» Members: 9,510
» Latest member: andromac
» Forum threads: 4,182
» Forum posts: 20,776
There are currently 49 online users.
» 0 Member(s) | 29 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Python-urllib, bot
KC868-A32 Malfunction Aft...
Forum: KC868-A32/A32 Pro
Last Post: sson6203
6 hours ago
KinCony F8 + ESPHome: Una...
Forum: F8
8 hours ago
F8 ESPHome yaml for home ...
Forum: F8
8 hours ago
Schema A16V3 for Research...
Forum: KC868-A16v3
Last Post: hamzachaouri
8 hours ago
B8 ADS1115 current inputs
Forum: B8
07-29-2026, 09:47 PM
KINCONY IN KSA
07-29-2026, 10:43 AM
» Replies: 14
A32 Pro ESPHome yaml for ...
07-27-2026, 06:25 AM
E8v3 E16v3 E24v3 relay mo...
Forum: Extender module
07-27-2026, 01:00 AM
KC868-H32B V5.08 firmware
Forum: News
07-25-2026, 11:53 PM
» Replies: 23
Forum: B2
07-25-2026, 06:40 AM
Wink KC868-A16 PWM LED
Posted by: Danp - 05-18-2023, 01:32 PM - Forum: KC868-A16 - Replies (5)
Is there a way to use the KC868-A16 Board to directly control an LED using PWM or are all mosfets only controllable using the PCF8574 I/O Expander?
Thank you!
  Connectors
Posted by: Vulcan - 05-18-2023, 01:55 AM - Forum: KC868-A6 - Replies (3)
I order a number of I2C connectors intending to use them on the 868-A6 board but none of them are the correct size. Can anyone provide the specifications for the female connectors or refer me to a site/s that has the specific connectors, please? I would appreciate a specific part or part number.
  Crystal interference DS1307
Posted by: bsarevalo - 05-18-2023, 12:57 AM - Forum: KC868-A6 - Replies (3)
Hello everyone ! especially Hifikat!  We recently connected a long-range antenna to the LoRa - SX1278 module, this cable passed near the RTC module of the KC868-A6 module, on occasions when we put the backup battery in the RTC Socket, our finger when making contact with the battery and being near the crystal, we have noticed that the RTC readings are beginning to fail, so we thought about placing a metal casing to protect this part of the circuit, we also thought about grounding the negative of the module to ground, is it okay to do this? What other recommendations could you give us for this situation? In advance thank you very much for your attention !
  KC868-E16S - Multiple
Posted by: keithc - 05-17-2023, 02:13 PM - Forum: KC868-E16S/E16P - Replies (7)
Dear Community,
I would like to confirm something please.
Do I need an additional Kincony / ESP enabled server if I have 10 x K868 E16S on the same via ESP Home / Home Assistant local network?
6 x K868 E16S in ground floor DB and 4 x K868 E16S in 2nd floor DB using local LAN to each device.
No wifi switches or devices, all hard wired.
Note: replacement for circa 2007 VIPA 200 PLC system in a large residential home.
I may also need a separate AI and DO 24v on each floor.
Regards,
Keith Smile
  KC868-H32B V5.04 firmware support Tuya app
Posted by: admin - 05-17-2023, 01:19 AM - Forum: News - No Replies
improvement:
[Image: attachment.php?aid=2412]
1. support use Tuya app for remote control OUTPUT and monitor INPUT state.
2. support TCP Server, TCP Client, UDP, MQTT, Tuya different protocol at the same time by ethernet.
such as you can use Home assistant (by mqtt) in local LAN network and Tuya app for remote monitor by internet.
3. add "MQTT send all" option. if "enabled" , MQTT state message will feedback all channel's information. if "disabled" , MQTT state message will feedback single channel's information.
4. support control by KC868-AK keyboard.
firmware download:
.zip   H32B_V504_230516.zip (Size: 134.3 KB / Downloads: 814)
how to order tuya licence:
here is Tuya licence for "H32BS,H32B,COLB" firmware , it can let your board remote control by internet.
1:telll us your email, we will send the licence to your email
2:tell us your area(choose from :China/Westen US/Eastern US/Central Europe/Western Europe/India)
IMPORTANT: check for your tuya account, which REGION you have registered.
Check in your tuya or smart life mobile phone app: Me -- Settings -- Account and Security -- Region
according to the "Region" visit here (https://developer.tuya.com/en/docs/iot/o...i0ku9l07qb) to check your server location.
[Image: attachment.php?aid=1928]    [Image: attachment.php?aid=1929]    [Image: attachment.php?aid=1930]
if you really don't know how to check, just send us your tuya or smart life app account name, we will check for you.
3:tell us you model(choose from Kincony A4/A6/A8/A8S/A16/A32/A64/A128/E16S/AI/AK/H32BS/H32B/COLB)
4: The license has no time limit, and the tuya platform provides corresponding services and guarantees
5:Once sold, it cannot be returned or refund
6:One licence only for one product
Tuya internet cloud server locate in 6 positon in the world:
Location-A: China
Location-B: Western US
Location-C: Eastern US
Location-D: Central Europe
Location-E: Western Europe
Location-F: India
please tell us which server location your app account used. such as if your account is "Western Europe" ,tell us "Location-E: Western Europe".
if you want to order, please contact with us, you can pay by PayPal or Bank account.
  A4S DIMMER
Posted by: mark2023 - 05-16-2023, 10:35 PM - Forum: KC868-HxB series Smart Controller - Replies (17)
I have connected up a dimmable led light bulb with a solid state relay from analogue 1 on the A4Sbut i seem to be getting the following problems.
1: when the relays are off from the color LED-1 in Home assistant the bulb is still on but very dim. when i switch it on it goes full brightness but when i switch off the bulb does not go out it goes back to very dim.
2: i set up a automation to use a momentry input switch to increase brightness and another input to dicrease brightness, again the bulb is still on when off but now i have to keep pressing the button several times to increase brightness instead of just holding the button. I also notice that the bulb starts to flicker at certain increases. can you explain whats going wrong please.
3: i have attached the photos to make sure it is all wired correctly.
  Template for KC868-A4 Tasmota
Posted by: VascoTeixeira - 05-16-2023, 06:41 PM - Forum: KC868-A4 - Replies (9)
I am using this template {"NAME":"KC868-A4","GPIO":[32,0,227,0,224,225,0,0,0,1312,1,226,0,0,480,1152,0,1120,1056,1088,0,1,1,1,0,0,0,0,4706,4707,4704,4705],"FLAG":0,"BASE":1} ("https://blakadder.com/kincony-KC868-A4/").
 I am using everything except the 4 analogs; instead, I would like to use the digital inputs to connect 4 float switches ("https://www.amazon.es/-/pt/dp/B089VTDG7P/ref=asc_df_B089VTDG7P/?tag=ptgogshpadde-21&linkCode=df0&hvadid=634424762838&hvpos=&hvnetw=g&hvrand=12299730209074816985&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=20876&hvtargid=pla-943952460943&th=1").
Could you please assist me with the template?
Thx Vasco Teixeira
  Application for free sample product
Posted by: ADEDAYO - 05-16-2023, 05:01 PM - Forum: Apply for free sample product - No Replies
Application condition A: free education.
Greetings,
As a project implementation engineer for Basscomm Nigeria Limited (with our head office in Lagos, Nigeria), I have experience in building automation using the SmartG4 system. I recently finished a project that automated the lighting and power of a building with great results.
I am interested in exploring other systems that use non-proprietary devices that can be controlled by a single controller. I want to set up a sample project at our office to demonstrate the product to our sales team and attract potential clients for building automation.
I hope to receive this product soon, install it successfully, and generate more business through this initiative.
Sincerely, Adedayo
Lightbulb Free sample KC868-A4
Posted by: SmartGuard - 05-16-2023, 11:05 AM - Forum: Apply for free sample product - No Replies
Hello, I'm an electrician and system integrator based in Italy, one of my business is home automation, I already install different devices for wireless and wired automation systems, but I'm interested in trying and learning to use your product, because for what I have understood, if I can program it and use the right integrations I can create whatever solution I want. We as a company want to create an our complete solution for home automation, if I learn and like your product we can surely create a cooperation and buy more of your products in the future.
Waiting for a response, regards.
  how to set firmware kc868-h32b
Posted by: jaydenaidan - 05-16-2023, 10:42 AM - Forum: KC868-HxB series Smart Controller - Replies (6)
[font=Söhne, ui-sans-serif, system-ui, -apple-system, 'Segoe UI', Roboto, Ubuntu, Cantarell, 'Noto Sans', sans-serif, 'Helvetica Neue', Arial, 'Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbol', 'Noto Color Emoji']If you are looking to set the firmware for the KC868-H32B device, as a professional proofreader in Canada I love to share something. here's a general guide to get you started. Begin by downloading the latest firmware from the manufacturer's website. Connect the KC868-H32B to your computer using a USB cable, ensuring a stable connection. Put the device into firmware update mode as per the provided instructions. Install the firmware update tool on your computer and open it. Select the downloaded firmware file within the tool and start the update process. Be patient and let the tool complete the update without any interruptions. Once finished, you'll be all set with the updated firmware for your KC868-H32B device. For detailed and device-specific instructions, consult the user manual or reach out to the manufacturer's support channels.
[/font]
