» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 22 online users.
» 0 Member(s) | 14 Guest(s)
Amazonbot, Google, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
Photo KC868-A16 Tasmota
Posted by: laimonas.kairiukstis - 01-13-2025, 06:49 PM - Forum: KC868-A16 - Replies (1)
what are the steps to start Tasmota on KC868-A16  rev.1.6 ESP32-Wroom-32E.
I started automatic install from Tasmota site:
Install Tasmota
Finally I got Tasmota installed, but the outputs do not work.
  ESPhome homeassistant
Posted by: charmacf - 01-13-2025, 01:24 PM - Forum: KC868-A6 - Replies (17)
i need help on how to control KC868-A6 i tried to install the demo version on the forums but i did something wrong.
  S3 V1.0 firmware
Posted by: henkrouwenhorst - 01-13-2025, 09:46 AM - Forum: "KCS" v2 firmware system - Replies (3)
I am new to programming I have 3 x KC868 A16 boards I have successfully loaded firmware on to all of them and all function great. My problem is to load firmware on the Kincony S3 V1.0 in the " how to use online " section it refers to newer ESP32 S3 boards with the aluminium black case with screen and not the S3 Core board that I have.
I assume my problem is I am trying to load the wrong firmware on my board therefore I have no success. Could someone please give some guidance and a link to the correct firmware.
I want to use this to monitor tank level and temperature and link to my Home Assistant.
It seems there is not many people posting about this specific board in your forum.
  KC-868-A4 0v-5v ADC no where near accurate
Posted by: Fleetz - 01-13-2025, 01:44 AM - Forum: KC868-A4 - Replies (5)
Connecting the 0-5v generator to the A3 or A4 the ADC is reporting considerably lower voltages than what is physically generated and measured using a multimeter.
Also if program an event using IFTTT using the ADC voltage to switch a Digital output it will not trigger the event?
E.G. IF AI3 is <=2.00v THEN DO1 to On  if I reduce the voltage to AI3 to less than 2.00v or even drop it down to zero volts DI1 output does not change state.
  Free samples
Posted by: Rineander - 01-12-2025, 05:23 PM - Forum: Apply for free sample product - No Replies
Hello, I’m very interested in trying your products and start using them as part of my home automation system based on home assistant. Since I prefer to use esphome to build my own sensors and stuff, integrating some of your products will take it to the next level. Making my system more efficient and more professional so I can start helping others by making step by step tutorial’s and reviews
Question Firmware A16ESP32
Posted by: jltluc57 - 01-11-2025, 05:59 PM - Forum: KC868-A16 - Replies (3)
Hello everyone,
Sorry for my English, I'm French...
I just bought an A16 and I can't see it on the wired or Wifi network.
I try to update the firmware without result. here is what I have
can you help me please
I'm starting with this product.
Thanks in advance
  Trigger LED on Wall Switch Panel
Posted by: petermac - 01-11-2025, 12:50 PM - Forum: F16 - Replies (5)
With the F16, without having digital out ports, is there any way to trigger the LED light on/off on wall switch panel?
  KC868_A24 FIRMWARE
Posted by: davidecioi - 01-10-2025, 08:57 PM - Forum: KinCony A24 - Replies (5)
HI EVERYONE, I'M LOOKING FOR THE LATEST FIRMWARE FOR THE KC868_A24 BOARD, CAN ANYONE HELP ME?
  Request for KCS Firmware Source Code
Posted by: umutc - 01-10-2025, 06:57 PM - Forum: "KCS" v2 firmware system - Replies (1)
I am currently developing automation software using the Sedona Framework and would like to integrate it with Tridium Niagara. To achieve this, I am seeking access to the KCS firmware source code to facilitate a seamless integration between both platforms.
If you are willing to share the source code, I would greatly appreciate it if you could send it via email to me.
Thank you for your time and consideration.
Best regards,
  Basic Steps to Connect MB to Home Assistant
Posted by: petermac - 01-10-2025, 02:30 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
Have received new MB DC Meter.
Please if you could provide the basics steps to get it connected to Home Assistant.
Thanks.
