» Members: 10,399
» Latest member: charlottehayes9923
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 608 online users.
» 0 Member(s) | 582 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
3 hours ago
4 hours ago
6 hours ago
KC868-A4 – Relay 1 clicks...
8 hours ago
450 Hz allowed on input?
Forum: Development
8 hours ago
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  [arduino code examples for AIO Hybrid]-03 Read analog input ports value
Posted by: admin - 09-15-2025, 01:27 AM - Forum: AIO Hybrid - No Replies
* Description:
* This Arduino program reads analog values from four analog input pins (A1, A2, A3, A4)
* and prints the values to the Serial Monitor. The analog inputs are defined with specific
* GPIO pins and the program reads the voltage levels from these pins every 2 seconds.
* Pin Definitions:
* - A1: GPIO 5
* - A2: GPIO 7
* - A3: GPIO 6
* - A4: GPIO 4
#define ANALOG_A1   5   // Define GPIO pin for analog input A1
#define ANALOG_A2   7   // Define GPIO pin for analog input A2
#define ANALOG_A3   6   // Define GPIO pin for analog input A3
#define ANALOG_A4   4   // Define GPIO pin for analog input A4
    delay(500); // Short delay to allow serial communication to start
    pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1
    pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2
    pinMode(ANALOG_A3, INPUT); // Set GPIO 6 as an input for analog signal A3
    pinMode(ANALOG_A4, INPUT); // Set GPIO 4 as an input for analog signal A4
    // Read and print analog values from the defined pins
    Serial.print("A1=");
    Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1
    Serial.print("A2=");
    Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2
    Serial.print("A3=");
    Serial.println(analogRead(ANALOG_A3)); // Read and print the value from A3
    Serial.print("A4=");
    Serial.println(analogRead(ANALOG_A4)); // Read and print the value from A4
    delay(2000); // Wait for 2 seconds before the next reading
arduino ino file download:
.zip   3-analog-input.zip (Size: 769 bytes / Downloads: 588)
.zip   3-analog-input.ino.merged.zip (Size: 189.25 KB / Downloads: 574)
  [arduino code examples for AIO Hybrid]-02 Read digital input ports state
Posted by: admin - 09-15-2025, 01:26 AM - Forum: AIO Hybrid - No Replies
* Description:
* This Arduino program continuously reads 12 digital inputs (P0~P11)
* from a PCF8575 I/O expander and prints their states to the Serial Monitor
* in binary format (0 = ON, 1 = OFF).
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24
#include <Arduino.h>
#include <Wire.h>
#include "PCF8575.h"
// I2C pin definitions
#define I2C_SDA 8
#define I2C_SCL 18
// PCF8575 object with I2C address 0x24
PCF8575 pcf8575_IN1(0x24);
    Wire.begin(I2C_SDA, I2C_SCL);
    // Initialize the PCF8575
    pcf8575_IN1.begin();
    Serial.println("Input state: 0=ON, 1=OFF");
    uint16_t state = 0;
    // Read the state of P0~P11
    for (int pin = 0; pin <= 11; pin++) {
        if (pcf8575_IN1.read(pin)) {
            state |= (1 << pin);
    // Print the state in binary format
    for (int pin = 11; pin >= 0; pin--) {
        Serial.print((state >> pin) & 1);
    Serial.println();
    delay(500); // Polling delay
.zip   2-digital-input.zip (Size: 764 bytes / Downloads: 645)
.zip   2-digital-input.ino.merged.zip (Size: 196.89 KB / Downloads: 596)
  [arduino code examples for AIO Hybrid]-01 Turn ON/OFF relay
Posted by: admin - 09-15-2025, 01:24 AM - Forum: AIO Hybrid - No Replies
* PCF8574 Relay Control Example
* Controls 5 relays connected to PCF8574 via I2C bus.
* Made By KinCony
* https://www.kincony.com
#include <Wire.h>
#include "PCF8574.h"
#define I2C_SDA 8
#define I2C_SCL 18
// Create PCF8574 object with I2C address 0x26
PCF8574 pcf8574(0x26);
  delay(500);
  // Initialize I2C with specified SDA and SCL pins
  // Set PCF8574 P3~P7 as OUTPUT (Relays)
  pcf8574.pinMode(P3, OUTPUT);
  pcf8574.pinMode(P4, OUTPUT);
  pcf8574.pinMode(P5, OUTPUT);
  pcf8574.pinMode(P6, OUTPUT);
  pcf8574.pinMode(P7, OUTPUT);
  if (pcf8574.begin()) {
    Serial.println("OK");
    Serial.println("KO");
    while (1); // Stop if initialization fails
  // Turn OFF all relays at startup
  for (int pin = P3; pin <= P7; pin++) {
    pcf8574.digitalWrite(pin, LOW);
  // Turn ON all relays one by one
    pcf8574.digitalWrite(pin, HIGH);
    delay(500);
  delay(1000); // Keep all relays ON for a while
  delay(1000); // Keep all relays OFF for a while
.zip   1-relay.zip (Size: 724 bytes / Downloads: 636)
.zip   1-relay.ino.merged.zip (Size: 198.37 KB / Downloads: 576)
  AIO Hybrid ESPHome yaml for home assistant without tuya
Posted by: admin - 09-15-2025, 01:19 AM - Forum: AIO Hybrid - No Replies
  friendly_name: AIO-hybrid
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      SOC_RMT_SUPPORT_RX_PINGPONG: "n"
  - id: uart_zsu
    baud_rate: 115200
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
    tx_pin: 15
    rx_pin: 48
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_output_1'  # for output channel 5
    i2c_id: bus_a
    address: 0x26
  - id: 'pcf8574_hub_input_1'  # for input channel 1-12
    i2c_id: bus_a
    pcf8575: true
  - platform: uart
    uart_id: uart_zsu
    data: [0x55, 0xaa, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x04] # ZSU zigbee module
      pcf8574: pcf8574_hub_output_1
  - platform: template
    turn_on_action:
      - remote_transmitter.transmit_pronto:
          transmitter_id: ir1
          data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0575 015B 0057 0016 0E6C"
      pcf8574: pcf8574_hub_input_1
      number: 8
      number: 9
      number: 10
      number: 11
## without resistance on PCB
      number: 40
      inverted:  false
      inverted:  false
mcp4728:
  - id: dac_output
output:
- platform: mcp4728
  mcp4728_id: dac_output
  channel: A
  vref: vdd
  power_down: normal # default
- platform: mcp4728
  channel: B
  vref: vdd
- platform: mcp4728
  channel: C
  vref: vdd
- platform: mcp4728
  channel: D
  vref: vdd
light:
  - platform: monochromatic
    output: dimmer1
    gamma_correct: 1.0
    output: dimmer2
    gamma_correct: 1.0
    output: dimmer3
    gamma_correct: 1.0
    output: dimmer4
    gamma_correct: 1.0
    rgb_order: GRB
    pin: GPIO21
    num_leds: 20
    chipset: ws2812
    name: "My Light IO21"
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "AIO-hybrid");
  - platform: adc
    pin: 5
    name: "AIO_hybrid A1 Voltage"
    update_interval: 55s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "AIO_hybrid A2 Voltage"
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "AIO_hybrid A3 Current"
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "AIO_hybrid A4 Current"
    attenuation: 11db
    filters:
remote_receiver:
  pin: 17
  dump: all
remote_transmitter:
  - id: ir1
    pin: 14
    carrier_duty_percent: 50%
web_server:
  port: 80
download yaml file:
.txt   AIO-hybrid_pin_define-HA-without-Tuya.txt (Size: 7.62 KB / Downloads: 481)
  AIO Hybrid ESPHome yaml for home assistant with tuya
Posted by: admin - 09-15-2025, 01:18 AM - Forum: AIO Hybrid - No Replies
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
#logger:
#  hardware_uart: USB_SERIAL_JTAG
external_components:
  - source:
      type: git
      ref: v1.1.0
#  - id: uart_zsu
#    baud_rate: 115200
#    debug:
#      direction: BOTH
#      dummy_receiver: true
#      after:
#        timeout: 10ms
#      sequence:
#        - lambda: UARTDebug::log_string(direction, bytes);
#    tx_pin: 15
#3    rx_pin: 48
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: 0x9gs3fuzgggwhi1
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    address: 0x26
    i2c_id: bus_a
    pcf8575: true
#  - platform: uart
#    uart_id: uart_zsu
#    name: "UART zigbee"
#    data: [0x55, 0xaa, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x04] # ZSU zigbee module
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "AIO_hybrid_output01"
    turn_on_action:
          transmitter_id: ir1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 40
      inverted:  false
      inverted:  false
mcp4728:
  - id: dac_output
output:
- platform: mcp4728
  channel: A
  vref: vdd
- platform: mcp4728
  channel: B
  vref: vdd
- platform: mcp4728
  channel: C
  vref: vdd
- platform: mcp4728
  channel: D
  vref: vdd
light:
    output: dimmer1
    gamma_correct: 1.0
    output: dimmer2
    gamma_correct: 1.0
    output: dimmer3
    gamma_correct: 1.0
    output: dimmer4
    gamma_correct: 1.0
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
  - platform: adc
    pin: 5
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    attenuation: 11db
    filters:
  - platform: adc
    pin: 4
    attenuation: 11db
    filters:
remote_receiver:
  pin: 17
  dump: all
remote_transmitter:
  - id: ir1
    pin: 14
web_server:
  port: 80
download yaml file:
.txt   AIO-hybrid_pin_define-HA-with-Tuya.txt (Size: 8.12 KB / Downloads: 389)
  AIO Hybrid ESP32-S3 IO pins define
Posted by: admin - 09-15-2025, 01:16 AM - Forum: AIO Hybrid - Replies (5)
ANALOG_A1(0-5v)    GPIO5
ANALOG_A2(0-5v)    GPIO7
ANALOG_A3(4-20mA)  GPIO6
ANALOG_A4(4-20mA)  GPIO4
IIC SDA:GPIO8
IIC SCL:GPIO18
PCF8575:  i2c address:0x24
PCF8575->P0 (DI1)
PCF8575->P1 (DI2)
PCF8575->P2 (DI3)
PCF8575->P3 (DI4)
PCF8575->P4 (DI5)
PCF8575->P5 (DI6)
PCF8575->P6 (DI7)
PCF8575->P7 (DI8)
PCF8575->P8 (DI9)
PCF8575->P9 (DI10)
PCF8575->P10 (DI11)
PCF8575->P11 (DI12)
PCF8574:  i2c address:0x26
PCF8574->P3 (RELAY1)
PCF8574->P4 (RELAY2)
PCF8574->P5 (RELAY3)
PCF8574->P6 (RELAY4)
PCF8574->P7 (RELAY5)
IR Sender: GPIO14
IR Receiver: GPIO17
RF433MHz wireless receiver: GPIO40
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
RS485:
RXD:GPIO47
TXD:GPIO3
Tuya wifi module:
RXD:GPIO38
TXD:GPIO39
Tuya network button: Toya module's P28
Tuya Zigbee module:
RXD: GPIO48
TXD: GPIO15
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SPI-CD:GPIO13
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
MCP4728 DAC: i2c address:0x60
Exclamation Change PIN define
Posted by: JuDie07 - 09-14-2025, 02:54 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
KC868-a8v3
Great, I have spent a whole afternoon looking for a bug!
And then, we quietly changed the PIN Define file without saying anythingAngry
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7970
Huh Is it so difficult to issue a short INFO?
  Board recommendation ?
Posted by: Lory - 09-14-2025, 01:53 PM - Forum: DIY Project - Replies (3)
I have 8 wooden doors and I want to install a 12v electric lock in each one and also a NFC card reader in each one.
To power the electric locks I can use a kincony board with 8 relays, but each card reader needs to be connected via SPI or with I2C
Is there a kincony board that can resolve this needs?
Edit:
problem is that the card readers might have the same I2C address, probably I do need a I2C multiplexor TCA9548A?
Also, if I want to use Kincony F series I see that the I2C port is utilized by a LCD screen… how can I overcome this difficulty?
  M30 - Inrush power recording
Posted by: dwarloch - 09-14-2025, 11:00 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Will it be possible to you can add in official FW support for recording the peak voltage, current, power and expose that through modbus registers? Plus add "clear peak values" modbus register where we can write a "1" to clear out the peak values. It would be great to monitor the spikes that can cause the breakers trigger. Also a great thing that implement for this type of devices would be support for LXI protocol so it could be used with software like this one: https://github.com/lxi-tools/lxi-tools
The peak values I think is most important here as it will be beneficial many users. The LXI support I will implement on my own but having it also out of the box would be beneficial.
Question regarding the ARM with modbus server, does it read the values from BL09010 in the loop or does it read for each request from modbus?
  switch dimensions
Posted by: swisstmack25 - 09-13-2025, 11:26 AM - Forum: KC868-HA /HA v2 - Replies (5)
please can you publish the dimensions of the switch https://shop.kincony.com/products/moment...5651591333
would be a good idea to have a technical drawing of the dimensions on your website.
is it the same for all gang variants, I want to understand if it will fit in a Swiss in wall housing (which is slightly smaller than that of the EU
60mm approx in diameter with 49mm depth
My wish is th use the keypad with the HAv2 module
Thanks!
