» Members: 9,584
» Latest member: soicauxsmbioo
» Forum threads: 4,191
» Forum posts: 20,830
There are currently 24 online users.
» 0 Member(s) | 13 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, bot
N60 Sensor channel label
Forum: N60
Today, 01:50 AM
» Replies: 17
solar production and cons...
Forum: N30
Today, 01:46 AM
Current direction detecti...
Forum: N30
Today, 01:44 AM
MQTT Discovery: missing s...
Forum: N30
Yesterday, 02:48 PM
ai automation
Forum: KinCony integrate with Loxone home automation
Last Post: mediverticals
Yesterday, 06:56 AM
Connecting sensors to Kin...
Forum: F16
Yesterday, 12:18 AM
CT Sensor Direction
Forum: N60
08-12-2026, 08:14 AM
N60 Voltage reference
Forum: N60
08-11-2026, 11:09 PM
4-20mA loop voltage consi...
Forum: B4M
08-11-2026, 08:05 AM
K868-a32 plastic case
08-10-2026, 08:48 AM
  KC868-A8 Inputs
Posted by: pier - 08-17-2023, 03:54 PM - Forum: KC868-A series and Uair Smart Controller - Replies (11)
Hi everyone,
I ask a silly thing: what maximum voltage can the 8 inputs (clean contacts) of the KC868-A8 board have? 12v? 220v?
The doubt arises from the fact that, when powered, with the tester, I measure 12v between the common and input 1 or input 2 or input 3 etc. etc.
Pier
  KC868-Meter
Posted by: hentes - 08-17-2023, 03:32 PM - Forum: KC868-HxB series Smart Controller - Replies (24)
Hello.
Anybody else having issues to read meter (KC868-Meter-1PV-RS485) data with KC868-COLB using Kincony Smart Board controller software?
Steps taken:
1. connected the Meter to COLB. Wire B to 12, wire A to 11
2. no other sensors or devices are connected to COLB, only the meter
3. successfully connected to COLB with Kincony SCB_V1.0.410.504
4. Enabled Autoreport
5. Opened the EMeter page
6. Set meter ID number
7. Clicked the Read button
After waiting about 1 minute all fields (kWH, V, A, kW, Q, Hz) are still 0.
Changed the meter to another one (replaced the meter ID in Kincony SCB_V1.0.410.504 ) but the result is the same. Cannot read meter data.
Any help will be appreciated. Thank you.
  KC868-A8S MQTT Setup
Posted by: saun2000 - 08-16-2023, 12:11 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (3)
Can you please help me with MQTT setup for the KC868-A8S board? It's already configured but I still cannot operate from Home Assistant. I believe it UID issue.
Thank you.
  KinCony E16P ESP32 I/O pin define
Posted by: admin - 08-16-2023, 05:37 AM - Forum: KC868-E16S/E16P - No Replies
ANALOG_A1  GPIO36
ANALOG_A2  GPIO35
ANALOG_A3  GPIO34
ANALOG_A4  GPIO39
IIC SDA:GPIO16
IIC SCL:GPIO15
PCF8574:U27 (relay1-8): 100 001 = 0x21
PCF8574:U28 (relay9-16): 100 101 = 0x25
PCF8574:U23 (DI1-8): 100 010 = 0x22
PCF8574:U24 (DI9-16): 100 100 = 0x24
RF433MHz wireless receiver: GPIO4
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO13
TXD:GPIO32
Extend serial port (3.3v TTL level):
RXD:GPIO14
TXD:GPIO33
  AG Pro ESP32 I/O pin define
Posted by: admin - 08-16-2023, 05:32 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - No Replies
IR receiver: IO23
IR sender: IO2
433MHz receiver: IO13
433MHz sender: IO22
Buzzer: IO4
Zigbee CP2652:
RXD:32
TXD:33
free GPIO:
IO26,IO14,IO34,IO21,IO18
IO25,IO27,IO39,IO35,IO19
  tasmota zigbee firmware for AG Pro controller
Posted by: admin - 08-16-2023, 05:28 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (18)
tasmota config module GPIO for Zigbee module RXD,TXD pins:
AG Pro work with Xiaomi Zigbee temperature & humidity sensor:
tasmota zigbee firmware download:
.zip   tasmota32_CP2652.zip (Size: 1.03 MB / Downloads: 962)
or you can download newest firmware from tasmota official webpage:
http://ota.tasmota.com/tasmota32/release/
ESP flasher for ESP32, ESP32-C3, ESP32-S2, ESP32-S3 and ESP8266 (Tasmota) download:
https://github.com/Jason2866/ESP_Flasher/releases
  download zigbee coordinator firmware by Jlink for AG Pro controller
Posted by: admin - 08-16-2023, 05:25 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - No Replies
firmware:
.zip   CC1352P2_CC2652P_launchpad_coordinator_20221226.zip (Size: 159.82 KB / Downloads: 804)
  Wireless ALL IN ONE controller - KC868-AG Pro released
Posted by: admin - 08-16-2023, 04:38 AM - Forum: News - No Replies
we have designed KC868-AG Pro by ESP32 + Tuya + Zigbee 3.0 module, it's easy to use ESPHome for home assistant. Now you can use home assistant and Tuya app at the same time. You can define RF buttons and IR buttons to control TV or air conditioner by IR signal. KinCony AG Pro also is a Zigbee3.0 gateway.
[Image: AG-Pro-1_01.jpg]
[Image: AG-Pro-1_02.jpg]
[Image: AG-Pro-1_03.jpg]
There are different use way for KC868-AG Pro smart controller.
1. download "KCS" firmware to ESP32 chip. You can use IR receiver/sender, RF receiver/sender with ESP32.
2. config ESPHome work with home assistant, the config ymal file as same as KC868-AG's yaml file, you can download from KinCony's forum.
3. use Tuya mobile phone app directly, remote control IR and RF device by internet.
4. download Zigbee3.0 coordinator firmware to Zigbee module (from factory we have already downloaded), work as Zigbee3.0 gateway. it support tasmota zigbee, support work as ZHA in home assistant.
if you want to update Zigbee coordinator firmware for Zigbee module, you can use Jlink download by JTAG on PCB pins.
KC868-AG Por can connect with extend IR cable, just connect to "P9" green terminal on PCB. extend IR signal from Tuya module. if you want to extend IR signal from ESP32. just set the resistance RJ10 and RJ11 value.
RJ10=0 ohm RJ11=NC extend IR cable signal from Tuya module.
RJ10=NC RJ11=0 ohm extend IR cable signal from ESP32 module.
LED indicator and button:
on the bottom of box, there is RESET button for config Tuya module. HOLD on will reset Tuya module, then you can begin pair with your Tuya mobile phone app.
Red LED: power
Yellow LED: Tuya module state
Green LED: Zigbee state
  Cant connect after FW update
Posted by: freedom1711 - 08-16-2023, 02:43 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
Did FW update so I can connect loxone.
IP address changed I still cant connect
after reboot led lights were red and yellow normally they are red and blue.
Please advise, since nobody is able to do live support after selling me the product.
After power reboot Red, Blue & yellow light are on
  Request for free sample product
Posted by: Rajkumar - 08-15-2023, 01:30 PM - Forum: Apply for free sample product - No Replies
Application condition A: Free education.
I am interested in IOT. I watched many KinCony's home automation videos from youtube. I am planning to setup automation for my new house. So, I would like to aquire both free sample of products will help me to learning and testing for home automation. I am excited to explore the capabilities of these products and to gain hands-on experience with them.
Thank you
Best Regards,
Rajkumar
