» Members: 10,399
» Latest member: charlottehayes9923
» Forum threads: 4,319
» Forum posts: 21,294
There are currently 212 online users.
» 0 Member(s) | 190 Guest(s)
Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Semrush, bot
KC868-A4 – Relay 1 clicks...
2 hours ago
450 Hz allowed on input?
Forum: Development
2 hours ago
How Do You Handle Relay C...
6 hours ago
"KCS" v3.27.4 firmware BI...
Today, 06:02 AM
how to check i2c extend c...
Forum: T16M
Today, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Today, 12:35 AM
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
  More PoE boards?
Posted by: lulu01 - 08-19-2025, 10:09 PM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
is there any chance that you add PoE to more boards in the future, for instance the F24?
  TA needs fallback cellular for monitoring service
Posted by: 5310h - 08-19-2025, 12:33 AM - Forum: TA - Replies (8)
Hi
In order to make the TA a complete security alarm system, it needs a method to communicate to a monitoring service when the Wifi / Internet is down.  Since Kincony already has the SIM7600e board that is used on other products, I would like to see it added to the TA ASAP.  Without it, the TA is just like all the other DIY products.  Really, it's the missing piece.
  F24 and KC868-AP dimmer sharing same wall switch panel
Posted by: stansvec - 08-18-2025, 07:13 AM - Forum: F24 - Replies (1)
Can I use one multi-gang Kincony momentary wall switch with different devices, one device per gang? I want a 2-gangs switch:
 - Gang 1 to an F24 (to control a light bulb by software)
 - Gang 2 to a KC868-AP (ESP32) dimmer (to control an LED strip).
Is this wiring possible?
Many thanks
  KinCony B24 Smart Controller released
Posted by: admin - 08-17-2025, 01:39 AM - Forum: News - No Replies
KinCony B24 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 24 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B24 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. B24 have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B24 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: B24-1.jpg]
Model No. KinCony B24
Description: KinCony 24 Channel ESP32-S3 Smart Relay Controller – B24
Power supply: 12V DC
SD Card: SPI bus
Installation method: DIN RAIL
OLED: SSD1306 I2C display
[Image: B24-2.jpg]
  how to use F16 tuya app with analog sensor
Posted by: admin - 08-16-2025, 09:55 AM - Forum: F16 - No Replies
1. download new firmware for F16:
.zip   KCS_F16_V3.11.6_beta_20250816-173359.zip (Size: 1.05 MB / Downloads: 743)
2. set ADC for Custom value1, Custom value2 and Threshold.
for example:
you are using DC 0-5v analog signal sensor. you can set as this photo.
3. enter "Protocol" -- "Tuya" webpage, select the product id = 2v6wdnkvsp5xhx9c
two different PID use different tuya UI interface for F16 Controller.
  KinCony N60 ESP32-S3 AC LoRa Energy Meter released
Posted by: admin - 08-14-2025, 11:42 PM - Forum: News - No Replies
We have designed 60 Channel ESP32 energy monitor board – N60 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The hardware have 60CH CT Clamp sensor INPUT ports + 6CH ZMPT101B voltage sensor + SD card + LoRa module + OLED display + free GPIOs. Ethernet+RS485+i2c extender 60CH high-accuracy energy meter ic-BL0910 with CT clamp. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32-S3 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant for smart home automation DIY. N60 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. N60 support connect to your own cloud server by MQTT.
[Image: N60-1.jpg]
Model No. KinCony N60
Description: KinCony 60 Channel AC Energy Meter – N60
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,LoRa,USB-C,i2c extender
CT Clamp: 60 channel 2000:1 CT clamp "voltage" sensor
6 channel AC voltage: AC 0-380v
Button-DL: ESP32S3 download
Button-EN: ESP32S3 reset
Button-RST: RESET for ARM CPU
LED:
D5: power LED
D7: error LED
D6: running LED
Free GPIOs: GPIO15,GPIO16
[Image: N60-2.jpg]
[Image: N60-diagram.jpg]
what's mainly different between N60 and M30 energy meter board:
1. N60 use by KCS v3 using ESP32-S3 large memory CPU, M30 use by KCS v2 using ESP32 CPU.
2. N60 have flash chip save the total energy data when N60 power off.
3. N60 use SD card to save energy data as excel file for every one hour.
4. N60 have i2c extender, easy extend i2c temperature and humidity sensors.
5. N60 have 2 free GPIOs use for sensor or KinCony G1 4G module.
6. N60 support use by MAX 250A CT clamp sensor. M30 support MAX 120A CT clamp sensor.
7. N60 support LoRa for KinCony ALR or KC868-A6v3 LoRa board.
8. N60 added new coefficient correction settings page
9. N60 use new Modbus protocol for user to read and config all channel data.
10. N60 support IFTTT, automatic send command by voltage or current or some other IF condition.
  Using a different OLED
Posted by: 1damo1 - 08-14-2025, 09:38 AM - Forum: KC868-A6v3 - Replies (1)
Good Evening,  hoping someone has done this or knows what I need todo.
I'm looking to add a larger screen to the A6v3.
I'm looking to add this type of screen, im having an issue with selecting the appropriate pins on the board & assigning the appropriate pins in my arduino code.
Thankyou in advance
Damien
  M30 new yaml
Posted by: sufpunk - 08-13-2025, 08:51 PM - Forum: KC868-M16 / M1 / MB / M30 - No Replies
Hi, I have a Kincony M30 and use it with ESPHome in Home Assistant.
Currently, my m30.yaml is configured from the following thread:
https://www.kincony.com/forum/showthread.php?tid=4088
Today I tried updating my M30 with ESPHome version 2025.7.5 and received error messages related to led id
light.partition: [source /config/esphome/garage-energiemesser.yaml:1864]
  platform: partition
  segments:
      Couldn't find ID 'light1'. Please check you have defined an ID with that name in your configuration.
      to: 29
      reversed: False
Is it possible to provide an updated and tested version of the M30 config YAML?
Best regards,
sufpunk
  Connect RS485 KC868-HAv2 to Server Mini
Posted by: Mijoo - 08-13-2025, 02:05 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (4)
Help: Connect RS485 I/O modules to the Raspberry Pi 4 Relay Board (Server Mini) + Home Assistant OS
Hardware
Goal
  1. Daisy-chain several KinCony RS485 I/O modules to the Server Mini’s onboard RS485.
  2. Control/monitor them from Home Assistant OS (HA Modbus if possible).
  3. Best-practice for addressing many modules (bulk provisioning) without connecting a laptop each time.
What I’ve found / tried so far
  • The board exposes RS485 via the Pi’s UART (I see pins marked GPIO14 = TX, GPIO15 = RX on documentation/pins).
  • On Home Assistant OS, I cannot just edit /boot/config.txt like on Raspberry Pi OS, so I’m not sure about the correct way to enable the UART for the onboard RS485 under HA OS.
  • I tried using generic HA Modbus config but I’m not 100% sure about the device path (e.g. /dev/ttyAMA0, /dev/ttyS0, or /dev/serial/by-id/...) and serial parameters (baud, parity, stop bits) for KinCony’s RS485 port on this board.
Questions
  1. Wiring
    • Do I need a 120 Ω termination resistor at the last device? Are there built-in bias resistors on the Server Mini’s RS485 transceiver, or should I add my own?
    • Any max bus length / topology recommendations? (I’ll use daisy chain, not star.)
  2. Protocol & parameters
    • Do those RS485 I/O modules speak Modbus RTU out of the box? If yes, what are the default serial parameters (baud, parity, stopbits) and the register map (coils/inputs/holding)?
    • If it’s not Modbus RTU by default, is there a Modbus firmware or config mode I should use?
  3. Addressing multiple modules
    • How do I set unique addresses for each module? DIP switches? Command?
    • For bulk installs, is there a recommended workflow to assign addresses without hooking up each module to a PC? (Auto-addressing, scan/assign tool, etc.)
  4. Home Assistant OS specifics
    • On this KinCony board with HA OS, what is the correct serial device path for the onboard RS485 (e.g., /dev/ttyAMA0)?
    • What is the recommended way to enable UART on HA OS for this board (since /boot/config.txt is read-only under HA OS)? Any KinCony-specific steps or an add-on?
    • A minimal, known-good Home Assistant modbus: YAML example for one RS485 I/O module would be super helpful.
  5. Examples
    • Could you share example register addresses (coils/inputs) for:
      • Reading digital inputs from a KinCony RS485 I/O module
      • Controlling a relay output (if the chosen module has relays)
    • Any sample configs for more than one module on the same bus?
  Server-Mini and RS485 - IO Module – KC868-HAv2
Posted by: Mijoo - 08-13-2025, 01:44 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (1)
Hello, friends.
Hardware
Goal
  • I previously attempted the old rpi_gpio integration for direct GPIO, but HA OS doesn’t include that — so I want to use RS485/Modbus properly instead.
