» Members: 9,884
» Latest member: gg88bbiz
» Forum threads: 4,230
» Forum posts: 20,975
There are currently 327 online users.
» 1 Member(s) | 306 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Sogou web, bot, lollo9710
"KCS" v3.27.2 firmware BI...
2 hours ago
N10 - ESPHome - ARM CPU s...
Forum: N10
5 hours ago
extend KC868-A16v3
5 hours ago
"KCS" v2.2.21 firmware BI...
Yesterday, 12:13 PM
KC868-A16 Outputs Y01-Y16...
09-09-2026, 11:15 PM
wish
Forum: KC868-A16v3
09-09-2026, 01:14 PM
Last Post: viko
09-09-2026, 11:39 AM
» Replies: 22
B32M maximum voltage
Last Post: velifetime
09-08-2026, 07:01 AM
KNX ETS software project ...
09-08-2026, 03:44 AM
"KCS" v3.27.1 firmware BI...
09-08-2026, 03:24 AM
  Pir sensor wiring for nodemcu esp32
Posted by: primeroz - 04-23-2023, 11:42 AM - Forum: DIY Project - Replies (9)
I have a kincony pir sensor but still waiting to receive the A4 board so in the meantime I was thinking to wire it to a nodemcu esp32.
Looking at the wiring diagram https://www.kincony.com/how-to-use-pir-sensor.html
How should I wire the signal and COM to a nodemcu ?
Is the signal just a 3.3v so I can just connect it to any gpio ?
What about the COM ?
  K868-A32 Domoticz
Posted by: lori72 - 04-22-2023, 11:32 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hi, I wanted to use this product with Domoticz and I saw that there is a plugin for Kinkony products: K868-A32 and supported by the Plugin for Domoticz? Thank you
  Life expectancy
Posted by: Philadam - 04-21-2023, 10:03 PM - Forum: KC868-A64 - Replies (3)
I have a 44 year old DIY low voltage lighting system based on TTL circuits that is still going strong. I want to update this system to include smart monitoring.
I have 2 questions.
1) What is the life expectancy of the kc868-a64?
2) What is the duration of your products before they go out if production?
  Product support
Posted by: Philadam - 04-20-2023, 10:18 PM - Forum: Suggestions and feedback on KinCony's products - Replies (5)
Do you support your products sold by other vendors on Aliexpress like Jijun Automatic Store?
  KC868-A128 PCB size details
Posted by: admin - 04-20-2023, 01:14 AM - Forum: KC868-A128 - No Replies
.pdf   KC868-A128_PCB_size_2.pdf (Size: 528.27 KB / Downloads: 926)
  KC868-A4 ESP32 DEFAULT FIRWARE
Posted by: ia1 - 04-19-2023, 03:23 AM - Forum: KC868-A4 - Replies (3)
Hi
Can  I know from where i can download default firmware for kc868-a4
thanks
Imran Alam
  KC868-A8M ESP32 8 Channel CAN Bus Board Released
Posted by: admin - 04-19-2023, 12:52 AM - Forum: News - No Replies
We have designed KC868-A8M (ESP32 CAN Bus Board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 8CH MOSFET output + 8CH digital input + 4CH analog input, support CAN Bus + RS485 + Ethernet + WiFi + Bluetooth + 4G SIM7600 or 2G SIM800L GSM module + DS3231 RTC module + manual control button panel.
[Image: KC868-A8M-1_01.jpg]
[Image: KC868-A8M-1_02.jpg]
[Image: KC868-A8M-1_03.jpg]
[Image: KC868-A8M-1_04.jpg]
[Image: KC868-A8M-1_05.jpg]
  Lora Range SX1278
Posted by: bsarevalo - 04-18-2023, 04:59 AM - Forum: KC868-A6 - Replies (8)
Hello everyone ! especially to Hificat... I am developing a project where we are using Lora SX1278 in the KC868-A6 module, according to the characteristics of the Lora the device has a range of 1 km - 5 km, the code used by the sender is the following :
#include "Arduino.h"
#include "PCF8574.h"
#include <RTClib.h>
#include <Wire.h>
#include <LoRa.h>
#include <SPI.h>
#include <WiFi.h>
#define ss 5
#define rst 21
#define dio0 2
  WiFi.mode(WIFI_STA);
  while (!Serial);
  Serial.println("LoRa Sender");
  LoRa.setPins(ss, rst, dio0);    //setup LoRa transceiver module
  while (!LoRa.begin(433E6))     //433E6 - Asia, 866E6 - Europe, 915E6 - North America
    Serial.println(".");
    delay(500);
  LoRa.setSyncWord(0xA5);
  Serial.println("LoRa Initializing OK!");
  Dwin_hmi.begin(115200);
  pcf8574.pinMode(P0, OUTPUT);
  pcf8574.pinMode(P1, OUTPUT);
  pcf8574.pinMode(P2, OUTPUT);
  pcf8574.pinMode(P3, OUTPUT);
  pcf8574.pinMode(P4, OUTPUT);
  pcf8574.pinMode(P5, OUTPUT);
  if (pcf8574.begin()){
    Serial.println("OK");
  }else{
    Serial.println("NO");
  pcf8574.digitalWrite(P0, HIGH);
  pcf8574.digitalWrite(P1, HIGH);
  pcf8574.digitalWrite(P2, HIGH);
  pcf8574.digitalWrite(P3, HIGH);
  pcf8574.digitalWrite(P4, HIGH);
  pcf8574.digitalWrite(P5, HIGH);
  LoRa.beginPacket();   //Send LoRa packet to receiver
  LoRa.print("LP01");
  LoRa.endPacket();
  Serial.println("Sending packet LP0: 1 ");
And the code for the receiver is the following
#include <RTClib.h>
#include <Wire.h>
#include <LoRa.h>
#include <SPI.h>
#include <MCP23017.h>
#define ss 5
#define rst 14
#define dio0 21
  Serial1.begin(9600,SERIAL_8N1,13,12);
  while (!Serial);
  Serial.println("LoRa Receiver");
    delay(500);
  //Serial1.write(0x01);
  //delay(20);
  //Serial1.flush();
  //delay(15);
  int packetSize = LoRa.parsePacket();    // try to parse packet
  if (packetSize)
    Serial.print("Received packet '");
    while (LoRa.available())              // read packet
      String LoRaData = LoRa.readString();
      Serial.print(LoRaData);
      if (LoRaData == "LP01") {
      if (LoRaData == "LP00") {
        pcf8574.digitalWrite(P0, LOW);
    Serial.print("' with RSSI ");         // print RSSI of packet
    Serial.println(LoRa.packetRssi());
I have soldered the antenna on the correct pin and have done some tests, the communication works fine up to 3 meters, but when I move the modules further than 3 meters the communication fails ... maybe you could help me a little, we require a range of more than 200 meters... can you help me and tell me if I'm making a mistake in programming or installing the hardware? Or if I need to buy another Lora module maybe...?
  SmartHome App: Support for Multiple Users?
Posted by: j_griffin100@yahoo.com - 04-18-2023, 02:22 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
Can the SmartHome app be used by multiple users to control the same controller (H868-16B), each user having their own login and password?
  KC868-A16S ESP32 16 Channel Relay Board Released
Posted by: admin - 04-17-2023, 11:11 AM - Forum: News - Replies (13)
We have designed KC868-A16S (ESP32 16 channel relay board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH relay (MAX AC250V 10A) output + 16CH digital input + 4CH analog input, support RS485 + Ethernet + WiFi + Bluetooth + 4G SIM7600 or 2G SIM800L GSM module + DS3231 RTC module + manual control button panel.
[Image: KC868-A16S-1_01.jpg]
[Image: KC868-A16S-1_02.jpg]
[Image: KC868-A16S-1_03.jpg]
[Image: KC868-A16S-1_04.jpg]
