» Members: 9,074
» Latest member: lostthcc
» Forum threads: 3,988
» Forum posts: 20,242
There are currently 50 online users.
» 0 Member(s) | 38 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Crawl, DataForSeoBot, bot
Cant flash esphom
Forum: B16M
Last Post: H_spadacini
13 minutes ago
» Replies: 4
CRC Errors with ESP Home ...
Forum: N60
5 hours ago
KC868-A8 ethernet work wi...
Forum: KC868-A8
Today, 12:23 AM
» Replies: 9
RS485
Today, 12:21 AM
» Replies: 4
N30 no Energy (kWh)
05-19-2026, 10:21 PM
» Replies: 13
Questions about KinCony F...
Forum: F16
05-19-2026, 12:12 PM
"KCS" v3.25.0 firmware BI...
05-19-2026, 12:03 PM
Energy calculation for ne...
Forum: N30
Last Post: GWS
05-19-2026, 06:23 AM
» Replies: 4
Las Firmware ?
05-19-2026, 12:07 AM
AIO Hybrid ESP32-S3 IO pi...
Forum: AIO Hybrid
05-19-2026, 12:06 AM
  Problem with A16 inputs 9-16
Posted by: jarekD - 11-23-2025, 07:25 PM - Forum: KC868-A16 - Replies (7)
On my A16, inputs 9-16 show all on, while nothing is physically connected.
I tested with a multimeter and there is +12V between GND and any input pin. It's the same on Inputs 1-8 btw, but they work just fine.
My device is connected to Home Assistant as ESPHome, below is the programmed YAML's relevant parts. I compared this with the recommended settings and it looks pretty much the same. Any clue what is wrong, or am I missing something in the config?
  sda: 4
  scl: 5
    pcf8575: false
    address: 0x25
    pcf8575: false
    pcf8575: false
    address: 0x21
    pcf8575: false
#skipped inputs 1-8, they work fine
      pcf8574: pcf8574_hub_in_2
# and so on for 11-16...
  TA details about RTC and RF
Posted by: 5310h - 11-23-2025, 03:40 PM - Forum: TA - Replies (1)
Hi. I am working on code for TA and have the following questions:
What RTC is used?
What is the RF Receiver type?
  KC-868-A1 linked Home Assistant
Posted by: Powerdata44 - 11-21-2025, 10:56 PM - Forum: News - Replies (3)
Try to linked up with my home assistant. I am getting these error from ESPHOME see photo:
why?
I get responded from kincony that - esphome new version have new syntax.
So what do i do to solve these problems?  What do I have to do, advise please.
[Image: A2c3321349c4c49909eccbc72379d5ea2d.jpg]
.txt   KC868-ai for Home Assistant.txt (Size: 7.9 KB / Downloads: 169)
Information Schematic
Posted by: thawad - 11-21-2025, 05:03 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (1)
hi dear, can send me the schematic of the
KinCony F32 or F24 or F16 or F8.
and
KinCony B24M or B16M.
and
KinCony AIO Hybrid.
I want to study some circuit on it and how you make because I'm developing my board and your schematic are helpfully. Help me as much as you can.
thiabatawad09@gmail.com
  N60 ESP Home Dallas sensor
Posted by: tapsakoo - 11-21-2025, 03:01 PM - Forum: N60 - Replies (7)
Hello All,
I have a n60  which I´m ore than happy as metering devise, but I´d like to add a Dallas sensor to it.
With Kinconys own programm it´s easy, but I´m using ESP Home and I just can´t figure out the right way to write it to YAML.
Could someone help me out?
DS18B2
Photo a16v3 - reed switch and motion sensor connection
Posted by: bartasp - 11-20-2025, 07:53 PM - Forum: KC868-A16v3 - Replies (17)
I have problem to connect reed switch (for doors and windows) and (motion sensor).
I trying to use a16v3 as alarm (connection with HA and Alarmo)
1. I have problem because when I connect reed switch Satel K-2 2E the Input alway ON. and when I bring the magnet closer to the read switch nothing changed.
Two cables: 1 GND , 2 DI1
A16v3 is connected to ESP Home.
.txt   sphomel.txt (Size: 8.9 KB / Downloads: 169)
Sensors configuration:
  device_class: door
    pcf8574: pcf8554_hub_in_1
    modę: INPUT
  filters:
    - deleyted_on: 100ms
    - deleyted_off: 3s
2. I have second problem with Motion Sensor Satel Graphite. Connect to 12V, GND and Input and is Enabling only when push "tamper switch" and its enabling always. but should enable only when motion sensor it detects movement.
Connection
12v in sensor to 12v in a16v3
COM in sensor to GDN
NC in sensor to Input PIR DI13
Configuration
- platform: glio
  device_class: motion
    pcf8574: pcf8554_hub_in_2
    modę: INPUT
    filters:
      - deleyted_off: 3s
In LOGS:
D binary_sensor:041 PIR DI13 New state is ON, pull down form tamper switch and state is OFF.
Photo GPIO numbers for Weigand
Posted by: surfmk - 11-20-2025, 06:33 PM - Forum: KC868-A16v3 - Replies (10)
I am finding the documentation for GPIO numbers a bit confusing.
Am I correct :
HT1 = GPIO1
HT2 = GPIO2
HT3 = GPIO3
Am I correct :
P39 = GPIO39
P40 = GPIO40
P41 = GPIO41
Finally, Can any of these pins be assigned for TX/RX for D0/D1 with Weigand Protocol?
Hopefully, this will allow me to configure my entry alarm system.
Many thanks in advance.
Paul
  Home Assistant Setup with Voice, Tablet & App Control Using KinCony ESP32 Relay Board
Posted by: Newcomer1 - 11-19-2025, 05:48 PM - Forum: DIY Project - Replies (1)
Hi everyone! This is my first post here — excited to join the community and learn from all of you. Looking forward to sharing ideas and getting your advice.
I would like to set up a system using Home Assistant, which will be controlled by voice commands, as well as via a tablet mounted on the wall and a smartphone app.
I found your device KinCony F32 ESP32-S3 16A Removable Relay Board released, and here is the question: is this device capable of handling all the listed components?
I am at the stage of cable routing in the house:
1. 3x2.5 cables for power outlets
2. 3x1.5 cables for light bulbs
3. Ethernet Cat 5 cables for switches/buttons that will control the bulbs
4. Ethernet Cat 5 cables for sensors
5. Ethernet Cat 6 cables for 6 reolink cameras
6. Ethernet Cat 5 cables for sensors/detectors
7. LED cables for lighting
8. 3x1.5 cable for garden lamps
9. 3x2.5 cable for the deep well pump
10. Underground cable 11x1 for the irrigation system
11. 3x1.5 cable for external blinds
12. 3x2.5 cable that in the future may be used for more powerful garden equipment
13. 3x2.5 cable for the sliding entrance gate and a separate cable for the garage gate.
    Additionally, a LAN network and 2 APs will be installed in the house.
The devices I want to connect to your system are:
1. Hitachi heat pump model Yutaki S8kW, for water heating and underfloor heating on the ground floor and first floor.
2. Domekt R450V LA/Z ventilation system (heat recovery).
3. 2 separate air conditioning units and an additional air conditioning unit that will support the ventilation system.
4. Cameras, NVR Frigate with CORAL AI module.
5. 11 external blinds on Yooda motors that can be connected to a micro control panel 1-channel DC 73 and wall remotes DC 315.
6. Irrigation system with 10 zones.
7. Entrance and garage gates.
8. Photovoltaic panels with an energy storage system.
9. All lighting points:
    16 zones in the house, 2 zones will have staircase switches. Additionally, some places will have LED strips installed.
10. Sensors:
- Presence/motion sensors
- Door/window opening sensors (contact sensors)
- Vibration sensors
- Smoke detectors
- Flood sensors
- CO detectors
- Temperature and humidity sensors
- Wind and rain sensors
Connection diagram:
Distribution board number 1 will contain only "power outlets," and all 3x2.5 cables are routed here. Initially, I did not consider integrating them with smart/automation solutions, but if this is possible, I will consider it. Additionally, the photovoltaic installation will also be connected here.
Distribution board number 2 will contain everything else listed.
Both distribution boards are located in different rooms.
How to connect these 2 distribution boards using your solution?
Can you recommend your sensors and everything needed to assemble this system?
All recommendations, enhancements, and any tips are highly welcome.
  Kincony KC868-A4 flashen not work
Posted by: jurgen2003 - 11-19-2025, 07:35 AM - Forum: Getting Started with ESPHome and Home Assistant - Replies (5)
Beste forum,
ik heb twee Kincony KC 868 A-serie IO-boards, één A4 die werkt met ESP Home en Home Assistant, maar de andere A4 ESP kan niet worden aangesloten. Het verbindingsboard is aangesloten via USB en blijft laden, het board schakelt relais en de zoemer om zonder resultaat. Moet dit board in de flashmodus worden gezet? Zo ja, hoe werkt dat?
groet jurgen
  How Watt Measurement Works
Posted by: margusveer - 11-18-2025, 06:52 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
I'm away from my project again for a few days, but I managed to quickly connect one cable before I left. I managed to connect one CT sensor and now I see that this channel even shows some Amp consumption on Current_1.
But same channel Power and Energy = 0 ?
Do I understand correctly that since I don't have L1 and N1 attached, it won't be able to calculate power and energy data?
And If I'm right, then since I have three-phase current (380V), I have to connect each phase separately, i.e. L1, L2 and L3
and in turn, since I have three different phases, it would be most correct to measure the devices that are behind the first phase in the first part and the devices that are behind the second phase in the second part, then the calculation will be most accurate, although at the same time the differences in phase currents are minimal, i.e. 0.0x Volts, it does not make much difference which phase is behind which sector to measure
