» Members: 9,254
» Latest member: Lomagno
» Forum threads: 4,105
» Forum posts: 20,576
There are currently 86 online users.
» 0 Member(s) | 74 Guest(s)
Amazonbot, Bytespider, PetalBot, Yandex, bot
How to get started
2 hours ago
» Replies: 12
Force sensitive sensor wi...
2 hours ago
DM16 output not turning o...
Forum: DM16
Yesterday, 01:11 PM
» Replies: 26
A Project in Saudi Arabia...
Last Post: Maxsys249
Yesterday, 07:56 AM
KinCony Pi5M32 – Raspberr...
Forum: News
06-25-2026, 10:40 AM
RS485 issue
Forum: B4M
06-25-2026, 02:04 AM
KinCony Pi5R32 – Raspberr...
Forum: News
06-24-2026, 02:54 PM
how to set "momentary" & ...
Forum: B16M
06-24-2026, 08:06 AM
[Bug] A16v3 (v3.24.3) - W...
Last Post: savingguillemot
06-23-2026, 08:22 AM
Switching power supply wi...
Forum: KC868-A16v3
06-22-2026, 11:34 PM
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#06-KC868-A8S_PCF8574-Digital input_cod
Posted by: KinCony Support - 06-01-2022, 01:19 AM - Forum: KC868-A8S - No Replies
[Arduino IDE demo source code for KC868-A8S]--#06-KC868-A8S_PCF8574-Digital input_code
/*KC868-A8S PCF8574 Digital input code*/
/*digital input will trigger digital output */
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574_IN1(0x22,4,5);
PCF8574 pcf8574_RE(0x24,4,5);
pcf8574_RE.pinMode(P0, OUTPUT);
pcf8574_RE.pinMode(P1, OUTPUT);
pcf8574_RE.pinMode(P2, OUTPUT);
pcf8574_RE.pinMode(P3, OUTPUT);
pcf8574_RE.pinMode(P4, OUTPUT);
pcf8574_RE.pinMode(P5, OUTPUT);
pcf8574_RE.pinMode(P6, OUTPUT);
pcf8574_RE.pinMode(P7, OUTPUT);
pcf8574_RE.begin();
pcf8574_IN1.pinMode(P0, INPUT);
pcf8574_IN1.pinMode(P1, INPUT);
pcf8574_IN1.pinMode(P2, INPUT);
pcf8574_IN1.pinMode(P3, INPUT);
pcf8574_IN1.pinMode(P4, INPUT);
pcf8574_IN1.pinMode(P5, INPUT);
pcf8574_IN1.pinMode(P6, INPUT);
pcf8574_IN1.pinMode(P7, INPUT);
pcf8574_IN1.begin();
uint8_t val1 = pcf8574_IN1.digitalRead(P0);
uint8_t val2 = pcf8574_IN1.digitalRead(P1);
uint8_t val3 = pcf8574_IN1.digitalRead(P2);
uint8_t val4 = pcf8574_IN1.digitalRead(P3);
uint8_t val5 = pcf8574_IN1.digitalRead(P4);
uint8_t val6 = pcf8574_IN1.digitalRead(P5);
uint8_t val7 = pcf8574_IN1.digitalRead(P6);
uint8_t val8 = pcf8574_IN1.digitalRead(P7);
if (val1==LOW) {
  pcf8574_RE.digitalWrite(P0,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P0,HIGH);
if (val2==LOW) {
  pcf8574_RE.digitalWrite(P1,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P1,HIGH);
if (val3==LOW)  {
  pcf8574_RE.digitalWrite(P2,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P2,HIGH);
if (val4==LOW)  {
  pcf8574_RE.digitalWrite(P3,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P3,HIGH);
if (val5==LOW)  {
  pcf8574_RE.digitalWrite(P4,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P4,HIGH);
if (val6==LOW)  {
  pcf8574_RE.digitalWrite(P5,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P5,HIGH);
if (val7==LOW)  {
  pcf8574_RE.digitalWrite(P6,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P6,HIGH);
if (val8==LOW)  {
  pcf8574_RE.digitalWrite(P7,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P7,HIGH);
    delay(300);
.zip   PCF8574-DI.zip (Size: 940 bytes / Downloads: 732)
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#05-KC868-A8S_LAN8720_UDP_code
Posted by: KinCony Support - 06-01-2022, 01:18 AM - Forum: KC868-A8S - No Replies
/*KC868-A8S LAN8720_UDP communication code*/
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
/*Set the default IP address to 192.168.1.200  */
/*you can change the default IP address*/
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   LAN8720_UDP.zip (Size: 1.09 KB / Downloads: 742)
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#04-KC868-A8S_DS18B20_code
Posted by: KinCony Support - 06-01-2022, 01:17 AM - Forum: KC868-A8S - No Replies
/*KC868-A8S DS18B20 Temperature sensor code*/
#include <DS18B20.h>
DS18B20 ds1(14);  //channel-1-DS18b20  IO14
  Serial.print("Temperature1:");
  Serial.print(ds1.getTempC());
  Serial.print(" C /");
  delay(500);
.zip   ds18b20.zip (Size: 498 bytes / Downloads: 775)
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#03-KC868-A8S_BEEP_code
Posted by: KinCony Support - 06-01-2022, 01:14 AM - Forum: KC868-A8S - No Replies
/*KC868-A8S Beep code*/
const int BEEP_Pin = 2;
  // initialize the BEEP_Pin as an output:
   pinMode(BEEP_Pin, OUTPUT);
    digitalWrite(BEEP_Pin, LOW);
    delay(2000);
    digitalWrite(BEEP_Pin, HIGH);
    delay(2000);
.zip   Beep.zip (Size: 632 bytes / Downloads: 725)
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#02-KC868-A8S_ADC_INOUT_code
Posted by: KinCony Support - 06-01-2022, 01:12 AM - Forum: KC868-A8S - No Replies
/*KC868-A8S Analog input code*/
/*When the analog input interface has some Voltage ,it will print to the Serial port */
/*A1 A2   Input---0-5V*/
/*A3 A4   Input---0-20MA*/
#define ANALOG_A1   36        // IO36
#define ANALOG_A2   39        // IO39
#define ANALOG_A3   34        // IO34
#define ANALOG_A4   35        // IO35
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  if(analogRead(ANALOG_A1)!=0)
    {  Serial.printf("Current Reading A1 on Pin(%d)=%d\n",ANALOG_A1,analogRead(ANALOG_A1));delay(500);}
  if(analogRead(ANALOG_A2)!=0)
    {  Serial.printf("Current Reading A2 on Pin(%d)=%d\n",ANALOG_A2,analogRead(ANALOG_A2));delay(500);}
  if(analogRead(ANALOG_A3)!=0)
    {  Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));delay(500);}
  if(analogRead(ANALOG_A4)!=0)
    {  Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));delay(500);}
.zip   ADC_INOUT.zip (Size: 710 bytes / Downloads: 737)
Lightbulb [Arduino IDE demo source code for KC868-A8S]--#01-KC868-A8S_433_receive_code
Posted by: KinCony Support - 06-01-2022, 01:11 AM - Forum: KC868-A8S - No Replies
/* RF-receive code for KC868-A8S*/
/*If receive the RF single,the LED will be turn the color to "0xff00ff"*/
/*install library RCSwitch and Adafruit_NeoPixel*/
#include <RCSwitch.h>  //Install library "rcswitch"
#include <Adafruit_NeoPixel.h>
Adafruit_NeoPixel rgb_display = Adafruit_NeoPixel(130,12,NEO_GRB + NEO_KHZ800);
//The WS2812 rgb LED is connect to IO12    RGB_LED number is 1
  Serial.begin(9600);
  rgb_display.begin();
  mySwitch.enableReceive(digitalPinToInterrupt(16));  //receive PIN IO16
if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.println( mySwitch.getReceivedValue() );
    rgb_display.setPixelColor((1)-1,(0xff00ff));
    rgb_display.setBrightness(100);
    rgb_display.show();
    mySwitch.resetAvailable();
.zip   433-decode.zip (Size: 777 bytes / Downloads: 784)
  KC868-A8 and PCF8574 Interrupt pin
Posted by: andhol - 05-31-2022, 07:53 PM - Forum: KC868-A8 - Replies (14)
Hi!
I am planning to use all 8 digital inputs of the KC868-A8, and it would be nice to be able to use the interrupt pin of the PCF8574 to detect changes. I'm just not sure if the pin is connected or not. When looking at the schematic, it looks like it is connected to GPIO16, but there is also a red X symbol next to it that might suggest otherwise.. Any hints?
/A
  KC868-A8S hotel room demo configure for ESPhome
Posted by: admin - 05-31-2022, 12:45 AM - Forum: KC868-A8S - Replies (16)
  platform: ESP32
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Individual outputs
      pcf8574: pcf8574_hub_out_1
    interlock: [relay6]
    interlock: [relay5]
    interlock: [relay8]
    interlock: [relay7]
    on_press:
      then:
        - switch.toggle: light1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
    on_press:
      then:
        - switch.toggle: relay6
    on_press:
      then:
        - switch.toggle: relay7
    on_press:
      then:
        - switch.toggle: relay8
  - platform: remote_receiver
    rc_switch_raw:
      code: '001111010111001010111000'
      protocol: 1
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '001111010111001010111100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 1
    on_press:
      then:
    filters:
    pin: 14
    device_class: motion
    on_release:
      - script.execute: motion_timer
script:
  - id: motion_timer
    mode: restart
    then:
      - delay: 10s
      - switch.turn_off: light1
      - switch.turn_off: light2
      - switch.turn_off: light3
      - switch.turn_off: light4
.txt   KC868-A8S-ha-config.txt (Size: 6.11 KB / Downloads: 1043)
  KC868-A8S ESP32 I/O pin define
Posted by: admin - 05-31-2022, 12:43 AM - Forum: KC868-A8S - Replies (5)
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Input_IIC_address 0x22
DS18B20/DHT11/DHT21/LED strip -2: 14
RF433MHz wireless receiver: 16
#define ETH_ADDR        0
RS485:
RXD:GPIO32
TXD:GPIO33
GSM:
RXD:GPIO13
TXD:GPIO15
Buzzer:GPIO2
WS2812B RGBW LED:GPIO12
  KC868 A4 - Help In Program
Posted by: mfjunior96 - 05-29-2022, 09:52 PM - Forum: KC868-A4 - Replies (3)
Good night sir,
I'm having a problem and I wanted some help, I have a KC868 A4, I'm using the 4 outputs and 3 digital inputs, but now I want a device (led drivers) connected to alexa to change its state, when I change the state of the digital input , I created a new device "F6" but I can't make "When F6 on > Led Driver ON" the alexa app doesn't let me put a lamp with imput, what can I do? Is there another app that I can do this interaction?
Thanks in Advance
