» Members: 9,903
» Latest member: qq8876net
» Forum threads: 4,232
» Forum posts: 20,985
There are currently 97 online users.
» 0 Member(s) | 81 Guest(s)
AhrefsBot, Amazonbot, Baidu, Bytespider, Crawl, PetalBot, bot
Pi5R8 Bundle B (CM5 Lite)...
Forum: Pi5R8
2 hours ago
Modbus 485 extender kcs V...
Forum: N30
Yesterday, 10:27 PM
"KCS" v3.27.2 firmware BI...
Yesterday, 02:40 AM
N10 - ESPHome - ARM CPU s...
Forum: N10
09-10-2026, 11:49 PM
extend KC868-A16v3
09-10-2026, 11:48 PM
"KCS" v2.2.21 firmware BI...
09-10-2026, 12:13 PM
KC868-A16 Outputs Y01-Y16...
09-09-2026, 11:15 PM
wish
Forum: KC868-A16v3
09-09-2026, 01:14 PM
Last Post: viko
09-09-2026, 11:39 AM
» Replies: 22
B32M maximum voltage
Last Post: velifetime
09-08-2026, 07:01 AM
  kc868-a6 Bluetooth issue
Posted by: AndyW - 06-28-2023, 03:39 PM - Forum: KC868-A6 - Replies (5)
I have a usecase for the kc868-a6 that requires the bluetooth to work with esphome. As soon as I enable anything bluetooth related I get fatal errors and the wifi never connects to the network.
This is the code I am trying to use that appears to corrupts the esp32.
substitutions:
mac_address: C8:47:8C:E1:E2:E2
esp32_ble_tracker:
ble_client:
- mac_address: ${mac_address}
- platform: ble_client
ble_client_id: client0
name: "enable bluetooth connection"
Any thoughts on why the esp32  does not like the bluetooth settings? After removing the bluetooth settings and reflashing I am able to connect to the controller again.
Thanks in advance.
Andy
  K868-E16S use digital input and I2C in the same time
Posted by: Jtefan - 06-28-2023, 01:59 PM - Forum: KC868-E16S/E16P - Replies (8)
I've defined the digital inputs and switches as in the example and also added a DS18B20 temp sensor to the I2C. But as soon as I add in yaml the Dallas configuration, the update_interval toggles the switches on and off at the interval set in the update_interval.
I saw that the I2C port is the same as the Dallas sensor but I don't know how I can connect them in a different way.
  friendly_name: Kincony KC868-E16S
  platform: ESP32
captive_portal:
  sda: 16
  scl: 15
    address: 0x21
    address: 0x25
      pcf8574: pcf8574_hub_out_2
    name: "DI1 - Entrance Left B1"
      pcf8574: pcf8574_hub_in_2
    internal: true
    on_press:
      then:
      - switch.toggle: output14
dallas:
  - pin: 16
    update_interval: 30s
  - platform: dallas
    address: 0x453c430457d4c928
    name: "Livingroom Temperature"
  - platform: dallas
    address: 0x9d3c450457bfc728
    name: "Bedroom Temperature"
  KC868 4A control water from phone
Posted by: Aleksis - 06-26-2023, 07:50 PM - Forum: KC868-A4 - Replies (7)
Good afternoon.
In my project, a water level sensor and a temperature sensor are connected to the KC868 A4 controller.
Please tell me which program is better to monitor the readings from the sensor. I tried to connect to Homekit, there were no problems with the temperature sensor, but I didn’t understand how to make the status bar for filling the tank with water.
Maybe tell me how best to implement control from the phone for these sensors through the 4
A4 controller?
Link to liquid level sensor:
https://sl.aliexpress.ru/p?key=bfXBZR9
And DS18B20
  Request for Free Sample
Posted by: sadranyi@gmail.com - 06-25-2023, 05:16 PM - Forum: Apply for free sample product - No Replies
Hello, my name is Samuel Adranyi,
I am an IoT enthusiast and content creator. I have been following your products for some time and would like to request some free samples.
This is my youtube channel where I do a lot of IoT stuff and also community engagement: https://www.youtube.com/live/9bGSxDGeS5c?feature=share
I am also a Microsoft Most Valuable Professional (MVP) in the Azure and IoT Category; you can find my profile herehttps://mvp.microsoft.com/en-us/PublicProfile/5003737
I want to create content around your products and educational projects for the IoT community here in Ghana.
I want to sample the KC868-A4 Bundle E. I welcome any other device or product you want me to test or create a project.
Thank you, and awaiting your kind response.  Smile
  Using two PCF8574s for DI and DO
Posted by: mafckz - 06-25-2023, 12:23 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
How to use two PCF8574s for DI and DO both?
Next program works correctly when I use only one PCF8574 (adress: 0x22; I2C pins: 4,15) that controls DI inputs on the board:
But it doesn't work when I uncomment code in red frames, trying to add another PCF8574 (adress: 0x24; I2C pins: 4,15) that controls DO outputs on the board.
Correct code for using digital input PCF8574 without errors   "1.png"
// Library: PCF8574_Library by RENZO MISCHIANTI
// https://mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574i(0x22,4,15);
// PCF8574 pcf8574(0x24,4,15);
unsigned long timelapsed;
    pcf8574i.pinMode(0, INPUT);
    pcf8574i.pinMode(1, INPUT);
  // pcf8574.pinMode(0, OUTPUT);
  // pcf8574.pinMode(1, OUTPUT);
  // sleep(100);
  // pcf8574.digitalWrite(0, LOW);
  // pcf8574.digitalWrite(1, LOW);
  delay(2000);
    Serial.print("Init pcf8574i...");
    if (pcf8574i.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
  // Serial.print("Init pcf8574...");
  //   if (pcf8574.begin()){
  //       Serial.println("OK");
  //   }else{
  //       Serial.println("KO");
    uint8_t val1 = pcf8574i.digitalRead(0);
    uint8_t val2 = pcf8574i.digitalRead(1);
  // if (val1==LOW) {
  //   Serial.println("KEY1 PRESSED");
  //   // pcf8574.digitalWrite(0, HIGH);
    // if (val2==LOW) {
  //   Serial.println("KEY2 PRESSED");
  //   // pcf8574.digitalWrite(1, HIGH);
  delay(100);
  // Serial.println("--");
Sad AM2120 Temperature Sensor
Posted by: mrteaiot - 06-24-2023, 06:02 AM - Forum: KC868-A8 - Replies (3)
I bought this AM2120 Temperature and Humidity Sensor and I am not able to get it to read input sensor on my ESPHOME.  I have bought AM2301 and it works fine with the same ESPHOME code as below:
  - platform: dht
    pin: 33
    model: AM2302   ## New Sensor AM2120  NOT WORKING - NA reading
    temperature:
      accuracy_decimals: 1
    humidity:
Do I use the wrong code for my board?
Thanks..
  GSM CALL RELAY
Posted by: Anthonio - 06-24-2023, 12:29 AM - Forum: KC868-A2 - Replies (9)
I am having difficulty for coding my script, I would like to make a GSM relay which activates the GPIO 15 relay upon the module receipt a call ! but I cannot do it can you help me?
I think my problem is from the command of call detection.
#include <SoftwareSerial.h>
// Create software serial object to communicate with A6
SoftwareSerial mySerial(13, 34); // A6 Tx & Rx is connected to Arduino #3 & #2
int relayPin = 15; // GPIO 15 connected to the relay
  // Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  // Begin serial communication with Arduino and A6
  mySerial.begin(115200);
  Serial.println("Initializing...");
  pinMode(relayPin, OUTPUT); // Set the relay pin as an output
  digitalWrite(relayPin, LOW); // Initialize the relay as OFF
  updateSerial();
  checkCall();
void updateSerial()
  delay(500);
  while (Serial.available())
    mySerial.write(Serial.read()); // Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read()); // Forward what Software Serial received to Serial Port
void checkCall()
  if (mySerial.available())
    String response = mySerial.readString();
    if (response.indexOf("+CLCC: 1,1,2,4,0") != -1) // Check if "+CLCC: 1,1,2,4,0" is present in the response
      activateRelay();
void activateRelay()
  digitalWrite(relayPin, HIGH); // Turn ON the relay
  delay(5000); // Keep the relay ON for 5 seconds
  digitalWrite(relayPin, LOW); // Turn OFF the relay
  Which GND to use for sensors ?
Posted by: primeroz - 06-23-2023, 01:58 PM - Forum: KC868-A2 - Replies (1)
Hi, the only GND i see on the A2 is the one also used for POWER IN
I want to connect a PIR , i can take the `3v3` from the board but i am not sure which GND to use . Should i use the same as the `INPUT power` ?
example diagram of what i want to do
  Trouble controlling the H100 Inverter using RS485 Protocol
Posted by: shaolink - 06-22-2023, 06:48 PM - Forum: DIY Project - Replies (9)
I was following this video
how to control VFD (Variable Frequency Drive) inverter by KC868-COLB - YouTube
And wrote this code to control my H100 Inverter ( How to: H100 VFD & 1.5KW Air-Cooled Spindle Setup - Zhong Hua Jiang - How To - Carbide 3D Community Site)
import serial
def calculate_crc(data):
    reg_crc = 0xFFFF
    for byte in data:
        reg_crc ^= byte
        for _ in range(8):
            if reg_crc & 0x0001:
                reg_crc = (reg_crc >> 1) ^ 0xA001
            else:
                reg_crc >>= 1
    return reg_crc
# RS485 port settings
rs485_port = 'COM12'
rs485_baud_rate = 115200
rs485_parity = serial.PARITY_NONE
rs485_stop_bits = serial.STOPBITS_ONE
rs485_data_bits = serial.EIGHTBITS
try:
    # Open the RS485 serial port
    ser = serial.Serial(
        port=rs485_port,
        baudrate=rs485_baud_rate,
        parity=rs485_parity,
        stopbits=rs485_stop_bits,
        bytesize=rs485_data_bits,
        timeout=1
    # Send a command via RS485 in RTU mode
    command = [0x64, 0x01, 0x02, 0x20, 0x00, 0x00, 0x01, 0x43, 0xCA]  # Modify the command in hexadecimal format
    crc = calculate_crc(command)
    command.append(crc & 0xFF)  # Low byte
    command.append((crc >> 8) & 0xFF)  # High byte
    ser.write(bytes(command))
    # Read the RS485 response
    response_rs485 = ser.readline()
    hex_response_rs485 = ' '.join(hex(byte) for byte in response_rs485)
    print("RS485 Response:", hex_response_rs485)
    # Close the RS485 serial port
    ser.close()
except serial.SerialException as e:
    print("Error opening or accessing the serial port:", str(e))
This is the code I wrote. The checksum passes, and everything else is fine. But when I run the code, it doesn't reflect any changes on the Inverter/ Motor. Please help.
The connections on the RS485 can be found in the images attached below.
Please help! Thanks in advance.
  Request a free sample
Posted by: marekduzi - 06-22-2023, 05:41 AM - Forum: Apply for free sample product - No Replies
Dobrý den,
chtěl bych získat zkušební bezplatný vzorek ovladače KC868-A4. Pracuji jako elektrikář v automobilovém průmyslu nákladních automobilů, kde jsme také prodejci značek TATRA Trucks CZECH a dále speciální nástavby na přání, kde jsme museli požádat o jinou firmu o vývoj hardwaru a pro daný typ zákazníka. Díky Vašemu ovladači bychom tyto věci zvládli sami a určitě bychom dokázali další udělat na nákup více kusů a vašich zařízení. Velmi bych ocenil vzorek zdarma.Heart
