» Members: 9,506
» Latest member: sutbongtvmee
» Forum threads: 4,179
» Forum posts: 20,770
There are currently 40 online users.
» 0 Member(s) | 25 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Google, PetalBot, bot
KinCony F8 + ESPHome: Una...
Forum: F8
Yesterday, 10:44 PM
B8 ADS1115 current inputs
Forum: B8
07-29-2026, 09:47 PM
KINCONY IN KSA
07-29-2026, 10:43 AM
» Replies: 14
A32 Pro ESPHome yaml for ...
Forum: KC868-A32/A32 Pro
07-27-2026, 06:25 AM
E8v3 E16v3 E24v3 relay mo...
Forum: Extender module
07-27-2026, 01:00 AM
KC868-H32B V5.08 firmware
Forum: News
07-25-2026, 11:53 PM
» Replies: 23
Forum: B2
07-25-2026, 06:40 AM
Forum: B2
07-25-2026, 06:39 AM
Forum: B2
07-25-2026, 06:38 AM
Forum: B2
07-25-2026, 06:37 AM
  KCS M1 Firmware? (Kincony M1)
Posted by: drony - 10-16-2025, 04:40 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
there are so many firmware files here, I’m really confused.. could you please tell me where the actual firmware is for Kincony M1-v1.2 Energy Meter? Thanks.
Lightbulb Centralized vs distributed control boards
Posted by: TonyB - 10-16-2025, 12:47 PM - Forum: DIY Project - Replies (3)
Hi everyone, I'm designing a new electrical system with Home Assistant integration for a 120 m² apartment with 8 rooms. I’m currently trying to decide on the best approach for the control boards.
Would you recommend using a single central control board to manage all lights, sockets, and other devices, or would it be better to install multiple smaller boards distributed around the apartment to keep wiring shorter and more efficient?
Any suggestions or examples from similar installations would be really appreciated!
Thanks in advance for your help.
  RF fo KC868-A6
Posted by: D2K - 10-16-2025, 08:00 AM - Forum: KC868-A6 - Replies (5)
Good afternoon
I need to connect an RF button fo KC868-A6 KCS v2.2.14
the firmware "KCS" description lists "support for EV1527 or PT2262, PT2264 wireless remote code"
there is no connection description.
  A16v3 work with HAv2 ESPHome yaml
Posted by: admin - 10-14-2025, 01:04 AM - Forum: KC868-A16v3 - No Replies
  friendly_name: HAv2
  board: esp32-s3-devkitc-1
    type: esp-idf
  baud_rate: 0
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO15
  interrupt_pin: GPIO2
  reset_pin: GPIO1
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.2
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: false
kc868_ha:
  # The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
  # bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
  # Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
  - platform: kc868_ha
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  # The switch is used to control the D1~D6 level output on the KC868 HA board
  # Other parameters refer to: https://esphome.io/components/switch/index.html
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
web_server:
  port: 80
esphome yaml file download:
.txt   HAv2-A16v3-yaml.txt (Size: 3.04 KB / Downloads: 289)
  F24 work with HAv2 with tuya app ESPHome yaml
Posted by: admin - 10-14-2025, 12:19 AM - Forum: F24 - No Replies
  friendly_name: f24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  - source:
      type: git
      ref: v1.3.0
  - source:
      type: git
      ref: v3.0.2
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_in_2'  # for output channel 1-8  + (input 17-24)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: cchos3g1j2ucfbyd
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
kc868_ha:
  uart_id: myuart1
      pcf8574: pcf8574_hub_out_in_2
      number: 12
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f24_output01"
      number: 13
    dp_id: 2
    internal: true
    bind_switch_id: "f24_output02"
      number: 14
    dp_id: 3
    internal: true
    bind_switch_id: "f24_output03"
      number: 15
    dp_id: 4
    internal: true
    bind_switch_id: "f24_output04"
      number: 8
    dp_id: 5
    internal: true
    bind_switch_id: "f24_output05"
      number: 9
    dp_id: 6
    internal: true
    bind_switch_id: "f24_output06"
      number: 10
    dp_id: 101
    internal: true
    bind_switch_id: "f24_output07"
      number: 11
    dp_id: 102
    internal: true
    bind_switch_id: "f24_output08"
      pcf8574: pcf8574_hub_out_1
    dp_id: 103
    internal: true
    bind_switch_id: "f24_output09"
    dp_id: 104
    internal: true
    bind_switch_id: "f24_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "f24_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "f24_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "f24_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "f24_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "f24_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "f24_output16"
      number: 8
    dp_id: 126
    internal: true
    bind_switch_id: "f24_output17"
      number: 9
    dp_id: 129
    internal: true
    bind_switch_id: "f24_output18"
      number: 10
    dp_id: 130
    internal: true
    bind_switch_id: "f24_output19"
      number: 11
    dp_id: 131
    internal: true
    bind_switch_id: "f24_output20"
      number: 12
    dp_id: 132
    internal: true
    bind_switch_id: "f24_output21"
      number: 13
    dp_id: 133
    internal: true
    bind_switch_id: "f24_output22"
      number: 14
    dp_id: 134
    internal: true
    bind_switch_id: "f24_output23"
      number: 15
    dp_id: 135
    internal: true
    bind_switch_id: "f24_output24"
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
    dp_id: 111
    bind_binary_sensor_id: f24_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f24_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f24_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f24_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: f24_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: f24_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: f24_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: f24_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f24_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f24_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f24_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f24_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f24_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f24_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f24_input15
    internal: true
      number: 15
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  - platform: adc
    pin: 5
    name: "f24 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f24 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f24 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f24 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F24");
esphome yaml download:
.txt   HAv2-F24-Tuya.txt (Size: 20.91 KB / Downloads: 276)
  F24 work with HAv2 without tuya app ESPHome yaml
Posted by: admin - 10-14-2025, 12:18 AM - Forum: F24 - No Replies
  friendly_name: HAv2
    type: esp-idf
  baud_rate: 0
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  - source:
      type: git
      ref: v3.0.1
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
kc868_ha:
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
web_server:
  port: 80
.txt   HAv2-F24-yaml.txt (Size: 3.04 KB / Downloads: 236)
Bug KC868-HAv2 issue
Posted by: innovation - 10-13-2025, 10:44 AM - Forum: KC868-A16v3 - Replies (1)
when KC868-A16V3 connected to KC868-HAV2 through ESPHOME it shows below error attached
  friendly_name: KINCONY A16 NEW BOARD
    type: esp-idf
# Enable Home Assistant API with encryption
  encryption:
    key: "71EREQeZmQA2vN1bu/ghatHKmh/3t5Ikq5HELUWX7Lc="
  reboot_timeout: 10s  # Adds a timeout for reboots, ensuring it doesn't hang for long if there's an issue.
ota:
  - platform: esphome
    password: "f93558fce51f7a51c03bd2be87fb08fc"
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO15
  reset_pin: GPIO1
  baud_rate: 9600       # Use standard baud rate for more reliable logging
  level: DEBUG            # Enable debug level for better diagnostics
  - source:
      type: git
      ref: v3.0.2
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
kc868_ha:
    bind_output: 1
    on_press:
      - switch.toggle: switch_1
    bind_output: 2
    on_press:
      - switch.toggle: switch_2
    bind_output: 3
    on_press:
      - switch.toggle: switch_3
    bind_output: 4
    on_press:
      - switch.toggle: switch_4
    bind_output: 5
    on_press:
      - switch.toggle: switch_5
    bind_output: 6
    on_press:
      - switch.toggle: switch_6
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  N30 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:24 AM - Forum: N30 - No Replies
  friendly_name: n30
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  - platform: modbus_controller
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    state_class: total_increasing
    device_class: energy
    address: 140
    unit_of_measurement: kWh
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
    address: 200
    filters:
    - multiply: 0.001
    address: 202
    filters:
    - multiply: 0.001
    address: 204
    filters:
    - multiply: 0.001
    address: 206
    filters:
    - multiply: 0.001
    address: 208
    filters:
    - multiply: 0.001
    address: 210
    filters:
    - multiply: 0.001
    address: 212
    filters:
    - multiply: 0.001
    address: 214
    filters:
    - multiply: 0.001
    address: 216
    filters:
    - multiply: 0.001
    address: 218
    filters:
    - multiply: 0.001
    address: 220
    device_class: power
    filters:
    - multiply: 0.1
    address: 222
    device_class: power
    filters:
    - multiply: 0.1
    address: 224
    device_class: power
    filters:
    - multiply: 0.1
    address: 226
    device_class: power
    filters:
    - multiply: 0.1
    address: 228
    device_class: power
    filters:
    - multiply: 0.1
    address: 230
    device_class: power
    filters:
    - multiply: 0.1
    address: 232
    device_class: power
    filters:
    - multiply: 0.1
    address: 234
    device_class: power
    filters:
    - multiply: 0.1
    address: 236
    device_class: power
    filters:
    - multiply: 0.1
    address: 238
    device_class: power
    filters:
    - multiply: 0.1
    address: 240
    address: 242
    address: 244
    address: 246
    address: 248
    address: 250
    address: 252
    address: 254
    address: 256
    address: 258
    address: 260
    address: 262
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 264
    unit_of_measurement: "°C"
    value_type: FP32_R
    address: 300
    filters:
    - multiply: 0.001
    address: 302
    filters:
    - multiply: 0.001
    address: 304
    filters:
    - multiply: 0.001
    address: 306
    filters:
    - multiply: 0.001
    address: 308
    filters:
    - multiply: 0.001
    address: 310
    filters:
    - multiply: 0.001
    address: 312
    filters:
    - multiply: 0.001
    address: 314
    filters:
    - multiply: 0.001
    address: 316
    filters:
    - multiply: 0.001
    address: 318
    filters:
    - multiply: 0.001
    address: 320
    device_class: power
    filters:
    - multiply: 0.1
    address: 322
    device_class: power
    filters:
    - multiply: 0.1
    address: 324
    device_class: power
    filters:
    - multiply: 0.1
    address: 326
    device_class: power
    filters:
    - multiply: 0.1
    address: 328
    device_class: power
    filters:
    - multiply: 0.1
    address: 330
    device_class: power
    filters:
    - multiply: 0.1
    address: 332
    device_class: power
    filters:
    - multiply: 0.1
    address: 334
    device_class: power
    filters:
    - multiply: 0.1
    address: 336
    device_class: power
    filters:
    - multiply: 0.1
    address: 338
    device_class: power
    filters:
    - multiply: 0.1
    address: 340
    address: 342
    address: 344
    address: 346
    address: 348
    address: 350
    address: 352
    address: 354
    address: 356
    address: 358
    address: 360
    address: 362
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 363
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 364
    value_type: FP32_R
yaml download:
.txt   N30-HA.txt (Size: 27.53 KB / Downloads: 427)
  N20 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:23 AM - Forum: N20 - No Replies
  friendly_name: n20
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
      address_0:
      address_1:
      address_2:
      address_3:
      address_4:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
    address: 200
    filters:
    - multiply: 0.001
    address: 202
    filters:
    - multiply: 0.001
    address: 204
    filters:
    - multiply: 0.001
    address: 206
    filters:
    - multiply: 0.001
    address: 208
    filters:
    - multiply: 0.001
    address: 210
    filters:
    - multiply: 0.001
    address: 212
    filters:
    - multiply: 0.001
    address: 214
    filters:
    - multiply: 0.001
    address: 216
    filters:
    - multiply: 0.001
    address: 218
    filters:
    - multiply: 0.001
    address: 220
    device_class: power
    filters:
    - multiply: 0.1
    address: 222
    device_class: power
    filters:
    - multiply: 0.1
    address: 224
    device_class: power
    filters:
    - multiply: 0.1
    address: 226
    device_class: power
    filters:
    - multiply: 0.1
    address: 228
    device_class: power
    filters:
    - multiply: 0.1
    address: 230
    device_class: power
    filters:
    - multiply: 0.1
    address: 232
    device_class: power
    filters:
    - multiply: 0.1
    address: 234
    device_class: power
    filters:
    - multiply: 0.1
    address: 236
    device_class: power
    filters:
    - multiply: 0.1
    address: 238
    device_class: power
    filters:
    - multiply: 0.1
    address: 240
    address: 242
    address: 244
    address: 246
    address: 248
    address: 250
    address: 252
    address: 254
    address: 256
    address: 258
    address: 260
    address: 262
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 264
    value_type: FP32_R
yaml download:
.txt   N20-HA.txt (Size: 18.78 KB / Downloads: 336)
  N10 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:22 AM - Forum: N10 - Replies (7)
  friendly_name: n10
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
      address_0:
      address_1:
      address_2:
      address_3:
      address_4:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
yaml download:
.txt   N10-HA.txt (Size: 10.03 KB / Downloads: 402)
