» Members: 9,831
» Latest member: socoliveglobal
» Forum threads: 4,222
» Forum posts: 20,946
There are currently 577 online users.
» 0 Member(s) | 560 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, Google-Apps-Script, PetalBot, bot
OLED not found in I2C sca...
Forum: KC868-A6v3
2 hours ago
"KCS" v3.27 firmware BIN ...
2 hours ago
ESPHome modbus not functi...
Forum: KC868-A8S
5 hours ago
8 hours ago
» Replies: 18
KC868-H32B
Yesterday, 10:25 AM
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
Yesterday, 08:12 AM
» Replies: 19
Kc868ia
Forum: KC868-AI
Yesterday, 01:26 AM
HAv2 ESPHome
Yesterday, 01:24 AM
Need Help Getting Started...
Yesterday, 01:20 AM
No ethernet communication
09-05-2026, 10:56 AM
» Replies: 10
  Somfy RTS Protocol RF
Posted by: cadejaja - 10-12-2025, 02:07 AM - Forum: KC868-Uair - No Replies
Hi, I am trying integrate shades with somfy motor with the video:
https://www.youtube.com/watch?v=1acVJ0xWJgs
ESP Somfy RTS in the Uair.
But doesn't work. The radio not inicialized.
Could you help me?
  KC868-A16 Rev V1.6: Second PCF8574 Inputs/Outputs Not Working
Posted by: mohaz - 10-09-2025, 08:47 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Dear Support Team,
I recently purchased another KC868-A16 (Revision V1.6). After successfully flashing it with ESPHome, LAN communication is working correctly, and the first 8 inputs/outputs function as expected.
However, the second set of 8 inputs/outputs is not responding. The 12V power supply is connected to the second output slot, and the N line is connected to the second input slot, but the LEDs remain off even when toggled via the web interface.
Below is my PCF8574 configuration, which works properly with my previous A16 units:
  - id: 'pcf8574_hub_output'
  - id: 'pcf8574_hub_output_2'
    address: 0x25
  - id: 'pcf8574_hub_input'
  - id: 'pcf8574_hub_input_2'
    address: 0x21
      pcf8574: pcf8574_hub_output
      # Use pin number 0
      # One of INPUT or OUTPUT
      pcf8574: pcf8574_hub_output_2
      # Use pin number 0
Could this issue be related to the I²C address configuration, or is there a known difference in hardware between revision V1.6 and earlier versions?
Thank you for your assistance.
Best regards,
  reset factory on A8
Posted by: philippe - 10-07-2025, 10:59 AM - Forum: KC868-AM - Replies (5)
Hi,several questions after I spent time on looking answers.
I lost access to my  A8.
What are the S1 and S2 usage? On the schematics, both seems to do the same.
I press more than 10s S1, then S2.
I can connect to Kinc AP on 4.1
On the login page, I tried  admin/null, admin/admin ,always login error.
I tried another board, same issue.
My 12v is 11,7. I guess its not a problem.
Please help
  add webcam
Posted by: shochif - 10-07-2025, 03:30 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (5)
can i add usb webcam to my kincony server 16?
if can what type of webcam must i use cause when i try using obsbot camera on hardware not detected
  Sauna automation with Loxone and Kincony
Posted by: Hakuna23 - 10-05-2025, 12:23 PM - Forum: KinCony integrate with Loxone home automation - Replies (2)
Hi everyone,
I’m planning to automate my sauna using Loxone together with Kincony hardware.
My setup requires:
  • Two temperature sensors (sauna room and heater)
  • At least three relay outputs for sauna control (heater, ventilation, safety, etc.)
  • One or two relays for lighting
I already found some information in the forum about integrating the relay outputs with Loxone, which looks straightforward.
However, I’m still unsure about the OneWire temperature sensors – I know how to connect them to the Kincony board, but I don’t know how to get the temperature values into Loxone.
Would the KC868-A8 v3 board be a good choice for this setup, or is there another Kincony board that fits better?
Thanks in advance for your help and suggestions!
  RTC Battery Holder
Posted by: molelightn - 10-05-2025, 07:33 AM - Forum: B16 - Replies (1)
may a stupid question, but what kind of cell i do have to use for KinCony B16 in the battery holder for the RTC Clock?
Tested some small different ones but none of them fit really good.
br mole
  Which CT clamps for the N30 or other boards N10/N20
Posted by: Vega - 10-04-2025, 03:41 PM - Forum: N30 - Replies (3)
Which CT clamps are for the N30 or N20/N10
Looking for CT clamp for 25A and 50A
  Z1 firmware Issues
Posted by: kz1user - 10-03-2025, 04:18 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (3)
hi, I recently received the Z1 device.
I have noticed a few issues in the Zigbee firmware. I am using the firmware 3.12
1. the Zigbee devices looses the name (label) given.
2. the device state on/off is reported wrongly.
3. the Zigbee devices removed still show up in the monitor.
4. need more time zones.
5. Zigbee tuneable driver not getting properly recognized. only show on and off. no slider for CCT and dimmer
6. sometimes losses the state with MQTT(HA). HA Reports wrong state.
Question Modbus register map
Posted by: nortien - 10-03-2025, 08:32 AM - Forum: KC868-HA /HA v2 - Replies (1)
Hello.
What protocol does the Modbus module use? Modbus RTU?
I need to understand how to connect this module to my non-Kincony controller.
Do you have a Modbus register map? Do you have technical documentation? Please share.
  KC868-32 arduino ide
Posted by: martin - 10-03-2025, 08:28 AM - Forum: KC868-A32/A32 Pro - Replies (8)
I have a new KC868-32. With USB connection, I loaded the exemple"01-control-one-relay" code from arduino ide. On the serial monitor I get the correct responses: "open relay 2 success" . But nothing happen on the board in reality. The relay is not switching. Do you know what could be the reason?  Thank you very much indeed
