» Members: 9,584
» Latest member: soicauxsmbioo
» Forum threads: 4,191
» Forum posts: 20,830
There are currently 23 online users.
» 0 Member(s) | 13 Guest(s)
Amazonbot, Semrush, bot
N60 Sensor channel label
Forum: N60
Today, 01:50 AM
» Replies: 17
solar production and cons...
Forum: N30
Today, 01:46 AM
Current direction detecti...
Forum: N30
Today, 01:44 AM
MQTT Discovery: missing s...
Forum: N30
Yesterday, 02:48 PM
ai automation
Forum: KinCony integrate with Loxone home automation
Last Post: mediverticals
Yesterday, 06:56 AM
Connecting sensors to Kin...
Forum: F16
Yesterday, 12:18 AM
CT Sensor Direction
Forum: N60
08-12-2026, 08:14 AM
N60 Voltage reference
Forum: N60
08-11-2026, 11:09 PM
4-20mA loop voltage consi...
Forum: B4M
08-11-2026, 08:05 AM
K868-a32 plastic case
08-10-2026, 08:48 AM
  Digital input max voltage
Posted by: jeepxj - 08-02-2023, 06:03 PM - Forum: KC868-HxB series Smart Controller - Replies (5)
What is the voltage range for the digital inputs?  I'm trying to use this in an automotive setting so it might see up to 18v at times.
what about the main power input.  is 12v really the max here?
  Node-Red apple homkit integration
Posted by: Saif Kitany - 07-30-2023, 10:37 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
I programmed this scheme to control my H32B by apple homekit. for test, programmed a "light1" by homekit service node, and i can controll it by homkit app in my iphone, but the command doesnt reach the H32B. IS there a miss in the way that i should add???
link for scheme image :
https://ibb.co/JKjY6L4
  Integrate Home Assistant by windows OS
Posted by: Saif Kitany - 07-28-2023, 12:47 AM - Forum: News - Replies (6)
I'm trying to integrate home assistant by windows OS.
I did all the steps as explained in this link : https://www.kincony.com/home-assistant-r...odule.html.
when i put the the command "hass --open-ui", i get the message " Home Assistant only supports Linux, OSX and Windows using WSL"!!!
what I might did wrong in the way?
  "KCS" v2.0.6 firmware BIN file download
Posted by: admin - 07-27-2023, 12:06 AM - Forum: "KCS" v2 firmware system - Replies (4)
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.0.6 improment:
add support KC868-A4S and KC868-AP dimmer board.
.zip   KCS_KC868_A32M_V2.0.6.zip (Size: 828.2 KB / Downloads: 1078)
.zip   KCS_KC868_A32_V2.0.6.zip (Size: 809.63 KB / Downloads: 1017)
.zip   KCS_KC868_A64_V2.0.6.zip (Size: 809.84 KB / Downloads: 909)
.zip   KCS_KC868_A128_V2.0.6.zip (Size: 809.83 KB / Downloads: 1065)
.zip   KCS_KC868_AG_V2.0.6.zip (Size: 786.79 KB / Downloads: 963)
.zip   KCS_KC868_AI_V2.0.6.zip (Size: 811.96 KB / Downloads: 984)
.zip   KCS_KC868_AK_V2.0.6.zip (Size: 790.03 KB / Downloads: 917)
.zip   KCS_KC868_AM_V2.0.6.zip (Size: 801.46 KB / Downloads: 976)
.zip   KCS_KC868_AP_v2.0.6.zip (Size: 769.51 KB / Downloads: 920)
.zip   KCS_KC868_ASR_V2.0.6.zip (Size: 776.95 KB / Downloads: 942)
.zip   KCS_KC868_E16S_V2.0.6.zip (Size: 812 KB / Downloads: 906)
.zip   KCS_KC868_UAIR_V2.0.6.zip (Size: 790.16 KB / Downloads: 900)
.zip   KCS_KC868_A2_V2.0.6.zip (Size: 814.49 KB / Downloads: 1012)
.zip   KCS_KC868_A4_V2.0.6.zip (Size: 804.82 KB / Downloads: 1009)
.zip   KCS_KC868_A4S_V2.0.6.zip (Size: 825.9 KB / Downloads: 1011)
.zip   KCS_KC868_A6_V2.0.6.zip (Size: 800.29 KB / Downloads: 904)
.zip   KCS_KC868_A8_V2.0.6.zip (Size: 808.17 KB / Downloads: 1066)
.zip   KCS_KC868_A8M_V2.0.6.zip (Size: 825.49 KB / Downloads: 924)
.zip   KCS_KC868_A8S_V2.0.6.zip (Size: 827.3 KB / Downloads: 932)
.zip   KCS_KC868_A16_V2.0.6.zip (Size: 815.81 KB / Downloads: 1036)
.zip   KCS_KC868_A16S_V2.0.6.zip (Size: 826.91 KB / Downloads: 851)
  KC868-M16v2 iot ESP32 power meter board released
Posted by: admin - 07-25-2023, 01:42 PM - Forum: News - Replies (10)
We have designed KC868-M16v2 new version (ESP32 16 Channel CT Clamp Energy Monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH CT Clamp sensor INPUT ports + 3CH ZMPT101B voltage sensor + SHT30 temperature & humidity sensor + Ethernet POE+ WiFi + Bluetooth + DS3231 RTC module + SSD1306 I2C LCD display + SD card.
[Image: KC868-M16v2-1_01.jpg]
[Image: KC868-M16v2-1_02.jpg]
[Image: KC868-M16v2-1_03.jpg]
  easiest way using home assistant with IR devices by KC868-AG
Posted by: admin - 07-25-2023, 11:47 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - No Replies
1. use KC868-AG download KCS v2 firmware.
2. learn IR signal from IR remote
3. copy send IR http command, create rest_command in home assistant:
rest_command:
  fan_http:
    url: "http://192.168.3.123/ctrl.cgi?cmd=run_ir&id=1&value=0&secret=abcd"
4. add a regular button card from the UI, you’ll see the option to change the tap action to a  call service.
  "KCS" v2 firmware HTTP protocol document
Posted by: admin - 07-24-2023, 03:44 AM - Forum: "KCS" v2 firmware system - No Replies
Note: This protocol document use for KinCony smart controller:
KC868-AM ASR A2 A4 A4S A6 A8 A8M A8S A16 A16S E16S A32 A32M A64 A128 AG AK AI AIO AP
Different board will have different channel of digital output, digital input , ADC, DAC, so the protocol is same , just according to the hardware resource to set channel number.
.pdf   KC868-A-series-protocol-HTTP_firmware_V2.pdf (Size: 202.86 KB / Downloads: 3304)
  "KCS" v2 firmware MQTT protocol document
Posted by: admin - 07-24-2023, 03:43 AM - Forum: "KCS" v2 firmware system - Replies (28)
.pdf   KC868-A-series-protocol-MQTT_firmware_V2.pdf (Size: 115.15 KB / Downloads: 5176)
  "KCS" v2 firmware STRING protocol document
Posted by: admin - 07-24-2023, 03:43 AM - Forum: "KCS" v2 firmware system - Replies (2)
.pdf   KC868-A-series-protocol-String_firmware_V2.pdf (Size: 151.42 KB / Downloads: 1969)
  Learn the remoter of E8T
Posted by: KinCony Support - 07-24-2023, 03:01 AM - Forum: KC868-E8T - Replies (28)
