» Members: 9,533
» Latest member: nagpurelitemodel
» Forum threads: 4,182
» Forum posts: 20,783
There are currently 34 online users.
» 0 Member(s) | 22 Guest(s)
Baidu, Crawl, PetalBot, Semrush, bot
How to get started
Last Post: Lomagno
28 minutes ago
» Replies: 36
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
8 hours ago
KC868-A16
Last Post: 5310h
Yesterday, 09:40 PM
» Replies: 9
KC868-A16 UART pins
Last Post: meowdokugame
08-04-2026, 07:40 AM
KC868-A32 Malfunction Aft...
Forum: KC868-A32/A32 Pro
08-04-2026, 06:19 AM
KinCony F8 + ESPHome: Una...
Forum: F8
08-02-2026, 11:00 PM
F8 ESPHome yaml for home ...
Forum: F8
Schema A16V3 for Research...
Forum: KC868-A16v3
Last Post: hamzachaouri
08-02-2026, 10:34 PM
B8 ADS1115 current inputs
Forum: B8
07-29-2026, 09:47 PM
KINCONY IN KSA
07-29-2026, 10:43 AM
» Replies: 14
Photo Details about RF pins at KC868-A8-schematic
Posted by: kontas - 11-23-2022, 09:54 AM - Forum: KC868-A8 - Replies (3)
The detail about RF pins at KC868-A8-schematic is not clear.
With try and error and help of a multimeter as the pins are covered.
The pins are as in picture.
  how to use tasmota firmware with KC868-A6
Posted by: admin - 11-23-2022, 08:18 AM - Forum: KC868-A6 - Replies (22)
firmware:
.zip   tasmota_KC868-A6.zip (Size: 991.5 KB / Downloads: 1397)
  What is the size of the Button switch module
Posted by: engmohades - 11-22-2022, 09:51 AM - Forum: DIY Project - Replies (1)
What is the size of the Button switch module and the contactor 25A and 45A and 100A
and DC12V 4.5A power supply
  KC868-HA RS485 Button Adapter Released
Posted by: admin - 11-21-2022, 02:15 PM - Forum: News - Replies (66)
We have designed KC868-HA RS485 button adapter, let your old switch or traditional switch become smart, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel work with your smart home automation. This time, regular switch can be used in smart home system.
[Image: detail_05.jpg]
[Image: detail_06.jpg]
  KC868-AK ESPHome demo config for home assistant
Posted by: admin - 11-20-2022, 12:17 PM - Forum: KC868-AK - No Replies
  platform: ESP32
  sda: 4
  scl: 5
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "A4 Fallback Hotspot"
    password: "ZvKhDPUYilHj"
captive_portal:
# Example configuration entry
    address: 0x25
  - id: 'pcf8574_hub_in_3'  # for input channel 17-24
    address: 0x21
  - id: 'pcf8574_hub_in_4'  # for input channel 25-32
  - id: 'pcf8574_hub_in_5'  # for input channel 33-40
    address: 0x26
# Individual outputs
      pcf8574: pcf8574_hub_in_2
      pcf8574: pcf8574_hub_in_3
      pcf8574: pcf8574_hub_in_4
      pcf8574: pcf8574_hub_in_5
.txt   KC868-AK_ESPhome.txt (Size: 6.06 KB / Downloads: 694)
  KC868-AK ESP32 I/O pin define
Posted by: admin - 11-20-2022, 12:16 PM - Forum: KC868-AK - No Replies
IIC Bus:
SDA:GPIO4
SCL:GPIO5
PCF8574:U14 (DI1-8): 100 100 = 0x24
PCF8574:U31 (DI9-16): 100 101 = 0x25
PCF8574:U56 (DI17-24): 100 001 = 0x21
PCF8574:U57 (DI25-32): 100 010 = 0x22
PCF8574:U58 (DI33-40): 100 110 = 0x26
PCF8574:U32 (DI41-48): 100 011 = 0x23
free GPIO:
GPIO35
GPIO39
GPIO34
GPIO36
RS485:
RXD:GPIO16
TXD:GPIO14
RS232:
RXD:GPIO33
TXD:GPIO32
  KC101 Tuya Electronic DIY Kit Released
Posted by: admin - 11-16-2022, 03:13 AM - Forum: News - No Replies
We have developed the first DIY product for smart home enthusiasts to cultivate everyone’s interest in electronic technology. “KC101” is 4 channels universal WiFi wireless smart switch with RF 433MHz module, it’s a DIY kit for DIYer. it for your smart home system to remotely and automatically turn ON/OFF home appliances and electronic devices by mobile phone APP. We have opened schematic, components list and all details. Also have made the video tour step by step help you easy to DIY make it.
[Image: KC101-6_2.jpg]
[Image: apps.png]
[Image: pcb_kit.JPG]
[Image: KC101_Component-list_pix1000.jpg]
[Image: KC101_V13_pix1000.jpg]
[Image: KC101_tuya_app_1.JPEG][Image: KC101_tuya_app_2.JPEG]
  How to appear MODBUS energy meter data to Home assistant
Posted by: Dober - 11-13-2022, 01:47 AM - Forum: KC868-HxB series Smart Controller - Replies (3)
Hello!
I install kc868 meter 4py to my distribution box and i connect it to my COLB with RS485 port.
I managed to get the readings  to the smart board controller software.
How to connect it with home assistant to appear the data?
  how to use tasmota firmware for KC868-A4
Posted by: admin - 11-12-2022, 12:54 AM - Forum: KC868-A4 - No Replies
  Pin define and pcb
Posted by: XaLex2 - 11-11-2022, 06:55 PM - Forum: KC868-A6 - Replies (9)
Hi there!
 Your products are very interesting and quite comfortable in use but finding technical data about product is utterly frustrating
   Could you make it clear, what pins on mcu are corresponded to the upper side? I mean where are the temperature sensors pins on pcb? There is not the place which is the only where I can find all the data about product. I have to get through all your webite, to find any info pice by pice: picture with pinout is on home page, schematic diagramm is on absolutely different page, pins defines is on the forum. And all of this info conflicts to each other.
  where is the temp sensor inputs on the picture? Why  in the description   it's sad there are only two analog inputs, but on the picture and pcb i can see 4 ones? What are the io-1 and  io-2 on the picture of the board? Are they temp sensor input? ok, but why they have absolutely different name wich aren't somewhere else? why is all the info so inconsistent?
  And why dont't you place all the information related to product the right on the product page?
