09][W][component:238]: Components should block for at most 30 ms.
[09:10:12][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:12][W][component:238]: Components should block for at most 30 ms.
[09:10:17][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:17][W][component:238]: Components should block for at most 30 ms.
[09:10:22][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:22][W][component:238]: Components should block for at most 30 ms.
[09:10:22][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:24][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:24][W][component:238]: Components should block for at most 30 ms.
[09:10:29][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:29][W][component:238]: Components should block for at most 30 ms.
[09:10:32][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:32][W][component:238]: Components should block for at most 30 ms.
[09:10:42][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:42][W][component:238]: Components should block for at most 30 ms.
[09:10:44][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:44][W][component:238]: Components should block for at most 30 ms.
[09:10:47][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:47][W][component:238]: Components should block for at most 30 ms.
[09:10:52][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:52][W][component:238]: Components should block for at most 30 ms.
[09:10:54][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:54][W][component:238]: Components should block for at most 30 ms.
[09:10:57][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:57][W][component:238]: Components should block for at most 30 ms.
[09:11:07][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:11:07][W][component:238]: Components should block for at most 30 ms.
[09:11:12][W][component:237]: Component <unknown> took a long time for an operation (55 ms).
[09:11:12][W][component:238]: Components should block for at most 30 ms.
[09:11:17][W][component:237]: Component <unknown> took a long time for an operation (58 ms).
[09:11:17][W][component:238]: Components should block for at most 30 ms.
[09:11:22][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:22][W][component:238]: Components should block for at most 30 ms.
[09:11:24][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:24][W][component:238]: Components should block for at most 30 ms.
[09:11:34][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:34][W][component:238]: Components should block for at most 30 ms.
  Help with Bioreactor Automation
Posted by: propag8tor - 02-04-2025, 05:42 AM - Forum: DIY Project - Replies (6)
Seeking Advice: Automating a CO₂-Controlled Bioreactor System with Raspberry Pi & KinCony
Hi everyone,
I’m building a temporary immersion bioreactor system for tissue culturing trees for restoration projects. I want to design a scalable, automated system that integrates CO₂ monitoring, solenoid-controlled gas flow, and light automation—with the ability to log data for future AI optimization.
System Overview:
  • Bioreactors: 10 shelves, each with 10 bioreactors (total of 100).
  • Aeration:
    • Each bioreactor receives CO₂-enriched air from a pump inside a CO₂ incubator (for sterilization and elevated CO₂ levels).
    • I plan to monitor CO₂ levels in 1 vessel per shelf (10 total monitored vessels).
    • The CO₂ sensor data will control a solenoid valve (normally closed) to regulate CO₂ for the entire shelf.
  • Lighting:
    • I want automated lighting with control based on PPFD (Photosynthetic Photon Flux Density) or intensity.
  • Data Logging & AI Integration:
    • The system should log all data (CO₂ levels, light intensity, etc.) for future AI-driven optimization.
My Approach & Questions:
  • I plan to use a Raspberry Pi as the main controller.
  • I’ve come across KinCony products and believe they could provide a solution. Has anyone used KinCony for similar automation projects?
  • I’d love suggestions for CO₂ sensors, solenoid controllers, and light intensity sensors that integrate well with a Raspberry Pi & KinCony setup.
  • I want to allow for future expansion, so modularity and scalability are key.
If anyone can offer suggestions or advice it would be extremely appreciated.  I attached an image to help understand what it is I am building.
[Image: view?usp=drive_link]
  Product packaging
Posted by: mitzuuu89 - 02-03-2025, 08:55 AM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
I've just received my K868-A32 and K868-A16s boards in Romania.
I just want to suggest to improve the package wrapping, the K868-A32 plastic case came broken.
Thanks! Looking forward to installing the boards.
  [arduino code examples for A16v3]-13 read DS18B20 temperature sensors
Posted by: admin - 02-03-2025, 06:17 AM - Forum: KC868-A16v3 - No Replies
// https://github.com/junkfix/esp32-ds18b20
#include "OneWireESP32.h"
const uint8_t MaxDevs = 1;
float currTemp[MaxDevs];
void tempTask(void *pvParameters){
    OneWire32 ds1(47); //gpio pin
    OneWire32 ds2(48); //gpio pin
  OneWire32 ds3(38); //gpio pin
    uint64_t addr1[MaxDevs];
  uint64_t addr2[MaxDevs];
  uint64_t addr3[MaxDevs];
    //uint64_t addr[] = {
    //    0x183c01f09506f428,
    //    0xf33c01e07683de28,
    //to find addresses
    uint8_t devices1 = ds1.search(addr1, MaxDevs);
    for (uint8_t i = 0; i < devices1; i += 1) {
        Serial.printf("T1: 0x%llx,\n", i, addr1[i]);
        //char buf[20]; snprintf( buf, 20, "0x%llx,", addr[i] ); Serial.println(buf);
    uint8_t devices2 = ds2.search(addr2, MaxDevs);
    for (uint8_t i = 0; i < devices2; i += 1) {
        Serial.printf("T2: 0x%llx,\n", i, addr2[i]);
    uint8_t devices3 = ds3.search(addr3, MaxDevs);
    for (uint8_t i = 0; i < devices3; i += 1) {
        Serial.printf("T3: 0x%llx,\n", i, addr3[i]);
    //end
    for(;;){
        ds1.request();
    ds2.request();
    ds3.request();
        vTaskDelay(750 / portTICK_PERIOD_MS);
        for(byte i = 0; i < MaxDevs; i++){
            uint8_t err = ds1.getTemp(addr1[i], currTemp[i]);
            if(err){
                const char *errt[] = {"", "CRC", "BAD","DC","DRV"};
                Serial.print(i); Serial.print(": "); Serial.println(errt[err]);
            }else{
                Serial.print("T1"); Serial.print(": "); Serial.println(currTemp[i]);
            uint8_t err = ds2.getTemp(addr2[i], currTemp[i]);
            if(err){
            }else{
                Serial.print("T2"); Serial.print(": "); Serial.println(currTemp[i]);
            uint8_t err = ds3.getTemp(addr3[i], currTemp[i]);
            if(err){
            }else{
                Serial.print("T3"); Serial.print(": "); Serial.println(currTemp[i]);
        vTaskDelay(3000 / portTICK_PERIOD_MS);
} // tempTask
    xTaskCreatePinnedToCore(tempTask, "tempTask", 4096,  NULL,  1,  NULL, 0);
void loop() {}
arduino ino file download:
.zip   13-ds18b20.zip (Size: 888 bytes / Downloads: 856)
.zip   13-ds18b20.ino.merged.zip (Size: 183.21 KB / Downloads: 849)
