» Members: 10,100
» Latest member: c168tbcom
» Forum threads: 4,256
» Forum posts: 21,082
There are currently 229 online users.
» 0 Member(s) | 208 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bytespider, Crawl, FeedFetcher, Feedspot, HeadlessChrome, PetalBot, bot
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
Yesterday, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
Yesterday, 12:43 PM
Getting inconsistent/wron...
Yesterday, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
  Pi5v2 server CM5 free GPIO extender pin define
Posted by: admin - 02-23-2026, 05:45 AM - Forum: Pi5 - No Replies
  how to check whether home assistant enabled i2c bus
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5 - No Replies
home assistant OS command line, input command:
ls /dev/i2c-*
then will show i2c dev as this photo.
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5R16 - No Replies
ls /dev/i2c-*
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5R8 - No Replies
ls /dev/i2c-*
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5M8 - No Replies
ls /dev/i2c-*
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5M16 - No Replies
ls /dev/i2c-*
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5R32 - No Replies
check in home assistant menu : Setting -- System -- Hardware -- System hardware page, search "i2c"
or
ls /dev/i2c-*
Posted by: admin - 02-23-2026, 05:37 AM - Forum: Pi5M32 - No Replies
ls /dev/i2c-*
  how to enable i2c bus for CM5 in config.txt file
Posted by: admin - 02-23-2026, 05:34 AM - Forum: Pi5 - No Replies
In the root of the hassos-boot partition, add a new folder called CONFIG.
In the CONFIG folder, add another new folder called modules.
Inside the modules folder add a text file called rpi-i2c.conf with the following content:
i2c-dev
In the root of the hassos-boot partition, edit the file called config.txt at last add two lines to it:
dtparam=i2c_arm=on
dtoverlay=i2c1-pi5,pins_2_3
restart home assistant.
how to check whether have enabled i2c bus for home assistant, see here: https://www.kincony.com/forum/showthread.php?tid=9075
Posted by: admin - 02-23-2026, 05:34 AM - Forum: Pi5R16 - No Replies
i2c-dev
dtparam=i2c_arm=on
