» Members: 9,560
» Latest member: dodynemr
» Forum threads: 4,183
» Forum posts: 20,807
There are currently 32 online users.
» 0 Member(s) | 15 Guest(s)
Amazonbot, Bing, Crawl, DataForSeoBot, PetalBot, Semrush, bot
K868-a32 plastic case
11 hours ago
CT Clamp Compatibility
Yesterday, 10:32 PM
» Replies: 10
KinCony F8 + ESPHome: Una...
Forum: F8
08-08-2026, 11:51 PM
How to get started
08-07-2026, 11:42 PM
» Replies: 39
Questions on the B4M
Forum: B4M
08-07-2026, 11:19 PM
cannot see KC868-A6 in ro...
08-07-2026, 09:59 AM
» Replies: 7
CAN-BUS Transceiver
Forum: T16M
08-07-2026, 09:57 AM
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
08-06-2026, 07:18 AM
KC868-A16
Last Post: 5310h
08-05-2026, 09:40 PM
» Replies: 9
KC868-A16 UART pins
Last Post: meowdokugame
08-04-2026, 07:40 AM
  4-20mA convert use for 0-5v of KC868-COLB analog input
Posted by: admin - 08-24-2022, 05:00 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
add 250 ohm resistance convert "current" to "voltage" signal.
  [Arduino IDE demo source code for KC868-A32]--#07-KC868-A32_Web_server_code
Posted by: KinCony Support - 08-24-2022, 12:46 AM - Forum: KC868-A32/A32 Pro - Replies (14)
.zip   KC868-A32_Web_Server.zip (Size: 483.68 KB / Downloads: 923)
* Create Your own WebServer for KC868-A32 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
int timeout =20; // seconds to run for
// Replace with your network credential
/*******config the WIFI by phone*****************/
/* const char* ssid     = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password*/
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_R1(&I2Ctwo, 0x24, 15, 13);
PCF8574 pcf8574_R2(&I2Ctwo, 0x25, 15, 13);
PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
PCF8574 pcf8574_R4(&I2Ctwo, 0x22, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x24, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x25, 4, 5);
PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
PCF8574 pcf8574_I4(&I2Cone, 0x22, 4, 5);
String relaystate[32]={
  "relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
  "relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",
  "relay17state","relay18state","relay19state","relay20state","relay21state","relay22state","relay23state","relay24state",
  "relay25state","relay26state","relay27state","relay18state","relay296state","relay30state","relay31state","relay32state",
String relay32state = "off";// state of relay32
  pinMode(TRIGGER_PIN, INPUT_PULLUP); // wifi reset button
  for(int i=0;i<=7;i++)
     pcf8574_R2.pinMode(i, OUTPUT);
     pcf8574_R3.pinMode(i, OUTPUT);
     pcf8574_R4.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
  pcf8574_R3.begin();
  pcf8574_R4.begin();
  for(int i=0;i<=7;i++){
  pcf8574_I1.pinMode(i, INPUT);
  pcf8574_I2.pinMode(i, INPUT);
  pcf8574_I3.pinMode(i, INPUT);
  pcf8574_I4.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
pcf8574_I3.begin();
pcf8574_I4.begin();
    pcf8574_R2.digitalWrite(i, HIGH);
    pcf8574_R3.digitalWrite(i, HIGH);
    pcf8574_R4.digitalWrite(i, HIGH);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  //WiFi.begin(ssid, password);
    wm.setConfigPortalTimeout(timeout);
     bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
       res = wm.autoConnect("KC868-A32-AP"); // anonymous ap
   //  res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        Serial.println("connected...yeey :)");
  /*while (WiFi.status() != WL_CONNECTED) {
     // delay(10);
    //Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected.");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
            else if (header.indexOf("GET /17/on") >= 0)  {relay17state = "on";pcf8574_R3.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /17/off") >= 0) {relay17state = "off";pcf8574_R3.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /18/on") >= 0)  {relay18state = "on";pcf8574_R3.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /18/off") >= 0) {relay18state = "off";pcf8574_R3.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /19/on") >= 0)  {relay19state = "on";pcf8574_R3.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /19/off") >= 0) {relay19state = "off";pcf8574_R3.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /20/on") >= 0)  {relay20state = "on";pcf8574_R3.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /20/off") >= 0) {relay20state = "off";pcf8574_R3.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /21/on") >= 0)  {relay21state = "on";pcf8574_R3.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /21/off") >= 0) {relay21state = "off";pcf8574_R3.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /22/on") >= 0)  {relay22state = "on";pcf8574_R3.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /22/off") >= 0) {relay22state = "off";pcf8574_R3.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /23/on") >= 0)  {relay23state = "on";pcf8574_R3.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /23/off") >= 0) {relay23state = "off";pcf8574_R3.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /24/on") >= 0)  {relay24state = "on";pcf8574_R3.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /24/off") >= 0) {relay24state = "off";pcf8574_R3.digitalWrite(P7, HIGH);}
            else if (header.indexOf("GET /25/on") >= 0)  {relay25state = "on";pcf8574_R4.digitalWrite(P0, LOW);}
            else if (header.indexOf("GET /25/off") >= 0) {relay25state = "off";pcf8574_R4.digitalWrite(P0, HIGH);}
            else if (header.indexOf("GET /26/on") >= 0)  {relay26state = "on";pcf8574_R4.digitalWrite(P1, LOW);}
            else if (header.indexOf("GET /26/off") >= 0) {relay26state = "off";pcf8574_R4.digitalWrite(P1, HIGH);}
            else if (header.indexOf("GET /27/on") >= 0)  {relay27state = "on";pcf8574_R4.digitalWrite(P2, LOW);}
            else if (header.indexOf("GET /27/off") >= 0) {relay27state = "off";pcf8574_R4.digitalWrite(P2, HIGH);}
            else if (header.indexOf("GET /28/on") >= 0)  {relay28state = "on";pcf8574_R4.digitalWrite(P3, LOW);}
            else if (header.indexOf("GET /28/off") >= 0) {relay28state = "off";pcf8574_R4.digitalWrite(P3, HIGH);}
            else if (header.indexOf("GET /29/on") >= 0)  {relay29state = "on";pcf8574_R4.digitalWrite(P4, LOW);}
            else if (header.indexOf("GET /29/off") >= 0) {relay29state = "off";pcf8574_R4.digitalWrite(P4, HIGH);}
            else if (header.indexOf("GET /30/on") >= 0)  {relay30state = "on";pcf8574_R4.digitalWrite(P5, LOW);}
            else if (header.indexOf("GET /30/off") >= 0) {relay30state = "off";pcf8574_R4.digitalWrite(P5, HIGH);}
            else if (header.indexOf("GET /31/on") >= 0)  {relay31state = "on";pcf8574_R4.digitalWrite(P6, LOW);}
            else if (header.indexOf("GET /31/off") >= 0) {relay31state = "off";pcf8574_R4.digitalWrite(P6, HIGH);}
            else if (header.indexOf("GET /32/on") >= 0)  {relay32state = "on";pcf8574_R4.digitalWrite(P7, LOW);}
            else if (header.indexOf("GET /32/off") >= 0) {relay32state = "off";pcf8574_R4.digitalWrite(P7, HIGH);}
               /* for(int i=0;i<32;i++)
                relaystate[i]="on";
              relay17state = "on";// state of relay1
              relay18state = "on";// state of relay2
              relay19state = "on";// state of relay3
              relay20state = "on";// state of relay4
              relay21state = "on";// state of relay5
              relay22state = "on";// state of relay6
              relay23state = "on";// state of relay7
              relay24state = "on";// state of relay8
              relay25state = "on";// state of relay9
              relay26state = "on";// state of relay10
              relay27state = "on";// state of relay11
              relay28state = "on";// state of relay12
              relay29state = "on";// state of relay13
              relay30state = "on";// state of relay14
              relay31state = "on";// state of relay15
              relay32state = "on";// state of relay16
                 pcf8574_R1.digitalWrite(i,LOW);
                 pcf8574_R2.digitalWrite(i,LOW);
                 pcf8574_R3.digitalWrite(i,LOW);
                 pcf8574_R4.digitalWrite(i,LOW);
              /*for(int i=0;i<32;i++)
                relaystate[i]="off";
              relay17state = "off";// state of relay1
              relay18state = "off";// state of relay2
              relay19state = "off";// state of relay3
              relay20state = "off";// state of relay4
              relay21state = "off";// state of relay5
              relay22state = "off";// state of relay6
              relay23state = "off";// state of relay7
              relay24state = "off";// state of relay8
              relay25state = "off";// state of relay9
              relay26state = "off";// state of relay10
              relay27state = "off";// state of relay11
              relay28state = "off";// state of relay12
              relay29state = "off";// state of relay13
              relay30state = "off";// state of relay14
              relay31state = "off";// state of relay15
              relay32state = "off";// state of relay16
            // Display the HTML web page
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            //client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            //client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button { background-color: #195B10; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 35px; margin: 2px; cursor: pointer;}");
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state + " relay17:" + relay17state + " relay18:" + relay18state + " relay19:" + relay19state + " relay20:" + relay20state + " relay21:" + relay21state + " relay22:" + relay22state + " relay23:" + relay23state + " relay24:" + relay24state + " relay25:" + relay25state + " relay26:" + relay26state + " relay27:" + relay27state + " relay28:" + relay28state + " relay29:" + relay29state + " relay30:" + relay30state + " relay31:" + relay31state + " relay32:" + relay32state);
            else
            // Web Page Heading
           client.println("<body><h1>KC868-A32 Web Server</h1>");
            if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05-ON </button></a>");
            if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06-ON </button></a>");
            if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07-ON </button></a>");
            if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08-ON </button></a>");
            if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09-ON </button></a>");
            if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-ON</button></a>");
            if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-ON</button></a>");
            if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-ON</button></a>");
            if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-ON</button></a>");
            if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-ON</button></a>");
            if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-ON</button></a>");
            if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-ON</button></a>");
            if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-OFF</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-ON</button></a>");
            if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-OFF</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-ON</button></a>");
            if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-OFF</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-ON</button></a>");
            if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-OFF</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-ON</button></a>");
            if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-OFF</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-ON</button></a>");
            if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-OFF</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-ON</button></a>");
            if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-OFF</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-ON</button></a>");
            if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-OFF</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-ON</button></a>");
            if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-OFF</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-ON</button></a>");
            if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-OFF</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-ON</button></a>");
            if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-OFF</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-ON</button></a>");
            if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-OFF</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-ON</button></a>");
            if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-OFF</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-ON</button></a>");
            if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-OFF</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-ON</button></a>");
            if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-OFF</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-ON</button></a>");
            if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-OFF</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-ON</button></a>");
              client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
              client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
    if(pcf8574_I2.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(i,!pcf8574_R2.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(i) == LOW) relaystate[i+9]="on";else relaystate[i+9]="off";
    if(pcf8574_I3.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I3.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R3.digitalWrite(i,!pcf8574_R3.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I3.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R3.digitalRead(i) == LOW) relaystate[i+17]="on";else relaystate[i+17]="off";
    if(pcf8574_I4.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I4.digitalRead(i) == LOW)       //key pressed again
          pcf8574_R4.digitalWrite(i,!pcf8574_R4.digitalRead(i));    // toggle relay1 state
          while(pcf8574_I4.digitalRead(i) == LOW); //wait remove hand
          if (pcf8574_R4.digitalRead(i) == LOW) relaystate[i+25]="on";else relaystate[i+25]="off";
  [Arduino IDE demo source code for KC868-E16S]--#07-KC868-E16S-Web_server_code
Posted by: KinCony Support - 08-24-2022, 12:44 AM - Forum: KC868-E16S/E16P - No Replies
.zip   KC868-E16S_Web_Server.zip (Size: 464.69 KB / Downloads: 793)
* Create Your own WebServer for KC868-E16S Smart Controller*
#include <WiFi.h>
WiFiManager wm;
String header;
// Current time
// Previous time
int flag_read_di=0;
PCF8574 pcf8574_I1(&I2Cone, 0x22, 16, 15);
PCF8574 pcf8574_I2(&I2Cone, 0x24, 16, 15);
PCF8574 pcf8574_R1(&I2Cone, 0x21, 16, 15);
PCF8574 pcf8574_R2(&I2Cone, 0x25, 16, 15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
                       "relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",};
  pcf8574_R1.begin();
  pcf8574_R2.begin();
  pcf8574_I1.begin();
  pcf8574_I2.begin();
     bool res;
       res = wm.autoConnect("KC868-E16S-AP"); // anonymous ap
    if(!res) {
        // ESP.restart();
    else {
  Serial.println("");
  server.begin();
void loop(){
        header += c;
            client.println();
                 pcf8574_R2.digitalWrite(i, LOW);
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-E16S Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
    for(int j=0;j<=7;j++)
    if(pcf8574_I2.digitalRead(j) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I2.digitalRead(j) == LOW)       //key pressed again
          pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j));    // toggle relay1 state
          while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
          if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
  [Arduino IDE demo source code for KC868-A16]--#09-KC868-A16_Web_server_code
Posted by: KinCony Support - 08-24-2022, 12:42 AM - Forum: KC868-A16 - Replies (20)
.zip   KC868-A16_Web_Server.zip (Size: 464.75 KB / Downloads: 1569)
* Create Your own WebServer for KC868-A16 Smart Controller*
#include <WiFi.h>
WiFiManager wm;
// Replace with your network credentials
String header;
// Current time
// Previous time
int flag_read_di=0;
/*******Check the I2C address **********/
/********If your board was purchased earlier, use an older I2C**/
/********OLD A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x21,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x25,4,5);*/
// Set A16 digital input i2c address
/********NEW A16 Board I2C address */
PCF8574 pcf8574_I1(&I2Cone,0x3A,4,5);
PCF8574 pcf8574_I2(&I2Cone,0x39,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x3C,4,5);
PCF8574 pcf8574_R2(&I2Cone,0x3D,4,5);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
    pcf8574_I1.begin();
    pcf8574_I2.begin();
     bool res;
       res = wm.autoConnect("KC868-A16-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
        header += c;
            client.println();
            client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;}");
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A16 Web Server</h1>");
              client.println("<a href=\"/all/on\"><button class=\"button\">All-ON</button></a>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
        delay(20);
  [Arduino IDE demo source code for KC868-A8S]--#15-KC868-A8S_Web_server_code
Posted by: KinCony Support - 08-24-2022, 12:39 AM - Forum: KC868-A8S - No Replies
.zip   KC868-A8S_Web_Server.zip (Size: 462.39 KB / Downloads: 912)
* Create Your own WebServer for KC868-A8S Smart Controller*
#include <WiFi.h>
WiFiManager wm;
String header;
// Current time
// Previous time
int flag_read_di=0;
//set I2C of A8S
  pcf8574_R1.begin();
    pcf8574_I1.begin();
     bool res;
       res = wm.autoConnect("KC868-A8S-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
        header += c;
            client.println();
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8S Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
  KC868-A4 PCB updated V1.2.4
Posted by: admin - 08-24-2022, 12:09 AM - Forum: News - Replies (7)
new pcb v1.2.4 of KC868-A4, replaced USB-C with MiniUSB port.
[Image: KC868-A4_03.jpg]
  KC 868 AG - YAML Code
Posted by: nrnr - 08-23-2022, 07:14 PM - Forum: Development - Replies (4)
I've edited YAML code for IR gateway. I'm recieving error message related to "if" command - "Component not found if."
The code:
remote_receiver:
  pin: GPIO23
  dump: all
  - platform: remote_receiver
    pronto:
      data: "0000 006D 0022 0000 0151 00AD 0015 0014 0017 0041 0015 0014 0017 0016 0015 0044 0012 0014 0017 0044 0013 0018 0013 0043 0013 0016 0015 0044 0012 0044 0013 0016 0015 0043 0013 0016 0015 0044 0013 0016 0015 0041 0016 0015 0015 0041 0016 0040 0015 0014 0017 0013 0018 0013 0018 003F 0018 0013 0018 003F 0019 0012 0018 0013 0018 003F 0018 003F 0018 003F 0018 06C3"
if:
  condition:
    binary_sensor.is_on: TEST
  then:
    - mqtt.publish:
        topic: IR_Bridge
        payload: "Something happened!"
component not found if.
  [Arduino IDE demo source code for KC868-A8]--#10-Web server_code
Posted by: KinCony Support - 08-23-2022, 09:01 AM - Forum: KC868-A8 - No Replies
.zip   KC868-A8_Web_Server.zip (Size: 462.26 KB / Downloads: 1027)
* Create Your own WebServer for KC868-A8 Smart Controller*
#include <WiFi.h>
WiFiManager wm;
String header;
// Current time
// Previous time
int flag_read_di=0;
//set I2C of A8
String relaystate[8]={"relay1state","relay2state","relay3state","relay4state",
  pcf8574_R1.begin();
    pcf8574_I1.begin();
     bool res;
       res = wm.autoConnect("KC868-A8-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
  if (client) {                             // If a new client connects,
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        header += c;
            client.println();
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A8 Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
  [Arduino IDE demo source code for KC868-A6]--#12-Web_server_code
Posted by: KinCony Support - 08-23-2022, 08:59 AM - Forum: KC868-A6 - Replies (11)
.zip   KC868-A6_Web_Server.zip (Size: 461.74 KB / Downloads: 1496)
* Create Your own WebServer for KC868-A6 Smart Controller*
#include <WiFi.h>
WiFiManager wm;
String header;
// Current time
// Previous time
int flag_read_di=0;
//set I2C of A6
PCF8574 pcf8574_I1(&I2Cone,0x22,4,15);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,15);
  for(int i=0;i<=5;i++)
  pcf8574_R1.begin();
    pcf8574_I1.begin();
     bool res;
       res = wm.autoConnect("KC868-A6-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
        header += c;
            client.println();
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A6 Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
        delay(20);
  [Arduino demo source code for KC868-A4]-12 web server by wifi
Posted by: KinCony Support - 08-23-2022, 08:54 AM - Forum: KC868-A4 - No Replies
[Arduino IDE demo source code for KC868-A4]--#12-WEB_SERVER_CODE
.zip   KC868-A4_Web_Server.zip (Size: 454.76 KB / Downloads: 935)
* Create Your own WebServer for KC868-A4 Smart Controller*
#include <WiFi.h>
WiFiManager wm;
String header;
// Current time
// Previous time
int flag_read_di=0;
  pinMode(2,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(36,INPUT);
  pinMode(39,INPUT);
  pinMode(27,INPUT);
  pinMode(14,INPUT);
  digitalWrite(2, HIGH);
  digitalWrite(15,HIGH);
  digitalWrite(5, HIGH);
  digitalWrite(4, HIGH);
     bool res;
       res = wm.autoConnect("KC868-A4-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
        header += c;
            client.println();
                 if (header.indexOf("GET /1/on") >= 0)  {relay1state = "on"; digitalWrite(2, HIGH);}
            else if (header.indexOf("GET /1/off") >= 0) {relay1state = "off";digitalWrite(2, LOW);}
            else if (header.indexOf("GET /2/on") >= 0)  {relay2state = "on"; digitalWrite(15, HIGH);}
            else if (header.indexOf("GET /2/off") >= 0) {relay2state = "off";digitalWrite(15, LOW);}
            else if (header.indexOf("GET /3/on") >= 0)  {relay3state = "on"; digitalWrite(5, HIGH);}
            else if (header.indexOf("GET /3/off") >= 0) {relay3state = "off";digitalWrite(5, LOW);}
            else if (header.indexOf("GET /4/on") >= 0)  {relay4state = "on"; digitalWrite(4, HIGH);}
            else if (header.indexOf("GET /4/off") >= 0) {relay4state = "off";digitalWrite(4, LOW);}
                digitalWrite(15,LOW);
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state );
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A4 Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(digitalRead(36) == LOW)         //key pressed
        delay(20);
        if(digitalRead(36) == LOW)       //key pressed again
          digitalWrite(2,!digitalRead(2));    // toggle relay1 state
          while(digitalRead(36) == LOW); //wait remove hand
          if (digitalRead(2) == LOW) relay1state="on";else relay1state="off";
if(digitalRead(39) == LOW)         //key pressed
        delay(20);
        if(digitalRead(39) == LOW)       //key pressed again
          digitalWrite(15,!digitalRead(15));    // toggle relay1 state
          while(digitalRead(39) == LOW); //wait remove hand
          if (digitalRead(15) == LOW) relay2state="on";else relay2state="off";
    if(digitalRead(27) == LOW)         //key pressed
        delay(20);
        if(digitalRead(27) == LOW)       //key pressed again
          digitalWrite(5,!digitalRead(5));    // toggle relay1 state
          while(digitalRead(27) == LOW); //wait remove hand
          if (digitalRead(5) == LOW) relay3state="on";else relay3state="off";
      if(digitalRead(14) == LOW)         //key pressed
            delay(20);
            if(digitalRead(14) == LOW)       //key pressed again
              digitalWrite(4,!digitalRead(4));    // toggle relay1 state
              while(digitalRead(14) == LOW); //wait remove hand
              if (digitalRead(4) == LOW) relay4state="on";else relay4state="off";
