» Members: 9,540
» Latest member: luckynyt
» Forum threads: 4,183
» Forum posts: 20,791
There are currently 46 online users.
» 0 Member(s) | 31 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Crawl, Google, PetalBot, bot
cannot see KC868-A6 in ro...
11 hours ago
» Replies: 7
CAN-BUS Transceiver
Forum: T16M
11 hours ago
How to get started
Last Post: Lomagno
Today, 03:31 AM
» Replies: 38
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
Yesterday, 07:18 AM
KC868-A16
Last Post: 5310h
08-05-2026, 09:40 PM
» Replies: 9
KC868-A16 UART pins
Last Post: meowdokugame
08-04-2026, 07:40 AM
KC868-A32 Malfunction Aft...
Forum: KC868-A32/A32 Pro
08-04-2026, 06:19 AM
KinCony F8 + ESPHome: Una...
Forum: F8
08-02-2026, 11:00 PM
F8 ESPHome yaml for home ...
Forum: F8
Schema A16V3 for Research...
Forum: KC868-A16v3
Last Post: hamzachaouri
08-02-2026, 10:34 PM
  KC868 A4 - Help In Program
Posted by: mfjunior96 - 02-16-2022, 02:38 AM - Forum: KC868-A4 - Replies (3)
I wanted to know if you can help me with a programming, I'm using the digital inputs to connect the relays 1 - 4, but I wanted to know if I can change the state of an alexa device with a digital input (ex: led driver)
  KC868 A4 - Pin Define
Posted by: mfjunior96 - 02-16-2022, 02:33 AM - Forum: KC868-A4 - Replies (3)
I have a KC868 A4 board and for some reason the relay 02 stopped working, in some measurements I verified that there is no voltage coming out of the esp32 (output burned) do you have any reserve IO ratio?
  KC868-A4 Part:1 hardware design details
Posted by: admin - 02-16-2022, 12:53 AM - Forum: KC868-A4 - No Replies
https://www.kincony.com/kc868-a4-hardwar...tails.html
  KC868-32BS state from wall switch
Posted by: udayansarma - 02-14-2022, 11:56 PM - Forum: KC868-HxB series Smart Controller - Replies (5)
How do I retain the state changes trigger from 12vdc wall switch that triggers the existing momentary relays? Please take a look at the existing relays and the wiring in the attached picture, all the yellow wires are triggers to those Finder relays. When I use the trigger from the 32BS controller both the apps and wall switches are in sync because the existing relays and triggers keep the wall switches in sync. But if I trigger via the wall switch, the app and the controller are not able to retain any state. Where the existing trigger wires (yellow for +ve and black for ground) should go to 32BS controller so the states between the controller, app and the wall switches are all in sync?
Thanks much
Exclamation KBOX COMMUNICATION WITH KC868-H32B
Posted by: ahmedk4444@yahoo.com - 02-14-2022, 02:48 AM - Forum: DIY Project - Replies (52)
Hi
I configured the device kC-868-H32B
Ethernet on UDP server
And wifi on TCP server
Home smart app communicate fine with controller, but 1. Kbox not working with controller and send java error with fault communication please see attached snap shot. Neither when ethernet cable connect not disconnected.
2. Can i use some output say 2 out of 8 terminal block connect to certain phase R and 3 on ohase S and 3 on ohase T?
3. How i can control the controller on my PC ,all software on Website didn't communicate with controller.
Thank you
Ahmed
  if install 2022 new KBOX android phone app crashed, how to do?
Posted by: admin - 02-14-2022, 01:13 AM - Forum: News - No Replies
Because there are many Android phone models, some may have compatibility problems. When you delete old KBOX app, installed a new version from Google Play Store , open app crashed. You can download and install this KBOX-debug version.
.zip   KBOX-RELEASE-202202261520-log.zip (Size: 22.42 MB / Downloads: 904)
download this ZIP file , after unzip, install the "KBOX_20220112_log.apk".
when you open the app , crashed, it will save the debug data on your phone via log file. You will find the log file at here:
path: myphone/Android/data/com.kincony.KControl/files/log
You can send to us this file by Email to hificat@163.com or post to our forum.
post content with follow information:
your phone brand, model, android OS verison. Then our software engineer will test it and make adaption work for you. if we solved, we will send you a new application APK file.
  Voltage digital input colb
Posted by: wilsonzanette - 02-13-2022, 03:02 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
what is the input voltage of the colb ports?
  KC868 H32B latest firmware
Posted by: Judele Roberto - 02-11-2022, 07:17 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Where can I get the latest firmware for the h32b?
Exclamation KC868-A4 with Nextion 5 inch display issue
Posted by: VovaN_60 - 02-11-2022, 09:30 AM - Forum: KC868-A4 - Replies (2)
Hello all.
System:
KC868-A4 board with Nextion NX8048P050-011C-Y display.
Problem:
UART communication with this particular display. Other 2.4 inch Nextion works well.
Possibly issue with TTL level.
Electrical connection info:
RS323 chip (SP3232EEN) removed from the KC868-A4 board.
The RX and TX of Nextion are connected directly to GPIO_16 and GPIO_17 of ESP32.
We have tried to use other GPIO's of ESP32. Nothing works.
The solution which works:
Replacing ESP32-S with original ESP32-WROOVER.
Question:
1) Can anyone suggest a simplier solution?
2) Is there any way to force Nextion to operate on 3.3v TTL level?
3) Can we connect Nextion to RS232 connector directly without removing SP3232EEN?
  KC868-A ESP32 RGBW LED Stripe
Posted by: janosch1337 - 02-11-2022, 08:47 AM - Forum: DIY Project - Replies (11)
Hey,
i'm searching for a solution to control warm white/cold white 24V stripes from KC868-A... (esp32). can you recommend something?
in the past i use H801 to control 24V stripes. But i want to control it over your kc868 board to have a direct connection from switch to lamp Wink
