Could you create a simple tutorial video on how to communicate between a PLC and KC868-Server Raspberry Pi4 via Ethernet? For example, sending data like temperature (Analog) from Raspberry Pi to Mitsubishi PLC, and controlling PLC inputs and outputs through Raspberry Pi.
Hello Kincony, am Nii, a security systems and IT technician who enjoy IoT and wants start a project of it.
I want to get a free sample in order to understand and improve myself of what I have learnt from the videos on Kincony YouTube channel.
As an IT technician, I want to also educate and install for clients so they can enjoy IoT.
Thank you.
It is producing this log (config_default_log.txt) when I am pressing the same button multiple times.
The following log entry correlates with each button press:
Quote:Component remote_receiver took a long time for an operation (0.05 s).
Logged code values are always somehow random.
Trying to send, one of the received random codes is not possible. Always because of: "Inconsistent data, not sending"
The log is attached as "config_default_log_error.txt"
Am I doing something incorrectly and causing this issue?
I downloaded on my KC868-AK V2.0.5 but it doesn't work well. can i get the old version (V 1.0.6) it works so well with my KC868-H32B and is much easier to config
