» Members: 9,989
» Latest member: 1Go
» Forum threads: 4,249
» Forum posts: 21,040
There are currently 514 online users.
» 0 Member(s) | 500 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Crawl, Google, PetalBot, bot
config modbus sensor in K...
7 hours ago
remember relay state
Forum: KC868-E16T
Today, 01:42 AM
getting the A8A inputs to...
Forum: Development
Today, 01:41 AM
Ceiling fan control not w...
Yesterday, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Modbus 485 extender kcs V...
Forum: N30
09-17-2026, 08:10 AM
» Replies: 11
N10 with L1 and L2 suppor...
Forum: N10
09-16-2026, 11:34 PM
KC868-A16v3 PCB layout CA...
09-16-2026, 11:33 PM
Case
Forum: KC868-A16S
09-15-2026, 02:26 AM
KC868-A16S PCB layout CAD...
09-14-2026, 11:23 PM
  KC868-A4 hardwareupdate
Posted by: plc - 11-09-2022, 09:20 AM - Forum: KC868-A4 - Replies (5)
Hello admin,
thanks a lot for these really nice PCB, which allow lot of powerful projects!
I've checked the circuits of KC868-A4 (and other KC868-versions) and you are right, the direct GPIO-communication is easier to handle for Arduino-newbies than bus-connected parts.
Nevertheless I found out some optimization for KC868-A4-hardware. Maybe you can use it for an future hw-update.
  • cancel RS232 (saves lot of space + USB-C is sufficient for controlling the PCB directly)
  • change IRD/IRS & 433MT/433MR to 1x I2C-bus (2x ordinary 4-Pin-connectors, i.e. for display & other I2C-parts)
  • add a connector for an accurate working I2C-DS3231 RTC-modul
  • make the 2x 0-10V-DAC jumperable also to 2x 0-5V (to control 0-5V-devices)
  • a relay OR mosfet option would be great (or to get only 1 PCB => 2x relay + 2x mosfet)
  • ESP32 on a socket => stackable ESP32 (allows different ESP32-versions (i.e. with external antenna) and change of controller, if there is a problem). I know it's more expensive, but fast changing a small ESP32 is a superior feature. I.e. a company can send only the small ESP32-modul to consumer, if somthing went wrong.
I intend to rebuild an individual PLC, which controls a heating system (7 kW oven with water heat exchanger) with some DS18B20-sensors, 24V-pump (0-5V-speedcontrol) and safety features. Actual I have to resolder some parts of KC868-A4 to get an I2C-display and RTC, but with the mods it would be nearly a 1:1 change. Also I think it goes more flexible.
best regards
plc
  How to integrate KC868-H32B/BS/B Pro to Loxone Mini Server
Posted by: admin - 11-09-2022, 05:49 AM - Forum: KinCony integrate with Loxone home automation - No Replies
  WebUI over wifi STA mode
Posted by: xray - 11-06-2022, 06:47 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
Hi KinCony IoT,
Is it possible to reach the WebUI over Wifi in STA mode to manage the relays?
I can reach the webUI over LAN port.
Both Ethernet and Wifi are set to TCP-Server.
I was able to configure Wifi in STA mode and connect to my Wifi router. Then I disconnect the wired LAN port, but when I try to connect to the relay over the Wifi IP it doesn't give back the Relay Web UI, but the Wifi ESP32 config UI.
I would like to use HTTP commands over Wifi. Is it possible?
  ESPHome GPIO
Posted by: lautarosrur - 11-04-2022, 09:00 PM - Forum: KC868-A16 - Replies (7)
How can I reference the GPIO and analog pins in ESPHome? Can you provide some example? Thanks.
  duvida sobre erro KC 868 A6
Posted by: EMSANTANA - 11-04-2022, 12:25 AM - Forum: KC868-A6 - Replies (1)
Boa noite.
Eu tenho uma placa WIFI KC868 A6 conectado a um roteador. Mas quando a energia acaba, quando a energia volta, a internet volta mas a placa KC868 A6 trava. Para voltar ao trabalho, tenho que desligar a energia e ligar novamente.
Que solução posso usar?
  how to conect 10 circuits of LED STIP LIGHT
Posted by: engmohades - 11-02-2022, 11:56 AM - Forum: KC868-A4 - Replies (3)
hello, admin
    What are  products from Kinkony  to conect 10 circuits of LED STIP LIGHT ?
    How to connect them to be dimmable from wall switch and at the same time to be itegrated in app Home Assistant (dimmable and change multy color)?
Thank you
  ESP32 arduino library for KC868-H32B Pro Controller
Posted by: admin - 11-01-2022, 12:41 AM - Forum: News - No Replies
Made ESP32 arduino library for KC868-H32B Pro Controller, easy to write arduino code for simple logical, such as sensor trigger relay or timer locally.
[Image: arduino_h32b_pro_2.png]
[Image: arduino_h32b_pro_3.jpg]
here is details: https://www.kincony.com/how-to-use-ardui...b-pro.html
  How to use "arduino library" for KC868-H32B Pro
Posted by: admin - 11-01-2022, 12:12 AM - Forum: KC868-HxB series Smart Controller - No Replies
We have made arduino library for KC868-H32B Pro smart controller. it is open source and free for DIYer use.
1. Install ESP32 USB driver to your computer.
download from: https://www.kincony.com/download/CH341SER.zip
after installed USB driver, connect USB cable to your KC868-H32B Pro USB port.
[Image: attachment.php?aid=1504]
Then you will find COM port in windows OS "device manager"
[Image: attachment.php?aid=1499]
2. Enable "ESP32 Development Mode" by KC868-H32B Pro Ethernet setting.
[Image: attachment.php?aid=1500]
3. Install library in arduino IDE.
here have many demo simple code for how to use KC868-H32B Pro smart controller's relay output and input sensor port.
This is sample code how to turn ON/OFF one relay.
  Great technical support
Posted by: petez69 - 10-31-2022, 11:24 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hello Kincony
Thankyou for sending me a board replacement for my A16.  The board arrived within 2 weeks in the mail.  I really appreciate you helping me and I have no hesitation in recommending your products.
Thankyou !
Peter
  DS1820 temperature sensor on KC868-A16
Posted by: marius - 10-30-2022, 09:20 AM - Forum: KC868-A16 - Replies (22)
I connected DS1820 temperature sensor to KC868-A16 GPIO pins and running Tasmota, but in Tasmota interface module configuration there is no option to select DS1820 sensor or any other similar type (like AM2301A) sensor.
Can someone advice on how to make this thing working?
Evrything else working perfectly
