» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 472 online users.
» 0 Member(s) | 448 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Google, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  KC868-A6v3 ESP32-S3 IO pins define
Posted by: admin - 02-15-2025, 05:42 AM - Forum: KC868-A6v3 - Replies (2)
ANALOG_A1  GPIO4
ANALOG_A2  GPIO5
ANALOG_A3  GPIO6
ANALOG_A4  GPIO7
1-wire1:GPIO15
1-wire2:GPIO16
GP8403 DAC i2c address: 0x58
IIC SDA:GPIO12
IIC SCL:GPIO11
Input_IIC_address 0x22
Relay_IIC_address 0x24
RS485 RXD: GPIO18
RS485 TXD: GPIO17
SPI_Bus: (For LoRA/nRF24L01)
CS: GPIO38
MOSI: GPIO43
MISO: GPIO44
SCK: GPIO39
LoRA sx1278:
RST:GPIO42
DIO0:GPIO41
nRF24L01:
CE: GPIO40
RS232:
TXD:GPIO9
RXD:GPIO10
free GPIO on PCB (beside ESP32-S3 module)
GPIO8
GPIO13
GPIO14
GPIO21
GPIO47
GPIO48
  "KCS" v3 HTTP protocol document
Posted by: admin - 02-15-2025, 04:04 AM - Forum: "KCS" v3 firmware - No Replies
Note: This protocol document use for KinCony ESP32-S3 smart controller:
you need to download KCS v3 firmware to ESP32-S3 firstly.
Different board will have different channel of digital output, digital input , ADC, DAC,IR, RF. So the protocol is same , just according to the hardware resource to set channel number.
protocol document download:
.pdf   KCSv3-protocol-HTTP.pdf (Size: 308.71 KB / Downloads: 1211)
  "KCS" v3 STRING protocol document
Posted by: admin - 02-15-2025, 04:01 AM - Forum: "KCS" v3 firmware - No Replies
.pdf   KCSv3-protocol-String.pdf (Size: 282.08 KB / Downloads: 1164)
for IR commands:
  "KCS" v3 MQTT protocol document
Posted by: admin - 02-15-2025, 03:49 AM - Forum: "KCS" v3 firmware - No Replies
.pdf   KCSv3-protocol-MQTT.pdf (Size: 287.19 KB / Downloads: 1001)
for IR commands:
  "KCS" v3 RS485 Modbus protocol document
Posted by: admin - 02-15-2025, 03:32 AM - Forum: "KCS" v3 firmware - No Replies
.pdf   KCSv3-protocol-ModBus.pdf (Size: 264.96 KB / Downloads: 1017)
for IR commands:
  "KCS" v3 UDP STRING protocol document for Loxone Miniserver
Posted by: admin - 02-15-2025, 03:21 AM - Forum: "KCS" v3 firmware - No Replies
Protocol
1: control digital output (DO)
Loxone send to KCS: RELAY-SET-255,2,1  //turn ON DO2
KCS back to Loxone: RELAY-SET-255,2,1,OK
Loxone send to KCS: RELAY-SET-255,2,0  //turn OFF DO2
KCS back to Loxone: RELAY-SET-255,2,0,OK
2: digital output (DO) state feedback
KCS back to Loxone: RELAY-SET-255,3,1,OK //DO3 is ON
KCS back to Loxone: RELAY-SET-255,3,0,OK //DO3 is OFF
3: digital input (DI) state feedback
KCS back to Loxone: RELAY-GET_INPUT-255,4,1,OK  //DI4 is ON
KCS back to Loxone: RELAY-GET_INPUT-255,4,0,OK  //DI4 is OFF
4: control analog output (AO)
Loxone send to KCS: RELAY-SET_DAC_255,2,0  //channel 2 AO=0  0%
KCS back to Loxone: RELAY-SET_DAC_255,2,0,OK
Loxone send to KCS: RELAY-SET_DAC_255,3,255  //channel 3 AO=255 100%
KCS back to Loxone: RELAY-SET_DAC_255,3,255,OK
5: analog output (AO) state feedback
KCS back to Loxone: RELAY-GET_DAC_255,1,107,OK  //channel 1 AO=107
KCS back to Loxone: RELAY-GET_DAC_255,2,255,OK  //channel 2 AO=255
6: analog input (AI) state feedback
KCS back to Loxone: RELAY-GET_ADC-255,1,2670,OK  //channel1 ADC is 2670
7: RF433M receiver state feedback
KCS back to Loxone: RELAY-GET_RF-255,2,1,OK  //channel2 RF sensor is ON
KCS back to Loxone: RELAY-GET_RF-255,3,0,OK  //channel3 RF sensor is OFF
8: temperature & humidity sensor feedback
KCS back to Loxone:RELAY-GET_SENSOR-255,3,16.8,46.8,OK //channel3 sensor temperature=16.8℃ humidity=46.8%
KCS back to Loxone:RELAY-GET_SENSOR-255,4,27.8,-100,OK //channel4 sensor temperature=27.8℃ without humidity
9: Learn IR (MAX support 192 IR signals):
Loxone send to KCS: RELAY-IR-LEARN-255,1,2    // begin learn IR signal ID=1, send by IR tube-2
KCS back to Loxone: RELAY-IR-LEARN-255,1,OK  // success
KCS back to Loxone: RELAY-IR-LEARN-255,1,TIMEOUT  // timeout
10: Send IR
Loxone send to KCS: RELAY-IR-RUN-255,1  // send IR signal ID=1
KCS back to Loxone: RELAY-IR-RUN-255,1,OK
11: Delete IR
Loxone send to KCS: RELAY-IR-DEL-255,1  // delete learned IR signal ID=1
KCS back to Loxone: RELAY-IR-DEL-255,1,OK
download Loxone config demo project file from KinCony forum
  "KCS" v3.7.0 firmware BIN file download
Posted by: admin - 02-15-2025, 03:18 AM - Forum: "KCS" v3 firmware - No Replies
v3.7.0 improvement:
1. add support KC868-A6v3, KC868-A16v3, AG8, T16M controller.
2. fixed some bugs.
.zip   KCS_A6V3_V3.7.0.zip (Size: 1 MB / Downloads: 879)
.zip   KCS_A16V3_V3.7.0.zip (Size: 1.08 MB / Downloads: 858)
.zip   KCS_A32PRO_V3.7.0.zip (Size: 1.04 MB / Downloads: 762)
.zip   KCS_AG8_V3.7.0.zip (Size: 1.03 MB / Downloads: 808)
.zip   KCS_B16M_V3.7.0.zip (Size: 1.07 MB / Downloads: 759)
.zip   KCS_F16_V3.7.0.zip (Size: 1.07 MB / Downloads: 752)
.zip   KCS_F24_V3.7.0.zip (Size: 1.07 MB / Downloads: 800)
.zip   KCS_T16M_V3.7.0.zip (Size: 1.02 MB / Downloads: 788)
  KC868-A16v3 ESPHome yaml for home assistant
Posted by: admin - 02-15-2025, 03:01 AM - Forum: KC868-A16v3 - Replies (10)
  friendly_name: a16v3
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO15
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 9
     scl: 10
     frequency: 400kHz
# Example configuration entry
    address: 0x25
    address: 0x21
  - id: uart_1
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      pcf8574: pcf8574_hub_out_2
      pcf8574: pcf8574_hub_in_2
      number: 47
      number: 48
      number: 38
      number: 39
      number: 40
      number: 41
  - platform: adc
    pin: 4
    name: "A16v3 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A16v3 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "A16v3 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 5
    name: "A16v3 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
# font:
#   - file: "gfonts://Roboto"
#     id: roboto
#     size: 20
# display:
#   - platform: ssd1306_i2c
#     i2c_id: bus_a
#     model: "SSD1306 128x64"
#     address: 0x3C
#     lambda: |-
#       it.printf(0, 0, id(roboto), "A16v3");
download yaml file:
.txt   A16v3-ESPHome.txt (Size: 7.81 KB / Downloads: 1493)
  KC868-A16v3 ESP32-S3 IO pins define
Posted by: admin - 02-15-2025, 03:00 AM - Forum: KC868-A16v3 - Replies (14)
ANALOG_A1  4
ANALOG_A2  6
ANALOG_A3  7
ANALOG_A4  5
IIC Bus:
SDA:GPIO9
SCL:GPIO10
Relay_IIC_address 0x25
Input_IIC_address 0x21
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO38
free gpio-1:GPIO39
free gpio-2:GPIO40
free gpio-3:GPIO41
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO15
reset_pin: GPIO1
RS485:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO12
SPI-SCK:GPIO13
SPI-MISO:GPIO14
SPI-CS:GPIO11
SD-CD:GPIO21
RF433MHz wireless receiver: GPIO8
RF433MHz wireless sender: GPIO18
free gpio on PCB (beside ESP32-S3 module)
GPIO39
GPIO40
GPIO41
  Page kincony problem
Posted by: balcerseb - 02-14-2025, 03:34 PM - Forum: KC868-A16 - Replies (1)
Gentlemen in the manual for the KC868 A16 after logging into the software the input web page in the manual looks like this (see first picture) and I am missing the ON, OFF TOGLLE table how to fix this anyone has an idea because you can't set the control
