» Members: 10,396
» Latest member: Natravn
» Forum threads: 4,318
» Forum posts: 21,290
There are currently 241 online users.
» 1 Member(s) | 220 Guest(s)
Amazonbot, AwarioBot, Baidu, Bytespider, Google, HeadlessChrome, PetalBot, bot, myke4416@gmail.com
How Do You Handle Relay C...
1 hour ago
450 Hz allowed on input?
Forum: Development
5 hours ago
"KCS" v3.27.4 firmware BI...
Today, 06:02 AM
how to check i2c extend c...
Forum: T16M
Today, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Today, 12:35 AM
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
SSD not visible for insta...
Forum: Pi5R16
10-29-2026, 12:30 PM
» Replies: 20
  [arduino code examples for DM32]-03 Read ADS1115 analog input ports value
Posted by: admin - 09-09-2025, 02:53 AM - Forum: DM32 - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
arduino ino file download:
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 609)
.zip   3-ads1115_adc.ino.merged.zip (Size: 190.05 KB / Downloads: 670)
  [arduino code examples for DM16]-02 Read digital input ports state
Posted by: admin - 09-09-2025, 02:51 AM - Forum: DM16 - No Replies
* KinCony DM16 16-Channel Digital Input Reader using PCF8575
* This Arduino sketch reads the state of 16 digital input channels from a
* PCF8575 I/O expander over I2C and prints their status to the serial monitor.
* Input logic:
*   - Input 0 = ON
*   - Input 1 = OFF (with pull-up logic)
* Hardware:
*   - PCF8575 I/O Expander (I2C Address: 0x22)
*   - Custom input pin mapping as defined below
*   - I2C SDA pin: GPIO8
*   - I2C SCL pin: GPIO18
* Author: KinCony IoT
* Website: https://www.kincony.com
* License: MIT License
#include <Wire.h>
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 8   // SDA pin
#define I2C_SCL 18  // SCL pin
// Set the I2C address for PCF8575
PCF8575 pcf8575_IN1(0x22); // 0x22 is the I2C address for the DM16 module
    // Initialize I2C with specified SDA and SCL pins
    Wire.begin(I2C_SDA, I2C_SCL);
    // Start communication with PCF8575 device
    pcf8575_IN1.begin();
    Serial.println("KinCony DM16 16 channel input state 0:ON  1:OFF");
    // Define custom pin read order to match hardware mapping
    uint8_t pin_order[16] = {
        8, 9, 10, 11, 12, 13, 14, 15,
        0, 1, 2, 3, 4, 5, 6, 7
    // Loop through all 16 pins and read their state
        bool state = pcf8575_IN1.read(pin_order[i]); // Read pin state (HIGH or LOW)
        Serial.print(state); // Print state: 0 = ON, 1 = OFF
        Serial.print(" ");
    Serial.println(); // Print new line
    delay(500);       // Wait for 500ms before next read
.zip   2-digital-input.zip (Size: 995 bytes / Downloads: 583)
.zip   2-digital-input.ino.merged.zip (Size: 192.34 KB / Downloads: 598)
  [arduino code examples for DM16]-01 16 Channel DAC output by digital input
Posted by: admin - 09-09-2025, 02:49 AM - Forum: DM16 - No Replies
#include <Adafruit_PCF8575.h>
#include <HardwareSerial.h>
// Define Modbus RTU frame format constants
#define MODBUS_READ_COILS 0x01
#define MODBUS_READ_REGISTERS 0x03
#define MODBUS_WRITE_SINGLE_REGISTER 0x06
#define MODBUS_WRITE_MULTIPLE_REGISTERS 0x10
/* Example for 16 input buttons that are connected from the GPIO expander pins to ground.
* Note the buttons must be connected with the other side of the switch to GROUND. There is
* a built in pull-up 'resistor' on each input, but no pull-down resistor capability.
#define DM_NUMS 16 // change for 16, 32 for KinCony DM16, DM32 Smart Dimmer Controller
#define SDA_PIN 8
#define SCL_PIN 18
#define ADDRESS_PCF8575     0x22
#define ADDRESS_PCF8575_2   0x24
#define ST_RX   4 ////ESP32_RCV
#define ST_TX   6 ///ESP32_SEND
typedef enum{KEY_RELEASE=0,KEY_SHORT_PRESSED,KEY_LONG_PRESSED}KEY_STATUS;
typedef struct{
  uint8_t key_index;
  KEY_STATUS key_status;
  long key_time_start;
  long key_time_rec;
  long key_press_time;
  int16_t key_press_cnt; ////Send serial data once every 100 ms
  int16_t key_press_cnt_old;
  float current_light; ///Percentage of 0–4095
}KEY_PRESS_PROP;
KEY_PRESS_PROP key_press_prop[32] = {0};
Adafruit_PCF8575 pcf,pcf2;
HardwareSerial myst_serial(1);
TwoWire myI2c = TwoWire(0);
ushort dm_num = DM_NUMS;
// Modbus CRC16 Calculation function
uint16_t modbus_crc16(uint8_t *data, uint16_t length) {
  uint16_t crc = 0xFFFF;
  for (uint16_t i = 0; i < length; i++) {
    crc ^= data[i];
    for (uint8_t j = 0; j < 8; j++) {
      if (crc & 0x0001) {
        crc = (crc >> 1) ^ 0xA001;
        crc = crc >> 1;
  return crc;
* Send a Modbus RTU frame
* @param serial HardwareSerial object
* @param address Slave address (1-247)
* @param function function code
* @param data
* @param dataLen
void send_modbus_frame(HardwareSerial &serial, uint8_t address, uint8_t function,
                      const uint8_t *data, uint16_t dataLen) {
  // Create a transmit buffer
  uint16_t totalLen = 1 + 1 + dataLen + 2; // address + function code + data + CRC
  uint8_t buffer[totalLen];
  buffer[0] = address;
  buffer[1] = function;
  memcpy(&buffer[2], data, dataLen);
  uint16_t crc = modbus_crc16(buffer, 2 + dataLen);
  // Add CRC (low byte first)
  buffer[2 + dataLen] = crc & 0xFF;      // CRC low byte
  buffer[3 + dataLen] = (crc >> 8) & 0xFF; // CRC high byte
  // Send the complete frame
  for (uint16_t i = 0; i < totalLen; i++) {
    serial.write(buffer[i]);
  // Flush the transmit buffer to ensure all data is sent
  serial.flush();
// Encapsulate commonly used Modbus functions
* Send a Read Holding Registers request
* @param serial
* @param address
* @param startReg
* @param numRegs
void modbus_read_registers(HardwareSerial &serial, uint8_t address,
                          uint16_t startReg, uint16_t numRegs) {
  uint8_t data[4];
  data[0] = (startReg >> 8) & 0xFF; // High byte of the register address
  data[1] = startReg & 0xFF;        // Low byte of the register address
  data[2] = (numRegs >> 8) & 0xFF;  // High byte of the register count
  data[3] = numRegs & 0xFF;         // Low byte of the register count
  send_modbus_frame(serial, address, MODBUS_READ_REGISTERS, data, sizeof(data));
* @param serial
* @param address
* @param regAddress
* @param value
void modbus_write_single_register(HardwareSerial &serial, uint8_t address,
                                uint16_t regAddress, uint16_t value) {
  uint8_t data[4];
  data[0] = (regAddress >> 8) & 0xFF; // High byte of the register address
  data[1] = regAddress & 0xFF;        // Low byte of the register address
  data[2] = (value >> 8) & 0xFF;      // High byte of the data
  data[3] = value & 0xFF;             // Low byte of the
  send_modbus_frame(serial, address, MODBUS_WRITE_SINGLE_REGISTER, data, sizeof(data));
* @param serial
* @param address
* @param startReg
* @param values
* @param numRegs
void modbus_write_multiple_registers(HardwareSerial &serial, uint8_t address,
                                   uint16_t startReg, const uint16_t *values,
                                   uint16_t numRegs) {
  uint8_t byteCount = numRegs * 2;
  uint8_t data[5 + byteCount];
  data[4] = byteCount;
  for (uint8_t i = 0; i < numRegs; i++) {
    data[5 + i*2] = (values[i] >> 8) & 0xFF;
    data[6 + i*2] = values[i] & 0xFF;
  send_modbus_frame(serial, address, MODBUS_WRITE_MULTIPLE_REGISTERS, data, sizeof(data));
  myI2c.begin(SDA_PIN,SCL_PIN,100000);
  myst_serial.begin(115200,SERIAL_8N1,ST_RX,ST_TX);///RXPIN FIRST
  while (!Serial) { delay(10); }
  Serial.println("Adafruit PCF8575 button read test");
  if (!pcf.begin(ADDRESS_PCF8575, &myI2c)) {
    Serial.println("err:DMxx Couldn't find 1_PCF8575!");
    while (1);
  else Serial.println("Find 1_PCF8575!");
  if(dm_num==32)
    if (!pcf2.begin(ADDRESS_PCF8575_2, &myI2c)) {
    Serial.println("DM32 Couldn't find 2_PCF8575");
    else Serial.println("Find 2_PCF8575!");
  for (uint8_t p=0; p<DM_NUMS; p++) {
    pcf.pinMode(p, INPUT_PULLUP);
    if(dm_num==32) pcf2.pinMode(p-16, INPUT_PULLUP);
    key_press_prop[p].key_index = p+1;
    key_press_prop[p].key_status = KEY_RELEASE;
    key_press_prop[p].key_press_time = 0;
  Serial.println("Now, starting!");
static uint16_t input_value_old[2] = {0xffff,0xffff};
uint16_t input_value[2] = {0} ;
int8_t current_operator_key = -1;
int8_t key_index = -1,key_index_last = -1;
int16_t key_press_cnt_old = 0;
uint16_t write_value=0;
static int8_t get_key_press(int8_t chip,uint16_t key_value)
  if(key_value == 0xffff || key_value == 0) return -1;
  for(int16_t i=0;i<16;i++)
    if((key_value & (1<<i) ) == 0)  return (chip==0)?i:i+16;
static uint16_t getKeycode()
  uint16_t input_value = 0,tmp_value;
  uint8_t h_value = 0 ,l_value = 0;
  tmp_value = pcf.digitalReadWord();
  h_value = tmp_value>>8;
  l_value = tmp_value&0xff;
  input_value = (l_value<<8 ) | h_value;
  return input_value;
static uint16_t getKeycode2()
  tmp_value = pcf2.digitalReadWord();
  input_value = (l_value ) | (h_value<<8);
  return input_value;
static void checkKeyPress(int8_t chip);
static uint16_t key_old_arr[2] = {0};
  input_value[0] = getKeycode();
  /*if(key_old_arr[0] != input_value[0] )
    key_old_arr[0] = input_value[0];
    Serial.printf("input0:%d\r\n",input_value[0]);
  checkKeyPress(0);
  if(dm_num == 32)
    delay(10);
    input_value[1] = getKeycode2();
    checkKeyPress(1);
    /*if(key_old_arr[1] != input_value[1] )
      key_old_arr[1] = input_value[1];
      Serial.printf("input1:%d\r\n",input_value[1]);
  delay(10); // a short debounce delay
  uint8_t start_index = (chip==0)?0:16;
  if(input_value_old[chip] != input_value[chip])
    input_value_old[chip] = input_value[chip];
    if(input_value[chip] == 0xffff)
      Serial.printf("key is released!");
      key_index_last = key_index = -1;
      for (uint8_t p=start_index; p<16+start_index; p++) ///all key status init.
        key_press_prop[p].key_time_start = 0;
        key_press_prop[p].key_time_rec = 0;
        key_press_prop[p].key_press_cnt = 0;
        key_press_prop[p].key_press_cnt_old = 0;
    else ///key press
      //Serial.printf("input_value = %04X \r\n",input_value);
      key_index = get_key_press(chip,input_value[chip]);
      if(key_index >= 0)
        key_index_last = key_index;
        Serial.printf("key %02d # is pressed! \r\n",key_index+1);
        current_operator_key = key_index;
        key_press_prop[current_operator_key].key_status = KEY_SHORT_PRESSED;
        key_press_prop[current_operator_key].key_time_start = millis();
        key_press_prop[current_operator_key].key_press_time = 0;
  else
    if(input_value[chip] != 0xffff) ///LONG PRESS!
      //Serial.printf("key long pressed! \r\n");
      if(key_index >= 0 && key_index_last == key_index)
        //Serial.printf("key long pressed! key_index = %d\r\n",key_index);
        key_press_prop[current_operator_key].key_status = KEY_LONG_PRESSED;
        key_press_prop[current_operator_key].key_time_rec = millis();
        key_press_prop[current_operator_key].key_press_time = key_press_prop[current_operator_key].key_time_rec - key_press_prop[current_operator_key].key_time_start;
        key_press_prop[current_operator_key].key_press_cnt = (key_press_prop[current_operator_key].key_press_time % 4080 ) / 100; ////100MS发一次
        //Serial.printf("key long time = %d, cnt = %d \r\n",key_press_prop[current_operator_key].key_press_time,key_press_prop[current_operator_key].key_press_cnt);
        if(key_press_prop[current_operator_key].key_press_cnt_old != key_press_prop[current_operator_key].key_press_cnt)
          key_press_prop[current_operator_key].key_press_cnt_old = key_press_prop[current_operator_key].key_press_cnt;
          /////send st_tx information.
          key_press_prop[current_operator_key].current_light = (float)key_press_prop[current_operator_key].key_press_cnt * 100.0f;
          write_value = (uint16_t) key_press_prop[current_operator_key].current_light;
          Serial.printf("key_long_press_time = %d, current_light = %d \r\n",key_press_prop[current_operator_key].key_press_time,write_value);
          modbus_write_multiple_registers(myst_serial,1,4000+current_operator_key,&write_value,1);
.zip   1-dac-16ch.zip (Size: 2.95 KB / Downloads: 457)
.zip   1-dac-16ch.ino.merged.zip (Size: 205.71 KB / Downloads: 452)
  DM16 ESPHome yaml for home assistant with tuya
Posted by: admin - 09-09-2025, 02:39 AM - Forum: DM16 - No Replies
  friendly_name: dm16
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.2.0
  baud_rate: 0
  hardware_uart: UART0
ota:
  platform: esphome
web_server:
  port: 80
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
  - id: dac_uart
    rx_pin: 4
    tx_pin: 6
    baud_rate: 115200
    stop_bits: 1
    data_bits: 8
    parity: NONE
  - id: tuya_mcu_uart
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: qdmpkznox0g9kkvo
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
modbus:
  - uart_id: dac_uart
modbus_controller:
  - address: 1
    update_interval: 5s
output:
  # CH1 (0x0FA0 / 4000)
  - platform: modbus_controller
    address: 0x0FA0
    value_type: U_WORD
    write_lambda: |-
      // state = 0.0 ~ 1.0 → 0 ~ 4095
      uint16_t reg = (uint16_t) round(x * 4095.0);
      return reg;
  # CH2 (0x0FA1 / 4001)
    address: 0x0FA1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH3
    address: 0x0FA2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH4
    address: 0x0FA3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH5
    address: 0x0FA4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH6
    address: 0x0FA5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH7
    address: 0x0FA6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH8
    address: 0x0FA7
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH9
    address: 0x0FA8
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH10
    address: 0x0FA9
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH11
    address: 0x0FAA
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH12
    address: 0x0FAB
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH13
    address: 0x0FAC
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH14
    address: 0x0FAD
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH15
    address: 0x0FAE
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH16
    address: 0x0FAF
    value_type: U_WORD
    write_lambda: |-
      return reg;
# 16 路 Light (调光灯)
light:
  - platform: monochromatic
    output: dac_ch1_out
    default_transition_length: 0s
  - platform: tuya_wifi_mcu
    name: "Tuya DAC CH1"
    # bind other light, sync state
    bind_light_id: light_1
    output: dac_ch1_out
    dp_id: 2
    # hide from homeassistant ui
    internal: true
    output: dac_ch2_out
    name: "Tuya DAC CH2"
    bind_light_id: light_2
    output: dac_ch2_out
    dp_id: 8
    internal: true
    output: dac_ch3_out
    name: "Tuya DAC CH3"
    bind_light_id: light_3
    output: dac_ch3_out
    dp_id: 16
    internal: true
    output: dac_ch4_out
    name: "Tuya DAC CH4"
    bind_light_id: light_4
    output: dac_ch4_out
    dp_id: 101
    internal: true
    output: dac_ch5_out
    name: "Tuya DAC CH5"
    bind_light_id: light_5
    output: dac_ch5_out
    dp_id: 102
    internal: true
    output: dac_ch6_out
    name: "Tuya DAC CH6"
    bind_light_id: light_6
    output: dac_ch6_out
    dp_id: 103
    internal: true
    output: dac_ch7_out
    name: "Tuya DAC CH7"
    bind_light_id: light_7
    output: dac_ch7_out
    dp_id: 104
    internal: true
    output: dac_ch8_out
    name: "Tuya DAC CH8"
    bind_light_id: light_8
    output: dac_ch8_out
    dp_id: 105
    internal: true
    output: dac_ch9_out
    name: "Tuya DAC CH9"
    bind_light_id: light_9
    output: dac_ch9_out
    dp_id: 106
    internal: true
    output: dac_ch10_out
    name: "Tuya DAC CH10"
    bind_light_id: light_10
    dp_id: 107
    internal: true
    output: dac_ch11_out
    name: "Tuya DAC CH11"
    bind_light_id: light_11
    dp_id: 108
    internal: true
    output: dac_ch12_out
    name: "Tuya DAC CH12"
    bind_light_id: light_12
    dp_id: 109
    internal: true
    output: dac_ch13_out
    name: "Tuya DAC CH13"
    bind_light_id: light_13
    dp_id: 110
    internal: true
    output: dac_ch14_out
    name: "Tuya DAC CH14"
    bind_light_id: light_14
    dp_id: 111
    internal: true
    output: dac_ch15_out
    name: "Tuya DAC CH15"
    bind_light_id: light_15
    dp_id: 112
    internal: true
    output: dac_ch16_out
    name: "Tuya DAC CH16"
    bind_light_id: light_16
    dp_id: 113
    internal: true
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
esphome yaml file download:
.txt   DM16-HA-with-Tuya.txt (Size: 13.11 KB / Downloads: 437)
  KinCony DM16 Smart Dimmer Controller released
Posted by: admin - 09-09-2025, 02:25 AM - Forum: News - No Replies
KinCony DM16 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. DM16 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. DM16 have 2pcs of RS485 port. one RS485 connect with ARM CPU, support use by modbus directly. Another RS485 work with ESP32. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. DM16 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: DM16-1.jpg]
Model No. KinCony DM16
Description: KinCony 16 Channel ESP32-S3 Smart Dimmer Controller – DM16
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
OLED: SSD1306 I2C display
Outputs:
16CH 0-10v Outputs.
Inputs:
4 buttons: 1:ESP32 Reset 2:ESP32 Download 3:Tuya config 4: ARM CPU Reset
[Image: DM16-2.jpg]
  DM16 ESPHome yaml for home assistant without tuya
Posted by: admin - 09-09-2025, 02:17 AM - Forum: DM16 - No Replies
  friendly_name: dm16
ota:
  platform: esphome
web_server:
  port: 80
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
text_sensor:
    ip_address:
      address_0:
      address_1:
      address_2:
      address_3:
      address_4:
    dns_address:
    mac_address:
font:
display:
    address: 0x3C
    lambda: |-
  rx_pin: 4
  tx_pin: 6
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
  debug:
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
output:
    address: 0x0FA0
    value_type: U_WORD
    write_lambda: |-
      return reg;
    address: 0x0FA1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH3
    address: 0x0FA2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH4
    address: 0x0FA3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH5
    address: 0x0FA4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH6
    address: 0x0FA5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH7
    address: 0x0FA6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH8
    address: 0x0FA7
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH9
    address: 0x0FA8
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH10
    address: 0x0FA9
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH11
    address: 0x0FAA
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH12
    address: 0x0FAB
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH13
    address: 0x0FAC
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH14
    address: 0x0FAD
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH15
    address: 0x0FAE
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH16
    address: 0x0FAF
    value_type: U_WORD
    write_lambda: |-
      return reg;
# 16 Channel Dimmer
light:
    output: dac_ch1_out
    output: dac_ch2_out
    output: dac_ch3_out
    output: dac_ch4_out
    output: dac_ch5_out
    output: dac_ch6_out
    output: dac_ch7_out
    output: dac_ch8_out
    output: dac_ch9_out
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
.txt   DM16-HA-without Tuya.txt (Size: 9.49 KB / Downloads: 450)
Sad AG Pro - Disappointed
Posted by: vishal.alex@gmail.com - 09-08-2025, 11:54 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (5)
I brought the AG Pro in June of 2024 when i saw that it had all in one as a Gateway. It was advertised in such a way that it was all in one solution. But as soon as i received it, i found that many of the things advertised is not functioning out of the box. the Zigbee had to be used with tasmota and remaining functions like IR, RF, Tuya and to be with Kincony firmware. and on top of this both firmware cannot work together. I some how managed to flash the Tasmota firmware because i needed the ZHA integration.. and this worked until last month. Now the tasmota firmware has failed to recognize the Zigbee device inside. i tried rolling back to several tasmota version but it all remains the same.
I sent a message to their support and all the response i get is to change the firmware. I feel dumped.. Kincony should have either fixed the firmware issues or informed the customer that these problems exits. 92$(inc Shipping) wasted.
  1-WIRE multiple sensors
Posted by: Ndogo - 09-08-2025, 09:29 AM - Forum: KC868-A16v3 - Replies (1)
Can I connect multiple DS18B20 sensors to one 47 GPIO in the native firmware?
  KinCony Raspberry Pi CM5 Linux Server released
Posted by: admin - 09-07-2025, 08:59 AM - Forum: News - No Replies
KinCony Pi5 is a Raspberry Pi CM5 server for smart home automation and industrial automation control. It can use for home assistant local server. It's a Linux computer, you can install software by yourself, such as Node red. The product default CM5 version is CM5004000. It without Bluetooth and wifi, RAM:4G Lite version.
[Image: Pi5_1.jpg]
Model No. KinCony Pi5
Description: KinCony Automation Local Server – Pi5
Processor: Raspberry Pi Compute Module 5
interfaces: Ethernet(RJ45)-LAN 1000Mbps IPv4/IPv6,USB-C
2 × USB 3 sockets
microSD card socket for CM5 Lite modules
M.2 M key PCIe socket
1 × full-size HDMI 2.0 connectors
DIP SWITCH for jumpers
[Image: Pi5_2.jpg]
  DM16 ESP32-S3 IO pins define
Posted by: admin - 09-07-2025, 02:31 AM - Forum: DM16 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8575: (input1-16): i2c address:0x22 by B16-core
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO7
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
ARM CPU TXD:GPIO4
ARM CPU RXD:GPIO6
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
