» Members: 9,820
» Latest member: SmileDesignDP
» Forum threads: 4,217
» Forum posts: 20,917
There are currently 83 online users.
» 0 Member(s) | 64 Guest(s)
Amazonbot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, Semrush, bot
29 minutes ago
» Replies: 12
No ethernet communication
10 hours ago
» Replies: 8
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
  Problem when connecting USB-C
Posted by: aym55 - 10-23-2025, 06:27 PM - Forum: N10 - Replies (1)
I just bought N10 module, i connected it to 24V power and it works. However when i try to put USB-C cable from computer to Kincony for download firmware it suddenly have short cut and my 24V power supply turn off , i must take off usb-c for it to work again, this situation is from early begining.I get deffective Unit ?
Thanks.
  Free Sample
Posted by: jamesfreeman - 10-23-2025, 05:58 PM - Forum: Apply for free sample product - No Replies
I would like to request a free sample, under conditions A and B. We are a 501c3 non profit educational makerspace in Austin Tx. We would like to develop a home automation class, and I believe your products would be a great platform to use. Please let me know if this works for you.
  Cant flash esphom
Posted by: muellerjm - 10-22-2025, 04:31 PM - Forum: B16M - Replies (23)
I bought a B16M device and want to flash esphome. However, when I connect the PC to USB, no USB connection is established. Also, no LED lights up. Is the device defective?
  Analog Input NTC
Posted by: Gazura36 - 10-22-2025, 09:22 AM - Forum: KC868-A16 - Replies (3)
I’m trying to connect a 10 kΩ NTC temperature sensor to my KC868-A16 board.
Unfortunately, I don’t get any readings at all.
Which GPIO pins are actually used for the analog inputs?
I used the example code from this forum, but I don’t get any plausible values on any pin.
I also tested by connecting each pin to GND to rule out a sensor issue, but the readings still don’t change.
I’m stuck now — what is the correct code to read the analog inputs properly?
Thanks in advance for your help!
  IIC Not working
Posted by: Eggman - 10-22-2025, 08:16 AM - Forum: KC868-A series and Uair Smart Controller - Replies (4)
All of a sudden none of my sketches using IIC work on my boards.  In the past I have used the sketch below to scan the IIC bus,  I would expect to see several devices detected by default.  However it just says " "No I2C devices found".  I have tested this on several K868 boards.  How could this happen all of a sudden?  It is due to a change in the Arduino IDE environment?  Is it possible that something has changed withing Wire.h?
Many thanks for any assistance.
// SPDX-FileCopyrightText: 2023 Carter Nelson for Adafruit Industries
// SPDX-License-Identifier: MIT
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
  WIRE.begin();
  Serial.begin(9600);
  while (!Serial)
     delay(10);
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    WIRE.beginTransmission(address);
    error = WIRE.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
Photo receive data from switch by RS485 and control output of KC868-A16
Posted by: edg72022 - 10-21-2025, 08:04 PM - Forum: KC868-A16 - Replies (3)
I try to find the way to control Output of KC868-A16.
I found the way to send information from KC868 but not on the other way.
Below a print screen of the way I used to do it.
and the link of data information
D8 Switch RS485
.pdf   D8 Switch RS485(XH)-Hotel polling-2022.12.16.pdf (Size: 619.95 KB / Downloads: 556)
  How to connect photo rezistor (LDR)
Posted by: simpl3x - 10-21-2025, 08:23 AM - Forum: KC868-A8 - Replies (1)
Hi, can I connect LDR to analog input A8 board for insolation detection?
  MODBUS RTU comunication KC868 wich Siemens S1200 RS485
Posted by: naurismaculskis - 10-20-2025, 08:06 PM - Forum: KC868-A6 - Replies (3)
Hello. I have siemens S1200 PLC and I try to comunicate over Modbus RTU and can't get KC868-A6 comunicate over Modbus. Maybe someone has been seting up MB master and has some example in TIA portal? Or maybe someone knows MB Master Data addr?
I was trying to find register addres in  "KC868-A series board protocol – Modbus"  file but there it says that register is 0000 which does not work.
I added MODBUS file in attacment for  KC868 series.
.pdf   KC868-A-series-protocol-ModBus.pdf (Size: 139.11 KB / Downloads: 562)
  a8v3 - RXTX and 4 pulse counters
Posted by: rockyhopper - 10-18-2025, 04:30 PM - Forum: KC868-A8v3 - Replies (1)
I plan to buy a8v3 and use it with ESPhome.
But, I would need:
- RXTX (https://esphome.io/components/uart/#uart) ideally on external connector
- 4 Pulse Counters (PCNT, https://esphome.io/components/sensor/pulse_counter/) on external connector
Could you confirm that:
- for RXTX, I can re-assign pins used for Analog Input (AI-1 and AI-2) and map RXTX on it.
  Would I lost any other feature (than ADS) from a8v3 in that case (I think that ESP32-S3 is limited to 2 end-user RXTX)?
  If that's not possible, can I directly re-use the RS485 connector (for my RXTX pins) as I don't plan to use RS485.
- for my 4 pulse counters, can I re-use the 4 "one-wire with pull-up" (S1 to S4)?
  (I plan to add 1-wire over i2c -- DS2484 to support 1-wire sensors, then I don't need those S1-S4 pins).
Thanks in advance for your support.
  KCS M1 Firmware? (Kincony M1)
Posted by: drony - 10-16-2025, 04:40 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
there are so many firmware files here, I’m really confused.. could you please tell me where the actual firmware is for Kincony M1-v1.2 Energy Meter? Thanks.
