» Members: 9,194
» Latest member: jessyjanitorial
» Forum threads: 4,091
» Forum posts: 20,516
There are currently 24 online users.
» 0 Member(s) | 15 Guest(s)
AhrefsBot, Amazonbot, Baidu, bot
Multiple phase L1,L2,L3
Forum: N20
Last Post: phrfpeixoto
1 hour ago
» Replies: 4
Single-family home automa...
Last Post: Jan_W
Today, 06:07 AM
KC868-a6 2 analog output...
Yesterday, 11:33 PM
Kincony A4s
Forum: KC868-A4S
Yesterday, 11:27 PM
"KCS" v3.25.0 firmware BI...
Yesterday, 11:26 PM
» Replies: 9
The watch shows the wrong...
Yesterday, 11:25 PM
KC868-A16v3 integration w...
Last Post: rosnoteh
Yesterday, 08:26 PM
[Arduino IDE demo source ...
Forum: KC868-A8S
Yesterday, 06:16 AM
Tiny Alarm board after fl...
Forum: TA
06-14-2026, 11:19 AM
» Replies: 7
Wiegand
06-14-2026, 01:13 AM
  KinCony Smart Controller IP SCAN tool launched
Posted by: admin - 08-20-2021, 04:25 AM - Forum: News - Replies (5)
[Image: ip-scan-1.png]
[Image: ip-scan-2.png]
Step1: chose your network device of your computer.
Step2: click "StartMonitorPort" button.
Step3: click "SCAN" button.
Now all KinCony Controller (KC868-HxB or KC868-HxBS) will be see.
download link: https://www.kincony.com/download/KinCony...Device.zip
  How to automate administrative offices and meeting rooms?
Posted by: engrezk - 08-17-2021, 11:24 AM - Forum: News - Replies (3)
Hello
Do you have a way to automate administrative offices and meeting rooms ?
So that in the case of people, the lighting and air conditioning devices are turned on, and when people leave the administrative offices, all loads are stopped?
  MQTT connect but no data
Posted by: papakigr - 08-16-2021, 05:18 PM - Forum: KC868-HxB series Smart Controller - Replies (9)
Hello, i see that the COLB is connected to the MQTT broker but i don't receive any data.
When i connect to the local pc software i see that the device working (have data).
What should i do?
Photo MQTT connection issues (firmware v4.35)
Posted by: bigramon - 08-16-2021, 02:15 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
I just received my H32B, upgraded to version 4.35 and configured it as follows (I only use wired Ethernet):
Unfortunately, the H32B does not connect to my Mosquitto MQTT broker although the MQTT Explorer running on my computer does, using the same credentials.
I tried to reset the configuration using the Ethernet mode button but it did not help.
Did I miss something in the configuration ?
Night update - it finally connected to the Mosquitto addon, without any additional action from my side.
I could set up all relays and inputs and restarted the KC868 to check whether it would re-establish the MQTT connection.
It actually did but after several minutes.
I then restarted the Mosquitto addon but this time the KC868 did NOT reconnect.
I waited for another 15 minutes and then power cycled the KC868.
But even after 10 minutes, it still did not connect to the MQTT broker.
It looks like the MQTT connection still needs work to become more reliable.
  Node-Red-flows for KC868-H32BS RS485 Modbus Demo
Posted by: admin - 08-14-2021, 06:53 AM - Forum: Development - No Replies
This flow use RS485 Modbus work with KC868-H32BS. Demo functions have:
Read 6 digital input sensor state,
Read 32 MOSFET output state,
turn ON/OFF output-1
turn ON/OFF multi-output ports by one command.
.zip   KC868-H32BS-Node-Red-Modbus-flows.zip (Size: 1.59 KB / Downloads: 842)
  KC868-H32BS RS485 Modbus protocol
Posted by: admin - 08-14-2021, 02:21 AM - Forum: News - No Replies
https://www.kincony.com/download/KC868-H...Modbus.pdf
  KC868-H32BS smart controller module released
Posted by: admin - 08-13-2021, 07:55 AM - Forum: News - Replies (10)
We have designed new smart controller KC868-H32BS. it have 6 digital input ports for sensors, 34 digital input ports for self-reset switch button and 32 P-MOSFET output ports, support use RF 433MHz wireless remoter. Add RS485 Modbus port. Also support MQTT and HTTP command for development.
[Image: kc868-h32bs-details_01.jpg]
  KC868-H32B
Posted by: juan - 08-12-2021, 06:36 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
Hello everybody.
First of all I apologize for my English as a translator, but I hope it is enough for me to be understood.
I am configuring the integration of the KC868-H32B board to Home Assistant via Node-Red. To do this, I have followed the instructions in the video.
https://www.youtube.com/watch?v=2UVbEHWu...2_&index=3
At the beginning, everything works perfectly, but only with the first 6 relays, from relay number 7 the Node-Red tcp out module is shown as not connected.
I can't find where the problem is, can you guide me?
Thank you very much in advance.
  KC868-H32B V4.35 new firmware update
Posted by: admin - 08-09-2021, 03:19 AM - Forum: News - Replies (5)
improvement:
Enable Wifi and Ethernet use MQTT at the same time. Now you can use KC868-H32B connect to two different MQTT broker. Every relay output or input port state changed, will send message to 2 MQTT brokers.
.zip   Relay32_V435_210807.zip (Size: 45.13 KB / Downloads: 878)
firmware update tool download: https://www.kincony.com/download/KC868-C...loader.zip
  display COL status
Posted by: athxp - 08-08-2021, 10:08 AM - Forum: KC868-HxB series Smart Controller - Replies (9)
I was wondering if it was possible to use a small display that warns of the status of the outputs or inputs of COL.
in the photo I put a led (far right) that warns me of a condition (lack of pellets in the boiler). but I would like a small lcd or display, maybe settable. is there anything compatible?
