» Members: 9,827
» Latest member: luckywinffund
» Forum threads: 4,218
» Forum posts: 20,923
There are currently 406 online users.
» 1 Member(s) | 388 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot, danielrio
Need Help Getting Started...
Last Post: philippe
57 minutes ago
No ethernet communication
1 hour ago
» Replies: 10
KC868-H32B
1 hour ago
Last Post: viko
3 hours ago
» Replies: 13
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
  ESPHOME KC868-E16S
Posted by: rodrigomallmann - 03-26-2023, 01:19 PM - Forum: KC868-E16S/E16P - Replies (11)
Olá, tudo bem, estou tentando implementar o esphome via home assistant no KC868-E16S, porem quando inicia a compilação esta dando um erro conforme imagem em anexo, e no final do processo de instalacao quando tento acionar o relay pelo switch touch o relay nao fica armado. Poderia me orientar onde eu estou errando no processo. Um detalhe importante, se instalo a versao web, o equipamento funciona normalmente.
  How can I control somfy rolling shutter over home assistant frequency 433.42 MHz
Posted by: engmohades - 03-25-2023, 11:14 PM - Forum: DIY Project - Replies (1)
Please, How can I control somfy rolling shutter over home assistant
  Relay
Posted by: lori72 - 03-24-2023, 07:31 PM - Forum: KC868-A4S - Replies (7)
Hi, I can't understand which doors are to be configured to command the relays from ESP32.
can you help me. From the example file I can't understand, thanks
  KC868-AIO configure yaml for ESPhome
Posted by: admin - 03-24-2023, 12:11 AM - Forum: KC868-AIO - Replies (25)
.txt   KC868-AIO-ESPHome.txt (Size: 20.73 KB / Downloads: 2131)
  KC868-AIO ESP32 I/O pin define
Posted by: admin - 03-24-2023, 12:09 AM - Forum: KC868-AIO - Replies (10)
ESP32 ANALOG_A1 GPIO36 For (Analog Multiplexer: cd74hc4067) to extend "analog input" 1-16
ESP32 ANALOG_A2  GPIO39  analog input 17
ESP32 ANALOG_A3  GPIO34  analog input 18
ESP32 ANALOG_A4  GPIO35  analog input 19
IIC Bus:A
SDA-A:GPIO4
SCL-A:GPIO16
PCF8575:U40 (output 1-16): 100 100 = 0x24
PCF8575:U41 (output 17-32): 100 101 = 0x25
PCF8575:U42 (output 33-38): 100 110 = 0x26
cd74hc4067
S0-A: PCF8575->U42->P10 (output 33)
S1-B: PCF8575->U42->P11 (output 34)
S2-C: PCF8575->U42->P12 (output 35)
S3-D: PCF8575->U42->P13 (output 36)
free LEDs:
LED-D7: PCF8575->U42->P14 (output 37)
LED-D8: PCF8575->U42->P15 (output 38)
PCF8575:U35 (input 1-16): 100 001 = 0x21
PCF8575:U37 (input 17-32): 100 010 = 0x22
PCF8575:U38 (input 33-48): 100 011 = 0x23
PCF8575:U42 (input 49-58): 100 110 = 0x26
PCF8575->U42->P0 (input 49)
PCF8575->U42->P1 (input 50)
PCF8575->U42->P2 (input 51)
PCF8575->U42->P3 (input 52)
PCF8575->U42->P4 (input 53)
PCF8575->U42->P5 (input 54)
PCF8575->U42->P6 (input 55)
PCF8575->U42->P7 (input 56)
PCF8575->U42->P14 (input 57)
PCF8575->U42->P15 (input 58)
PCA9685: address 0x00
Button-S1: reset
Button-S2: GPIO0
Button-S3: PCF8575->U42->P14 (input 57)
Button-S4: PCF8575->U42->P15 (input 58)
DS18B20/DHT11/DHT21/LED strip -(TP1): GPIO14
DS18B20/DHT11/DHT21/LED strip -(TP2): GPIO5
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD(A): GPIO32
TXD(B): GPIO33
4G GSM Module / Extend serial port:
RXD: GPIO13
TXD: GPIO15
DS3231 RTC module: IIC address 0x68
EEPROM's default I2C address is 0x57
  KC868-AIO datasheet PDF
Posted by: admin - 03-24-2023, 12:08 AM - Forum: KC868-AIO - No Replies
.pdf   KC868-AIO.pdf (Size: 18.41 MB / Downloads: 3140)
  Interruptions from PCF8574
Posted by: istopnic - 03-23-2023, 02:06 PM - Forum: KC868-A16 - Replies (1)
Is it possible to use interruptions on the I2C bus. As I understand, the pins of interruptions from PCF8574 is not connect anywhere.
Which ESP pin can be used to interrupt?
  [Arduino source code for KC868-AIO]-08 DIGITAL_INPUT
Posted by: KinCony Support - 03-23-2023, 01:24 AM - Forum: KC868-AIO - No Replies
#include "Arduino.h"
#include "PCF8575.h"
// Set i2c address
PCF8575 pcf8575_IN1(0x21,4,16);
PCF8575 pcf8575_IN2(0x22,4,16);
PCF8575 pcf8575_IN3(0x23,4,16);
PCF8575 pcf8575_IN4(0x26,4,16);
unsigned long timeElapsed;
  pcf8575_IN1.begin();
  pcf8575_IN2.begin();
  pcf8575_IN3.begin();
  pcf8575_IN4.begin();
  pcf8575_IN1.pinMode(P0,INPUT);
  pcf8575_IN1.pinMode(P1,INPUT);
  pcf8575_IN1.pinMode(P2,INPUT);
  pcf8575_IN1.pinMode(P3,INPUT);
  pcf8575_IN1.pinMode(P4,INPUT);
  pcf8575_IN1.pinMode(P5,INPUT);
  pcf8575_IN1.pinMode(P6,INPUT);
  pcf8575_IN1.pinMode(P7,INPUT);
  pcf8575_IN1.pinMode(P8,INPUT);
  pcf8575_IN1.pinMode(P9,INPUT);
  pcf8575_IN1.pinMode(P10,INPUT);
  pcf8575_IN1.pinMode(P11,INPUT);
  pcf8575_IN1.pinMode(P12,INPUT);
  pcf8575_IN1.pinMode(P13,INPUT);
  pcf8575_IN1.pinMode(P14,INPUT);
  pcf8575_IN1.pinMode(P15,INPUT);
  pcf8575_IN2.pinMode(P0,INPUT);
  pcf8575_IN2.pinMode(P1,INPUT);
  pcf8575_IN2.pinMode(P2,INPUT);
  pcf8575_IN2.pinMode(P3,INPUT);
  pcf8575_IN2.pinMode(P4,INPUT);
  pcf8575_IN2.pinMode(P5,INPUT);
  pcf8575_IN2.pinMode(P6,INPUT);
  pcf8575_IN2.pinMode(P7,INPUT);
  pcf8575_IN2.pinMode(P8,INPUT);
  pcf8575_IN2.pinMode(P9,INPUT);
  pcf8575_IN2.pinMode(P10,INPUT);
  pcf8575_IN2.pinMode(P11,INPUT);
  pcf8575_IN2.pinMode(P12,INPUT);
  pcf8575_IN2.pinMode(P13,INPUT);
  pcf8575_IN2.pinMode(P14,INPUT);
  pcf8575_IN2.pinMode(P15,INPUT);
  pcf8575_IN3.pinMode(P0,INPUT);
  pcf8575_IN3.pinMode(P1,INPUT);
  pcf8575_IN3.pinMode(P2,INPUT);
  pcf8575_IN3.pinMode(P3,INPUT);
  pcf8575_IN3.pinMode(P4,INPUT);
  pcf8575_IN3.pinMode(P5,INPUT);
  pcf8575_IN3.pinMode(P6,INPUT);
  pcf8575_IN3.pinMode(P7,INPUT);
  pcf8575_IN3.pinMode(P8,INPUT);
  pcf8575_IN3.pinMode(P9,INPUT);
  pcf8575_IN3.pinMode(P10,INPUT);
  pcf8575_IN3.pinMode(P11,INPUT);
  pcf8575_IN3.pinMode(P12,INPUT);
  pcf8575_IN3.pinMode(P13,INPUT);
  pcf8575_IN3.pinMode(P14,INPUT);
  pcf8575_IN3.pinMode(P15,INPUT);
  pcf8575_IN4.pinMode(P0,INPUT);
  pcf8575_IN4.pinMode(P1,INPUT);
  pcf8575_IN4.pinMode(P2,INPUT);
  pcf8575_IN4.pinMode(P3,INPUT);
  pcf8575_IN4.pinMode(P4,INPUT);
  pcf8575_IN4.pinMode(P5,INPUT);
  pcf8575_IN4.pinMode(P6,INPUT);
  pcf8575_IN4.pinMode(P7,INPUT);
  pcf8575_IN4.pinMode(P8,OUTPUT);
  pcf8575_IN4.pinMode(P9,OUTPUT);
  pcf8575_IN4.pinMode(P10,OUTPUT);
  pcf8575_IN4.pinMode(P11,OUTPUT);
  pcf8575_IN4.pinMode(P12,OUTPUT);
  pcf8575_IN4.pinMode(P13,OUTPUT);
  pcf8575_IN4.pinMode(P14,INPUT);
  pcf8575_IN4.pinMode(P15,INPUT);
uint16_t var_rcv = 0;
var_rcv = pcf8575_IN1.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input16-input1 state:");
    Serial.println(var_rcv,BIN);
var_rcv = pcf8575_IN2.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input32-input17 state:");
var_rcv = pcf8575_IN3.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input48-input33 state:");
var_rcv = pcf8575_IN4.digitalReadAll();
if (var_rcv!=65535)
    Serial.print("input64-input49 state:");
   delay(500);
.zip   KC868-AIO-PCF8575_DI_XU.zip (Size: 940 bytes / Downloads: 947)
  [Arduino source code for KC868-AIO]-07 PWM_ALL_ON AND OFF
Posted by: KinCony Support - 03-23-2023, 01:24 AM - Forum: KC868-AIO - Replies (2)
/* KC868-AIO_PWM OUTPUT AO_O01----AO_O016*/
#include "PCA9685.h"
PCA9685 pwmController;
    Wire.begin(4,16);
    pwmController.resetDevices();
    pwmController.init();
    pwmController.setPWMFrequency(100);
          for(int j=0;j<=15;j++){
              pwmController.setChannelPWM(j, 0);
              Serial.println(pwmController.getChannelPWM(j));
              pwmController.setChannelPWM(j, 4096);
           delay(3000);
.zip   KC868-AIO-PWM_ALL_ON_OFF.zip (Size: 687 bytes / Downloads: 902)
  [Arduino source code for KC868-AIO]-06 RS485
/*/*WWW.KINCONY.COM*/
/*KC868-AIO code of RS485 */
  Serial2.begin(115200,SERIAL_8N1,32,33);//AIO
   Serial2.println("KC868-AIO RS485 SEND is OK!!");
   Serial2.println("******************");
  /*print the received data of RS485 port*/
  while(Serial2.available()>0)
    Serial2.print((char)Serial2.read());//Read rs485 receive data  and print it
  delay(200);
.zip   KC868-AIO_RS485.zip (Size: 614 bytes / Downloads: 899)
