» Members: 10,098
» Latest member: oCBot
» Forum threads: 4,255
» Forum posts: 21,081
There are currently 83 online users.
» 0 Member(s) | 72 Guest(s)
Amazonbot, Baidu, Bing, Crawl, Google, PetalBot, bot
N20 Energy RS485 Modbus P...
Forum: N20
8 hours ago
Getting inconsistent/wron...
8 hours ago
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
  code not working
Posted by: soccer - 05-08-2023, 08:53 PM - Forum: KC868-A16 - Replies (3)
Could someone tell what is wrong in the code? it's not working with a hmi delta dop-107EV, I don't know what could be an error in the code.
#include <WiFi.h>
#include <ETH.h>
#include <ModbusIP_ESP8266.h>
#include <SPI.h>
#include <Ethernet.h>
#include <PCF8574.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
const int port = 502;
TwoWire I2Cone = TwoWire(0);
//TwoWire I2Ctwo = TwoWire(1);
// Set i2c address
PCF8574 pcf8574_I1(&I2Cone, 0x21, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x22, 4, 5);
PCF8574 pcf8574_R1(&I2Cone, 0x24, 4, 5);
PCF8574 pcf8574_R2(&I2Cone, 0x25, 4, 5);
const int LED_COIL = 100;
const int ledPin = pcf8574_R1.pinMode (P1); //GPIO0
const int TEST_HREG = 100;
IPAddress staticIP(192, 168, 0, 40);
IPAddress gateway(192, 168, 0, 1);
IPAddress dns(192, 168, 0, 1);
ModbusIP mb;
ETH mb;
  ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE);
  if (WiFi.config(staticIP, gateway, subnet, dns, dns) == false) {
    Serial.println("Configuration failed.");
pcf8574_R1.pinMode(P0, OUTPUT);
pcf8574_R1.pinMode(P1, OUTPUT);
pcf8574_R1.pinMode(P2, OUTPUT);
pcf8574_I1.pinMode(P0, INPUT);
pcf8574_I1.pinMode(P1, INPUT);
pcf8574_I1.pinMode(P2, INPUT);
modbus.server(port);
  mb.addCoil(LED_COIL);
      mb.task();
  //Attach ledPin to LED_COIL register
  digitalWrite(ledPin, mb.Coil(LED_COIL));
  delay(10);
  access control panel by wiegand protocol configure yaml for ESPhome
Posted by: admin - 05-08-2023, 03:31 AM - Forum: KC868-A32/A32 Pro - Replies (15)
here is demo config file for access control panel. control relay2 or relay3 by different finger or IC card or INPUT NUMBER by touch panel.
.txt   HA_A32_finger_wiegand26_tag.txt (Size: 12.93 KB / Downloads: 1732)
  KC868-AP ESPHome demo config switch panel control LED for home assistant by ethernet
Posted by: admin - 05-08-2023, 01:19 AM - Forum: KC868-AP / ADR - Replies (4)
this is config file for digital input1 with button control KC868-AP output1:
1: click button for ON/OFF LED,
2: hold on button for change led brightness.
[Image: attachment.php?aid=2392]
[Image: attachment.php?aid=2393] esphome:
  encryption:
    key: "hx8eSqbwjWs9/2bK0qK55QfTIOpI4gCfzLOeaOXZMaU="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 16
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8    maybe 0x22  /  0x3A
    address: 0x21
    on_click:
      then:
        - if:
            condition:
              light.is_off: light_1
            then:
              light.turn_on:
                brightness: 1.0
            else:
              light.turn_off: light_1
    on_press:
      then:
      - if:
          condition:
          then:
          - delay: 0.5s
          - while:
              condition:
                binary_sensor.is_on: light_1_touch
              then:
                - light.dim_relative:
                    relative_brightness: 5%
                    transition_length: 0.1s
                - delay: 0.1s
          else:
          - delay: 0.5s
          - while:
              condition:
                and:
                  - binary_sensor.is_on: light_1_touch
                  - light.is_on: light_1
              then:
                    relative_brightness: -5%
                - delay: 0.1s
      pcf8574: pcf8574_hub_in_2
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
  Momentry Switches A4S
Posted by: mark2023 - 05-07-2023, 07:47 PM - Forum: DIY Project - Replies (5)
I have a A4S Controller and a 2 button glass momentry switch and a 6 button momentry switch. Can someone share a wiring diagram for both these switches onto the A4S.
I connected the glass switch but the input was permantly on in HA and pessing the switch made no difference. If i could have a wiring digram for all terminals on the switches as a example that would be great.
  Free sample request
Posted by: skajer - 05-07-2023, 12:44 PM - Forum: Apply for free sample product - No Replies
I am interested in learning about KinCony's products and would like to apply for a free sample. As someone who is passionate about technology, I believe that KinCony's products have the potential to enhance my understanding of smart control systems and related fields.
I would like to apply under condition A, as I plan to use the KC868-A4 or KC101 kit for my personal learning and development. I am excited to explore the capabilities of these products and to gain hands-on experience with them.
Best regards,
skajer
Question ESPHome DAC output DC 0-10V
Posted by: Loki - 05-06-2023, 11:39 PM - Forum: KC868-A4S - Replies (9)
I don't understand how to correctly integrate the AO 01-08 (0-10V) as DAC output in the ESPHome yaml.
Could you please show me an example programme?
Many thanks in advance
  [Arduino source code for KC868-A32M]-07_PCF8574_DO
Posted by: KinCony Support - 05-06-2023, 01:16 AM - Forum: KC868-A32M - No Replies
/*kc868-a32m pcf8575 out*/
#include "Arduino.h"
#include "PCF8574.h"
#define a 100
// Set i2c address
PCF8574 pcf8574_R1(0x23,4,5);
PCF8574 pcf8574_R2(0x24,4,5);
PCF8574 pcf8574_R3(0x25,4,5);
PCF8574 pcf8574_R4(0x26,4,5);
    Wire.begin();
for(int i=0;i<=7;i++){
  pcf8574_R1.pinMode(i,OUTPUT);
  pcf8574_R2.pinMode(i,OUTPUT);
  pcf8574_R3.pinMode(i,OUTPUT);
  pcf8574_R4.pinMode(i,OUTPUT);
    pcf8574_R1.begin();
    pcf8574_R2.begin();
    pcf8574_R3.begin();
    pcf8574_R4.begin();
    for(int j=0;j<=31;j++){
     if(j<=7){
              pcf8574_R1.digitalWrite(j,LOW);
              delay(a);
     if(7<j<=15){
              pcf8574_R2.digitalWrite(j-8,LOW);
              delay(a);
     if(15<j<=23){
              pcf8574_R3.digitalWrite(j-16,LOW);
              delay(a);
     if(23<j<=31){
              pcf8574_R4.digitalWrite(j-24,LOW);
              delay(a);
     if(j<=7){
              pcf8574_R1.digitalWrite(j,HIGH);
              delay(a);
     if(7<j<=15){
              pcf8574_R2.digitalWrite(j-8,HIGH);
              delay(a);
     if(15<j<=23){
              pcf8574_R3.digitalWrite(j-16,HIGH);
              delay(a);
     if(23<j<=31){
              pcf8574_R4.digitalWrite(j-24,HIGH);
              delay(a);
.zip   KC868-A32M-PCF8574_DO.zip (Size: 779 bytes / Downloads: 806)
  [Arduino source code for KC868-A32M]-06_ADC
Posted by: KinCony Support - 05-06-2023, 01:14 AM - Forum: KC868-A32M - No Replies
/*KC868-A32M- ADC*/
#define ANALOG_A1   34
#define ANALOG_A2   35
#define ANALOG_A3   39
#define ANALOG_A4   36
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  if(analogRead(ANALOG_A1)!=0){
   if(analogRead(ANALOG_A2)!=0){
   if(analogRead(ANALOG_A3)!=0){
    Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));
   if(analogRead(ANALOG_A4)!=0){
    Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));
   delay(100);
.zip   KC868-A32M-ADC.zip (Size: 650 bytes / Downloads: 761)
  [Arduino source code for KC868-A32M]-05_433_RECEIVE
Posted by: KinCony Support - 05-06-2023, 01:13 AM - Forum: KC868-A32M - No Replies
#include <RCSwitch.h>
  mySwitch.enableReceive(digitalPinToInterrupt(14));  //IO19
  Serial.print("begin test");
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print(" / ");
    Serial.print("bit ");
    Serial.print("Protocol: ");
    mySwitch.resetAvailable();
.zip   KC868-A32M-433_RECEIVE.zip (Size: 641 bytes / Downloads: 805)
  [Arduino source code for KC868-A32M]-04_RS485
/*KC868-A32M RS485*/
#define A8M_RS485_RX 15
#define A8M_RS485_TX 13
  Serial2.begin(115200,SERIAL_8N1,A8M_RS485_RX,A8M_RS485_TX);//A8M
  Serial2.println("A32M RS485 SEND is OK!!");
  while(Serial2.available()>0)
    Serial2.print((char)Serial2.read());
  delay(200);
.zip   KC868-A32M_RS485.zip (Size: 569 bytes / Downloads: 805)
