» Members: 9,817
» Latest member: dawtaylor
» Forum threads: 4,218
» Forum posts: 20,917
There are currently 338 online users.
» 0 Member(s) | 313 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
Last Post: viko
3 hours ago
» Replies: 11
No ethernet communication
5 hours ago
» Replies: 8
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
  KC868-H32B V4.41 new firmware update
Posted by: admin - 03-07-2022, 12:18 AM - Forum: News - No Replies
improvement:
1. Fixed an issue where mqtt would disconnect under certain circumstances
2. Fixed the bug that some times more than 23 relays could not be controlled at the some time
.zip   Relay32_V441_220306.zip (Size: 46.76 KB / Downloads: 920)
Wink Help needed/wanted?
Posted by: gay - 03-06-2022, 10:19 AM - Forum: KC868-HxB series Smart Controller - Replies (45)
How do i post a message larger than 800 Characters, I have one that is 3388, It details my setup and total layout connections etc which is needed to understand the message
Gary
  Delay Scene
Posted by: Narcis - 03-05-2022, 06:21 PM - Forum: KC868-HxB series Smart Controller - Replies (4)
Hi, I have a KC868-32L and I want to use it to control the roller shutters.
I was looking for a way to set an autoOFF delay in the application and I can't. I searched Scene and I can't set the delay in KBOX app.
please help me with a video or useful information.
thank you!
  H32BS 24vdc output
Posted by: udayansarma - 03-04-2022, 06:07 PM - Forum: KC868-HxB series Smart Controller - Replies (2)
Can the H32BS controller output 24VDC? I guess we can mix 12vdc and 24vdc as far as output is concerned as long as the VIN has the desired voltage. How do we ground the 24VDC output for a specific VIN assuming the same controller will have 12VDC VIN as well?
Thanks much
  Col B wifi config
Posted by: James Alabama - 03-03-2022, 02:11 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
I located your youtube video for H32B wifi config which is very good: https://www.youtube.com/watch?v=2AViXMH8yHM
Do you have a similar video for ColB wifi configuration?
  KC868-32BS -ve/ground output
Posted by: udayansarma - 03-03-2022, 12:13 AM - Forum: KC868-HxB series Smart Controller - Replies (4)
I've about 15 shades operated by 12vdc board. Please take a look at the attached photo. The blue wires are the triggers for the different electric motors for the shades. When I connect the blue wires with 12VDC ground(-ve), the shade operates.  Is there a way to configure the H32BS to output ground/-ve 12vdc?
Thanks much
  What we would like to see as a development of KBox 3rd party software vs. competitor
Posted by: ahmedk4444@yahoo.com - 03-01-2022, 08:56 PM - Forum: DIY Project - Replies (4)
Hi All and zkincony custmer technical support.
After heavely tedted the Kbox on H32B last month, i saw Kbix need more development regarding the functions.
1. The Scene is quite limited without  ability to add more functions such as :-
At sunset current location time switch on certain loads and vice versa at sunrise dwitvh off.
2. Adfing timer for certain time opening and closing certain load such as shutter then then if you would like to shut in 25% or 50% can be achieved.
3. Reading volt, frequency, current Amp, PF on each circuit and total of those.
 I attached some useful features for compatitor app.
  What we would like to see as a development of KBox 3rd party software comparing to th
Posted by: ahmedk4444@yahoo.com - 03-01-2022, 08:51 PM - Forum: DIY Project - Replies (3)
Posted by: ahmedk4444@yahoo.com - 03-01-2022, 08:18 PM - Forum: DIY Project - Replies (1)
  A32 module planed?
Posted by: janosch1337 - 02-28-2022, 11:16 AM - Forum: KC868-A32/A32 Pro - Replies (3)
hey,
i read here in forum that a module with 32 I/O is planed. so i have some questions Wink
is it planed with relays or mosfets?
i2c possible?
release date?
12V or 24V?
which other additional inputs are planed? (analog in/out etc...)
greetings
