» Members: 9,708
» Latest member: xx88ac
» Forum threads: 4,198
» Forum posts: 20,859
There are currently 50 online users.
» 0 Member(s) | 38 Guest(s)
Amazonbot, Bytespider, Crawl, PetalBot, bot
kc868-A16S3 v3.2
Forum: Development
Last Post: 5310h
9 minutes ago
SSD1306 with case
Forum: KC868-A16v3
Today, 10:41 AM
N60 power supply - power ...
Forum: N60
Yesterday, 11:26 PM
KC868-meter-7pv-rs485
Forum: Development
Yesterday, 10:20 AM
» Replies: 7
N60 configure yaml for ES...
Forum: N60
08-23-2026, 01:42 AM
» Replies: 7
KCS VERSUS ESPHOME
Last Post: EDVALDO DE MARINGA
08-22-2026, 01:31 PM
KC868-AGv3
08-20-2026, 10:18 PM
Forum: KC868-A32/A32 Pro
Last Post: huanmarie
08-19-2026, 07:09 AM
KC868-H32B V5.08 firmware
Forum: News
Last Post: meoowu77
08-18-2026, 11:46 AM
» Replies: 24
KinCony B2 Smart Controll...
Forum: News
08-17-2026, 01:07 PM
  KC868-H32B V5.06 firmware support Loxone Miniserver directly
Posted by: admin - 07-10-2023, 02:10 AM - Forum: News - No Replies
improvement:
support integrate to Loxone Miniserver system by UDP command directly. Because when relay state and switch state feedback by HTTP command, Loxone need >= every 10 seconds for update, it's slowly. Now we developing new firmware feedback state by UDP command, it's fast. If you want to add to Loxone Miniserver, just enable option for "LOXONE INTEGRATION", then fill the Miniserver IP and Port.
firmware BIN file download for KC868-H32B controller:
.zip   H32B_V506_230629.zip (Size: 134.79 KB / Downloads: 831)
Loxone project file download:
.zip   KinCony-32CH-Relay-Controller.zip (Size: 28.23 KB / Downloads: 822)
added UDP command protocol:
1. control single relay:
RELAY-SET-255,X,Y
X: relay channel ID
Y: 1: ON  0: OFF
For example a: TURN ON relay1:
Send: RELAY-SET-255,1,1  feedback:RELAY-SET-255,1,1,OK
For example b: TURN OFF relay1:
Send: RELAY-SET-255,1,0  feedback:RELAY-SET-255,1,0,OK
2. when relay state changed by any way , will auto feedback to UDP:
RELAY-SET-255,X,Y,OK
X: relay channel ID
Y: 1: ON  0: OFF
RELAY-SET-255,1,1,OK  means: relay1 is ON
RELAY-SET-255,2,0,OK  means: relay2 is OFF
3. when digital input port changed, will auto feedback to UDP:
RELAY-GET_INPUT-255,X,Y,OK
X: digital input ID
Y: 1: ON  0: OFF
For example: digital input2 is ON:
RELAY-GET_INPUT-255,2,1,OK
4. when KinCony Smart Controller re power on , will auto feedback (32 channel relay state+ 6 channel digital input state) to UDP:
[2023-06-29 09:20:23.205]# RECV ASCII FROM 192.168.1.200 :4001>
[2023-06-29 09:20:23.206]# RECV ASCII FROM 192.168.1.200 :4001>
[2023-06-29 09:20:23.207]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,3,0,OK
[2023-06-29 09:20:23.208]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,4,0,OK
[2023-06-29 09:20:23.209]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,5,0,OK
RELAY-SET-255,6,0,OK
[2023-06-29 09:20:23.210]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,7,0,OK
RELAY-SET-255,8,0,OK
[2023-06-29 09:20:23.213]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,9,0,OK
[2023-06-29 09:20:23.219]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,10,0,OK
[2023-06-29 09:20:23.222]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,11,0,OK
[2023-06-29 09:20:23.223]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,12,0,OK
[2023-06-29 09:20:23.225]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,13,0,OK
[2023-06-29 09:20:23.227]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,14,0,OK
[2023-06-29 09:20:23.229]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,15,0,OK
[2023-06-29 09:20:23.230]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,16,0,OK
[2023-06-29 09:20:23.232]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,17,0,OK
[2023-06-29 09:20:23.236]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,18,0,OK
[2023-06-29 09:20:23.237]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,19,0,OK
[2023-06-29 09:20:23.239]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,20,0,OK
[2023-06-29 09:20:23.241]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,21,0,OK
[2023-06-29 09:20:23.243]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,22,0,OK
[2023-06-29 09:20:23.245]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,23,0,OK
[2023-06-29 09:20:23.246]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,24,0,OK
[2023-06-29 09:20:23.249]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,25,0,OK
[2023-06-29 09:20:23.250]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,26,0,OK
[2023-06-29 09:20:23.252]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,27,0,OK
[2023-06-29 09:20:23.254]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,28,0,OK
[2023-06-29 09:20:23.256]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,29,0,OK
[2023-06-29 09:20:23.257]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,30,0,OK
[2023-06-29 09:20:23.261]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,31,0,OK
[2023-06-29 09:20:23.262]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,32,0,OK
[2023-06-29 09:20:23.265]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,1,0,OK
[2023-06-29 09:20:23.266]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,2,0,OK
[2023-06-29 09:20:23.268]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,3,0,OK
[2023-06-29 09:20:23.270]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,4,0,OK
[2023-06-29 09:20:23.271]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,5,0,OK
[2023-06-29 09:20:23.273]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,6,0,OK
  KC868-H32BS V2.12sp firmware support Loxone Miniserver directly
Posted by: admin - 07-10-2023, 02:05 AM - Forum: News - No Replies
improvement:
firmware BIN file download for KC868-H32BS controller:
.zip   H32BS_V212SP_20230629.zip (Size: 143.34 KB / Downloads: 916)
.zip   KinCony-32CH-Relay-Controller.zip (Size: 28.23 KB / Downloads: 933)
RELAY-SET-255,X,Y
X: relay channel ID
Y: 1: ON  0: OFF
X: relay channel ID
Y: 1: ON  0: OFF
X: digital input ID
Y: 1: ON  0: OFF
  KC868-H32B_Pro V1.18 firmware support Loxone Miniserver directly
Posted by: admin - 07-10-2023, 01:29 AM - Forum: News - Replies (8)
improvement:
firmware BIN file download for KC868-H32B Pro controller:
.zip   H32B_Pro_V118_230629.zip (Size: 55.51 KB / Downloads: 906)
.zip   KinCony-32CH-Relay-Controller.zip (Size: 28.23 KB / Downloads: 940)
RELAY-SET-255,X,Y
X: relay channel ID
Y: 1: ON  0: OFF
X: relay channel ID
Y: 1: ON  0: OFF
X: digital input ID
Y: 1: ON  0: OFF
  KC868 Pulse Command
Posted by: freedom1711 - 07-09-2023, 10:24 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
Does the KC868- H32b have a pulse command? I need to pulse each relay to open a locker door?
If so what is the command via http://
  A16 flash problem
Posted by: saint_code - 07-09-2023, 12:50 PM - Forum: KC868-A series and Uair Smart Controller - Replies (26)
Hi
I am try to flash my brand new KinKony A16 controller with empty sketch using Arduino 2.1.1
earn "A fatal error occurred: Invalid head of packet (0xA6)" error
Linking everything together...
/Users/myuser/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc -nostdlib -L/Users/myuser/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/lib -L/Users/myuser/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/ld -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch/sketch_jul9a.ino.cpp.o /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/core/core.a -lgcc -lesp_websocket_client -lwpa2 -ldetection -lesp_https_server -lwps -lhal -lconsole -lpe -lsoc -lsdmmc -lpthread -llog -lesp_http_client -ljson -lmesh -lesp32-camera -lnet80211 -lwpa_supplicant -lc -lmqtt -lcxx -lesp_https_ota -lulp -lefuse -lpp -lmdns -lbt -lwpa -lspiffs -lheap -limage_util -lunity -lrtc -lmbedtls -lface_recognition -lnghttp -ljsmn -lopenssl -lcore -lfatfs -lm -lprotocomm -lsmartconfig -lxtensa-debug-module -ldl -lesp_event -lesp-tls -lfd -lespcoredump -lesp_http_server -lfr -lsmartconfig_ack -lwear_levelling -ltcp_transport -llwip -lphy -lvfs -lcoap -lesp32 -llibsodium -lbootloader_support -ldriver -lcoexist -lasio -lod -lmicro-ecc -lesp_ringbuf -ldetection_cat_face -lapp_update -lespnow -lface_detection -lapp_trace -lnewlib -lbtdm_app -lwifi_provisioning -lfreertos -lfreemodbus -lethernet -lnvs_flash -lspi_flash -lc_nano -lexpat -lfb_gfx -lprotobuf-c -lesp_adc_cal -ltcpip_adapter -lstdc++ -Wl,--end-group -Wl,-EL -o /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.elf
/Users/myuser/Library/Arduino15/packages/esp32/tools/esptool_py/3.0.0/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.bin /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.elf
esptool.py v3.0-dev
python /Users/myuser/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/gen_esp32part.py -q /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/partitions.csv /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.partitions.bin
/Users/myuser/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-size -A /private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.elf
Sketch uses 199324 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13224 bytes (4%) of dynamic memory, leaving 314456 bytes for local variables. Maximum is 327680 bytes.
"/Users/myuser/Library/Arduino15/packages/esp32/tools/esptool_py/3.0.0/esptool" --chip esp32 --port "/dev/cu.usbserial-210" --baud 921600  --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 "/Users/myuser/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/partitions/boot_app0.bin" 0x1000 "/Users/myuser/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/bin/bootloader_dio_80m.bin" 0x10000 "/private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.bin" 0x8000 "/private/var/folders/42/swzk51zs3x93tjqmp7mlcmhm0000gn/T/arduino/sketches/F59284665596F1CC333E4934A94B676A/sketch_jul9a.ino.partitions.bin"
esptool.py v3.0-dev
Serial port /dev/cu.usbserial-210
Connecting....
Chip is ESP32-D0WD-V3 (revision 3)
Crystal is 40MHz
MAC: b0:a7:32:80:e4:a0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Failed uploading: uploading error: exit status 2
also esptool shows some other errors
esptool.py --baud 115200 write_flash 0x0 tasmota32.bin --flash_freq 80m --flash_mode dio --flash_size 4MB
esptool.py v4.6.2
Found 2 serial ports
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Detecting chip type... ESP32
Chip is ESP32-D0WD-V3 (revision v3.1)
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Flash will be erased from 0x00000000 to 0x001d3fff...
Compressed 1915648 bytes to 1228182...
Writing at 0x0000e5d8... (4 %)Traceback (most recent call last):
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/__init__.py", line 1073, in _main
    main()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/__init__.py", line 868, in main
    operation_func(esp, args)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/cmds.py", line 595, in write_flash
    esp.flash_defl_block(block, seq, timeout=timeout)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/loader.py", line 131, in inner
    return func(*args, **kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/loader.py", line 1037, in flash_defl_block
    self.check_command(
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/loader.py", line 436, in check_command
    val, data = self.command(op, data, chk, timeout=timeout)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/loader.py", line 405, in command
    p = self.read()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/esptool/loader.py", line 338, in read
    return next(self._slip_reader)
StopIteration
A fatal error occurred: The chip stopped responding.
but erase  successfully
esptool.py erase_flash
esptool.py v4.6.2
Connecting....
Connecting....
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 0.1s
Hard resetting via RTS pin...
some additional info from Arduino serial port monitor
looks like A16 is into continius loop reset ?
[13:42:55]rst:0x3 (SW_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
[13:42:55]configsip: 0, SPIWP:0xee
[13:42:56]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[13:42:56]mode:DIO, clock div:2
[13:42:56]load:0x3fff0030,len:1184
[13:42:56]load:0x40078000,len:12784
[13:42:56]load:0x40080400,len:3032
[13:42:56]entry 0x400805e4
[13:42:56]ets Jul 29 2019 12:21:46
[13:42:56]
[13:42:56]rst:0x3 (SW_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
[13:42:56]configsip: 0, SPIWP:0xee
[13:42:56]
[13:42:57]ets Jul 29 2019 12:21:46
  KC868-A8-E
Posted by: avihay - 07-09-2023, 07:39 AM - Forum: "KCS" v2 firmware system - Replies (11)
Our company purchased a KC868-A8-E board for the project. We received a file that can be used in RF. The file is locked. It is not possible to add an INA266 card in order to finish the automation. Please ESP file or open file of KCS_KC868_A8_V2.0.2
  KC868-A8 with Motion Sensor HC-SR501
Posted by: vijjav - 07-06-2023, 03:03 PM - Forum: KC868-A8 - Replies (7)
I need help connecting pir motion sensor with A8 board. Should i connect with DI 1-8 or s2, s3 terminals?
Here is the code part I am currently using.
    name: "Study Room PIR"
      pcf8574: pcf8574_hub_out_1
      inverted: false
    device_class: motion
#    on_press:
#      then:
#        - switch.toggle: a8_study_room_pir
      inverted: false
  how instal firmware.
Posted by: befree8 - 07-06-2023, 09:24 AM - Forum: KC868-A16S - Replies (13)
Please help, I installed tasmota and wants to return for esphome, how to return to the original software because now by home assistant can not add the device.  ( info with home assistans: "Unable to connect to the ESP. Make sure your YAML file contains the 'api:' line.)
  MQTT SET syntax
Posted by: philippe - 07-05-2023, 04:13 PM - Forum: "KCS" v2 firmware system - Replies (3)
What is the exact syntax to send Relay1 ON with MQTT. I am reading the document , I have my module sending State data, but cant find the right syntax to end  orders.
  kc868-a6 use 2 sensor inputs for analog input
Posted by: Siebje - 07-05-2023, 03:57 PM - Forum: KC868-A6 - Replies (1)
Is there any way to use the two sensor inputs:
[Image: a6-connections.jpg]
I mean the two IO1 and IO2 pins.
is there any way I can read/connect a 0-10 volt sensor to and read out the voltage/analogvalue?
thanks for any help in advance!
