» Members: 10,109
» Latest member: 8xbettbdcom
» Forum threads: 4,257
» Forum posts: 21,085
There are currently 174 online users.
» 0 Member(s) | 155 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, PetalBot, Yandex, bot
Update to latest esphome
Last Post: Elgatoguiri
Yesterday, 07:10 PM
m16v2 energy meter - cali...
Yesterday, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
Video KC868-AP
Posted by: eligijus - 05-26-2023, 05:13 AM - Forum: KC868-AP / ADR - Replies (5)
Hello, why is the flashing light being dimmed
Maybe this board does not work with ssr
  NTC 10k
Posted by: GDN20 - 05-24-2023, 09:24 PM - Forum: KC868-A8S - Replies (5)
how to connect an NTC 10K thermistor and get readings?
  Does your device support the frequency measurement mode at the Digital Input pin?
Posted by: Bogdan107 - 05-24-2023, 07:56 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
I want to build the monitoring system for the ribbon saw (KASTO HBA-430) with KC868-A8 device.
I have difficulties in understanding whether your device can measure the frequency.
I want to measure the rotation frequency of the pulley of the ribbon saw.
At the moment, the rotation frequency of the pulley is measured by the CF5135C-Z device with sensor NJK-5002C NPN NO.
Typical frequency range is 0..120 rpm.
Does your device support the frequency measurement mode by the Digital Input pin?
Does your device support the frequency measurement mode by the some I2C external device?
Which of your devices can measure frequency using a sensor like NJK-5002C?
  WindowsError(5, 'Access Denied.')
Posted by: dampire - 05-24-2023, 02:45 PM - Forum: KC868-A8 - Replies (1)
HI,
I can't run any code from arduino.
I run the ide with arduine on windows 10.
I installed the drivers that I read in a post for the usb port.
The error:
esptool.py v3.0-dev
Serial port COM3
Traceback (most recent call last):
  File "esptool.py", line 3682, in <module>
  File "esptool.py", line 3675, in _main
  File "esptool.py", line 3329, in main
  File "esptool.py", line 263, in __init__
  File "site-packages\serial\__init__.py", line 88, in serial_for_url
  File "site-packages\serial\serialwin32.py", line 62, in open
serial.serialutil.SerialException: could not open port 'COM3': WindowsError(5, 'Access Denied.')
  Free sample KC868-A4 ESP32 board
Posted by: vitorxlima - 05-24-2023, 12:59 PM - Forum: Apply for free sample product - No Replies
Dear Kincony,
I Would like to try to aquire one sample for of KC868-A4 to learning and testing for home automation (type of use A).
Best Regards.
Brick Free gpio in KC868-E16S
Posted by: Sewek0 - 05-23-2023, 11:38 AM - Forum: KC868-E16S/E16P - Replies (3)
Is anyone try to use free gpio on this board?
I mean solder cables to not used GPIO (6-11)??
Marked red in diagram. 17-22
  Schematic of Power Distribution Box Made by KC868-Server
Posted by: admin - 05-23-2023, 07:25 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
  5V DC Input
Posted by: italo - 05-22-2023, 01:51 PM - Forum: KC868-A4S - Replies (3)
hi, first of all thanks for the great product. it fits 100% to our requirements.
we use the board togehter with home assistant and ESPhome V 2023.5.2.
We like to messure Temperature via NTC sensors. We use this settings.
10K NTC
9.89K resistor
5V DC Power Supply
Connected on INA1
We get a wrong temperature reading. If we connect the 5V DC direkt to the  INA1 input we get max. 3.03V on the GPIO36. As we see you use a LMxxx bevor the ESP32. Is the conversion of the 5V linear
to the 3.3V input of the ESP32? Do you have any hints? as the  reference_voltage we use 3V because of the limitation of the ESP32.
BR
Giuseppe
ESPHome Code:
  -  platform:  ntc
     sensor:  resistance_sensor
     name:  NTC Temperature
     calibration:
      b_constant: 3950
      reference_temperature: 25°C
      reference_resistance: 10kOhm
  # Example source sensors:
  - platform: resistance
    sensor: INA1
    configuration: DOWNSTREAM
    resistor: 9.89kOhm
    reference_voltage: 3V
  - platform: adc
    pin: GPIO36
    attenuation: auto
    update_interval: 5s
Big Grin KC868-COLB Mini Logic Controller
Posted by: ahmedwizza - 05-22-2023, 10:07 AM - Forum: News - Replies (7)
hello kincony
I have some problem when I add analog in my yamal file
--give me wrong when I make restart
--and all mqtt stop
---when i remove all thing good
this my yamal file in attach
.txt   my yamal file.txt (Size: 56.11 KB / Downloads: 710)
  Free sample controller KC868-A4
Posted by: Aleksis - 05-22-2023, 08:45 AM - Forum: Apply for free sample product - No Replies
I am very interested in Kincony products and features and would like to explore all the possibilities in practice.
I would like to apply with condition A as I plan to use the KC868-A4 kit for personal training and development. I am very excited to explore the possibilities of these products and gain hands-on experience with them. I would like to try to implement various projects and in the future to purchase a large controller to automate other processes.
Best wishes,
Aleksandra
