» Members: 10,405
» Latest member: ll88tvcom
» Forum threads: 4,322
» Forum posts: 21,298
There are currently 37 online users.
» 0 Member(s) | 24 Guest(s)
Amazonbot, Bing, Bytespider, Crawl, PetalBot, bot
24 minutes ago
» Replies: 24
Today, 03:04 AM
Today, 01:34 AM
Today, 12:15 AM
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
  [arduino code examples for A6v3]-05 RS232 communication test
Posted by: admin - 01-15-2025, 03:06 AM - Forum: KC868-A6v3 - No Replies
#include "Arduino.h"
// Define RS232 pins
#define RS232_TXD 9 // TX pin
#define RS232_RXD 10 // RX pin
// Define RS232 communication
HardwareSerial RS232(1); // Use UART1
  // Initialize RS232 serial communication
  RS232.begin(9600, SERIAL_8N1, RS232_RXD, RS232_TXD); // Baud rate 9600, 8 data bits, no parity, 1 stop bit
  Serial.begin(115200); // Debug serial communication
  Serial.println("RS232 Communication Initialized");
  static unsigned long lastSendTime = 0;
  // Send a string to RS232 every 5 seconds
  if (millis() - lastSendTime >= 5000) {
    RS232.println("This is KinCony A6v3");
    Serial.println("Sent: This is KinCony A6v3");
    lastSendTime = millis();
  // Check if data is available from RS232
  while (RS232.available()) {
    String receivedData = RS232.readStringUntil('\n'); // Read data from RS232
    RS232.println(receivedData); // Echo the received data back to RS232
    Serial.println("Received and echoed: " + receivedData); // Print the received data to the debug console
arduino ino file download:
.zip   RS232.zip (Size: 659 bytes / Downloads: 809)
.zip   RS232.ino.merged.zip (Size: 184.5 KB / Downloads: 776)
  [arduino code examples for A6v3]-04 RS485 communication test
Posted by: admin - 01-15-2025, 03:04 AM - Forum: KC868-A6v3 - No Replies
* RS485 Communication Test with Echo
* This program tests RS485 communication using ESP32-S3.
* It sends a message over RS485, reads incoming messages, and echoes them back.
* The TXD pin is defined as GPIO 9 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 18
#define RS485_TXD 17
  while (!Serial);
  // Send a test message periodically
// rs485Serial.println("Hello from KinCony A32 Pro!");
  // Wait for a short period
  delay(100);
  // Check if data is available to read from RS485
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message to the serial monitor
    Serial.print("Received: ");
    // Echo the received message back over RS485
    rs485Serial.print("Echo: ");
    rs485Serial.println(receivedMessage);
  delay(2000);
.zip   RS485.zip (Size: 810 bytes / Downloads: 781)
.zip   RS485.ino.merged.zip (Size: 184.34 KB / Downloads: 751)
  [arduino code examples for A6v3]-03 Read analog input ports value
Posted by: admin - 01-15-2025, 03:00 AM - Forum: KC868-A6v3 - No Replies
#include "PCF8574.h"
#define ANALOG_A1   4
#define ANALOG_A2   5
#define ANALOG_A3   6
#define ANALOG_A4   7
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));
  Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));
  delay(500);
.zip   ADC.zip (Size: 397 bytes / Downloads: 813)
.zip   ADC.ino.merged.zip (Size: 195.06 KB / Downloads: 797)
  [arduino code examples for A6v3]-02 Read digital input ports state
Posted by: admin - 01-15-2025, 02:57 AM - Forum: KC868-A6v3 - No Replies
// Set i2c address
PCF8574 pcf8574(0x22);
unsigned long timeElapsed;
Wire.begin(12, 11); // SDA: GPIO12, SCL: GPIO11
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
    if (pcf8574.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
    delay(300);
.zip   8574-DI.zip (Size: 567 bytes / Downloads: 762)
.zip   8574-DI.ino.merged.zip (Size: 191.22 KB / Downloads: 759)
  [arduino code examples for A6v3]-01 Turn ON/OFF OUTPUT
Posted by: admin - 01-15-2025, 02:54 AM - Forum: KC868-A6v3 - No Replies
Blink led on PIN0
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
// Set i2c address
PCF8574 pcf8574(0x24);
//    delay(1000);
    // Set pinMode to OUTPUT
    pcf8574.pinMode(P0, OUTPUT);
  pcf8574.pinMode(P1, OUTPUT);
  pcf8574.pinMode(P2, OUTPUT);
  pcf8574.pinMode(P3, OUTPUT);
  pcf8574.pinMode(P4, OUTPUT);
  pcf8574.pinMode(P5, OUTPUT);
  pcf8574.digitalWrite(P0, HIGH);
  pcf8574.digitalWrite(P1, HIGH);
  pcf8574.digitalWrite(P2, HIGH);
  pcf8574.digitalWrite(P3, HIGH);
  pcf8574.digitalWrite(P4, HIGH);
  pcf8574.digitalWrite(P5, HIGH);
    }else{
    delay(300);
    pcf8574.digitalWrite(P0, LOW);
  delay(300);
  pcf8574.digitalWrite(P1, LOW);
  delay(300);
  pcf8574.digitalWrite(P2, LOW);
  delay(300);
  pcf8574.digitalWrite(P3, LOW);
  delay(300);
  pcf8574.digitalWrite(P4, LOW);
  delay(300);
  pcf8574.digitalWrite(P5, LOW);
  delay(300);
.zip   8574-DO.zip (Size: 594 bytes / Downloads: 851)
.zip   8574-DO.ino.merged.zip (Size: 191.2 KB / Downloads: 819)
  Modbus CRC mistake
Posted by: jltluc57 - 01-14-2025, 02:54 PM - Forum: Development - Replies (20)
I think there is an error in the Modbus document
The CRC is reversed, in the document is FA 3D for me is 3D FA
My tests for this example give me this
Regards
JL
  Problem with names in port monitor - KC868_16A
Posted by: Poczwara13 - 01-14-2025, 01:24 PM - Forum: "KCS" v2 firmware system - Replies (5)
I shared the recording with the problem in the link below:
https://drive.google.com/file/d/1NRPJGf5...KmdYB/edit
The problem occurs when the page is refreshed and affects the names of the input and output ports.
Alternatively, can you add a few additional characters to the port descriptions?
Photo KC868-A16 Tasmota
Posted by: laimonas.kairiukstis - 01-13-2025, 06:49 PM - Forum: KC868-A16 - Replies (1)
what are the steps to start Tasmota on KC868-A16  rev.1.6 ESP32-Wroom-32E.
I started automatic install from Tasmota site:
Install Tasmota
Finally I got Tasmota installed, but the outputs do not work.
  ESPhome homeassistant
Posted by: charmacf - 01-13-2025, 01:24 PM - Forum: KC868-A6 - Replies (17)
i need help on how to control KC868-A6 i tried to install the demo version on the forums but i did something wrong.
  S3 V1.0 firmware
Posted by: henkrouwenhorst - 01-13-2025, 09:46 AM - Forum: "KCS" v2 firmware system - Replies (3)
I am new to programming I have 3 x KC868 A16 boards I have successfully loaded firmware on to all of them and all function great. My problem is to load firmware on the Kincony S3 V1.0 in the " how to use online " section it refers to newer ESP32 S3 boards with the aluminium black case with screen and not the S3 Core board that I have.
I assume my problem is I am trying to load the wrong firmware on my board therefore I have no success. Could someone please give some guidance and a link to the correct firmware.
I want to use this to monitor tank level and temperature and link to my Home Assistant.
It seems there is not many people posting about this specific board in your forum.
