» Members: 10,014
» Latest member: 91Clubso
» Forum threads: 4,252
» Forum posts: 21,054
There are currently 101 online users.
» 0 Member(s) | 86 Guest(s)
Amazonbot, Baidu, Bytespider, Crawl, Google, PetalBot, bot, owler
Las Firmware ?
9 hours ago
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
  Lesson29- How to use tasmota for KC868-A8 via PCF8574 IIC extend GPIO
Posted by: admin - 11-15-2021, 01:24 AM - Forum: KC868-A8 - Replies (54)
Thanks for "blakadder" from https://blakadder.com supply the tasmota firmware BIN file for KC868-A8
details you can see : https://blakadder.com/kincony-KC868-A8
1. download tasmota firmware for KC868-A8
.zip   KC868-A8-Tasmota-firmware.zip (Size: 877.69 KB / Downloads: 2937)
2. After you get it running on your Wi-Fi network, set the template in " Configuration - Other"
copy this code:
{"NAME":"KC868-A8","GPIO":[32,0,1120,0,640,608,0,0,0,1,1,1152,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1,"CMND":"EthClockMode 3 | EthAddress 0 | EthType 0 | I2CDriver2 1"}
3. After applying the template you need one more configuration step. Navigate to " Configuration - Configure PCF8574 " and set the PCF8574 connected to relays to Output.
[Image: setup.jpg]
[Image: webui.jpg]
  What is the main language code for Kincony? And what is main advantage than others?
Posted by: ahmed - 11-14-2021, 12:49 PM - Forum: DIY Project - Replies (1)
  Is any way to link elecyric gate motor and wireless security alarm to use kincony app
Posted by: ahmed - 11-14-2021, 12:18 PM - Forum: DIY Project - Replies (18)
Is any way to link electrc gate motor and wireless security alarm to use kincony app?
The wirless security alarm is :-  SL6 Response Wirefree Telecommunicating Alarm System 868 MHZ
And the electric gate motor is 433MHZ RF , i attached the specifications and details
.pdf   207-SM-Control-panel-for-swing-gates-12VDC-and-24VDC.pdf (Size: 2.08 MB / Downloads: 1707)
.pdf   sl5.pdf (Size: 1.23 MB / Downloads: 1453)
  Controlling Shutter and curtain Motors using wifi touch button swith rectangle size
Posted by: ahmed - 11-14-2021, 11:12 AM - Forum: DIY Project - Replies (9)
I had one of this to my master bedroom shutter it is the standard rectangle shape in Egypt from sonoff brand.
It is wifi connect to rf remote or sonoff mobile apps i need to use one app for everything do you able your kincony mobile app work on sonoff wifi? Or do you have touch button 3 position to shutter/ curtain up and down and stop.
Note each floor has 1 circuit 220 volt to all floor shutters and the current control manual rocker switch beside each curtain, it is mandatory to use wifi switch to connect wireless to mobile apos.
Also please tell me how many of this wifi switches can work with confusion and  interruption because i had 12 shutters
  What do i need to run Alexa or google voice command to KinCony?
Posted by: ahmed - 11-13-2021, 01:15 PM - Forum: DIY Project - Replies (1)
Do i need a certain module for each controller all one for all controllers in the same electric panel?
Assume all my systems are
KC-868-H32BS with omron relay 250v 16 A
KC-868-H32B with smart buttons
  Why the RF remote control 433MHZ not 868 MHZ?
Posted by: ahmed - 11-12-2021, 12:14 PM - Forum: DIY Project - Replies (3)
And if i had different wireless system 433 and 868 MHz at the same house , am i able to change the frequency if conflict with other systems ?
  Why DC 12 volt coil for kinCony system?
Posted by: ahmed - 11-12-2021, 12:00 PM - Forum: DIY Project - Replies (14)
I'm new to this system and need to start a new project soon and test that on my house network first.
I had before X10 modules that are 220 volt coil and each module for one circuit single phase with momentary switch, mobile apps and RF remote i had 1 home automation panel that contain all house interior floors lighting load that are coming from 2 sources main and emergency through 3 DB's
Then finally the automation panel contain the following
1- 2 sources main, emergency 3 phases
2- 3 DBs each are 3 phases
3. All relays are 220 volt coil and distributed each phase and source
If you are trying to replace the system to DC coil 12 volt then you need for each source and single phase a separate AC 220v/ 12 vdc converter
This mean that you need for the automation panel
3 converters for emergency to present each phase.
6 converters for main 3 for each DB.
Then i need to convert to DC 9 separate converters.
Other wise you will use single phase for emergency as an example phase R convert to DC 12 v and feed all controllers if this phase failed all system will be off.
I really need to know the big reason behind the all system 12 v DC coils !?
And is any way to release version with 220 v AC coil?
  free KC868-A8 for Mr Evgeniy Antoshkin from Russian
Posted by: admin - 11-11-2021, 11:51 AM - Forum: Apply for free sample product - No Replies
You applied free sample KC868-A8 have sent by YANWEN, tracking number is VR445934410YP .
Hope your project goes well and share everyone your achievements.
  OpenSprinkler ESP32 port on KC868-A8 ?
Posted by: mr.sneezy - 11-11-2021, 09:20 AM - Forum: KC868-A8 - Replies (1)
Is this a possibility to use the open source OpenSprinkler ported firmware ?
https://opensprinkler.com/forums/topic/e...-firmware/
https://github.com/arijav/AriloSprinkler..._dev_esp32
If there is no technical barrier, then I guess the I/O of this board needs to be matched on the OpenSprinkler build I/O ?
Thanks.
  Lesson28- How to use KC868-A4 (ESP32) DAC output DC 0-10V by ESPHome
Posted by: admin - 11-10-2021, 02:17 AM - Forum: KC868-A series and Uair Smart Controller - Replies (9)
  platform: ESP32
output:
  - platform: esp32_dac
    pin: GPIO25
    pin: GPIO26
light:
  - platform: monochromatic
    output: dac_output1
    gamma_correct: 2
    output: dac_output2
ota:
  password: "3b853165e19b67ba8193c59fe59f21a7"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Kc868-A4 Fallback Hotspot"
    password: "RgIGz8qo4bVC"
captive_portal:
