» Members: 9,989
» Latest member: 1Go
» Forum threads: 4,249
» Forum posts: 21,040
There are currently 447 online users.
» 0 Member(s) | 432 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Crawl, Google, PetalBot, bot
config modbus sensor in K...
7 hours ago
remember relay state
Forum: KC868-E16T
Today, 01:42 AM
getting the A8A inputs to...
Forum: Development
Today, 01:41 AM
Ceiling fan control not w...
Yesterday, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Modbus 485 extender kcs V...
Forum: N30
09-17-2026, 08:10 AM
» Replies: 11
N10 with L1 and L2 suppor...
Forum: N10
09-16-2026, 11:34 PM
KC868-A16v3 PCB layout CA...
09-16-2026, 11:33 PM
Case
Forum: KC868-A16S
09-15-2026, 02:26 AM
KC868-A16S PCB layout CAD...
09-14-2026, 11:23 PM
  KC868-E16S board/schematic errors
Posted by: AshS - 04-16-2023, 09:41 AM - Forum: KC868-E16S/E16P - Replies (7)
I have been trying to get the A1-A4 inputs working without success.
Working from this drawing: KC868-E16S schematic
I have found some errors:
[Image: KC868-E16-S-fault.png]
I have marked up the errors in red.
A1/CHA1 is connected to R92
A2CHA2 is connected to R91
A3/CHA3 is connected to R83
A4/CHA4 is connected to R82
It seems that the labelling on the board connectors, shown below, is incorrect.
[Image: Screenshot-2023-04-16-at-11-44-40.png]
A1 is connected to GPIO36
A2 is connected to GPIO34
A3 is connected to GPIO35
A4 is connected to GPIO39
Input AA1 is connected to LM224 pin 12
Input AA2 is connected to LM224 pin 10
Input AA3 is connected to LM224 pin 5
Input AA4 is connected to LM224 pin 3
The component labelling of the board matches the corrections that I have made for you on the drawing.
Additionally, you will see that two of the zero ohm resistors on my board, R82 and R83 are open circuit, marked with an X.
Please can you tell me how this can be resolved and provide a link to a correct drawing for my board.
Please can you confirm which GPIO is connected to which Analogue input.
Thank you.
  KC868-A6 PCB size details
Posted by: admin - 04-15-2023, 01:15 PM - Forum: KC868-A6 - No Replies
.pdf   A6 SIZE.pdf (Size: 52.1 KB / Downloads: 1035)
  Control relay on KC868-E16S from K868-AM using RS485
Posted by: AshS - 04-14-2023, 09:17 PM - Forum: KC868-AM - Replies (1)
I am using ESPHome on a E16S and an AM board.
I need to control 1 relay on the E16S from the AM board using RS485.
Please can you tell me how do use this?
I have not used RS485 before.
Thank you.
  KC868-A16 - Different digital Output modes
Posted by: oxedgar - 04-14-2023, 04:42 AM - Forum: DIY Project - Replies (8)
Hello, I try to get KCS-Firmware to work has i want...
I have one output to need to work in two modes ...
the first is  normal On-OFF toggle with one input triggered (this work fine)
The the second mode is to delayed this same output if i trigger another input (this do not work)
The result is to provide one wall button to ON Off Light and for the same light one motion PIR not temporised to work with specific delay set in this smart controller!
Can i make this with KCS firmware?
  [Arduino source code for KC868-A8M]-06 RS485
Posted by: KinCony Support - 04-14-2023, 03:19 AM - Forum: KC868-A8M - Replies (6)
#define A8M_RS485_RX 15
#define A8M_RS485_TX 13
  Serial2.begin(115200,SERIAL_8N1,A8M_RS485_RX,A8M_RS485_TX);//A8M
  Serial2.println("A8M RS485 SEND is OK!!");
  /*print the received data of RS485 port*/
  while(Serial2.available()>0)
    Serial2.print((char)Serial2.read());//Read rs485 receive data  and print it
  delay(200);
.zip   KC868-A8M_RS485.zip (Size: 596 bytes / Downloads: 880)
  [Arduino source code for KC868-A8M]-05 OUTPUT
Posted by: KinCony Support - 04-14-2023, 03:16 AM - Forum: KC868-A8M - No Replies
#include "Arduino.h"
#include "PCF8574.h"
#define SDA 5
#define SCL 4
PCF8574 pcf8574_RE1(0x24,SDA,SCL);//DO
for(int i=0;i<=7;i++)
   pcf8574_RE1.pinMode(i, OUTPUT);
   pcf8574_RE1.begin();
  pcf8574_RE1.digitalWrite(i, LOW);delay(200);
  pcf8574_RE1.digitalWrite(i, HIGH);delay(200);
  /******Output is all off by default, and can be turned
on or off manually when pressed by the keypad**************/
  pcf8574_RE1.digitalWrite(i, HIGH);delay(100);
.zip   KC868-A8M_OUTPUT.zip (Size: 664 bytes / Downloads: 806)
  [Arduino source code for KC868-A8M]-04 LAN8720_UDP
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-A8M_LAN8720_UDP.zip (Size: 1.13 KB / Downloads: 831)
  [Arduino source code for KC868-A8M]-03 INPUT
Posted by: KinCony Support - 04-14-2023, 03:15 AM - Forum: KC868-A8M - No Replies
/*KC868-A8M input trigger output*/
#define SDA 5
#define SCL 4
// Set i2c address
PCF8574 pcf8574_IN1(0x22,SDA,SCL);
PCF8574 pcf8574_RE(0x24,SDA,SCL);
unsigned long timeElapsed;
    pcf8574_RE.pinMode(P0, OUTPUT);
    pcf8574_RE.pinMode(P1, OUTPUT);
    pcf8574_RE.pinMode(P2, OUTPUT);
    pcf8574_RE.pinMode(P3, OUTPUT);
    pcf8574_RE.pinMode(P4, OUTPUT);
    pcf8574_RE.pinMode(P5, OUTPUT);
    pcf8574_RE.pinMode(P6, OUTPUT);
    pcf8574_RE.pinMode(P7, OUTPUT);
    pcf8574_IN1.pinMode(P0, INPUT);
    pcf8574_IN1.pinMode(P1, INPUT);
    pcf8574_IN1.pinMode(P2, INPUT);
    pcf8574_IN1.pinMode(P3, INPUT);
    pcf8574_IN1.pinMode(P4, INPUT);
    pcf8574_IN1.pinMode(P5, INPUT);
    pcf8574_IN1.pinMode(P6, INPUT);
    pcf8574_IN1.pinMode(P7, INPUT);
    pcf8574_IN1.begin();
    pcf8574_RE.begin();
uint8_t val1 = pcf8574_IN1.digitalRead(P0);
uint8_t val2 = pcf8574_IN1.digitalRead(P1);
uint8_t val3 = pcf8574_IN1.digitalRead(P2);
uint8_t val4 = pcf8574_IN1.digitalRead(P3);
uint8_t val5 = pcf8574_IN1.digitalRead(P4);
uint8_t val6 = pcf8574_IN1.digitalRead(P5);
uint8_t val7 = pcf8574_IN1.digitalRead(P6);
uint8_t val8 = pcf8574_IN1.digitalRead(P7);
if (val1==LOW) {
  pcf8574_RE.digitalWrite(P0,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P0,HIGH);
if (val2==LOW) {
  pcf8574_RE.digitalWrite(P1,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P1,HIGH);
if (val3==LOW)  {
  pcf8574_RE.digitalWrite(P2,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P2,HIGH);
if (val4==LOW)  {
  pcf8574_RE.digitalWrite(P3,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P3,HIGH);
if (val5==LOW)  {
  pcf8574_RE.digitalWrite(P4,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P4,HIGH);
if (val6==LOW)  {
  pcf8574_RE.digitalWrite(P5,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P5,HIGH);
if (val7==LOW)  {
  pcf8574_RE.digitalWrite(P6,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P6,HIGH);
if (val8==LOW)  {
  pcf8574_RE.digitalWrite(P7,LOW);
  delay(100);
else pcf8574_RE.digitalWrite(P7,HIGH);
    delay(300);
.zip   KC868-A8M_INPUT.zip (Size: 822 bytes / Downloads: 829)
  [Arduino source code for KC868-A8M]-02 DS18B20
Posted by: KinCony Support - 04-14-2023, 03:15 AM - Forum: KC868-A8M - Replies (2)
#include <DS18B20.h>
DS18B20 ds(14);   //IO13
    Serial.printf("Temperature: %.2f C\n",ds.getTempC());
.zip   KC868-A8M_DS18B20.zip (Size: 514 bytes / Downloads: 838)
  [Arduino source code for KC868-A8M]-01 ADC
/*Code for KC868-A8S*/
#define ANALOG_A1   34        // IO36
#define ANALOG_A2   35        // IO39
#define ANALOG_A3   39        // IO34
#define ANALOG_A4   36        // IO35
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  if(analogRead(ANALOG_A1)!=0)
    {  Serial.printf("A1 on Pin(%d)=%d\n",ANALOG_A1,analogRead(ANALOG_A1));delay(500);}
  if(analogRead(ANALOG_A2)!=0)
    {  Serial.printf("A2 on Pin(%d)=%d\n",ANALOG_A2,analogRead(ANALOG_A2));delay(500);}
  if(analogRead(ANALOG_A3)!=0)
    {  Serial.printf("A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));delay(500);}
  if(analogRead(ANALOG_A4)!=0)
    {  Serial.printf("A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));delay(500);}
.zip   KC868-A8M_ADC.zip (Size: 643 bytes / Downloads: 797)
