» Members: 9,695
» Latest member: officepowercom
» Forum threads: 4,196
» Forum posts: 20,852
There are currently 28 online users.
» 1 Member(s) | 19 Guest(s)
Applebot, Baidu, Crawl, PetalBot, bot, admin
N60 power supply - power ...
Forum: N60
3 hours ago
KC868-meter-7pv-rs485
Forum: Development
Yesterday, 10:20 AM
» Replies: 7
N60 configure yaml for ES...
Forum: N60
08-23-2026, 01:42 AM
» Replies: 7
KCS VERSUS ESPHOME
Last Post: EDVALDO DE MARINGA
08-22-2026, 01:31 PM
KC868-AGv3
08-20-2026, 10:18 PM
Forum: KC868-A32/A32 Pro
Last Post: huanmarie
08-19-2026, 07:09 AM
KC868-H32B V5.08 firmware
Forum: News
Last Post: meoowu77
08-18-2026, 11:46 AM
» Replies: 24
KinCony B2 Smart Controll...
Forum: News
08-17-2026, 01:07 PM
KC868-A8v3 PCB layout CAD...
08-17-2026, 08:44 AM
CT Clamp Compatibility
08-16-2026, 11:08 PM
» Replies: 12
  KC868-A8V3 and ESPHome firmware
Posted by: JuDie07 - 11-12-2025, 09:22 AM - Forum: KC868-HxB series Smart Controller - Replies (7)
Question: According to the description, the KC868-A8v3 board has an ESP32-S3-WROOM-1U (N16R8) installed, right?
According to the datasheet, it is built around the ESP32-S3 series of SoCs, Xtensa® dual-core 32-bit LX7 microprocessor, flash up to 16 MB,
and PSRAM up to 16 MB, so 16 MB is installed!
Do I need to specify this in the configuration?
 flash_size: 16MB
   type: esp-idf
  board: esp32-s3-devkitc-1
  N30 + KCS v3.15.0 firmware
Posted by: HolyKirka - 11-12-2025, 08:49 AM - Forum: N30 - Replies (4)
Hello.
I bought N30. Download and write KCS v3.15.0 firmware for N30.
Some observations.
After changing Current Factor to take effect Reset ARM CPU button must be pressed.
Current Factor:
In youtube video Current Factor mean:
Value*CurrentFactor=desired value.
It's not TRUE. It works like:
Value/CurrentFactor=desired value.
[Image: N30-04.webp]
[Image: N30-01.webp]
I use CT 3000/1 and need to correct values. N30 gives 0.12A instead real value is about 0.17A
Next one. I connect to N2L2 to power source.
[Image: N30-02.webp]
[Image: N30-03.webp]
And I have Power Factor is 0.00. Is it correct?
Voltage and 228.9Frequency are shown correctly.
Best wishes.
  KinCony E16v3 RS485 Din Rail Relay Module released
Posted by: admin - 11-12-2025, 12:17 AM - Forum: News - Replies (1)
KinCony E16v3 RS485 Modbus Din Rail Relay Module based on ARM CPU. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. The manual control buttons can be extend by user. The extend cable MAX support 500 meters. 16 channel removable OMRON high-quality relay. It can integrate to home assistant by ESPHome using RS485 modbus controller.
[Image: E16v3-2.jpg]
Inside relay model : OMRON G2R-1-E SPDT
every channel output : COM,NO,NC
Coil voltage: 12V
MAX current: 16A at 250VAC
Operation Temperature: -40~55℃
Relay consumption: 0.53W/each
Mechanical life: more than 5 million times
Electrical life: (under rated control capacity) more than 100,000 times (ON-OFF frequency 20 times/minute)
Maximum operating frequency: 20 times/minute (under rated control capacity)
16 channel manual control buttons
[Image: E16v3-1.jpg]
There are 3 control mode:
a. relay control by HIGH level (12V or 24V) or LOW level (0v). (It have two different work voltage version)
b. relay control by manual control buttons on board or by extend manual control buttons.
c. relay control by RS485 modbus command.
4 bit DIP switch:
bit 1-2-3: set RS485 address
bit 4: ON: disable RS485 communication  OFF: enable RS485 communication
RS485 protocol: standard MODBUS protocol. default baud rate: 38400bps
[Image: E16V3-diagram-1.jpg]
  Input and output on same pin
Posted by: david.karlas - 11-11-2025, 01:09 AM - Forum: KC868-HxB series Smart Controller - Replies (5)
I wonder if there is any board that fits my needs...
I'm driving lights & blinds using 24VDC relays and all over the house I have buttons(lights) or up/down buttons(blinds). All this buttons have 24VDC and are connected to main junction box that has all this relays which drive 240VAC lights/blinds.
I want board that has single pin(so I need to connect just 1 wire, per light) that reads that wire 24V via optocoupler at same time board has on same pin MOSFET that can drive that relay.
So idea is, that I can detect when user is pressing some button and they drive lights, but at same time I can drive lights and in both cases I want to read this signals.
Does such board exist?
I already have KC868-A16 but as far as understand I need additional optocoupler, since I'm not allowed to connect 24VDC on input, so I need external optocoupler to simulate dry contact on KC868-A16 and makes everything ugly with additional optocoupler and 2 wires per relay.
Thanks,
David
  Esphome restart stand alone
Posted by: wchpikus - 11-08-2025, 08:02 PM - Forum: KC868-A16 - Replies (3)
I have 3x a16 added to HA, but when HA is not availble,i have restart from time to time.
I added api, reboot_timeout 0, but not help.
Now i see on debug no client connected, rebooting.
Is it any sollution to fix restarts when a16 with esphome can working stand alone?
Mayby connect a16 together? Then any a16 will be as serwer and client?
I made light shaft and any reboot reset relays..
Need solution,please.
Regards
  adding HAv2 into Discoverable MQTT for homeassistant
Posted by: swisstmack25 - 11-07-2025, 10:12 AM - Forum: F24 - Replies (1)
I would like to use the discoverable entity for homeassistant , is it possible that the 485 interface HAv2 can also be adopted this way into home assistant?
  KinCony F32 ESP32-S3 16A Removable Relay Board released
Posted by: admin - 11-05-2025, 09:54 PM - Forum: News - Replies (2)
KinCony F32 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. 32 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F32 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F32 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware(tasmota total support MAX 32channel INPUT+OUTPUT ports) for smart home automation DIY. F32 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant.
[Image: F32-1.jpg]
Model No. KinCony F32
Description: KinCony 32 Channel ESP32-S3 Removable Relay Controller – F32
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
32CH OMRON removable relay, every channel have "COM"(common) and "NO"(normal open) ports.
MAX load 250VAC/16A 30VDC/16A
Inputs:
[Image: F32-2.jpg]
  KC868-A8v3 ModBus Temp. Sensor
Posted by: JuDie07 - 11-05-2025, 09:54 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hello, can I read and display an "RS485 Temperature and Humidity Sensor Modbus RTU Use By SHT30" using KCS v3 (3.15.0)?
Under Sensors “Type,” I can only set TR (RS485) and TS (RS485).
  KC868-A6 Flow Control
Posted by: Edomicianoa - 11-04-2025, 04:47 PM - Forum: KC868-A6 - Replies (3)
Prezada Equipe de Suporte Técnico da KinCony,
Estou usando a placa de automação residencial inteligente KC868-A6 V1 4SP .
Preciso saber se é possível usar o controle de fluxo de hardware RTS/CTS (Request To Send / Clear To Send) nas portas seriais RS232 e/ou RS485 integradas .
  • Em caso afirmativo: Poderia especificar quais pinos da placa estão atribuídos aos sinais RTS e CTS para as interfaces RS232 e/ou RS485?
  • Caso a resposta seja NÃO: Você poderia recomendar um modelo alternativo de placa KinCony que suporte o controle de fluxo de hardware RTS/CTS por meio de sua interface RS232?
Agradecemos imensamente sua ajuda para esclarecer as capacidades de hardware da placa KC868-A6.
Muito obrigado, Smile
  D16 Dimmer - Set memory value without turning on via MQTT?
Posted by: stansvec - 11-04-2025, 08:48 AM - Forum: KC868-HxB series Smart Controller - Replies (6)
Is there an MQTT command to update the D16 dimmer's stored brightness memory value WITHOUT actually turning on the dimmer?
Current behavior:
  • Send
    {"dimmer1": {"value": 50}}
    → Light turns on at 50%
  • Send
    {"dimmer1": {"value": 0}}
    → Light turns off, hardware remembers 50%
  • Physical button press → Light restores to 50%
What I need:
  • While dimmer is OFF, update the stored memory to a different value (e.g., 30%)
  • So next physical button press turns on at 30%, not 50%
  • Without the light briefly flashing on
Is there a command like
{"dimmer1": {"memory": 30}}
or similar that only updates the stored value?
Thanks!
