» Members: 10,405
» Latest member: ll88tvcom
» Forum threads: 4,322
» Forum posts: 21,298
There are currently 155 online users.
» 0 Member(s) | 134 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Sogou web, Yandex, bot
26 minutes ago
» Replies: 24
Today, 03:04 AM
Today, 01:34 AM
Today, 12:15 AM
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
  "KCS" v2.2.12 firmware BIN file download
Posted by: admin - 02-28-2025, 07:05 AM - Forum: "KCS" v2 firmware system - Replies (5)
v2.2.12 improvement:
fixed MQTT bug.
.zip   KCS_KC868_A4_V2.2.12.zip (Size: 782.24 KB / Downloads: 881)
.zip   KCS_KC868_A4S_V2.2.12.zip (Size: 805.95 KB / Downloads: 903)
.zip   KCS_KC868_A6_V2.2.12.zip (Size: 780.65 KB / Downloads: 1106)
.zip   KCS_KC868_A8_V2.2.12.zip (Size: 789.37 KB / Downloads: 957)
.zip   KCS_KC868_A8M_V2.2.12.zip (Size: 805.7 KB / Downloads: 827)
.zip   KCS_KC868_A8S_V2.2.12.zip (Size: 806.98 KB / Downloads: 846)
.zip   KCS_KC868_A16_V2.2.12.zip (Size: 796.81 KB / Downloads: 1385)
.zip   KCS_KC868_A16S_V2.2.12.zip (Size: 807.11 KB / Downloads: 863)
.zip   KCS_KC868_A32_V2.2.12.zip (Size: 786.9 KB / Downloads: 885)
.zip   KCS_KC868_A32M_V2.2.12.zip (Size: 805.11 KB / Downloads: 833)
.zip   KCS_KC868_A64_V2.2.12.zip (Size: 786.97 KB / Downloads: 882)
.zip   KCS_KC868_A128_V2.2.12.zip (Size: 786.95 KB / Downloads: 845)
.zip   KCS_KC868_AG_V2.2.12.zip (Size: 765.02 KB / Downloads: 864)
.zip   KCS_KC868_AI_V2.2.12.zip (Size: 789.65 KB / Downloads: 801)
.zip   KCS_KC868_AIO_V2.2.12.zip (Size: 806.48 KB / Downloads: 861)
.zip   KCS_KC868_AK_V2.2.12.zip (Size: 767.51 KB / Downloads: 799)
.zip   KCS_KC868_AM_V2.2.12.zip (Size: 782.41 KB / Downloads: 838)
.zip   KCS_KC868_AP_V2.2.12.zip (Size: 785.01 KB / Downloads: 825)
.zip   KCS_KC868_ASR_V2.2.12.zip (Size: 761.93 KB / Downloads: 778)
.zip   KCS_KC868_E16S_V2.2.12.zip (Size: 791.52 KB / Downloads: 847)
.zip   KCS_KC868_UAIR_V2.2.12.zip (Size: 768.43 KB / Downloads: 783)
.zip   KCS_KC868_A2_V2.2.12.zip (Size: 795.41 KB / Downloads: 865)
  Analog Input voltage incorrect
Posted by: marrbacca - 02-27-2025, 06:51 PM - Forum: KC868-A8 - Replies (1)
I'm trying to connect 2 analog temperature sensors to analog input on my A8 but I have 2 problems.
When the sensors are not connected, checking the voltage, the meter shows 1.062v (real value).
One problem is, that immediately after connecting to the board, the voltage drops to 1.015v.
While this could be handled and read correctly, as long as the voltage changes remain constant between temperatures - this sensor is connected in parallel with another board, so changing the voltage on it is also affecting the other board reading.
Second problem is, that esphome code I'm using to read the voltage is showing 0.68198v...
The code for that particular sensor I'm using is:
  - platform: adc
    pin: 35
    attenuation: auto
Can anyone help me and explain why is this happening?
  Issues with KinCony ESP32-S3-WROOM-1U N16R8 Core Development Board
Posted by: dammyr7a - 02-27-2025, 04:32 PM - Forum: Extender module - Replies (3)
Hi guys,
I am having issues with programming this module in arduino.
1. need possibly a demo code to get the ethernet to work and how to work with its inbuilt adc,
2.Also, the demo code in arduinoide for other features such as rs485 and co would be good as well.
3. Can i connect a display screen to the socket for the 4g modemand hope i canalso use the port for sd card module for dat logging purposes.
Pleas note, number one is urgent and most important to me.
thanks
Dammy
  A16: IFTTT Time based actions not working
Posted by: sebfromgermany - 02-27-2025, 02:19 PM - Forum: KC868-A16 - Replies (28)
Hello.
I set up an A16 device with the software version v.2.2.12. The display of the time on index page is still not correct. It should always follow the format YYYY-MM-DD HH:MI:SS.
Unfortunatlely the date & time is displayed like this: "2025-02.27 7:5:27" Please see attached image.
In addition to that, the IFTTT time function is not working. When time is reached, the configured output is not switched on.
What am I doing wrong?
Image(s)
  Usb config
Posted by: desert286 - 02-27-2025, 09:18 AM - Forum: F16 - Replies (3)
How should i connect F16 to PC? Always got appear and disappear usb port shown. What should i do? Thanks
  KCS A128 mqtt disconneting after inputs action
Posted by: gitbejbe - 02-26-2025, 11:14 PM - Forum: "KCS" v2 firmware system - Replies (10)
I have a problem that I can't solve. This is already my second board because I have a well-functioning A64 version, and now I'm trying to use the A128 version.
I'll start by saying that enabling MQTT (protocol->general->mqtt) is only possible for me on version v1.0.27. In firmware versions > v2 with IFTTT, it doesn't work—when I enable MQTT, the controller freezes, I can't access the web panel, and only a factory reset helps.
Only in version v1.0.27 does the controller not freeze after enabling MQTT. But here, I have another issue. When MQTT is enabled and I set any input to perform an action, after executing the action, the controller temporarily loses connection with the MQTT broker and then reconnects after a few seconds—I can't smoothly control the lights.
As I mentioned, I also have the A64 version, which runs on the same broker with firmware version 2.2.2, and everything works fine there. I have no more ideas on what could be wrong. I've checked the broker configuration, tried different settings, and nothing helps. I've also connected to external brokers, and the issue persists. I have flashed all your firmware versions onto the controller, and I can't get MQTT to work on any of them except for v1.0.27.
mqtt logs after input action (disconnectings)
[Image: Bez-tytu-czxcxzcu.png]
[Image: veiosn.png]
[Image: mqttt.png]
[Image: status.png]
[Image: status-errur.png]
  B16M 4-20ma pressure sensor input
Posted by: mattorola7 - 02-26-2025, 10:05 PM - Forum: B16M - Replies (4)
I'm trying to install a Wika A-10 Pressure Sensor/Transmitter 8-30VDC 4-20mA P# 13361091. This is the first time I've used a 4-20ma sensor. I've used other 0-5V and 0-10V sensors before with voltage dividers and have been successful.
Can you help me understand how the A1 and A2 Analog Inputs on the B16M work to convert the 4-20ma signal into a voltage and what I should use for the gain? ChatGPT is trying to explain it to me but it describes using a 250ohm shunt resistor. How do I know what internal shunt resistor(s) have been used to convert the signal to be readable by the internal ads1115 chip?
I will be using 12VDC to excite the pressure sensor which is rated for 8-30VDC. The Wika test report shows that the sensor should produce 4ma at 0 bar and 20ma at 2.5 bar (36.2595 PSI). Here is a snapshot of my YAML code for esphome so far:
# ADC
ads1115:
 - address: 0x48
# SENSORS
  - platform: ads1115
    name: "Filter Pressure Voltage"
    web_server:
      sorting_group_id: sortgroup_hidden_sensors
    device_class: voltage
    multiplexer: "A0_GND"
    gain: 6.144
    resolution: 16_BITS
    unit_of_measurement: "V"
    icon: mdi:lightning-bolt-circle
    internal: false
    update_interval: 5s
  - platform: template
    name: "Filter Pressure Gauge"
    web_server:
        sorting_group_id: sortgroup_sensors
    device_class: pressure
    lambda: |-
      // Pressure Sensor Model: Wika A-10 Pressure Transmitter 8-30VDC 4-20mA P# 13361091
      // Convert the voltage (1V to 5V) to PSI (0 to 36.2595 PSI)
      return (id(filter_pressure_voltage).state / 5.0) * 36.2595;
    unit_of_measurement: "PSI"
    accuracy_decimals: 2
    icon: mdi:gauge
    internal: false
    update_interval: 5s
  KC868-A8 TCP - Transmitter
Posted by: Dm81 - 02-26-2025, 12:34 PM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Good Morning
Is it possible send frequency through TCP to the KC868-A8 Transmitter?
thank you
  Modeling software for Kinkony
Posted by: korvin - 02-25-2025, 06:32 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (1)
Hi
Can you suggest some software that I can use to model Kinkony devices wiring? Ideally I want Kinkony controllers and relays to be in that software library so I can drop them into my projects and design wiring.
  KC868-A16S analog input
Posted by: DK5EW - 02-24-2025, 06:16 PM - Forum: KC868-A16S - Replies (2)
I`m giving 1.5V DC at the analog input.
I save in the webserver my setup but I do not see any voltage at the Tuya app.
Any hint what is wrong ?
regrds
