» Members: 10,108
» Latest member: vf555ttattoo
» Forum threads: 4,257
» Forum posts: 21,085
There are currently 241 online users.
» 0 Member(s) | 224 Guest(s)
AhrefsBot, Amazonbot, Baidu, Bytespider, Crawl, Google, PetalBot, bot
Update to latest esphome
Last Post: Elgatoguiri
9 hours ago
m16v2 energy meter - cali...
Yesterday, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
  WebUI over wifi STA mode
Posted by: xray - 11-06-2022, 06:47 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
Hi KinCony IoT,
Is it possible to reach the WebUI over Wifi in STA mode to manage the relays?
I can reach the webUI over LAN port.
Both Ethernet and Wifi are set to TCP-Server.
I was able to configure Wifi in STA mode and connect to my Wifi router. Then I disconnect the wired LAN port, but when I try to connect to the relay over the Wifi IP it doesn't give back the Relay Web UI, but the Wifi ESP32 config UI.
I would like to use HTTP commands over Wifi. Is it possible?
  ESPHome GPIO
Posted by: lautarosrur - 11-04-2022, 09:00 PM - Forum: KC868-A16 - Replies (7)
How can I reference the GPIO and analog pins in ESPHome? Can you provide some example? Thanks.
  duvida sobre erro KC 868 A6
Posted by: EMSANTANA - 11-04-2022, 12:25 AM - Forum: KC868-A6 - Replies (1)
Boa noite.
Eu tenho uma placa WIFI KC868 A6 conectado a um roteador. Mas quando a energia acaba, quando a energia volta, a internet volta mas a placa KC868 A6 trava. Para voltar ao trabalho, tenho que desligar a energia e ligar novamente.
Que solução posso usar?
  how to conect 10 circuits of LED STIP LIGHT
Posted by: engmohades - 11-02-2022, 11:56 AM - Forum: KC868-A4 - Replies (3)
hello, admin
    What are  products from Kinkony  to conect 10 circuits of LED STIP LIGHT ?
    How to connect them to be dimmable from wall switch and at the same time to be itegrated in app Home Assistant (dimmable and change multy color)?
Thank you
  ESP32 arduino library for KC868-H32B Pro Controller
Posted by: admin - 11-01-2022, 12:41 AM - Forum: News - No Replies
Made ESP32 arduino library for KC868-H32B Pro Controller, easy to write arduino code for simple logical, such as sensor trigger relay or timer locally.
[Image: arduino_h32b_pro_2.png]
[Image: arduino_h32b_pro_3.jpg]
here is details: https://www.kincony.com/how-to-use-ardui...b-pro.html
  How to use "arduino library" for KC868-H32B Pro
Posted by: admin - 11-01-2022, 12:12 AM - Forum: KC868-HxB series Smart Controller - No Replies
We have made arduino library for KC868-H32B Pro smart controller. it is open source and free for DIYer use.
1. Install ESP32 USB driver to your computer.
download from: https://www.kincony.com/download/CH341SER.zip
after installed USB driver, connect USB cable to your KC868-H32B Pro USB port.
[Image: attachment.php?aid=1504]
Then you will find COM port in windows OS "device manager"
[Image: attachment.php?aid=1499]
2. Enable "ESP32 Development Mode" by KC868-H32B Pro Ethernet setting.
[Image: attachment.php?aid=1500]
3. Install library in arduino IDE.
here have many demo simple code for how to use KC868-H32B Pro smart controller's relay output and input sensor port.
This is sample code how to turn ON/OFF one relay.
  Great technical support
Posted by: petez69 - 10-31-2022, 11:24 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hello Kincony
Thankyou for sending me a board replacement for my A16.  The board arrived within 2 weeks in the mail.  I really appreciate you helping me and I have no hesitation in recommending your products.
Thankyou !
Peter
  DS1820 temperature sensor on KC868-A16
Posted by: marius - 10-30-2022, 09:20 AM - Forum: KC868-A16 - Replies (22)
I connected DS1820 temperature sensor to KC868-A16 GPIO pins and running Tasmota, but in Tasmota interface module configuration there is no option to select DS1820 sensor or any other similar type (like AM2301A) sensor.
Can someone advice on how to make this thing working?
Evrything else working perfectly
  KC868-A6 tasmota
Posted by: rodrigo_rjn - 10-29-2022, 06:06 PM - Forum: KC868-A6 - Replies (15)
ola personal, someone has already cofollowed install the tasmota, I can install more does not open the field to configure the pulse input, someone has already managed
  KC868-A8 ethernet work with home assistant by ESPHome configure
Posted by: admin - 10-28-2022, 12:23 AM - Forum: KC868-A8 - Replies (9)
.txt   A8-esphome.txt (Size: 3.35 KB / Downloads: 1602)
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
    address: 0x1c0000031edd2a28
