» Members: 9,584
» Latest member: soicauxsmbioo
» Forum threads: 4,191
» Forum posts: 20,830
There are currently 53 online users.
» 0 Member(s) | 45 Guest(s)
Amazonbot, Applebot, Baidu, Google, bot
N60 Sensor channel label
Forum: N60
Today, 01:50 AM
» Replies: 17
solar production and cons...
Forum: N30
Today, 01:46 AM
Current direction detecti...
Forum: N30
Today, 01:44 AM
MQTT Discovery: missing s...
Forum: N30
Yesterday, 02:48 PM
ai automation
Forum: KinCony integrate with Loxone home automation
Last Post: mediverticals
Yesterday, 06:56 AM
Connecting sensors to Kin...
Forum: F16
Yesterday, 12:18 AM
CT Sensor Direction
Forum: N60
08-12-2026, 08:14 AM
N60 Voltage reference
Forum: N60
08-11-2026, 11:09 PM
4-20mA loop voltage consi...
Forum: B4M
08-11-2026, 08:05 AM
K868-a32 plastic case
08-10-2026, 08:48 AM
  [Arduino IDE demo source code for KC868-A128]--#04--LAN8720 code
Posted by: KinCony Support - 08-05-2022, 02:13 AM - Forum: KC868-A128 - No Replies
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
IPAddress local_ip(192, 168, 123, 200);
IPAddress gateway(192, 168, 123, 1);
IPAddress dns(192, 168, 123, 1);
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
  [Arduino IDE demo source code for KC868-A128]--#03--PCF8575-DO code
Posted by: KinCony Support - 08-05-2022, 02:11 AM - Forum: KC868-A128 - Replies (2)
#include "Arduino.h"
#include "PCF8575.h"
// Set i2c address
PCF8575 pcf8575_R1(0x24,5,16);
PCF8575 pcf8575_R2(0x25,5,16);
PCF8575 pcf8575_R3(0x21,5,16);
PCF8575 pcf8575_R4(0x22,5,16);
PCF8575 pcf8575_R5(0x26,5,16);
PCF8575 pcf8575_R6(0x27,5,16);
PCF8575 pcf8575_R7(0x20,5,16);
PCF8575 pcf8575_R8(0x23,5,16);
unsigned long timeElapsed;
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  pcf8575_R3.begin();
  pcf8575_R4.begin();
  pcf8575_R5.begin();
  pcf8575_R6.begin();
  pcf8575_R7.begin();
  pcf8575_R8.begin();
pcf8575_R1.pinMode(P0,OUTPUT);
pcf8575_R1.pinMode(P1,OUTPUT);
pcf8575_R1.pinMode(P2,OUTPUT);
pcf8575_R1.pinMode(P3,OUTPUT);
pcf8575_R1.pinMode(P4,OUTPUT);
pcf8575_R1.pinMode(P5,OUTPUT);
pcf8575_R1.pinMode(P6,OUTPUT);
pcf8575_R1.pinMode(P7,OUTPUT);
pcf8575_R1.pinMode(P8,OUTPUT);
pcf8575_R1.pinMode(P9,OUTPUT);
pcf8575_R1.pinMode(P10,OUTPUT);
pcf8575_R1.pinMode(P11,OUTPUT);
pcf8575_R1.pinMode(P12,OUTPUT);
pcf8575_R1.pinMode(P13,OUTPUT);
pcf8575_R1.pinMode(P14,OUTPUT);
pcf8575_R1.pinMode(P15,OUTPUT);
pcf8575_R2.pinMode(P0,OUTPUT);
pcf8575_R2.pinMode(P1,OUTPUT);
pcf8575_R2.pinMode(P2,OUTPUT);
pcf8575_R2.pinMode(P3,OUTPUT);
pcf8575_R2.pinMode(P4,OUTPUT);
pcf8575_R2.pinMode(P5,OUTPUT);
pcf8575_R2.pinMode(P6,OUTPUT);
pcf8575_R2.pinMode(P7,OUTPUT);
pcf8575_R2.pinMode(P8,OUTPUT);
pcf8575_R2.pinMode(P9,OUTPUT);
pcf8575_R2.pinMode(P10,OUTPUT);
pcf8575_R2.pinMode(P11,OUTPUT);
pcf8575_R2.pinMode(P12,OUTPUT);
pcf8575_R2.pinMode(P13,OUTPUT);
pcf8575_R2.pinMode(P14,OUTPUT);
pcf8575_R2.pinMode(P15,OUTPUT);
pcf8575_R3.pinMode(P0,OUTPUT);
pcf8575_R3.pinMode(P1,OUTPUT);
pcf8575_R3.pinMode(P2,OUTPUT);
pcf8575_R3.pinMode(P3,OUTPUT);
pcf8575_R3.pinMode(P4,OUTPUT);
pcf8575_R3.pinMode(P5,OUTPUT);
pcf8575_R3.pinMode(P6,OUTPUT);
pcf8575_R3.pinMode(P7,OUTPUT);
pcf8575_R3.pinMode(P8,OUTPUT);
pcf8575_R3.pinMode(P9,OUTPUT);
pcf8575_R3.pinMode(P10,OUTPUT);
pcf8575_R3.pinMode(P11,OUTPUT);
pcf8575_R3.pinMode(P12,OUTPUT);
pcf8575_R3.pinMode(P13,OUTPUT);
pcf8575_R3.pinMode(P14,OUTPUT);
pcf8575_R3.pinMode(P15,OUTPUT);
pcf8575_R4.pinMode(P0,OUTPUT);
pcf8575_R4.pinMode(P1,OUTPUT);
pcf8575_R4.pinMode(P2,OUTPUT);
pcf8575_R4.pinMode(P3,OUTPUT);
pcf8575_R4.pinMode(P4,OUTPUT);
pcf8575_R4.pinMode(P5,OUTPUT);
pcf8575_R4.pinMode(P6,OUTPUT);
pcf8575_R4.pinMode(P7,OUTPUT);
pcf8575_R4.pinMode(P8,OUTPUT);
pcf8575_R4.pinMode(P9,OUTPUT);
pcf8575_R4.pinMode(P10,OUTPUT);
pcf8575_R4.pinMode(P11,OUTPUT);
pcf8575_R4.pinMode(P12,OUTPUT);
pcf8575_R4.pinMode(P13,OUTPUT);
pcf8575_R4.pinMode(P14,OUTPUT);
pcf8575_R4.pinMode(P15,OUTPUT);
pcf8575_R5.pinMode(P0,OUTPUT);
pcf8575_R5.pinMode(P1,OUTPUT);
pcf8575_R5.pinMode(P2,OUTPUT);
pcf8575_R5.pinMode(P3,OUTPUT);
pcf8575_R5.pinMode(P4,OUTPUT);
pcf8575_R5.pinMode(P5,OUTPUT);
pcf8575_R5.pinMode(P6,OUTPUT);
pcf8575_R5.pinMode(P7,OUTPUT);
pcf8575_R5.pinMode(P8,OUTPUT);
pcf8575_R5.pinMode(P9,OUTPUT);
pcf8575_R5.pinMode(P10,OUTPUT);
pcf8575_R5.pinMode(P11,OUTPUT);
pcf8575_R5.pinMode(P12,OUTPUT);
pcf8575_R5.pinMode(P13,OUTPUT);
pcf8575_R5.pinMode(P14,OUTPUT);
pcf8575_R5.pinMode(P15,OUTPUT);
pcf8575_R6.pinMode(P0,OUTPUT);
pcf8575_R6.pinMode(P1,OUTPUT);
pcf8575_R6.pinMode(P2,OUTPUT);
pcf8575_R6.pinMode(P3,OUTPUT);
pcf8575_R6.pinMode(P4,OUTPUT);
pcf8575_R6.pinMode(P5,OUTPUT);
pcf8575_R6.pinMode(P6,OUTPUT);
pcf8575_R6.pinMode(P7,OUTPUT);
pcf8575_R6.pinMode(P8,OUTPUT);
pcf8575_R6.pinMode(P9,OUTPUT);
pcf8575_R6.pinMode(P10,OUTPUT);
pcf8575_R6.pinMode(P11,OUTPUT);
pcf8575_R6.pinMode(P12,OUTPUT);
pcf8575_R6.pinMode(P13,OUTPUT);
pcf8575_R6.pinMode(P14,OUTPUT);
pcf8575_R6.pinMode(P15,OUTPUT);
pcf8575_R7.pinMode(P0,OUTPUT);
pcf8575_R7.pinMode(P1,OUTPUT);
pcf8575_R7.pinMode(P2,OUTPUT);
pcf8575_R7.pinMode(P3,OUTPUT);
pcf8575_R7.pinMode(P4,OUTPUT);
pcf8575_R7.pinMode(P5,OUTPUT);
pcf8575_R7.pinMode(P6,OUTPUT);
pcf8575_R7.pinMode(P7,OUTPUT);
pcf8575_R7.pinMode(P8,OUTPUT);
pcf8575_R7.pinMode(P9,OUTPUT);
pcf8575_R7.pinMode(P10,OUTPUT);
pcf8575_R7.pinMode(P11,OUTPUT);
pcf8575_R7.pinMode(P12,OUTPUT);
pcf8575_R7.pinMode(P13,OUTPUT);
pcf8575_R7.pinMode(P14,OUTPUT);
pcf8575_R7.pinMode(P15,OUTPUT);
pcf8575_R8.pinMode(P0,OUTPUT);
pcf8575_R8.pinMode(P1,OUTPUT);
pcf8575_R8.pinMode(P2,OUTPUT);
pcf8575_R8.pinMode(P3,OUTPUT);
pcf8575_R8.pinMode(P4,OUTPUT);
pcf8575_R8.pinMode(P5,OUTPUT);
pcf8575_R8.pinMode(P6,OUTPUT);
pcf8575_R8.pinMode(P7,OUTPUT);
pcf8575_R8.pinMode(P8,OUTPUT);
pcf8575_R8.pinMode(P9,OUTPUT);
pcf8575_R8.pinMode(P10,OUTPUT);
pcf8575_R8.pinMode(P11,OUTPUT);
pcf8575_R8.pinMode(P12,OUTPUT);
pcf8575_R8.pinMode(P13,OUTPUT);
pcf8575_R8.pinMode(P14,OUTPUT);
pcf8575_R8.pinMode(P15,OUTPUT);
//R1 LOW----------------------
pcf8575_R1.digitalWrite(P0,LOW);
delay(50);
pcf8575_R1.digitalWrite(P1,LOW);
delay(50);
pcf8575_R1.digitalWrite(P2,LOW);
delay(50);
pcf8575_R1.digitalWrite(P3,LOW);
delay(50);
pcf8575_R1.digitalWrite(P4,LOW);
delay(50);
pcf8575_R1.digitalWrite(P5,LOW);
delay(50);
pcf8575_R1.digitalWrite(P6,LOW);
delay(50);
pcf8575_R1.digitalWrite(P7,LOW);
delay(50);
pcf8575_R1.digitalWrite(P8,LOW);
delay(50);
pcf8575_R1.digitalWrite(P9,LOW);
delay(50);
pcf8575_R1.digitalWrite(P10,LOW);
delay(50);
pcf8575_R1.digitalWrite(P11,LOW);
delay(50);
pcf8575_R1.digitalWrite(P12,LOW);
delay(50);
pcf8575_R1.digitalWrite(P13,LOW);
delay(50);
pcf8575_R1.digitalWrite(P14,LOW);
delay(50);
pcf8575_R1.digitalWrite(P15,LOW);
delay(50);
//R2 LOW------------------------
pcf8575_R2.digitalWrite(P0,LOW);
delay(50);
pcf8575_R2.digitalWrite(P1,LOW);
delay(50);
pcf8575_R2.digitalWrite(P2,LOW);
delay(50);
pcf8575_R2.digitalWrite(P3,LOW);
delay(50);
pcf8575_R2.digitalWrite(P4,LOW);
delay(50);
pcf8575_R2.digitalWrite(P5,LOW);
delay(50);
pcf8575_R2.digitalWrite(P6,LOW);
delay(50);
pcf8575_R2.digitalWrite(P7,LOW);
delay(50);
pcf8575_R2.digitalWrite(P8,LOW);
delay(50);
pcf8575_R2.digitalWrite(P9,LOW);
delay(50);
pcf8575_R2.digitalWrite(P10,LOW);
delay(50);
pcf8575_R2.digitalWrite(P11,LOW);
delay(50);
pcf8575_R2.digitalWrite(P12,LOW);
delay(50);
pcf8575_R2.digitalWrite(P13,LOW);
delay(50);
pcf8575_R2.digitalWrite(P14,LOW);
delay(50);
pcf8575_R2.digitalWrite(P15,LOW);
delay(50);
//R3 LOW------------------------
pcf8575_R3.digitalWrite(P0,LOW);
delay(50);
pcf8575_R3.digitalWrite(P1,LOW);
delay(50);
pcf8575_R3.digitalWrite(P2,LOW);
delay(50);
pcf8575_R3.digitalWrite(P3,LOW);
delay(50);
pcf8575_R3.digitalWrite(P4,LOW);
delay(50);
pcf8575_R3.digitalWrite(P5,LOW);
delay(50);
pcf8575_R3.digitalWrite(P6,LOW);
delay(50);
pcf8575_R3.digitalWrite(P7,LOW);
delay(50);
pcf8575_R3.digitalWrite(P8,LOW);
delay(50);
pcf8575_R3.digitalWrite(P9,LOW);
delay(50);
pcf8575_R3.digitalWrite(P10,LOW);
delay(50);
pcf8575_R3.digitalWrite(P11,LOW);
delay(50);
pcf8575_R3.digitalWrite(P12,LOW);
delay(50);
pcf8575_R3.digitalWrite(P13,LOW);
delay(50);
pcf8575_R3.digitalWrite(P14,LOW);
delay(50);
pcf8575_R3.digitalWrite(P15,LOW);
delay(50);
//R4 LOW------------------------
pcf8575_R4.digitalWrite(P0,LOW);
delay(50);
pcf8575_R4.digitalWrite(P1,LOW);
delay(50);
pcf8575_R4.digitalWrite(P2,LOW);
delay(50);
pcf8575_R4.digitalWrite(P3,LOW);
delay(50);
pcf8575_R4.digitalWrite(P4,LOW);
delay(50);
pcf8575_R4.digitalWrite(P5,LOW);
delay(50);
pcf8575_R4.digitalWrite(P6,LOW);
delay(50);
pcf8575_R4.digitalWrite(P7,LOW);
delay(50);
pcf8575_R4.digitalWrite(P8,LOW);
delay(50);
pcf8575_R4.digitalWrite(P9,LOW);
delay(50);
pcf8575_R4.digitalWrite(P10,LOW);
delay(50);
pcf8575_R4.digitalWrite(P11,LOW);
delay(50);
pcf8575_R4.digitalWrite(P12,LOW);
delay(50);
pcf8575_R4.digitalWrite(P13,LOW);
delay(50);
pcf8575_R4.digitalWrite(P14,LOW);
delay(50);
pcf8575_R4.digitalWrite(P15,LOW);
delay(50);
//R5 LOW----------------------
pcf8575_R5.digitalWrite(P0,LOW);
delay(50);
pcf8575_R5.digitalWrite(P1,LOW);
delay(50);
pcf8575_R5.digitalWrite(P2,LOW);
delay(50);
pcf8575_R5.digitalWrite(P3,LOW);
delay(50);
pcf8575_R5.digitalWrite(P4,LOW);
delay(50);
pcf8575_R5.digitalWrite(P5,LOW);
delay(50);
pcf8575_R5.digitalWrite(P6,LOW);
delay(50);
pcf8575_R5.digitalWrite(P7,LOW);
delay(50);
pcf8575_R5.digitalWrite(P8,LOW);
delay(50);
pcf8575_R5.digitalWrite(P9,LOW);
delay(50);
pcf8575_R5.digitalWrite(P10,LOW);
delay(50);
pcf8575_R5.digitalWrite(P11,LOW);
delay(50);
pcf8575_R5.digitalWrite(P12,LOW);
delay(50);
pcf8575_R5.digitalWrite(P13,LOW);
delay(50);
pcf8575_R5.digitalWrite(P14,LOW);
delay(50);
pcf8575_R5.digitalWrite(P15,LOW);
delay(50);
//R6 LOW------------------------
pcf8575_R6.digitalWrite(P0,LOW);
delay(50);
pcf8575_R6.digitalWrite(P1,LOW);
delay(50);
pcf8575_R6.digitalWrite(P2,LOW);
delay(50);
pcf8575_R6.digitalWrite(P3,LOW);
delay(50);
pcf8575_R6.digitalWrite(P4,LOW);
delay(50);
pcf8575_R6.digitalWrite(P5,LOW);
delay(50);
pcf8575_R6.digitalWrite(P6,LOW);
delay(50);
pcf8575_R6.digitalWrite(P7,LOW);
delay(50);
pcf8575_R6.digitalWrite(P8,LOW);
delay(50);
pcf8575_R6.digitalWrite(P9,LOW);
delay(50);
pcf8575_R6.digitalWrite(P10,LOW);
delay(50);
pcf8575_R6.digitalWrite(P11,LOW);
delay(50);
pcf8575_R6.digitalWrite(P12,LOW);
delay(50);
pcf8575_R6.digitalWrite(P13,LOW);
delay(50);
pcf8575_R6.digitalWrite(P14,LOW);
delay(50);
pcf8575_R6.digitalWrite(P15,LOW);
delay(50);
//R7 LOW------------------------
pcf8575_R7.digitalWrite(P0,LOW);
delay(50);
pcf8575_R7.digitalWrite(P1,LOW);
delay(50);
pcf8575_R7.digitalWrite(P2,LOW);
delay(50);
pcf8575_R7.digitalWrite(P3,LOW);
delay(50);
pcf8575_R7.digitalWrite(P4,LOW);
delay(50);
pcf8575_R7.digitalWrite(P5,LOW);
delay(50);
pcf8575_R7.digitalWrite(P6,LOW);
delay(50);
pcf8575_R7.digitalWrite(P7,LOW);
delay(50);
pcf8575_R7.digitalWrite(P8,LOW);
delay(50);
pcf8575_R7.digitalWrite(P9,LOW);
delay(50);
pcf8575_R7.digitalWrite(P10,LOW);
delay(50);
pcf8575_R7.digitalWrite(P11,LOW);
delay(50);
pcf8575_R7.digitalWrite(P12,LOW);
delay(50);
pcf8575_R7.digitalWrite(P13,LOW);
delay(50);
pcf8575_R7.digitalWrite(P14,LOW);
delay(50);
pcf8575_R7.digitalWrite(P15,LOW);
delay(50);
//R8 LOW------------------------
pcf8575_R8.digitalWrite(P0,LOW);
delay(50);
pcf8575_R8.digitalWrite(P1,LOW);
delay(50);
pcf8575_R8.digitalWrite(P2,LOW);
delay(50);
pcf8575_R8.digitalWrite(P3,LOW);
delay(50);
pcf8575_R8.digitalWrite(P4,LOW);
delay(50);
pcf8575_R8.digitalWrite(P5,LOW);
delay(50);
pcf8575_R8.digitalWrite(P6,LOW);
delay(50);
pcf8575_R8.digitalWrite(P7,LOW);
delay(50);
pcf8575_R8.digitalWrite(P8,LOW);
delay(50);
pcf8575_R8.digitalWrite(P9,LOW);
delay(50);
pcf8575_R8.digitalWrite(P10,LOW);
delay(50);
pcf8575_R8.digitalWrite(P11,LOW);
delay(50);
pcf8575_R8.digitalWrite(P12,LOW);
delay(50);
pcf8575_R8.digitalWrite(P13,LOW);
delay(50);
pcf8575_R8.digitalWrite(P14,LOW);
delay(50);
pcf8575_R8.digitalWrite(P15,LOW);
delay(50);
//R1 HIGH-----------------------
pcf8575_R1.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R1.digitalWrite(P15,HIGH);
delay(50);
//R3 HIGH------------------------
pcf8575_R2.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R2.digitalWrite(P15,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R3.digitalWrite(P15,HIGH);
delay(50);
//R4 HIGH------------------------
pcf8575_R4.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R4.digitalWrite(P15,HIGH);
delay(100);
//R5 HIGH-----------------------
pcf8575_R5.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R5.digitalWrite(P15,HIGH);
delay(50);
//R6 HIGH------------------------
pcf8575_R6.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R6.digitalWrite(P15,HIGH);
delay(50);
//R7 HIGH-----------------------
pcf8575_R7.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R7.digitalWrite(P15,HIGH);
delay(50);
//R8 HIGH------------------------
pcf8575_R8.digitalWrite(P0,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P1,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P2,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P3,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P4,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P5,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P6,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P7,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P8,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P9,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P10,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P11,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P12,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P13,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P14,HIGH);
delay(50);
pcf8575_R8.digitalWrite(P15,HIGH);
delay(100);
  [Arduino IDE demo source code for KC868-A128]--#02--PCF8575-DI code
Posted by: KinCony Support - 08-05-2022, 02:09 AM - Forum: KC868-A128 - Replies (2)
// Set i2c address
PCF8575 pcf8575_IN1(0x24,15,4);
PCF8575 pcf8575_IN2(0x25,15,4);
PCF8575 pcf8575_IN3(0x21,15,4);
PCF8575 pcf8575_IN4(0x22,15,4);
PCF8575 pcf8575_IN5(0x26,15,4);
PCF8575 pcf8575_IN6(0x27,15,4);
PCF8575 pcf8575_IN7(0x20,15,4);
PCF8575 pcf8575_IN8(0x23,15,4);
  pcf8575_IN1.begin();
  pcf8575_IN2.begin();
  pcf8575_IN3.begin();
  pcf8575_IN4.begin();
  pcf8575_IN5.begin();
  pcf8575_IN6.begin();
  pcf8575_IN7.begin();
  pcf8575_IN8.begin();
  pcf8575_IN1.pinMode(P0,INPUT);
  pcf8575_IN1.pinMode(P1,INPUT);
  pcf8575_IN1.pinMode(P2,INPUT);
  pcf8575_IN1.pinMode(P3,INPUT);
  pcf8575_IN1.pinMode(P4,INPUT);
  pcf8575_IN1.pinMode(P5,INPUT);
  pcf8575_IN1.pinMode(P6,INPUT);
  pcf8575_IN1.pinMode(P7,INPUT);
  pcf8575_IN1.pinMode(P8,INPUT);
  pcf8575_IN1.pinMode(P9,INPUT);
  pcf8575_IN1.pinMode(P10,INPUT);
  pcf8575_IN1.pinMode(P11,INPUT);
  pcf8575_IN1.pinMode(P12,INPUT);
  pcf8575_IN1.pinMode(P13,INPUT);
  pcf8575_IN1.pinMode(P14,INPUT);
  pcf8575_IN1.pinMode(P15,INPUT);
  pcf8575_IN2.pinMode(P0,INPUT);
  pcf8575_IN2.pinMode(P1,INPUT);
  pcf8575_IN2.pinMode(P2,INPUT);
  pcf8575_IN2.pinMode(P3,INPUT);
  pcf8575_IN2.pinMode(P4,INPUT);
  pcf8575_IN2.pinMode(P5,INPUT);
  pcf8575_IN2.pinMode(P6,INPUT);
  pcf8575_IN2.pinMode(P7,INPUT);
  pcf8575_IN2.pinMode(P8,INPUT);
  pcf8575_IN2.pinMode(P9,INPUT);
  pcf8575_IN2.pinMode(P10,INPUT);
  pcf8575_IN2.pinMode(P11,INPUT);
  pcf8575_IN2.pinMode(P12,INPUT);
  pcf8575_IN2.pinMode(P13,INPUT);
  pcf8575_IN2.pinMode(P14,INPUT);
  pcf8575_IN2.pinMode(P15,INPUT);
  pcf8575_IN3.pinMode(P0,INPUT);
  pcf8575_IN3.pinMode(P1,INPUT);
  pcf8575_IN3.pinMode(P2,INPUT);
  pcf8575_IN3.pinMode(P3,INPUT);
  pcf8575_IN3.pinMode(P4,INPUT);
  pcf8575_IN3.pinMode(P5,INPUT);
  pcf8575_IN3.pinMode(P6,INPUT);
  pcf8575_IN3.pinMode(P7,INPUT);
  pcf8575_IN3.pinMode(P8,INPUT);
  pcf8575_IN3.pinMode(P9,INPUT);
  pcf8575_IN3.pinMode(P10,INPUT);
  pcf8575_IN3.pinMode(P11,INPUT);
  pcf8575_IN3.pinMode(P12,INPUT);
  pcf8575_IN3.pinMode(P13,INPUT);
  pcf8575_IN3.pinMode(P14,INPUT);
  pcf8575_IN3.pinMode(P15,INPUT);
  pcf8575_IN4.pinMode(P0,INPUT);
  pcf8575_IN4.pinMode(P1,INPUT);
  pcf8575_IN4.pinMode(P2,INPUT);
  pcf8575_IN4.pinMode(P3,INPUT);
  pcf8575_IN4.pinMode(P4,INPUT);
  pcf8575_IN4.pinMode(P5,INPUT);
  pcf8575_IN4.pinMode(P6,INPUT);
  pcf8575_IN4.pinMode(P7,INPUT);
  pcf8575_IN4.pinMode(P8,INPUT);
  pcf8575_IN4.pinMode(P9,INPUT);
  pcf8575_IN4.pinMode(P10,INPUT);
  pcf8575_IN4.pinMode(P11,INPUT);
  pcf8575_IN4.pinMode(P12,INPUT);
  pcf8575_IN4.pinMode(P13,INPUT);
  pcf8575_IN4.pinMode(P14,INPUT);
  pcf8575_IN4.pinMode(P15,INPUT);
  pcf8575_IN5.pinMode(P0,INPUT);
  pcf8575_IN5.pinMode(P1,INPUT);
  pcf8575_IN5.pinMode(P2,INPUT);
  pcf8575_IN5.pinMode(P3,INPUT);
  pcf8575_IN5.pinMode(P4,INPUT);
  pcf8575_IN5.pinMode(P5,INPUT);
  pcf8575_IN5.pinMode(P6,INPUT);
  pcf8575_IN5.pinMode(P7,INPUT);
  pcf8575_IN5.pinMode(P8,INPUT);
  pcf8575_IN5.pinMode(P9,INPUT);
  pcf8575_IN5.pinMode(P10,INPUT);
  pcf8575_IN5.pinMode(P11,INPUT);
  pcf8575_IN5.pinMode(P12,INPUT);
  pcf8575_IN5.pinMode(P13,INPUT);
  pcf8575_IN5.pinMode(P14,INPUT);
  pcf8575_IN5.pinMode(P15,INPUT);
  pcf8575_IN6.pinMode(P0,INPUT);
  pcf8575_IN6.pinMode(P1,INPUT);
  pcf8575_IN6.pinMode(P2,INPUT);
  pcf8575_IN6.pinMode(P3,INPUT);
  pcf8575_IN6.pinMode(P4,INPUT);
  pcf8575_IN6.pinMode(P5,INPUT);
  pcf8575_IN6.pinMode(P6,INPUT);
  pcf8575_IN6.pinMode(P7,INPUT);
  pcf8575_IN6.pinMode(P8,INPUT);
  pcf8575_IN6.pinMode(P9,INPUT);
  pcf8575_IN6.pinMode(P10,INPUT);
  pcf8575_IN6.pinMode(P11,INPUT);
  pcf8575_IN6.pinMode(P12,INPUT);
  pcf8575_IN6.pinMode(P13,INPUT);
  pcf8575_IN6.pinMode(P14,INPUT);
  pcf8575_IN6.pinMode(P15,INPUT);
  pcf8575_IN7.pinMode(P0,INPUT);
  pcf8575_IN7.pinMode(P1,INPUT);
  pcf8575_IN7.pinMode(P2,INPUT);
  pcf8575_IN7.pinMode(P3,INPUT);
  pcf8575_IN7.pinMode(P4,INPUT);
  pcf8575_IN7.pinMode(P5,INPUT);
  pcf8575_IN7.pinMode(P6,INPUT);
  pcf8575_IN7.pinMode(P7,INPUT);
  pcf8575_IN7.pinMode(P8,INPUT);
  pcf8575_IN7.pinMode(P9,INPUT);
  pcf8575_IN7.pinMode(P10,INPUT);
  pcf8575_IN7.pinMode(P11,INPUT);
  pcf8575_IN7.pinMode(P12,INPUT);
  pcf8575_IN7.pinMode(P13,INPUT);
  pcf8575_IN7.pinMode(P14,INPUT);
  pcf8575_IN7.pinMode(P15,INPUT);
  pcf8575_IN8.pinMode(P0,INPUT);
  pcf8575_IN8.pinMode(P1,INPUT);
  pcf8575_IN8.pinMode(P2,INPUT);
  pcf8575_IN8.pinMode(P3,INPUT);
  pcf8575_IN8.pinMode(P4,INPUT);
  pcf8575_IN8.pinMode(P5,INPUT);
  pcf8575_IN8.pinMode(P6,INPUT);
  pcf8575_IN8.pinMode(P7,INPUT);
  pcf8575_IN8.pinMode(P8,INPUT);
  pcf8575_IN8.pinMode(P9,INPUT);
  pcf8575_IN8.pinMode(P10,INPUT);
  pcf8575_IN8.pinMode(P11,INPUT);
  pcf8575_IN8.pinMode(P12,INPUT);
  pcf8575_IN8.pinMode(P13,INPUT);
  pcf8575_IN8.pinMode(P14,INPUT);
  pcf8575_IN8.pinMode(P15,INPUT);
uint16_t var_rcv = 0;
var_rcv = pcf8575_IN1.digitalReadAll();
if ((pcf8575_IN1.digitalReadAll())!=65535)
    Serial.print("input16-input1 state:");
    Serial.println(var_rcv,BIN);
var_rcv = pcf8575_IN2.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input32-input17 state:");
var_rcv = pcf8575_IN3.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input48-input33 state:");
var_rcv = pcf8575_IN4.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input64-input49 state:");
var_rcv = pcf8575_IN5.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input80-input65 state:");
var_rcv = pcf8575_IN6.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input96-input81 state:");
var_rcv = pcf8575_IN7.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input112-input97 state:");
var_rcv = pcf8575_IN8.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input128-input113 state:");
   delay(500);
  [Arduino IDE demo source code for KC868-A128]--#01--ADC_INOUT code
Posted by: KinCony Support - 08-05-2022, 02:07 AM - Forum: KC868-A128 - No Replies
#define ANALOG_A1   39
#define ANALOG_A2   34
#define ANALOG_A3   36
#define ANALOG_A4   35
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  delay(500);
  Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));
  Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));
  led doesn't light up
Posted by: 2sdaymars - 08-05-2022, 01:38 AM - Forum: KC868-A16 - Replies (7)
I bought it and used it, but it doesn't work.
I put the code on esphome and turned on the switch, but the led doesn't light up.
i use this code
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
    address: 0x25
    address: 0x21
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      inverted: false
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "xxxxxxxxxxxxxxx"
    password: "xxxxxxxx"
captive_portal:
  KC868-A128 configure for ESPhome
Posted by: admin - 08-04-2022, 09:47 PM - Forum: KC868-A128 - Replies (16)
.txt   KC868-A128-ESPHome_PCF8575_Analog.txt (Size: 40.53 KB / Downloads: 941)
  platform: ESP32
  - id: bus_a
    sda: 5
    scl: 16
    frequency: 400kHz
  - id: bus_b
    sda: 15
    scl: 4
    frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.198
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_5'  # for output channel 65-80
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_out_6'  # for output channel 81-96
    i2c_id: bus_a
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_out_7'  # for output channel 97-112
    i2c_id: bus_a
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_out_8'  # for output channel 113-128
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for a128-input channel 1-16
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a128-input channel 17-32
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for a128-input channel 33-48
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for a128-input channel 49-64
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_5'  # for a128-input channel 65-80
    i2c_id: bus_b
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_6'  # for a128-input channel 81-96
    i2c_id: bus_b
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_in_7'  # for a128-input channel 97-112
    i2c_id: bus_b
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_in_8'  # for a128-input channel 113-128
    i2c_id: bus_b
    address: 0x23
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_4
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_5
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_6
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_8
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
# Individual inputs
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_4
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_5
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_6
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_8
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  KC868-A128 ESP32 I/O pin define
Posted by: admin - 08-04-2022, 09:46 PM - Forum: KC868-A128 - No Replies
#define ANALOG_A1  GPIO39
#define ANALOG_A2  GPIO34
#define ANALOG_A3  GPIO36
#define ANALOG_A4  GPIO35
IIC Bus-1:A
SDA-A:GPIO5
SCL-A:GPIO16
PCF8575:U144 (relay1-16): 100 100 = 0x24
PCF8575:U146 (relay17-32): 100 101 = 0x25
PCF8575:U148 (relay33-48): 100 001 = 0x21
PCF8575:U150 (relay49-64): 100 010 = 0x22
PCF8575:U280 (relay65-80): 100 110 = 0x26
PCF8575:U282 (relay81-96): 100 111 = 0x27
PCF8575:U284 (relay97-112): 100 000 = 0x20
PCF8575:U286 (relay113-128): 100 011 = 0x23
IIC Bus-2:B
SDA-B:GPIO15
SCL-B:GPIO4
PCF8575:U143 (DI1-16): 100 100 = 0x24
PCF8575:U145 (DI17-32): 100 101 = 0x25
PCF8575:U147 (DI33-48): 100 001 = 0x21
PCF8575:U149 (DI49-64): 100 010 = 0x22
PCF8575:U279 (DI65-80): 100 110 = 0x26
PCF8575:U281 (DI81-96): 100 111 = 0x27
PCF8575:U283 (DI97-112): 100 000 = 0x20
PCF8575:U285 (DI113-128): 100 011 = 0x23
#define ETH_ADDR        0
RS485:
RXD:GPIO13
TXD:GPIO14
Extend serial port (3.3v TTL level):
RXD:GPIO32
TXD:GPIO33
  Home Assistant Support
Posted by: naveenppm - 08-04-2022, 08:16 AM - Forum: DIY Project - Replies (2)
I am using TCP IN node for getting value. Depending on the value I need to set the value brightness of light 1 . my entity is input_number.light_1.
but I getting errors. how to write JSON for the above requirement.
Objective : Set the value to input_bumber.light_1 using json
please find the attachment for your reference..Please help me to sort out this issue.
  KC868-A128 ESP32 GPIO Module Released!
Posted by: admin - 08-04-2022, 02:45 AM - Forum: News - No Replies
We have designed KC868-A128 ESP32 board use for huge INPUT and OUTPUT devices for home automation DIY. it is a input module based on ESP32 chip. it have 128 channel digital input ports, every input channel use optocoupler isolation, so that can work for 1000 meter with sensors or any dry contact devices. Support work with RS485. Made For ESPHome and easily integrate to home assistant for smart home automation project DIY. You can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet RS485 module.
[Image: KC868-A128-1_01.jpg]
[Image: KC868-A128-2_01.jpg]
  KC868-A8 PCB updated V1.5
Posted by: admin - 08-04-2022, 01:34 AM - Forum: News - Replies (23)
new pcb v1.5 of KC868-A8, replaced USB-C with MiniUSB port.
[Image: KC868-A8-1_03.png]
