» Members: 9,694
» Latest member: Vynith
» Forum threads: 4,196
» Forum posts: 20,852
There are currently 13 online users.
» 0 Member(s) | 6 Guest(s)
Amazonbot, Baidu, Crawl, bot
N60 power supply - power ...
Forum: N60
Less than 1 minute ago
KC868-meter-7pv-rs485
Forum: Development
Today, 10:20 AM
» Replies: 7
N60 configure yaml for ES...
Forum: N60
08-23-2026, 01:42 AM
» Replies: 7
KCS VERSUS ESPHOME
Last Post: EDVALDO DE MARINGA
08-22-2026, 01:31 PM
KC868-AGv3
08-20-2026, 10:18 PM
Forum: KC868-A32/A32 Pro
Last Post: huanmarie
08-19-2026, 07:09 AM
KC868-H32B V5.08 firmware
Forum: News
Last Post: meoowu77
08-18-2026, 11:46 AM
» Replies: 24
KinCony B2 Smart Controll...
Forum: News
08-17-2026, 01:07 PM
KC868-A8v3 PCB layout CAD...
08-17-2026, 08:44 AM
CT Clamp Compatibility
08-16-2026, 11:08 PM
» Replies: 12
  Why DC 12 volt coil for kinCony system?
Posted by: ahmed - 11-12-2021, 12:00 PM - Forum: DIY Project - Replies (14)
I'm new to this system and need to start a new project soon and test that on my house network first.
I had before X10 modules that are 220 volt coil and each module for one circuit single phase with momentary switch, mobile apps and RF remote i had 1 home automation panel that contain all house interior floors lighting load that are coming from 2 sources main and emergency through 3 DB's
Then finally the automation panel contain the following
1- 2 sources main, emergency 3 phases
2- 3 DBs each are 3 phases
3. All relays are 220 volt coil and distributed each phase and source
If you are trying to replace the system to DC coil 12 volt then you need for each source and single phase a separate AC 220v/ 12 vdc converter
This mean that you need for the automation panel
3 converters for emergency to present each phase.
6 converters for main 3 for each DB.
Then i need to convert to DC 9 separate converters.
Other wise you will use single phase for emergency as an example phase R convert to DC 12 v and feed all controllers if this phase failed all system will be off.
I really need to know the big reason behind the all system 12 v DC coils !?
And is any way to release version with 220 v AC coil?
  free KC868-A8 for Mr Evgeniy Antoshkin from Russian
Posted by: admin - 11-11-2021, 11:51 AM - Forum: Apply for free sample product - No Replies
You applied free sample KC868-A8 have sent by YANWEN, tracking number is VR445934410YP .
Hope your project goes well and share everyone your achievements.
  OpenSprinkler ESP32 port on KC868-A8 ?
Posted by: mr.sneezy - 11-11-2021, 09:20 AM - Forum: KC868-A8 - Replies (1)
Is this a possibility to use the open source OpenSprinkler ported firmware ?
https://opensprinkler.com/forums/topic/e...-firmware/
https://github.com/arijav/AriloSprinkler..._dev_esp32
If there is no technical barrier, then I guess the I/O of this board needs to be matched on the OpenSprinkler build I/O ?
Thanks.
  Lesson28- How to use KC868-A4 (ESP32) DAC output DC 0-10V by ESPHome
Posted by: admin - 11-10-2021, 02:17 AM - Forum: KC868-A series and Uair Smart Controller - Replies (9)
  platform: ESP32
output:
  - platform: esp32_dac
    pin: GPIO25
    pin: GPIO26
light:
  - platform: monochromatic
    output: dac_output1
    gamma_correct: 2
    output: dac_output2
ota:
  password: "3b853165e19b67ba8193c59fe59f21a7"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Kc868-A4 Fallback Hotspot"
    password: "RgIGz8qo4bVC"
captive_portal:
  How to use TCP Server and TCP Client work mode for your own software
Posted by: admin - 11-09-2021, 02:18 AM - Forum: Development - No Replies
1: Ethernet work mode = "TCP Server"
controller is a "server", your software is "client".
2: WiFi work mode = "TCP Server"
3: Ethernet work mode = "TCP Client"
your software is a "server", controller is "client". when power on, controller will auto connect to your software by ethernet. just "client" will auto connect to "server".
4: WiFi work mode = "TCP Client" instead by MQTT in new firmware
your software is a "server", controller is "client". when power on, controller will auto connect to your software by wifi. just "client" will auto connect to "server".
5: Ethernet work mode = "TCP Client"; WiFi work mode = "TCP Server"
A. your software is a "server", controller is "client". when power on, controller will auto connect to your software by ethernet.
B. controller is a "server", you software is "client".
  one KC868-COL/COLB/COLBS control multi controller
Posted by: admin - 11-08-2021, 08:01 AM - Forum: KC868-HxB series Smart Controller - Replies (3)
use one KC868-COL/COLB/COLBS send command to KC868-H32BS, KC868-D8 dimmer controller by RS485 modbus. MAX support 254 devices.
  HC868 COLB kickstart
Posted by: leliodm - 11-07-2021, 09:09 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
I just opened and connected by COLB. I am able to visualize the change of status of the DI input ports from the smart board controller app.
I would like to know
1. what is the procedure to update the firmware step by step - I could not find the right thread in the forum, sorry if I missed something
2. I cannot connect to the web interface where to configure the MQTT server - I can only see the interface as attached to this message.
Any help is welcome!
Lee
  KC868-H32BS V1.41 new firmware update
Posted by: admin - 11-04-2021, 01:13 AM - Forum: News - No Replies
improvement:
support set domain for your own server. old version only set server IP address by number. This verison can set by a server domain name for TCP and MQTT server, added DNS function.
download the ZIP file , unzip update the bin file for KC868-H32BS relay controller by USB-RS232 cable.
.zip   H32BS_V141_211101.zip (Size: 52.11 KB / Downloads: 893)
  i need help how to use tcp feedback node to update relay state
Posted by: itzek - 11-02-2021, 07:38 PM - Forum: Development - Replies (5)
Hi
I have H32L I connect it to home assistant : https://www.kincony.com/how-to-create-sw...stant.html
When I power on or off channel from switch terminal board  or wall push bottom it power on but the real status not update on home assistant  app is not changing the status in home assistant to on or off
i work whit node-red ,          , need help whit this
  Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command
Posted by: admin - 11-02-2021, 12:38 AM - Forum: KC868-A series and Uair Smart Controller - Replies (2)
ESPHome configure for KC868-A8:
function list:
1. 8 relay output
2. 8 switch input trigger relay output by on_press action
3. monitor 2 channel analog input for DC
4. TEMP-1 port: 2 channel DS18B20 temperature sensor use by 1 ports, actually, you can connect multi DS18B20 by one wire.
5. TEMP-4 port: WS2812B LED strip for 1 meter (30 LEDs)
6. network by Ethernet cable
  platform: ESP32
ota:
  password: "bfb55afbf347b27a4bda0a1d36ee994f"
web_server:
  port: 80
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  - id: 'pcf8574_hub_output'
  - id: 'pcf8574_hub_input'
# Individual outputs
      pcf8574: pcf8574_hub_output
      # Use pin number 0
      # One of INPUT or OUTPUT
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      pcf8574: pcf8574_hub_input
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch1
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch2
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch3
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch4
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch5
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch6
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch7
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch8
dallas:
  - pin: GPIO14
    update_interval: 5s
  - platform: dallas
    address: 0xE701202C5ADED628
  - platform: dallas
    address: 0xBE012115DCBEBC28
  - platform: adc
    pin: GPIO34
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: GPIO35
    update_interval: 5s
    attenuation: 11db
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO33    # Pin Define connected with LED strip
    num_leds: 150  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
KC868-A8/A4 http command list for third party software integration:
read relay state:
http://192.168.1.199/switch/switch1
control relay:
http://192.168.1.199/switch/switch1/turn_on
http://192.168.1.199/switch/switch1/turn_off
http://192.168.1.199/switch/switch1/toggle
read DI state:
http://192.168.1.199/binary_sensor/input1
read temperature:
http://192.168.1.199/sensor/temperature_1
read analog input:
http://192.168.1.199/sensor/analog-in1
read LED strip:
http://192.168.1.199/light/light_strip
control LED strip:
http://192.168.1.199/light/light_strip/turn_on
http://192.168.1.199/light/light_strip/turn_off
http://192.168.1.199/light/light_strip/turn_toggle
debug send command for TEST example: curl -X POST http://192.168.1.199/switch/switch1/toggle
