» Members: 10,010
» Latest member: adhennick
» Forum threads: 4,252
» Forum posts: 21,052
There are currently 57 online users.
» 0 Member(s) | 42 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Crawl, PetalBot, Yandex, bot
Las Firmware ?
Yesterday, 11:39 PM
kc868-a6 analog input
Yesterday, 11:38 PM
A32 pro tuya
Yesterday, 11:38 PM
Disconnect loop with Home...
Forum: F16
Yesterday, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
Yesterday, 01:16 AM
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Lightbulb Fireplace stove combustion automation
Posted by: SvetZitrka - 09-06-2022, 10:40 AM - Forum: DIY Project - Replies (3)
Hi, I would like to equip my fireplace insert with an automation that will measure the temperature of the flue gas in the chimney and control the air supply damper based on that.
Systems like this can make the whole burning process much more efficient, using up to 30% less wood. Which is great. Plus, they can be very user-friendly and alert the user to add wood to the fireplace.
All you have to do is measure the temperature with a ceramic sensor that can withstand high temperatures and a servo drive to control the air supply damper.
All the logic should be able to be set up through Home Assistant.
  • Which HW Kincony would handle this and how?
  • Can you give me any advice?
I believe that similar automation would save many users a lot of stress, especially now that winter is coming and there is an energy crisis.
  KC868-A8S - Trying to connect with GSM
Posted by: AbrahamAV97 - 09-05-2022, 05:08 PM - Forum: Development - Replies (1)
Hi!  Big Grin
I have recently purchased a KC868-A8S.
My goal is to get a GSM web server, from which I can activate the relays.
I have managed to create a web server by creating my own AP, taking a tutorial from the forum as an example.
But this, although it is something similar, does not serve my purpose.
I have worked before with ESP32 and GSM (I used to work with TinyGSM), and when I wanted to connect it was necessary to define the MODEM_TX and MODEM_RX pins in code.
In this case I cannot find anywhere, neither in the documentation nor in the forum, how to connect the ESP to the GSM network, nor to which pins the modem corresponds.
I have a SIM800L module.
Is there an example of code (.ino) in which the configuration and connection of the GSM can be seen logically?
Any help is appreciated.
Thank you very much in advance and sorry for my level of English.
  [Arduino IDE demo source code for KC868-E16S]--#08-E16S-Ethernet_Web_server_code
Posted by: KinCony Support - 09-05-2022, 08:15 AM - Forum: KC868-E16S/E16P - Replies (10)
Refer to code #11 of KC868-A8 for download methods
.zip   KC868-E16S_Web_Server-ETH.zip (Size: 474.02 KB / Downloads: 1179)
* Create Your own WebServer for KC868-E16S Smart Controller*
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT       Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_       3
#include <WebServer_WT32_ETH01.h>
WiFiServer server(80);
// Current time
// Previous time
int flag_read_di=0;
String header;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_I1(&I2Cone, 0x22, 16, 15);
PCF8574 pcf8574_I2(&I2Cone, 0x24, 16, 15);
PCF8574 pcf8574_R1(&I2Cone, 0x21, 16, 15);
PCF8574 pcf8574_R2(&I2Cone, 0x25, 16, 15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
                       "relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",};
  for(int i=0;i<=7;i++)
     pcf8574_R2.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
     pcf8574_I1.pinMode(i, INPUT);
     pcf8574_I2.pinMode(i, INPUT);
  pcf8574_I1.begin();
  pcf8574_I2.begin();
     pcf8574_R2.digitalWrite(i, HIGH);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
while (!Serial);
  // Using this if Serial debugging is not necessary or not using Serial port
  //while (!Serial && (millis() < 3000));
  Serial.print("\nStarting WebServer on " + String(ARDUINO_BOARD));
  Serial.println(" with " + String(SHIELD_TYPE));
  Serial.println(WEBSERVER_WT32_ETH01_VERSION);
  WT32_ETH01_onEvent();
  //bool begin(uint8_t phy_addr=ETH_PHY_ADDR, int power=ETH_PHY_POWER, int mdc=ETH_PHY_MDC, int mdio=ETH_PHY_MDIO,
  //           eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
  //ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER, ETH_PHY_MDC, ETH_PHY_MDIO, ETH_PHY_TYPE, ETH_CLK_MODE);
  ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER);
// ETH.config(myIP, myGW, mySN, myDNS);
  //WT32_ETH01_waitForConnect();
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    currentTime = millis();
    previousTime = currentTime;
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        header += c;
            client.println();
            // turns 16 relays on and off
                 pcf8574_R2.digitalWrite(i, LOW);
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;text-align: center;font-size: 10px;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-E16S Web Server</h1>");
            if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">01-OFF</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">01--ON </button></a>");
            if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">02-OFF</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">02--ON </button></a>");
            if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">03-OFF</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">03--ON </button></a>");
            if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">04-OFF</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">04--ON </button></a>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05--ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06--ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07--ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08--ON </button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09--ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10--ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11--ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12--ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13--ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14--ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15--ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16--ON</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All--ON</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
    for(int j=0;j<=7;j++)
    if(pcf8574_I2.digitalRead(j) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(j) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
  [Arduino IDE demo source code for KC868-A16]--#11-KC868-A16_Ethernet_Web_server_code
Posted by: KinCony Support - 09-05-2022, 03:35 AM - Forum: KC868-A16 - Replies (18)
                      Refer to code #11 of A8 for download methods
.zip   KC868-A16_Web_Server_Eth.zip (Size: 413.26 KB / Downloads: 2093)
* Create Your own Ethernet-WebServer for KC868-A32 Smart Controller*
* https://www.kincony.com                                ***********
// Select the IP address according to your local network
IPAddress myIP(192, 168, 1, 232);
IPAddress myGW(192, 168, 1, 1);
IPAddress mySN(255, 255, 255, 0);
// Google DNS Server IP
IPAddress myDNS(8, 8, 8, 8);
// Current time
// Previous time
int flag_read_di=0;
String header;
//TwoWire I2Ctwo = TwoWire(1);
// Set relay output i2c address
PCF8574 pcf8574_R1(&I2Cone, 0x3C, 4, 5);
PCF8574 pcf8574_R2(&I2Cone, 0x3D, 4, 5);
//PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
//PCF8574 pcf8574_R4(&I2Ctwo, 0x22, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x3A, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x39, 4, 5);
//PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
//PCF8574 pcf8574_I4(&I2Cone, 0x22, 4, 5);
String relay32state = "off";// state of relay32*/
pcf8574_R1.pinMode(P0, OUTPUT);
pcf8574_R1.pinMode(P1, OUTPUT);
pcf8574_R1.pinMode(P2, OUTPUT);
pcf8574_R1.pinMode(P3, OUTPUT);
pcf8574_R1.pinMode(P4, OUTPUT);
pcf8574_R1.pinMode(P5, OUTPUT);
pcf8574_R1.pinMode(P6, OUTPUT);
pcf8574_R1.pinMode(P7, OUTPUT);
pcf8574_R2.pinMode(P0, OUTPUT);
pcf8574_R2.pinMode(P1, OUTPUT);
pcf8574_R2.pinMode(P2, OUTPUT);
pcf8574_R2.pinMode(P3, OUTPUT);
pcf8574_R2.pinMode(P4, OUTPUT);
pcf8574_R2.pinMode(P5, OUTPUT);
pcf8574_R2.pinMode(P6, OUTPUT);
pcf8574_R2.pinMode(P7, OUTPUT);
pcf8574_R3.pinMode(P0, OUTPUT);
pcf8574_R3.pinMode(P1, OUTPUT);
pcf8574_R3.pinMode(P2, OUTPUT);
pcf8574_R3.pinMode(P3, OUTPUT);
pcf8574_R3.pinMode(P4, OUTPUT);
pcf8574_R3.pinMode(P5, OUTPUT);
pcf8574_R3.pinMode(P6, OUTPUT);
pcf8574_R3.pinMode(P7, OUTPUT);
pcf8574_R4.pinMode(P0, OUTPUT);
pcf8574_R4.pinMode(P1, OUTPUT);
pcf8574_R4.pinMode(P2, OUTPUT);
pcf8574_R4.pinMode(P3, OUTPUT);
pcf8574_R4.pinMode(P4, OUTPUT);
pcf8574_R4.pinMode(P5, OUTPUT);
pcf8574_R4.pinMode(P6, OUTPUT);
pcf8574_R4.pinMode(P7, OUTPUT);*/
  Serial.print("Init pcf8574_R1...");
  if (pcf8574_R1.begin()){
    Serial.println("PCF8574_R1_OK");
  }else{
    Serial.println("PCF8574_R1_KO");
  Serial.print("Init pcf8574_R2...");
  if (pcf8574_R2.begin()){
    Serial.println("PCF8574_R2_OK");
  }else{
    Serial.println("PCF8574_R2_KO");
  Serial.print("Init pcf8574_R3...");
  if (pcf8574_R3.begin()){
    Serial.println("PCF8574_R3_OK");
  }else{
    Serial.println("PCF8574_R3_KO");
  Serial.print("Init pcf8574_R4...");
  if (pcf8574_R4.begin()){
    Serial.println("PCF8574_R4_OK");
  }else{
    Serial.println("PCF8574_R4_KO");
pcf8574_I1.pinMode(P0, INPUT);
pcf8574_I1.pinMode(P1, INPUT);
pcf8574_I1.pinMode(P2, INPUT);
pcf8574_I1.pinMode(P3, INPUT);
pcf8574_I1.pinMode(P4, INPUT);
pcf8574_I1.pinMode(P5, INPUT);
pcf8574_I1.pinMode(P6, INPUT);
pcf8574_I1.pinMode(P7, INPUT);
pcf8574_I2.pinMode(P0, INPUT);
pcf8574_I2.pinMode(P1, INPUT);
pcf8574_I2.pinMode(P2, INPUT);
pcf8574_I2.pinMode(P3, INPUT);
pcf8574_I2.pinMode(P4, INPUT);
pcf8574_I2.pinMode(P5, INPUT);
pcf8574_I2.pinMode(P6, INPUT);
pcf8574_I2.pinMode(P7, INPUT);
pcf8574_I3.pinMode(P0, INPUT);
pcf8574_I3.pinMode(P1, INPUT);
pcf8574_I3.pinMode(P2, INPUT);
pcf8574_I3.pinMode(P3, INPUT);
pcf8574_I3.pinMode(P4, INPUT);
pcf8574_I3.pinMode(P5, INPUT);
pcf8574_I3.pinMode(P6, INPUT);
pcf8574_I3.pinMode(P7, INPUT);
pcf8574_I4.pinMode(P0, INPUT);
pcf8574_I4.pinMode(P1, INPUT);
pcf8574_I4.pinMode(P2, INPUT);
pcf8574_I4.pinMode(P3, INPUT);
pcf8574_I4.pinMode(P4, INPUT);
pcf8574_I4.pinMode(P5, INPUT);
pcf8574_I4.pinMode(P6, INPUT);
pcf8574_I4.pinMode(P7, INPUT);*/
  if (pcf8574_I1.begin()){
    Serial.println("pcf8574_I1_OK");
  }else{
    Serial.println("pcf8574_I1_KO");
  if (pcf8574_I2.begin()){
    Serial.println("pcf8574_I2_OK");
  }else{
    Serial.println("pcf8574_I2_KO");
  Serial.print("Init pcf8574_I3...");
  if (pcf8574_I3.begin()){
    Serial.println("pcf8574_I3_OK");
  }else{
    Serial.println("pcf8574_I3_KO");
  Serial.print("Init pcf8574_I4...");
  if (pcf8574_I4.begin()){
    Serial.println("pcf8574_I4_OK");
  }else{
    Serial.println("pcf8574_I4_KO");
  pcf8574_R1.digitalWrite(P0, HIGH);
  pcf8574_R1.digitalWrite(P1, HIGH);
  pcf8574_R1.digitalWrite(P2, HIGH);
  pcf8574_R1.digitalWrite(P3, HIGH);
  pcf8574_R1.digitalWrite(P4, HIGH);
  pcf8574_R1.digitalWrite(P5, HIGH);
  pcf8574_R1.digitalWrite(P6, HIGH);
  pcf8574_R1.digitalWrite(P7, HIGH);
  pcf8574_R2.digitalWrite(P0, HIGH);
  pcf8574_R2.digitalWrite(P1, HIGH);
  pcf8574_R2.digitalWrite(P2, HIGH);
  pcf8574_R2.digitalWrite(P3, HIGH);
  pcf8574_R2.digitalWrite(P4, HIGH);
  pcf8574_R2.digitalWrite(P5, HIGH);
  pcf8574_R2.digitalWrite(P6, HIGH);
  pcf8574_R2.digitalWrite(P7, HIGH);
  pcf8574_R3.digitalWrite(P0, HIGH);
  pcf8574_R3.digitalWrite(P1, HIGH);
  pcf8574_R3.digitalWrite(P2, HIGH);
  pcf8574_R3.digitalWrite(P3, HIGH);
  pcf8574_R3.digitalWrite(P4, HIGH);
  pcf8574_R3.digitalWrite(P5, HIGH);
  pcf8574_R3.digitalWrite(P6, HIGH);
  pcf8574_R3.digitalWrite(P7, HIGH);
  pcf8574_R4.digitalWrite(P0, HIGH);
  pcf8574_R4.digitalWrite(P1, HIGH);
  pcf8574_R4.digitalWrite(P2, HIGH);
  pcf8574_R4.digitalWrite(P3, HIGH);
  pcf8574_R4.digitalWrite(P4, HIGH);
  pcf8574_R4.digitalWrite(P5, HIGH);
  pcf8574_R4.digitalWrite(P6, HIGH);
  pcf8574_R4.digitalWrite(P7, HIGH);*/
  while (!Serial);
  // start the web server on port 80
  server.begin();
  // listen for incoming clients
        header += c;
            client.println();
            // turns 32 relays on and off
     /*       else if (header.indexOf("GET /17/on") >= 0)  {relay17state = "on";pcf8574_R3.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /17/off") >= 0) {relay17state = "off";pcf8574_R3.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /18/on") >= 0)  {relay18state = "on";pcf8574_R3.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /18/off") >= 0) {relay18state = "off";pcf8574_R3.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /19/on") >= 0)  {relay19state = "on";pcf8574_R3.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /19/off") >= 0) {relay19state = "off";pcf8574_R3.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /20/on") >= 0)  {relay20state = "on";pcf8574_R3.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /20/off") >= 0) {relay20state = "off";pcf8574_R3.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /21/on") >= 0)  {relay21state = "on";pcf8574_R3.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /21/off") >= 0) {relay21state = "off";pcf8574_R3.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /22/on") >= 0)  {relay22state = "on";pcf8574_R3.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /22/off") >= 0) {relay22state = "off";pcf8574_R3.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /23/on") >= 0)  {relay23state = "on";pcf8574_R3.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /23/off") >= 0) {relay23state = "off";pcf8574_R3.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /24/on") >= 0)  {relay24state = "on";pcf8574_R3.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /24/off") >= 0) {relay24state = "off";pcf8574_R3.digitalWrite(P7, HIGH);}
            else if (header.indexOf("GET /25/on") >= 0)  {relay25state = "on";pcf8574_R4.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /25/off") >= 0) {relay25state = "off";pcf8574_R4.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /26/on") >= 0)  {relay26state = "on";pcf8574_R4.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /26/off") >= 0) {relay26state = "off";pcf8574_R4.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /27/on") >= 0)  {relay27state = "on";pcf8574_R4.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /27/off") >= 0) {relay27state = "off";pcf8574_R4.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /28/on") >= 0)  {relay28state = "on";pcf8574_R4.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /28/off") >= 0) {relay28state = "off";pcf8574_R4.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /29/on") >= 0)  {relay29state = "on";pcf8574_R4.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /29/off") >= 0) {relay29state = "off";pcf8574_R4.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /30/on") >= 0)  {relay30state = "on";pcf8574_R4.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /30/off") >= 0) {relay30state = "off";pcf8574_R4.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /31/on") >= 0)  {relay31state = "on";pcf8574_R4.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /31/off") >= 0) {relay31state = "off";pcf8574_R4.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /32/on") >= 0)  {relay32state = "on";pcf8574_R4.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /32/off") >= 0) {relay32state = "off";pcf8574_R4.digitalWrite(P7, HIGH);}*/
              relay17state = "on";// state of relay17
              relay18state = "on";// state of relay18
              relay19state = "on";// state of relay19
              relay20state = "on";// state of relay20
              relay21state = "on";// state of relay21
              relay22state = "on";// state of relay22
              relay23state = "on";// state of relay23
              relay24state = "on";// state of relay24
              relay25state = "on";// state of relay25
              relay26state = "on";// state of relay26
              relay27state = "on";// state of relay27
              relay28state = "on";// state of relay28
              relay29state = "on";// state of relay29
              relay30state = "on";// state of relay30
              relay31state = "on";// state of relay31
              relay32state = "on";// state of relay32*/
              pcf8574_R1.digitalWrite(P0, LOW);
              pcf8574_R1.digitalWrite(P1, LOW);
              pcf8574_R1.digitalWrite(P2, LOW);
              pcf8574_R1.digitalWrite(P3, LOW);
              pcf8574_R1.digitalWrite(P4, LOW);
              pcf8574_R1.digitalWrite(P5, LOW);
              pcf8574_R1.digitalWrite(P6, LOW);
              pcf8574_R1.digitalWrite(P7, LOW);
              pcf8574_R2.digitalWrite(P0, LOW);
              pcf8574_R2.digitalWrite(P1, LOW);
              pcf8574_R2.digitalWrite(P2, LOW);
              pcf8574_R2.digitalWrite(P3, LOW);
              pcf8574_R2.digitalWrite(P4, LOW);
              pcf8574_R2.digitalWrite(P5, LOW);
              pcf8574_R2.digitalWrite(P6, LOW);
              pcf8574_R2.digitalWrite(P7, LOW);
              pcf8574_R4.digitalWrite(P7, LOW);*/
              relay17state = "off";// state of relay17
              relay18state = "off";// state of relay18
              relay19state = "off";// state of relay19
              relay20state = "off";// state of relay20
              relay21state = "off";// state of relay21
              relay22state = "off";// state of relay22
              relay23state = "off";// state of relay23
              relay24state = "off";// state of relay24
              relay25state = "off";// state of relay25
              relay26state = "off";// state of relay26
              relay27state = "off";// state of relay27
              relay28state = "off";// state of relay28
              relay29state = "off";// state of relay29
              relay30state = "off";// state of relay30
              relay31state = "off";// state of relay31
              pcf8574_R4.digitalWrite(P7, HIGH);   */
          client.print("<!DOCTYPE HTML>\r\n");
          client.print("<html>\r\n");
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state );
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A16 Ethernet Web Server</h1>");
            if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">1-ON</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">1-OFF</button></a>");
            if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">2-ON</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">2-OFF</button></a>");
            if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">3-ON</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">3-OFF</button></a>");
            if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">4-ON</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">4-OFF</button></a>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">5-ON</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">5-OFF</button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">6-ON</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">6-OFF</button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">7-ON</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">7-OFF</button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">8-ON</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">8-OFF</button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">9-ON</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">9-OFF</button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-ON</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-OFF</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-ON</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-OFF</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-ON</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-OFF</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-ON</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-OFF</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-ON</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-OFF</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-ON</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-OFF</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-ON</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-OFF</button></a>");
        /*    if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-ON</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-OFF</button></a>");
            if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-ON</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-OFF</button></a>");
            if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-ON</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-OFF</button></a>");
            if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-ON</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-OFF</button></a>");
            if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-ON</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-OFF</button></a>");
            if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-ON</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-OFF</button></a>");
            if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-ON</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-OFF</button></a>");
            if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-ON</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-OFF</button></a>");
            if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-ON</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-OFF</button></a>");
            if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-ON</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-OFF</button></a>");
            if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-ON</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-OFF</button></a>");
            if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-ON</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-OFF</button></a>");
            if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-ON</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-OFF</button></a>");
            if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-ON</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-OFF</button></a>");
            if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-ON</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-OFF</button></a>");
            if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-ON</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-OFF</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
  if(pcf8574_I1.digitalRead(P0) == LOW)         //key1 pressed
    delay(20);                        //anti-interference
    if(pcf8574_I1.digitalRead(P0) == LOW)       //key1 pressed again
      pcf8574_R1.digitalWrite(P0,!pcf8574_R1.digitalRead(P0));    // toggle relay1 state
      while(pcf8574_I1.digitalRead(P0) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P0) == LOW) relay1state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P1) == LOW)         //key2 pressed
    if(pcf8574_I1.digitalRead(P1) == LOW)       //key2 pressed again
      pcf8574_R1.digitalWrite(P1,!pcf8574_R1.digitalRead(P1));    // toggle relay2 state
      while(pcf8574_I1.digitalRead(P1) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P1) == LOW) relay2state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P2) == LOW)         //key3 pressed
    if(pcf8574_I1.digitalRead(P2) == LOW)       //key3 pressed again
      pcf8574_R1.digitalWrite(P2,!pcf8574_R1.digitalRead(P2));    // toggle relay3 state
      while(pcf8574_I1.digitalRead(P2) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P2) == LOW) relay3state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P3) == LOW)         //key4 pressed
    if(pcf8574_I1.digitalRead(P3) == LOW)       //key4 pressed again
      pcf8574_R1.digitalWrite(P3,!pcf8574_R1.digitalRead(P3));    // toggle relay4 state
      while(pcf8574_I1.digitalRead(P3) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P3) == LOW) relay4state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P4) == LOW)         //key5 pressed
    if(pcf8574_I1.digitalRead(P4) == LOW)       //key5 pressed again
      pcf8574_R1.digitalWrite(P4,!pcf8574_R1.digitalRead(P4));    // toggle relay5 state
      while(pcf8574_I1.digitalRead(P4) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P4) == LOW) relay5state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P5) == LOW)         //key6 pressed
    if(pcf8574_I1.digitalRead(P5) == LOW)       //key6 pressed again
      pcf8574_R1.digitalWrite(P5,!pcf8574_R1.digitalRead(P5));    // toggle relay6 state
      while(pcf8574_I1.digitalRead(P5) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P5) == LOW) relay6state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P6) == LOW)         //key7 pressed
    if(pcf8574_I1.digitalRead(P6) == LOW)       //key7 pressed again
      pcf8574_R1.digitalWrite(P6,!pcf8574_R1.digitalRead(P6));    // toggle relay7 state
      while(pcf8574_I1.digitalRead(P6) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P6) == LOW) relay7state= "on"; else relay1state= "off";
  if(pcf8574_I1.digitalRead(P7) == LOW)         //key8 pressed
    if(pcf8574_I1.digitalRead(P7) == LOW)       //key8 pressed again
      pcf8574_R1.digitalWrite(P7,!pcf8574_R1.digitalRead(P7));    // toggle relay8 state
      while(pcf8574_I1.digitalRead(P7) == LOW); //wait remove hand
      if (pcf8574_R1.digitalRead(P7) == LOW) relay8state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P0) == LOW)         //key9 pressed
    if(pcf8574_I2.digitalRead(P0) == LOW)       //key9 pressed again
      pcf8574_R2.digitalWrite(P0,!pcf8574_R2.digitalRead(P0));    // toggle relay9 state
      while(pcf8574_I2.digitalRead(P0) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P0) == LOW) relay9state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P1) == LOW)         //key10 pressed
    if(pcf8574_I2.digitalRead(P1) == LOW)       //key10 pressed again
      pcf8574_R2.digitalWrite(P1,!pcf8574_R2.digitalRead(P1));    // toggle relay10 state
      while(pcf8574_I2.digitalRead(P1) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P1) == LOW) relay10state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P2) == LOW)         //key11 pressed
    if(pcf8574_I2.digitalRead(P2) == LOW)       //key11 pressed again
      pcf8574_R2.digitalWrite(P2,!pcf8574_R2.digitalRead(P2));    // toggle relay11 state
      while(pcf8574_I2.digitalRead(P2) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P2) == LOW) relay11state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P3) == LOW)         //key12 pressed
    if(pcf8574_I2.digitalRead(P3) == LOW)       //key12 pressed again
      pcf8574_R2.digitalWrite(P3,!pcf8574_R2.digitalRead(P3));    // toggle relay12 state
      while(pcf8574_I2.digitalRead(P3) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P3) == LOW) relay12state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P4) == LOW)         //key13 pressed
    if(pcf8574_I2.digitalRead(P4) == LOW)       //key13 pressed again
      pcf8574_R2.digitalWrite(P4,!pcf8574_R2.digitalRead(P4));    // toggle relay13 state
      while(pcf8574_I2.digitalRead(P4) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P4) == LOW) relay13state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P5) == LOW)         //key14 pressed
    if(pcf8574_I2.digitalRead(P5) == LOW)       //key14 pressed again
      pcf8574_R2.digitalWrite(P5,!pcf8574_R2.digitalRead(P5));    // toggle relay14 state
      while(pcf8574_I2.digitalRead(P5) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P5) == LOW) relay14state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P6) == LOW)         //key15 pressed
    if(pcf8574_I2.digitalRead(P6) == LOW)       //key15 pressed again
      pcf8574_R2.digitalWrite(P6,!pcf8574_R2.digitalRead(P6));    // toggle relay15 state
      while(pcf8574_I2.digitalRead(P6) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P6) == LOW) relay15state= "on"; else relay1state= "off";
  if(pcf8574_I2.digitalRead(P7) == LOW)         //key16 pressed
    if(pcf8574_I2.digitalRead(P7) == LOW)       //key16 pressed again
      pcf8574_R2.digitalWrite(P7,!pcf8574_R2.digitalRead(P7));    // toggle relay16 state
      while(pcf8574_I2.digitalRead(P7) == LOW); //wait remove hand
      if (pcf8574_R2.digitalRead(P7) == LOW) relay16state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P0) == LOW)         //key17 pressed
    if(pcf8574_I3.digitalRead(P0) == LOW)       //key17 pressed again
      pcf8574_R3.digitalWrite(P0,!pcf8574_R3.digitalRead(P0));    // toggle relay17 state
      while(pcf8574_I3.digitalRead(P0) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P0) == LOW) relay17state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P1) == LOW)         //key18 pressed
    if(pcf8574_I3.digitalRead(P1) == LOW)       //key18 pressed again
      pcf8574_R3.digitalWrite(P1,!pcf8574_R3.digitalRead(P1));    // toggle relay18 state
      while(pcf8574_I3.digitalRead(P1) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P1) == LOW) relay18state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P2) == LOW)         //key19 pressed
    if(pcf8574_I3.digitalRead(P2) == LOW)       //key19 pressed again
      pcf8574_R3.digitalWrite(P2,!pcf8574_R3.digitalRead(P2));    // toggle relay19 state
      while(pcf8574_I3.digitalRead(P2) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P2) == LOW) relay19state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P3) == LOW)         //key20 pressed
    if(pcf8574_I3.digitalRead(P3) == LOW)       //key20 pressed again
      pcf8574_R3.digitalWrite(P3,!pcf8574_R3.digitalRead(P3));    // toggle relay20 state
      while(pcf8574_I3.digitalRead(P3) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P3) == LOW) relay20state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P4) == LOW)         //key21 pressed
    if(pcf8574_I3.digitalRead(P4) == LOW)       //key21 pressed again
      pcf8574_R3.digitalWrite(P4,!pcf8574_R3.digitalRead(P4));    // toggle relay21 state
      while(pcf8574_I3.digitalRead(P4) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P4) == LOW) relay21state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P5) == LOW)         //key22 pressed
    if(pcf8574_I3.digitalRead(P5) == LOW)       //key22 pressed again
      pcf8574_R3.digitalWrite(P5,!pcf8574_R3.digitalRead(P5));    // toggle relay22 state
      while(pcf8574_I3.digitalRead(P5) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P5) == LOW) relay22state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P6) == LOW)         //key23 pressed
    if(pcf8574_I3.digitalRead(P6) == LOW)       //key23 pressed again
      pcf8574_R3.digitalWrite(P6,!pcf8574_R3.digitalRead(P6));    // toggle relay23 state
      while(pcf8574_I3.digitalRead(P6) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P6) == LOW) relay23state= "on"; else relay1state= "off";
  if(pcf8574_I3.digitalRead(P7) == LOW)         //key24 pressed
    if(pcf8574_I3.digitalRead(P7) == LOW)       //key24 pressed again
      pcf8574_R3.digitalWrite(P7,!pcf8574_R3.digitalRead(P7));    // toggle relay24 state
      while(pcf8574_I3.digitalRead(P7) == LOW); //wait remove hand
      if (pcf8574_R3.digitalRead(P7) == LOW) relay24state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P0) == LOW)         //key25 pressed
    if(pcf8574_I4.digitalRead(P0) == LOW)       //key25 pressed again
      pcf8574_R4.digitalWrite(P0,!pcf8574_R4.digitalRead(P0));    // toggle relay25 state
      while(pcf8574_I4.digitalRead(P0) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P0) == LOW) relay25state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P1) == LOW)         //key26 pressed
    if(pcf8574_I4.digitalRead(P1) == LOW)       //key26 pressed again
      pcf8574_R4.digitalWrite(P1,!pcf8574_R4.digitalRead(P1));    // toggle relay26 state
      while(pcf8574_I4.digitalRead(P1) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P1) == LOW) relay26state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P2) == LOW)         //key27 pressed
    if(pcf8574_I4.digitalRead(P2) == LOW)       //key27 pressed again
      pcf8574_R4.digitalWrite(P2,!pcf8574_R4.digitalRead(P2));    // toggle relay27 state
      while(pcf8574_I4.digitalRead(P2) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P2) == LOW) relay27state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P3) == LOW)         //key28 pressed
    if(pcf8574_I4.digitalRead(P3) == LOW)       //key28 pressed again
      pcf8574_R4.digitalWrite(P3,!pcf8574_R4.digitalRead(P3));    // toggle relay28 state
      while(pcf8574_I4.digitalRead(P3) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P3) == LOW) relay28state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P4) == LOW)         //key29 pressed
    if(pcf8574_I4.digitalRead(P4) == LOW)       //key29 pressed again
      pcf8574_R4.digitalWrite(P4,!pcf8574_R4.digitalRead(P4));    // toggle relay29 state
      while(pcf8574_I4.digitalRead(P4) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P4) == LOW) relay29state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P5) == LOW)         //key30 pressed
    if(pcf8574_I4.digitalRead(P5) == LOW)       //key30 pressed again
      pcf8574_R4.digitalWrite(P5,!pcf8574_R4.digitalRead(P5));    // toggle relay30 state
      while(pcf8574_I4.digitalRead(P5) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P5) == LOW) relay30state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P6) == LOW)         //key31 pressed
    if(pcf8574_I4.digitalRead(P6) == LOW)       //key31 pressed again
      pcf8574_R4.digitalWrite(P6,!pcf8574_R4.digitalRead(P6));    // toggle relay31 state
      while(pcf8574_I4.digitalRead(P6) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P6) == LOW) relay31state= "on"; else relay1state= "off";
  if(pcf8574_I4.digitalRead(P7) == LOW)         //key32 pressed
    if(pcf8574_I4.digitalRead(P7) == LOW)       //key32 pressed again
      pcf8574_R4.digitalWrite(P7,!pcf8574_R4.digitalRead(P7));    // toggle relay32 state
      while(pcf8574_I4.digitalRead(P7) == LOW); //wait remove hand
      if (pcf8574_R4.digitalRead(P7) == LOW) relay32state= "on"; else relay1state= "off";
  [Arduino IDE demo source code for KC868-A8S]--#16-KC868-A8S_Ethernet_Web_server_code
Posted by: KinCony Support - 09-05-2022, 03:30 AM - Forum: KC868-A8S - No Replies
.zip   KC868-A8S_Web_Server-ETH.zip (Size: 471.57 KB / Downloads: 1020)
* Create Your own WebServer for KC868-A8S Smart Controller*
// Current time
// Previous time
int flag_read_di=0;
String header;
//set I2C of A8S
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
String relaystate[8]={"relay1state","relay2state","relay3state","relay4state",
void ScanKey()
        delay(20);
  pcf8574_R1.begin();
    pcf8574_I1.begin();
   while (!Serial);
  server.begin();
void loop(){
        header += c;
            client.println();
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px auto;text-align: center;font-size: 10px;}");
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8S Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
  [Arduino IDE demo source code for KC868-A8]--#11-Ethernet_Web server_code
Posted by: KinCony Support - 09-05-2022, 03:12 AM - Forum: KC868-A8 - Replies (6)
.zip   KC868-A8_Web_Server-ETH.zip (Size: 33.43 MB / Downloads: 1361)
* Create Your own WebServer for KC868-A8 Smart Controller*
// Current time
// Previous time
int flag_read_di=0;
String header;
//set I2C of A8
void ScanKey()
        delay(20);
  pcf8574_R1.begin();
    pcf8574_I1.begin();
   while (!Serial);
  server.begin();
void loop(){
        header += c;
            client.println();
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8 Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
  [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server
Posted by: admin - 09-02-2022, 11:24 PM - Forum: KC868-A32/A32 Pro - Replies (16)
this arduino source code is web server use for Ethernet via KC868-A32
digital input can trigger relay output. just connect with ethernet cable
.zip   KC868-A32_Web_Server - ETH.zip (Size: 478.62 KB / Downloads: 1080)
// Current time
// Previous time
int flag_read_di=0;
String header;
PCF8574 pcf8574_R1(&I2Ctwo, 0x24, 15, 13);
PCF8574 pcf8574_R2(&I2Ctwo, 0x25, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x24, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x25, 4, 5);
String relaystate[32]={
  "relay17state","relay18state","relay19state","relay20state","relay21state","relay22state","relay23state","relay24state",
  "relay25state","relay26state","relay27state","relay18state","relay296state","relay30state","relay31state","relay32state",
     pcf8574_R3.pinMode(i, OUTPUT);
     pcf8574_R4.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
  pcf8574_R3.begin();
  pcf8574_R4.begin();
  for(int i=0;i<=7;i++){
  pcf8574_I3.pinMode(i, INPUT);
  pcf8574_I4.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
pcf8574_I3.begin();
pcf8574_I4.begin();
    pcf8574_R3.digitalWrite(i, HIGH);
    pcf8574_R4.digitalWrite(i, HIGH);
while (!Serial);
  server.begin();
void loop(){
        header += c;
            client.println();
               /* for(int i=0;i<32;i++)
                relaystate[i]="on";
              relay18state = "on";// state of relay2
              relay19state = "on";// state of relay3
              relay20state = "on";// state of relay4
              relay21state = "on";// state of relay5
              relay22state = "on";// state of relay6
              relay23state = "on";// state of relay7
              relay24state = "on";// state of relay8
              relay25state = "on";// state of relay9
              relay26state = "on";// state of relay10
              relay27state = "on";// state of relay11
              relay28state = "on";// state of relay12
              relay29state = "on";// state of relay13
              relay30state = "on";// state of relay14
              relay31state = "on";// state of relay15
              relay32state = "on";// state of relay16
                 pcf8574_R1.digitalWrite(i,LOW);
                 pcf8574_R2.digitalWrite(i,LOW);
                 pcf8574_R3.digitalWrite(i,LOW);
                 pcf8574_R4.digitalWrite(i,LOW);
              /*for(int i=0;i<32;i++)
                relaystate[i]="off";
              relay18state = "off";// state of relay2
              relay19state = "off";// state of relay3
              relay20state = "off";// state of relay4
              relay21state = "off";// state of relay5
              relay22state = "off";// state of relay6
              relay23state = "off";// state of relay7
              relay24state = "off";// state of relay8
              relay25state = "off";// state of relay9
              relay26state = "off";// state of relay10
              relay27state = "off";// state of relay11
              relay28state = "off";// state of relay12
              relay29state = "off";// state of relay13
              relay30state = "off";// state of relay14
              relay31state = "off";// state of relay15
              relay32state = "off";// state of relay16
            //client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            //client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button { background-color: #195B10; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 35px; margin: 2px; cursor: pointer;}");
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state + " relay17:" + relay17state + " relay18:" + relay18state + " relay19:" + relay19state + " relay20:" + relay20state + " relay21:" + relay21state + " relay22:" + relay22state + " relay23:" + relay23state + " relay24:" + relay24state + " relay25:" + relay25state + " relay26:" + relay26state + " relay27:" + relay27state + " relay28:" + relay28state + " relay29:" + relay29state + " relay30:" + relay30state + " relay31:" + relay31state + " relay32:" + relay32state);
            else
            // Web Page Heading
           client.println("<body><h1>KC868-A32 Web Server</h1>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
            if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-OFF</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-ON</button></a>");
            if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-OFF</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-ON</button></a>");
            if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-OFF</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-ON</button></a>");
            if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-OFF</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-ON</button></a>");
            if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-OFF</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-ON</button></a>");
            if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-OFF</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-ON</button></a>");
            if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-OFF</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-ON</button></a>");
            if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-OFF</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-ON</button></a>");
            if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-OFF</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-ON</button></a>");
            if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-OFF</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-ON</button></a>");
            if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-OFF</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-ON</button></a>");
            if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-OFF</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-ON</button></a>");
            if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-OFF</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-ON</button></a>");
            if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-OFF</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-ON</button></a>");
            if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-OFF</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-ON</button></a>");
            if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-OFF</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-ON</button></a>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
    if(pcf8574_I2.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(i,!pcf8574_R2.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(i) == LOW) relaystate[i+9]="on";else relaystate[i+9]="off";
    if(pcf8574_I3.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I3.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R3.digitalWrite(i,!pcf8574_R3.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I3.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R3.digitalRead(i) == LOW) relaystate[i+17]="on";else relaystate[i+17]="off";
    if(pcf8574_I4.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I4.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R4.digitalWrite(i,!pcf8574_R4.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I4.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R4.digitalRead(i) == LOW) relaystate[i+25]="on";else relaystate[i+25]="off";
  [Arduino demo source code for KC868-A4]-16 homekit with DS18B20 temperature sensor
Posted by: admin - 09-02-2022, 01:13 PM - Forum: KC868-A4 - Replies (2)
here is source code used by homespan library and onewire library.
.zip   KC868-A4-HomeKit-DS18B20.zip (Size: 3.23 KB / Downloads: 1090)
apple homekit pair code
  alexa
Posted by: davesmithr1 - 09-01-2022, 02:58 PM - Forum: KC868-A16 - Replies (1)
hi, im looking to set this up to work with alexa and is there an app for these, also i want to web browse to it for setup so what is the ip address and login?
  KC868-A16 work with KC868-E16
Posted by: admin - 08-30-2022, 11:34 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
