» Members: 10,186
» Latest member: Lottery7
» Forum threads: 4,264
» Forum posts: 21,141
There are currently 286 online users.
» 0 Member(s) | 270 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
SSD not visible for insta...
Forum: Pi5R16
Last Post: Verresen
15 minutes ago
KC868-A16 and Tuya
Last Post: newdos
46 minutes ago
» Replies: 8
KC868-AI mDNS problem
Forum: KC868-AI
2 hours ago
remember relay state
Forum: KC868-E16T
2 hours ago
» Replies: 9
N30 (KCS): energy counter...
Forum: N30
11 hours ago
Bricked KC868-A16
11 hours ago
» Replies: 7
KinCony G1 ESP32-S3 SIM76...
Forum: News
11 hours ago
» Replies: 4
Current direction detecti...
Forum: N30
Last Post: dominique_manas@hotmail.com
Yesterday, 07:31 AM
» Replies: 4
KC868-A8 on Heat Pump for...
Last Post: marktuan
Yesterday, 03:17 AM
B32M maximum voltage
Last Post: felixandrea
Yesterday, 03:14 AM
  For a 16 firmware
Posted by: reehanlambe - 01-10-2023, 05:46 AM - Forum: KC868-A16 - Replies (40)
Hi sir   just want to know   can we download your new firmware   which you have in e16 t   without coding   ( for  a16)  if yes  pls send firmware link
Photo KC868-AG - Tasmota firmware - cant read ir remote data
Posted by: ADLER LINHARES - 01-08-2023, 10:24 PM - Forum: Development - Replies (1)
Hello folks,
i am facing a problem with my KC868-AG and I would apreciate some help.
first of all i am a noob on tasmota subject so probaly my poor knowledge should be the reason that i dont get result.
as stated in the body of the message, I recently acquired a KC868-AG. As soon as I opened the package, I performed the recording of the tasmota through the link below:
https://tasmota.github.io/install/
[Image: view?usp=sharing]
image 01 - tasmota
after completing the previous step, went to the following path: CONFIGURATION > CONFIGURE OTHER
and insert the following template:
{"NAME":"KC868-AG","GPIO":[0,0,1056,0,480,0,0,0,0,0,1,0,1,1,1,1,0,1,1120,1152,0,7968,0,0,0,0,0,0,1,1,1,1,1,0,0,1],"FLAG":0,"BASE":1,"CMND":"BuzzerPwm 1"}
as in kincony site - template
image 02
after that i have no idea how to read te code of a ir remote control of mine.
when i go to console I can see only this :
image 03 - tasmota console
Is there a way to read the remote control IR signal through the console?
Is there a command model in order to modulate the signal?
Best regards,
  Can A1 to A4 used as buttons too?
Posted by: exico - 01-08-2023, 05:42 PM - Forum: KC868-E16S/E16P - Replies (7)
Hello, I'm going to buy a couple of these boards for a new house but I'd like to know if the connectors A1 to A4 can be used to attach more switches/buttons.
I will use ESPHOME and connect the boards to Home Assistant. These extra buttons would be nice to have for activating automations.
In the schematics the connectors are attached to pin 36, 35, 34 and 39. Searches on google tells me that it might work but I'd like a confirmation from who built the board  Big Grin
Thank you
  KC102 Tuya IR universal remote Released
Posted by: admin - 01-08-2023, 01:29 PM - Forum: News - No Replies
KC102 Smart IR Controller is tuya ir universal remote product. it can use by Tuya application to remote control IR device by internet. There are some IR code on cloud server, you just need to change electrical appliances brand, then you can use quick guide to config IR signal. if your electrical appliances IR code not in clould server’s code database, you can learn IR signal from remoter and it will save and send IR signal out to your electrical appliances.
[Image: KC102-1_01.jpg]
[Image: KC102-1_02.jpg]
[Image: KC102-1_03.jpg]
  I would like to suggest to you the following
Posted by: engmohades - 01-08-2023, 06:16 AM - Forum: News - Replies (1)
Hello, every on e
dear kincony
1- Adding a settings page to trigger the 6 inputs in the output of the H32B PRO relay, such as the Interlock settings page
Because when the internet or Toya server stops, automation will not work
2-  Updating the Touch and Montary switches by adding an rs485 bus to it bluit in , not adding another special piece to it
3- Run all Kincony products that contain rs485 to reduce the large number of wires used in connection, and by making one software and programming the entire system through it
  KC868-A64 work with KC868-E16v2 + lamp and manual control by switch panel
Posted by: admin - 01-07-2023, 03:52 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
KC868-A64 work with lamp via KC868-E16v2 extend relay module and manual control by momentary switch panel.
  KC868-A4 with lamp and curtain motor and manual control switch panel
Posted by: admin - 01-07-2023, 03:49 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
KC868-A4 work with lamp and curtain motor and manual control by momentary switch panel.
  KC868-H32B Pro + KC868-AK + curtain motor
Posted by: admin - 01-07-2023, 03:47 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (2)
Here is KC868-H32B Pro smart controller work with curtain motor and KC868-AK for manual control switch panel. You can enable KC868-H32B Pro "interlock" function for motor protect, so that will not let two relay ALL ON simultaneously.
  Can i integrate kincony product with TIS Smart home?
Posted by: engmohades - 01-06-2023, 06:46 PM - Forum: News - Replies (3)
  Firmware problem KC868-E16S
Posted by: Fran - 01-05-2023, 09:22 PM - Forum: Development - Replies (5)
Hi, I'm new to the forum, I bought a KC868-E16S motherboard. when upgrading the firmware as in the example "KC868-E16S_Web_Server-ETH", the network card does not work and cannot find the card. I need help for this problem.
Thank you
fleira@gessco.es
