» Members: 9,692
» Latest member: purpleshopcanna
» Forum threads: 4,195
» Forum posts: 20,850
There are currently 39 online users.
» 0 Member(s) | 21 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Crawl, DataForSeoBot, Google, PetalBot, bot
KC868-meter-7pv-rs485
Forum: Development
7 hours ago
» Replies: 7
N60 configure yaml for ES...
Forum: N60
08-23-2026, 01:42 AM
» Replies: 7
KCS VERSUS ESPHOME
Last Post: EDVALDO DE MARINGA
08-22-2026, 01:31 PM
KC868-AGv3
08-20-2026, 10:18 PM
Forum: KC868-A32/A32 Pro
Last Post: huanmarie
08-19-2026, 07:09 AM
KC868-H32B V5.08 firmware
Forum: News
Last Post: meoowu77
08-18-2026, 11:46 AM
» Replies: 24
KinCony B2 Smart Controll...
Forum: News
08-17-2026, 01:07 PM
KC868-A8v3 PCB layout CAD...
08-17-2026, 08:44 AM
CT Clamp Compatibility
08-16-2026, 11:08 PM
» Replies: 12
N60 Sensor channel label
Forum: N60
Last Post: marekd1
08-14-2026, 09:14 PM
» Replies: 18
  Add i2c pins or RTC time
Posted by: GDN20 - 08-13-2023, 08:42 AM - Forum: KC868-A4 - Replies (1)
hello, does the company plan to add i2c pins to the board to connect the RTC (as in kc868 a8s)clock or integrate the clock module?(as in в ks868 a6)
  How can the configuration files be separated in the configuration.yaml file?
Posted by: engmohades - 08-12-2023, 06:00 AM - Forum: Home automation training courses - Replies (1)
I have 6 devices, including kc868-16t and kc868-server, and I will be using kcs-v2. I will use Home Assistant with MQTT. However, the number of lines written in the configuration.yaml file is too long.
 Is it possible to write separate configuration lines for each device in a separate file?
  Does it work with 220v bulbs?
Posted by: phrfpeixoto - 08-11-2023, 02:58 AM - Forum: KC868-AP / ADR - Replies (3)
I'm considering using this board in my new apartment setup, and I'd like to have dimmer-able lights.
The thing is: The market around here (Brazil) 99% of dimmer-able lights are 110/220v.
I've seen that this would require Solid State Regulators to actually regulate the high voltage, but I've also seen posts stating compatibility issues.
Is this board really recommended for this setup?
If so, is there an SSR bank (ie, a board with multiple channels)? Using individual SSR is expensive and will likely take a lot of physical room on the box
Examples:
https://pt.aliexpress.com/item/1005004999414308.html
Photo H16B
Posted by: MartinHenenne - 08-10-2023, 03:01 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
Good day support
We are using one of the Kincony controllers(Frimware H16B_V4.35) and we are facing some issues with communication stability. We have the below device in production.
I can constantly get a ping reply from the device on its local IP address. Yet I lose communication with the TCP port 7000. When this happens I can not send remote commands to the device. To get the device to respond to the TCP port 7000 again. I have to perform one of the following actions.
- Reboot the controller
OR
- Remove the RJ-45 connector and re-seat the connector
Once I have completed 1 of the steps mentioned above, I can get a response from TCP port 7000. My issue is that this happens 20-30 times a day and I can not keep rebooting the device.
Please can you assist me in resolving this issue?
  Can the output be an input?
Posted by: gsmstudio - 08-10-2023, 02:56 PM - Forum: KC868-A32M - Replies (1)
Hello. How do I convert a mosfet 32 output channel into an input one?
  KC868-H32B_Pro Factory Original Firmware ESP32
Posted by: Pawel2 - 08-09-2023, 07:53 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
I need full original firmware for KC868 H32B Pro Smile
  IFTTT Scheduling not work
Posted by: domotic31 - 08-09-2023, 12:41 PM - Forum: "KCS" v2 firmware system - Replies (1)
I have a KC868_A8 board with firmware 2.0.5 and I can't get a scheduled daily action to work. When the time is reached, the output is not activated. See picture below.
Can you help?
  Problem in H32B and terminal swich board connected
Posted by: ahmed - 08-09-2023, 07:41 AM - Forum: KC868-HxB series Smart Controller - Replies (9)
I can't control H32B
It is not responding neither by terminal switchboard push button nor using ip address of controller.
  Channels always have current
Posted by: beto1705 - 08-08-2023, 10:07 AM - Forum: KC868-AP / ADR - Replies (21)
I have a problem with the board... Channels 0, 3, 7, and 13 are always powered.
I have disconnected everything from the board except the power and only in those 4 channels always have 24v at the output.
Is it a board or programming problem? I think it's the board because the other outputs work fine...
What can I do?
  KC868_A64
Posted by: Sten - 08-06-2023, 09:16 PM - Forum: KC868-A series and Uair Smart Controller - Replies (9)
Dear Admin
After KC868_A64 update to KCS 2, there is probeb to stay online.
Every time when I press SAVE button, I have to make the power restart to the A64 board. Without restart the board is offline, the device scaner does not see the A64 board.
And sometimes Tuya app does not see the A64 board, then I have to make the power restart.
I made a restart to my router and tried another router also.
What can be the problem?
Regards
Sten
