» Members: 10,074
» Latest member: ReelsOn
» Forum threads: 4,254
» Forum posts: 21,076
There are currently 396 online users.
» 0 Member(s) | 382 Guest(s)
Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
KC868-A6 Analog inputs
Last Post: Tomas4289
5 hours ago
N60/N30/N20/N10 PC softwa...
Forum: N10
5 hours ago
» Replies: 13
getting the A8A inputs to...
Forum: Development
9 hours ago
Best way to read from N30
Forum: N30
Yesterday, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
  DM8 ESPHome yaml for home assistant without tuya
Posted by: admin - 03-17-2026, 12:49 AM - Forum: DM8 - No Replies
  friendly_name: dm8
  board: esp32-s3-devkitc-1
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
  - id: uart_1 # RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: dac_uart
    rx_pin: 4
    tx_pin: 6
    baud_rate: 115200
    stop_bits: 1
    data_bits: 8
    parity: NONE
    debug:
modbus:
  uart_id: dac_uart
modbus_controller:
  - address: 1
    update_interval: 5s
  - id: bus_a
    sda: 8
    scl: 18
    frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
output:
  # CH1 (0x0FA0 / 4000)
  - platform: modbus_controller
    address: 0x0FA0
    value_type: U_WORD
    write_lambda: |-
      // state = 0.0 ~ 1.0 → 0 ~ 4095
      uint16_t reg = (uint16_t) round(x * 4095.0);
      return reg;
  # CH2 (0x0FA1 / 4001)
    address: 0x0FA1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH3
    address: 0x0FA2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH4
    address: 0x0FA3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH5
    address: 0x0FA4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH6
    address: 0x0FA5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH7
    address: 0x0FA6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH8 (0x0FA7 / 4007)
    address: 0x0FA7
    value_type: U_WORD
    write_lambda: |-
      return reg;
# 8 路 Light (调光灯)
light:
  - platform: monochromatic
    output: dac_ch1_out
    default_transition_length: 0s
    output: dac_ch2_out
    output: dac_ch3_out
    output: dac_ch4_out
    output: dac_ch5_out
    output: dac_ch6_out
    output: dac_ch7_out
    output: dac_ch8_out
  - id: pcf8574_hub_1 # for input channel 1-8
    i2c_id: bus_a
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_1
  ## pull-up resistance on PCB
      number: 47
      number: 48
      number: 17
      number: 40
  ## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted: false
      number: 21
      inverted: false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
esphome yaml file download:
.txt   esphome_dm8.txt (Size: 6.63 KB / Downloads: 275)
  How restart а board using IFTTT and Custom Protocol?
Posted by: apps4check - 03-16-2026, 07:59 PM - Forum: "KCS" v2 firmware system - Replies (1)
Hello, is it possible to restart the board (KC868-A2 or KC868-A4S, KCS v2 firmware) using IFTTT and Custom Protocol?
Any advice would be greatly appreciated.
  Battery backup model on AOI
Posted by: H_spadacini - 03-16-2026, 09:42 AM - Forum: AIO Hybrid - Replies (1)
Francais :
Serait-il possible de connaitre la référence de la pile bouton qui doit va dans le rtc battery socket  qui peut-être mis sur le AIO pour maintenir sa sauvegarde.
Cordialement.
English :
 Could you please provide the part number for the button cell battery that fits into the RTC battery socket, which can be installed on the AIO to maintain its backup?
Regards.
  KinCony DM8 8CH ESP32 Dimmer Board released
Posted by: admin - 03-16-2026, 08:16 AM - Forum: News - No Replies
KinCony DM8 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. DM8 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. DM8 have 2pcs of RS485 port. one RS485 connect with ARM CPU, support use by modbus directly. Another RS485 work with ESP32. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. DM8 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: DM8-1.jpg]
Model No. KinCony DM8
Description: KinCony 8 Channel ESP32-S3 Smart Dimmer Controller – DM8
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
OLED: SSD1306 I2C display
Outputs:
8CH 0-10v Outputs.
Inputs:
4 buttons: 1:ESP32 Reset 2:ESP32 Download 3:Tuya config 4: ARM CPU Reset
[Image: DM8-1.jpg]
  Monitor 1 shows power=0 while Monitor 2 shows correct values
Posted by: tombueng - 03-15-2026, 03:48 PM - Forum: N20 - Replies (1)
My Monitor 1 shows Power=0 for all channels even if there is current which is wrong.
Monitor 2 shows values correctly.
Voltage  / Freq  226V, 50Hz is shown on both inputs (both connect to the same phase)
Protocol -> Energy has the same values for Energy 1 and 2 for all of the values of Current Factor=0.5, Power Factor=1, Energy Factor=1
Firmware  v3.22.0
What might be the Problem?
Is there no OTA-Update available?  Do I need to connect a via USB PC to Update the Firmware?
  KinCony DM32 32CH ESP32 Dimmer Board released
Posted by: admin - 03-15-2026, 10:31 AM - Forum: News - No Replies
KinCony DM32 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. DM32 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. DM32 have 2pcs of RS485 port. one RS485 connect with ARM CPU, support use by modbus directly. Another RS485 work with ESP32. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. DM32 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: DM32-1.jpg]
Model No. KinCony DM32
Description: KinCony 32 Channel ESP32-S3 Smart Dimmer Controller – DM32
Size:
SD Card: SPI bus
Outputs:
32CH 0-10v Outputs.
Inputs:
[Image: DM32-2.jpg]
  KinCony DM4 4CH ESP32 Dimmer Board released
Posted by: admin - 03-15-2026, 04:21 AM - Forum: News - No Replies
KinCony DM4 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. DM4 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. DM4 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: DM4-1.jpg]
Model No. KinCony DM4
Description: KinCony 4 Channel ESP32-S3 Smart Dimmer Controller – DM4
SD Card: SPI bus
Outputs:
4CH 0-10v Outputs.
Inputs:
4CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
[Image: DM4-2.jpg]
  F8 on device physical switches in ESPHome
Posted by: Vinceken - 03-14-2026, 08:07 PM - Forum: F8 - Replies (1)
Hi - with esp-idf in ESPHome, how can I access the state of the physical on device switches?
I can't seem to observe those on any GPIO pins.
I would like to configure (in esphome) some of them to control their output relay directly, but for others for them to act as momentary switches. I can manage all the coding myself if I can work out where to observe their state...
Thanks.
  Adding a debounce capability to inputs
Posted by: twostar - 03-14-2026, 02:09 PM - Forum: KC868-A16v3 - Replies (6)
At the moment the KC868 inputs are instantaneous which is a problem for signals that glitch occasionally from things like noise coupled onto the input lines.  Would it be possible to add a debounce capability where you can specify that an input has to be asserted for x seconds, x user-settable, before it gets reported as an asserted input?  What I'm thinking of is adding a per-input capability where you can specify that it needs to be asserted for (say) 5 seconds before it's treated as valid.  The overall range would be maybe 0-60s, 0s = instant response, > 0s = input must be asserted for that long before it's reported as asserted.
  KC868-a8v3 IFTTT for Aircon use
Posted by: beegeenz - 03-12-2026, 10:59 AM - Forum: KC868-A2v3 - Replies (1)
I have KC868-a8v3.1 board loaded with the current firmware V3.23.2
It is used for switching 24VAC to control AC ducts in conjunction with Home Assistant.
My challenge is that the Rumpus room duct (controlled by DO8 on KC868) is fed from a master upstairs duct (controller by DO2 on KC868) so both ducts need to be open for AC to reach the Rumpus room.
For ease of user operation I would like to setup the a IFTTT rule so that;
1. when a user turns on the Rumpus duct (D08) the upstairs duct will also activate (D02) (turn on could by by HA or RF on the KC868)
2. if the user subsequently turns off the Rumpus duct, the Upstairs duct will remain open.
Also, if the Upstairs duct is turned off, there should be a rule to turn on the Rumpus room duct, this is necessary to reflect through to the HA dashboard.
Using IFTTT I setup an IF condition on the DO8 which performs an action on D02.
I found that this doesn't work properly and the KC web page status indicator for D02 and D08 are not linked corectly by the rule.  At one stage the KC868 crashed and I had to relead the formward with the formward loader tool.
Can you please advise if IFTTT can be used for this sort of rules or is there another way on the KC868 to achieve this.
Regards
