» Members: 9,904
» Latest member: mattst88
» Forum threads: 4,232
» Forum posts: 20,985
There are currently 147 online users.
» 0 Member(s) | 135 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Crawl, Google, PetalBot, bot
Pi5R8 Bundle B (CM5 Lite)...
Forum: Pi5R8
6 hours ago
Modbus 485 extender kcs V...
Forum: N30
Yesterday, 10:27 PM
"KCS" v3.27.2 firmware BI...
Yesterday, 02:40 AM
N10 - ESPHome - ARM CPU s...
Forum: N10
09-10-2026, 11:49 PM
extend KC868-A16v3
09-10-2026, 11:48 PM
"KCS" v2.2.21 firmware BI...
09-10-2026, 12:13 PM
KC868-A16 Outputs Y01-Y16...
09-09-2026, 11:15 PM
wish
Forum: KC868-A16v3
09-09-2026, 01:14 PM
Last Post: viko
09-09-2026, 11:39 AM
» Replies: 22
B32M maximum voltage
Last Post: velifetime
09-08-2026, 07:01 AM
  add KinCony energy meter to home assistant by Raspberry Pi CM4 RS485
Posted by: admin - 04-10-2023, 07:39 AM - Forum: KC868-Server Raspberry Pi4 local server - No Replies
.pdf   KinCony-energy-meter-rs485-modbus-protocol.pdf (Size: 120.39 KB / Downloads: 879)
modbus:
  - name: hub1
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyS0
    stopbits: 1
    sensors:
    - name: meter-voltage
      slave: 1
      address: 100
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: V
      device_class: voltage
    - name: meter-current
      slave: 1
      address: 106
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: A
      device_class: current
    - name: meter-power
      slave: 1
      address: 118
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: kW
      device_class: power
    - name: meter-factor
      slave: 1
      address: 142
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
    #  unit_of_measurement:
      device_class: power_factor
    - name: meter-frequency
      slave: 1
      address: 144
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: Hz
      device_class: frequency
    - name: meter-consumption
      slave: 1
      address: 0
      input_type: holding
      data_type: float32
      count: 2
      precision: 2
      unit_of_measurement: kWh
      device_class: energy_storage
  KC868-H32B Pro + KC868-AK work with multi switch panel control same relay
Posted by: admin - 04-06-2023, 06:04 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (6)
such as relay1 control by 2 switch button or 3 switch button or many buttons.
  integrate KC868-Server by RS485 modbus switch to home assistant
Posted by: admin - 04-06-2023, 03:32 AM - Forum: KC868-Server Raspberry Pi4 local server - No Replies
modbus:
  - name: hub1
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyS0
    stopbits: 1
    switches:
      - name: Modbus-S1
        slave: 1
        address: 0
        write_type: coil
      - name: Modbus-S2
        slave: 1
        address: 1
        write_type: coil
      - name: Modbus-S3
        slave: 1
        address: 2
        write_type: coil
      - name: Modbus-S4
        slave: 1
        address: 3
        write_type: coil
      - name: Modbus-S5
        slave: 1
        address: 4
        write_type: coil
      - name: Modbus-S6
        slave: 1
        address: 5
        write_type: coil
      - name: Modbus-S7
        slave: 1
        address: 6
        write_type: coil
      - name: Modbus-S8
        slave: 1
        address: 7
        write_type: coil
      - name: Modbus-S9
        slave: 1
        address: 8
        write_type: coil
      - name: Modbus-S10
        slave: 1
        address: 9
        write_type: coil
      - name: Modbus-S11
        slave: 1
        address: 10
        write_type: coil
      - name: Modbus-S12
        slave: 1
        address: 11
        write_type: coil
      - name: Modbus-S13
        slave: 1
        address: 12
        write_type: coil
      - name: Modbus-S14
        slave: 1
        address: 13
        write_type: coil
      - name: Modbus-S15
        slave: 1
        address: 14
        write_type: coil
      - name: Modbus-S16
        slave: 1
        address: 15
        write_type: coil
Photo RS-232 - LCD Dwin communication
Posted by: bsarevalo - 04-06-2023, 03:16 AM - Forum: KC868-A6 - Replies (3)
Hello everyone ! I have bought some KC868 - A6 modules, a Dwin DMG10600T070 display, which has a configurable RS232 or TTL serial interface port. The screen is powered at 12V and GND is linked to the power and RX - TX communication pins (DB9, pin 2 TX2, pin 3 RX2, pin 5 gnd). When I use the screen simulator and connect the KC868-A6 module to the PC's USB port, the program works perfectly and the communication executes the programmed commands. My query now is how can I program the arduino based KC868-A6 module for RS232 serial communication with the display with the RS232 port that the module has!.
  "KCS" v1.0.24 firmware BIN file download
Posted by: admin - 04-05-2023, 10:48 AM - Forum: "KCS" v2 firmware system - Replies (35)
How to download and use, online guide: https://www.kincony.com/kcs-firmware-esp32-board.html
v1.0.24 improment:
1. Fix some text in webpage.
2. Fix timer bug for different channel reset problem.
3. Let MQTT message feedback only one time, before will be twice.
4. Support RS485 MODBUS Button Adapter – KC868-HA
5. Fix bug of DAC output with tuya app problem.
.zip   KCS_KC868_A4_V1.0.24.zip (Size: 737.3 KB / Downloads: 1164)
.zip   KCS_KC868_A6_V1.0.24.zip (Size: 744.95 KB / Downloads: 990)
.zip   KCS_KC868_A8_V1.0.24.zip (Size: 748.43 KB / Downloads: 945)
.zip   KCS_KC868_A8S_V1.0.24.zip (Size: 755.91 KB / Downloads: 918)
.zip   KCS_KC868_A16_V1.0.24.zip (Size: 756.16 KB / Downloads: 982)
.zip   KCS_KC868_A32_V1.0.24.zip (Size: 756.24 KB / Downloads: 1070)
.zip   KCS_KC868_A64_V1.0.24.zip (Size: 756.17 KB / Downloads: 936)
.zip   KCS_KC868_A128_V1.0.24.zip (Size: 756.25 KB / Downloads: 981)
.zip   KCS_KC868_AI_V1.0.24.zip (Size: 750.33 KB / Downloads: 1164)
.zip   KCS_KC868_AK_V1.0.24.zip (Size: 738.35 KB / Downloads: 943)
.zip   KCS_KC868_E16S_V1.0.24.zip (Size: 756.17 KB / Downloads: 977)
.zip   KCS_KC868_A2_V1.0.25.zip (Size: 716.5 KB / Downloads: 938)
  KC868-H32B_Pro V1.16 firmware
Posted by: admin - 04-05-2023, 10:35 AM - Forum: News - No Replies
.zip   H32B_Pro_V1.16_230404.zip (Size: 54.87 KB / Downloads: 897)
improvement:
add "MOTT feedback all channels" option in webpage setting. Support home bridge.
Enable= MQTT message will feedback all channels state
Disable= MQTT message will feedback single channel
  KC868-A6 Digital input IRQ
Posted by: Libramale - 04-04-2023, 10:51 PM - Forum: KC868-A4 - Replies (5)
Can anybody help me with information relating to the ESP32 GPIO pin used to connect the IRQ (nINT) from the PCF8574 (Digital inputs 1 to 6).
I need to be able to capture very irregular (maybe 10 per minute) but short pulses (< 10mS duration) pulses without missing any.
I would hate to have to schedule I2C reads every 5mS or less to make sure nothing is missed.
I have had a look at the KC868-A4 schematic and the DI1-DI4 pins are directly GPIO connect, not through a PCF8574 GPIO extender.
  Bluetooth of the esp32
Posted by: kontas - 04-04-2023, 08:50 PM - Forum: KC868-A8 - Replies (1)
Hi
It's possible to use the bluetooth of the A8 ;
How to have access to bluetooth (esphome, tasmota, KCS);
Thank you.
Question New project
Posted by: revenson - 04-04-2023, 06:20 AM - Forum: DIY Project - Replies (9)
I am building a house, tell me what is better to use for a smart home:
16 group curtains and roller shutters (I have an RR06 receiver under the roller shutter and I need to connect it to a low current switch and see them in the home assistant) ).
I want to manage underfloor heating, I have 2 floors and warm floors everywhere, it is desirable to manage separately separately.
I will also have RGB in my room and the lighting will also control it (about 5 rooms with RGB), and around the house there will also be ice in the caecum, but an ordinary tape, 300 meters of tape in a circle.
There is also a snow melting system in a circle (ProfiTherm D-4, D-3, ProfiTherm Eko Plus), the shower would be controlled. Lighting will also be about 50 groups.
Cameras in a circle (I want to implement the structure of faces)
Also interested in IC management.
I have a rassbury pi 4 8gb.
  RS485 modbus energy meter integrate to ESPHome yaml file for home assistant
Posted by: admin - 04-03-2023, 12:04 PM - Forum: KC868-A8S - Replies (18)
  platform: ESP32
wifi:
  ssid: "KinCony"
  password: "a12345678"
captive_portal:
  tx_pin: 33
  rx_pin: 32
  baud_rate: 9600
  stop_bits: 1
  parity: EVEN
modbus:
  uart_id: mod_bus
modbus_controller:
  - id: a8s
    address: 0x01
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 5s
  - platform: modbus_controller
    modbus_controller_id: a8s
    register_type: holding
    address: 0x64
    unit_of_measurement: "V"
    value_type: FP32
    accuracy_decimals: 2
    address: 0x6A
    unit_of_measurement: "A"
    value_type: FP32
    address: 0x76
    unit_of_measurement: "kW"
    value_type: FP32
    address: 0x8E
    unit_of_measurement: ""
    value_type: FP32
    name: "Grid Frequency"
    address: 0x90
    unit_of_measurement: "hz"
    value_type: FP32
    address: 0x0
    unit_of_measurement: "kWh"
    value_type: FP32
yaml file for KC868-A8S download:
.txt   HA_modbus_energy-meter.txt (Size: 1.91 KB / Downloads: 1379)
KinCony energy meter RS485 modbus protocol document:
.pdf   KinCony-energy-meter-rs485-modbus-protocol.pdf (Size: 117.75 KB / Downloads: 1770)
