» Members: 9,830
» Latest member: comhosp
» Forum threads: 4,219
» Forum posts: 20,940
There are currently 146 online users.
» 0 Member(s) | 131 Guest(s)
Amazonbot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
KC868-H32B
5 hours ago
Last Post: viko
5 hours ago
» Replies: 17
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
7 hours ago
» Replies: 19
Kc868ia
Forum: KC868-AI
Today, 01:26 AM
HAv2 ESPHome
Today, 01:24 AM
Need Help Getting Started...
Today, 01:20 AM
No ethernet communication
Yesterday, 10:56 AM
» Replies: 10
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
09-04-2026, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
  KC868-H32BS V1.41 new firmware update
Posted by: admin - 11-04-2021, 01:13 AM - Forum: News - No Replies
improvement:
support set domain for your own server. old version only set server IP address by number. This verison can set by a server domain name for TCP and MQTT server, added DNS function.
download the ZIP file , unzip update the bin file for KC868-H32BS relay controller by USB-RS232 cable.
.zip   H32BS_V141_211101.zip (Size: 52.11 KB / Downloads: 909)
  i need help how to use tcp feedback node to update relay state
Posted by: itzek - 11-02-2021, 07:38 PM - Forum: Development - Replies (5)
Hi
I have H32L I connect it to home assistant : https://www.kincony.com/how-to-create-sw...stant.html
When I power on or off channel from switch terminal board  or wall push bottom it power on but the real status not update on home assistant  app is not changing the status in home assistant to on or off
i work whit node-red ,          , need help whit this
  Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command
Posted by: admin - 11-02-2021, 12:38 AM - Forum: KC868-A series and Uair Smart Controller - Replies (2)
ESPHome configure for KC868-A8:
function list:
1. 8 relay output
2. 8 switch input trigger relay output by on_press action
3. monitor 2 channel analog input for DC
4. TEMP-1 port: 2 channel DS18B20 temperature sensor use by 1 ports, actually, you can connect multi DS18B20 by one wire.
5. TEMP-4 port: WS2812B LED strip for 1 meter (30 LEDs)
6. network by Ethernet cable
  platform: ESP32
ota:
  password: "bfb55afbf347b27a4bda0a1d36ee994f"
web_server:
  port: 80
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  - id: 'pcf8574_hub_output'
  - id: 'pcf8574_hub_input'
# Individual outputs
      pcf8574: pcf8574_hub_output
      # Use pin number 0
      # One of INPUT or OUTPUT
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      # Use pin number 0
      pcf8574: pcf8574_hub_input
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch1
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch2
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch3
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch4
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch5
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch6
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch7
      # Use pin number 0
      inverted: false
    on_press:
      then:
        - switch.toggle: switch8
dallas:
  - pin: GPIO14
    update_interval: 5s
  - platform: dallas
    address: 0xE701202C5ADED628
  - platform: dallas
    address: 0xBE012115DCBEBC28
  - platform: adc
    pin: GPIO34
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: GPIO35
    update_interval: 5s
    attenuation: 11db
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO33    # Pin Define connected with LED strip
    num_leds: 150  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
KC868-A8/A4 http command list for third party software integration:
read relay state:
http://192.168.1.199/switch/switch1
control relay:
http://192.168.1.199/switch/switch1/turn_on
http://192.168.1.199/switch/switch1/turn_off
http://192.168.1.199/switch/switch1/toggle
read DI state:
http://192.168.1.199/binary_sensor/input1
read temperature:
http://192.168.1.199/sensor/temperature_1
read analog input:
http://192.168.1.199/sensor/analog-in1
read LED strip:
http://192.168.1.199/light/light_strip
control LED strip:
http://192.168.1.199/light/light_strip/turn_on
http://192.168.1.199/light/light_strip/turn_off
http://192.168.1.199/light/light_strip/turn_toggle
debug send command for TEST example: curl -X POST http://192.168.1.199/switch/switch1/toggle
  KC868-H32B V4.40 new firmware update
Posted by: admin - 11-01-2021, 01:25 AM - Forum: News - Replies (6)
[Image: kc868-h32b_pix550.jpg]
improvement:
fixed bug when use domain name for server IP need to re power on.
.zip   Relay32_V440_211030.zip (Size: 46.94 KB / Downloads: 1185)
  please help to use mqtt for 32bs
Posted by: engmohades - 10-31-2021, 05:46 AM - Forum: News - Replies (1)
I installed virtual home assistant and i put ip of home assistant in edite node mqtt in & out But no any response and not read state or change chanel relay ( On or Off ) of 32bs relay
and not appear thebutton switch in home assistant dashbord
  KC868-A4 digital input1 trigger relay1 output by ESPHome config demo
Posted by: admin - 10-31-2021, 12:35 AM - Forum: KC868-A4 - No Replies
    pin: GPIO2
    pin: GPIO36
    name: "room lamp Toggle Button"
    on_press:
      then:
        - switch.toggle: lamp
  Lesson26- how to DIY Music Reactive LED strip for Christmas tree
Posted by: admin - 10-29-2021, 06:56 AM - Forum: KC868-A series and Uair Smart Controller - No Replies
1. WS2812B LED strip connect with DS18B20 temperature's port. (it's GPIO13)
2. Sound detect connect with KC868-A4's (DC 0-5V) analog input port. Sound detect is a sensor convert sound to DC 0-5v output.
3. install arduino library "FastLED" online.
arduino IDE source code download:
.zip   music-led.zip (Size: 3.28 KB / Downloads: 946)
  Lesson24- how to use Telegram control KC868-A4 A8 (ESP32) relay output
Posted by: admin - 10-28-2021, 12:41 AM - Forum: KC868-A series and Uair Smart Controller - No Replies
1. Creating a Telegram Bot
Open Telegram and follow the next steps to create a Telegram Bot. First, search for “botfather” and click the BotFather as shown below. Or open this link t.me/botfather in your smartphone.
2. The following window should open and you’ll be prompted to click the "start" button.
3. Type "/newbot" and follow the instructions to create your bot. Give it a name and username.
4. If your bot is successfully created, you’ll receive a message with a link to access the bot and the "bot token". Save the bot token because you’ll need it so that the ESP32/ESP8266 can interact with the bot.
5. Get Your Telegram User ID
a. In your Telegram account, search for “IDBot” or open this link t.me/myidbot in your smartphone.
b. Start a conversation with that bot and type /getid. You will get a reply back with your user ID. Save that user ID, because you’ll need it later in this tutorial.
6. Preparing Arduino IDE
a. download arduino library and source code:
.zip   KC868-A4-A8-Telegram.zip (Size: 75.98 KB / Downloads: 1403)
b. install "Universal Telegram Bot Library" : Go to Sketch > Include Library > Add.ZIP Library...
c. install "ArduinoJson Library" :
  Go to Skech > Include Library > Manage Libraries.
  Search for “ArduinoJson”.
  Install the library.
d. open source code, replace ssid , password, CHAT_ID, BOTtoken for youself.
e. download firmware and test.
  Lesson25- how to send alert message to Whatsapp by KC868-A4 A8 (ESP32)
Posted by: admin - 10-27-2021, 06:45 AM - Forum: KC868-A8 - Replies (21)
You need to get the apikey form the bot before using the API:
1. Add the phone number +34 644 56 55 18  into your Phone Contacts. (Name it it as you wish)
2. Send this message "I allow callmebot to send me messages" to the new Contact created (using WhatsApp of course)
3. Wait until you receive the message "API Activated for your phone number. Your APIKEY is 123123" from the bot. As this is still in beta testing, the activation can take up to 2 minutes.
4. The WhatsApp message from the bot will contain the apikey needed to send messages using the API.
You can send text messages using the API after receiving the confirmation.
Example:
5. Enjoy
How to send a WhatsApp text message
https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
[phone_number]: Is your phone number asociated to your WhatsApp including the country code. (Ex: +34 123 123 123).
[text]: Message to send (urlencoded). You can use this online converter to encode the message. (i.e. %20 for space, %0A for new lines). WhatsApp formatting characters are allowed (i.e "*" for bold, etc.). Check here how to include emoticons in the message.
[your_apikey]: The apikey that you received during the activation process (step 4-5 above)
Example:
https://api.callmebot.com/whatsapp.php?p...1234567890
If you have problems building the URL, you can try the Web Browser assistant to test the API.
As this API is in beta testing, the messages can be delayed up to 1 minute.
Preparing 433MHz RF wireless sensor
Welding wireless module to KC868-A4 or KC868-A8 PCB board.
install RCSwitch library online.
.zip   KC868-Whatsapp.zip (Size: 1.54 KB / Downloads: 1370)
you need to change WiFi ssid, password, apiKey, phone number, sensor_address, message_to_whatsapp by yourself.
  KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE
Posted by: admin - 10-27-2021, 02:14 AM - Forum: KC868-A8 - Replies (2)
#define ANALOG_A1  34  updated in PCB V1.4
#define ANALOG_A2  35  updated in PCB V1.4
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Relay1 = pcf8574.pinMode(P0, OUTPUT);
Relay2 = pcf8574.pinMode(P1, OUTPUT);
Relay3 = pcf8574.pinMode(P2, OUTPUT);
Relay4 = pcf8574.pinMode(P3, OUTPUT);
Relay5 = pcf8574.pinMode(P4, OUTPUT);
Relay6 = pcf8574.pinMode(P5, OUTPUT);
Relay7 = pcf8574.pinMode(P6, OUTPUT);
Relay8 = pcf8574.pinMode(P7, OUTPUT);
Input_IIC_address 0x22
Input1 = pcf8574.pinMode(P0, INPUT);
Input2 = pcf8574.pinMode(P1, INPUT);
Input3 = pcf8574.pinMode(P2, INPUT);
Input4 = pcf8574.pinMode(P3, INPUT);
Input5 = pcf8574.pinMode(P4, INPUT);
Input6 = pcf8574.pinMode(P5, INPUT);
Input7 = pcf8574.pinMode(P6, INPUT);
Input8 = pcf8574.pinMode(P7, INPUT);
DS18B20/DHT11/DHT21/LED strip -1: 14
DS18B20/DHT11/DHT21/LED strip -2: 13
DS18B20/DHT11/DHT21/LED strip -3: 32   updated in PCB V1.4
DS18B20/DHT11/DHT21/LED strip -4: 33   updated in PCB V1.4
RF433MHz wireless receiver: 15
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
