» Members: 10,407
» Latest member: ghostwritingservices
» Forum threads: 4,322
» Forum posts: 21,300
There are currently 452 online users.
» 0 Member(s) | 432 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
KC868-A4 – Relay 1 clicks...
48 minutes ago
5 hours ago
» Replies: 24
Yesterday, 03:04 AM
Yesterday, 01:34 AM
Yesterday, 12:15 AM
450 Hz allowed on input?
Forum: Development
11-02-2026, 09:41 PM
How Do You Handle Relay C...
11-02-2026, 05:41 PM
"KCS" v3.27.4 firmware BI...
11-02-2026, 06:02 AM
how to check i2c extend c...
Forum: T16M
11-02-2026, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
11-02-2026, 12:35 AM
Exclamation Problem flashing firmware
Posted by: dolphin78 - 01-03-2025, 12:10 PM - Forum: B16M - Replies (12)
Hello, i m new here and maybe i m doing something wrong but i can't flash the KCS_B16M_V3.4.0.bin in my new arrived B16M device.
I have followed the guide indicated on this page "https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html" step by step, but always after a few seconds of starting, the same error appears.
"8-download data fail"
Tips:
Maybe communication instability cuased this error, you can try to reduce the baud rate of download.
And in the rear command window (black window) appears:
test offset :  0 0x0
case ok
test offset :  0 0x0
case ok
Uploading stub...
Running stub...
Stub running...
Compressed 2718032 bytes to 1085371...
[2025-01-03 13:04:58,490][ESP8266Loader_spi[1]][espDownloader.py][line:606][ERROR]: ESP32S3 Chip flash download error esp_write_flash.
I'm sure i selected chipType: ESP32S3 on the initial screen, why appears "ESP8266Loader_spi" text? Is something wrong?
I have tried different cables, bauds anb firmware versions and managed to make the process last longer each time and the green bar grow more, but it still gives an error and never finishes successfully.
I don't know what to do anymore.
I have searched the forum but haven't found any case similar to mine.
What can I do, any help would be appreciated.
Thanks in advance.
  How to measure a gas meter with a reed sensor and a KC868-A8 board
Posted by: pacitzu - 01-02-2025, 06:35 PM - Forum: KC868-A8 - Replies (1)
I would like to measure a gas meter with a reed sensor and a KC868-A8 board.
I tried to connect it to the dry contacts of the KC868-A8 (pcb v 1.5) but it seems that the pulses that are too fast are not read.
Is it correct to connect the reed sensor directly between GND and a free GPIO S1,S2,S3 or S4 to avoid losing these pulses?
Furthermore, since the KC868-A8 board and the gas meter are very far away (10 meters) and the gas meter is located outside the house, it is recommended to isolate the signals with a board with a 3.3v/12v optocoupler.
Thanks in advance
  GPIO AND Pulse Counter
Posted by: wanball - 01-02-2025, 02:47 AM - Forum: KC868-AM - Replies (1)
Hi
I am making a weather station. I want to know about Pulse Counter. Can I use GPIO1-4. Or do I have to use free GPIOs onboard.
Pulse Counter Sensor
ESPHome Weather Station
[Image: station.jpg]
[Image: pulse-counter.png]
  Can only access password change or System page in incognito mode
Posted by: puterboy - 01-02-2025, 01:04 AM - Forum: KC868-A16 - Replies (2)
I just flashed a new  KC868_A16 board with the latest KCS  v2.2.10 firmware.
I was able to login and change my password the first time via my Chrome browser.
But now I can no longer change the password or even access the "System" tab (all the other tabs seem to work fine)
Specifically, every time I click on either "Admin->Change Password" or on the "System" tab, I get redirected to the "login.html" page and re-prompted for my (current) Login & Password. After successfully logging in (again),  I get re-directed to the "index.html" page.
This happens repeatedly... meaning that I can't change my password or access the System page.
I tried enabling pop-ups, clearing cache, deleting cookies, allowing "insecure" sites, disabling Ad Blocker, etc. but none of this helped.
However if I use "Incognito" mode in Chrome then everything works!!!!
When I use MS Edge, I can't log in *at all* in normal mode -- it just re-displays the login page with blank entries and NO incorrect password pop-up, so presumably it is recognizing my password.
Again, if I use an "InPrivate" window, it all works fine.
  MQTT over wifi not work
Posted by: itzek - 01-01-2025, 05:16 PM - Forum: KC868-HxB series Smart Controller - Replies (9)
Hello admin
, I'm trying to configure the H32B pro and the kc 868 server to work using the mqtt protocol over wifi in front of home assistants, and it doesn't work when I configure the mqtt over ethernet, it works when I configure the same parameters (server, port, username and password)  It doesn't connect on wifi (when I set it up on wifi, I cancel the mqtt on the ethernet)
  A32 pro - 50x ds18b20
Posted by: Tbag - 01-01-2025, 12:21 PM - Forum: KC868-A32/A32 Pro - Replies (1)
Hello, i am looking for information. I want to controll house with home asistent i found that a32 pro should Be enought. But i dont understand all.
I want to controll heating,cooling, fve.... So i need around 50x ds18b20 it is possible to connect it to a32pro? How?
I have more experience with high voltage
  AS voice assistant - Home Assistant - cannot install faster-whisper
Posted by: ZodInLynn - 12-31-2024, 11:19 PM - Forum: KinCony AS - Replies (2)
I have a new AS voice assistant, and am attempting to install it on Home Assistant (running on an 64 bit x86 under a bunch of Linux in virtualbox VM)
While attempting to install faster-whisper I continuously get installation errors, and faster whisper will not install.
--------error log from HA---------
Logger: homeassistant.util.package
Source: util/package.py:152
First occurred: 5:15:01 PM (3 occurrences)
Last logged: 5:15:04 PM
Unable to install package wyoming-faster-whisper==1.0.1: × No solution found when resolving dependencies: ╰─▶ Because only the following versions of ctranslate2 are available: ctranslate2<=3.17.0 ctranslate2==3.17.1 ctranslate2==3.18.0 ctranslate2==3.19.0 ctranslate2==3.20.0 ctranslate2==3.21.0 ctranslate2==3.22.0 ctranslate2==3.23.0 ctranslate2==3.24.0 ctranslate2>4 and ctranslate2>=3.17.0,<=3.24.0 has no wheels with a matching Python ABI tag, we can conclude that ctranslate2>=3.17.0,<3.17.1 cannot be used. And because wyoming-faster-whisper==1.0.1 depends on ctranslate2>=3.17,<4 and you require wyoming-faster-whisper==1.0.1, we can conclude that your requirements are unsatisfiable.
---------END ERROR LOG------
My question is, is there a workaround (already checked faster whisper GitHub for any solutions none there, and this issue has been around since 2023) or can another piece of software be substituted for faster whisper?
Thanks in advance....?
  PWM output
Posted by: TurSolution - 12-29-2024, 10:29 AM - Forum: B16M - Replies (3)
It is possible to do PWM to working with motor and PWM ,
If yes in which voltage?
If no what about the ads1115 it can be config as output or input it possible?
TurSolution
  screens automation with B16M and KCS
Posted by: WimVL - 12-29-2024, 01:00 AM - Forum: "KCS" v2 firmware system - Replies (7)
I testing a B16M controller for my home automation, running KCS v3.4.0 firmware
The screens in my house today work like this:
1 up button, 1 down button per screen with interlock.
Short press = Run for 10 seconds (up or down)
Long press = jogging (up or down)
Can this be implemented with KCS V3 firmware?
Thanks.
  "KCS" v2.2.10 firmware BIN file download
Posted by: admin - 12-29-2024, 12:54 AM - Forum: "KCS" v2 firmware system - Replies (30)
v2.2.10 improvement:
1. Fix the problem that multiple DI false configurations in ifttt cannot work well.
2. Fix the problem that ifttt processing will be blocked when mqtt is disconnected
.zip   KCS_KC868_A32_V2.2.10.zip (Size: 786.31 KB / Downloads: 1040)
.zip   KCS_KC868_A32M_V2.2.10.zip (Size: 804.31 KB / Downloads: 813)
.zip   KCS_KC868_A64_V2.2.10.zip (Size: 786.62 KB / Downloads: 939)
.zip   KCS_KC868_A128_V2.2.10.zip (Size: 786.19 KB / Downloads: 900)
.zip   KCS_KC868_AG_V2.2.10.zip (Size: 764.43 KB / Downloads: 961)
.zip   KCS_KC868_AI_V2.2.10.zip (Size: 789.12 KB / Downloads: 907)
.zip   KCS_KC868_AIO_V2.2.10.zip (Size: 806.16 KB / Downloads: 868)
.zip   KCS_KC868_AK_V2.2.10.zip (Size: 766.85 KB / Downloads: 870)
.zip   KCS_KC868_AM_V2.2.10.zip (Size: 781.85 KB / Downloads: 848)
.zip   KCS_KC868_AP_V2.2.10.zip (Size: 784.5 KB / Downloads: 834)
.zip   KCS_KC868_ASR_V2.2.10.zip (Size: 761.24 KB / Downloads: 899)
.zip   KCS_KC868_E16S_V2.2.10.zip (Size: 791.25 KB / Downloads: 871)
.zip   KCS_KC868_UAIR_V2.2.10.zip (Size: 767.77 KB / Downloads: 912)
.zip   KCS_KC868_A2_V2.2.10.zip (Size: 794.89 KB / Downloads: 885)
.zip   KCS_KC868_A4_V2.2.10.zip (Size: 781.89 KB / Downloads: 936)
.zip   KCS_KC868_A4S_V2.2.10.zip (Size: 805.4 KB / Downloads: 925)
.zip   KCS_KC868_A6_V2.2.10.zip (Size: 780.15 KB / Downloads: 1230)
.zip   KCS_KC868_A8_V2.2.10.zip (Size: 788.76 KB / Downloads: 993)
.zip   KCS_KC868_A8M_V2.2.10.zip (Size: 804.97 KB / Downloads: 881)
.zip   KCS_KC868_A8S_V2.2.10.zip (Size: 806.63 KB / Downloads: 889)
.zip   KCS_KC868_A16_V2.2.10.zip (Size: 796.35 KB / Downloads: 1400)
.zip   KCS_KC868_A16S_V2.2.10.zip (Size: 806.56 KB / Downloads: 903)
