» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 254 online users.
» 0 Member(s) | 224 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Issue with http request - Says http not open
Posted by: fabien1506 - 12-24-2024, 05:47 PM - Forum: KC868-A8 - Replies (12)
Hello Community of Kincony !
I am using a KC868-A8, which is a great product.
I have activated http server to send some commands in tcp to the board.
When I am trying : http://192.168.1.200/ctrl.cgi?secret=abc...=0&value=0
I have the answer : {"code":-2,"status":"http not open"}
I have the answer : { "outputs": [0, 0, 0, 0, 0, 0, 0, 0], "status": "success", "code": 0 }
Any idea of what could be wrong by reading the inputs ?
Thank you !
Fabien
  Cant connect to wifi STA
Posted by: Mesene - 12-23-2024, 03:59 PM - Forum: KC868-A6 - Replies (5)
Hi! First time user here!
I've just received my KC868-A6, I'd like to connect it to my home assistant.
I'm trying to follow the instructions from https://www.kincony.com/esp32-kcsv2-firmware.html using the bin  KC868_A6_V1.0.10.zip
I say "trying" because the instructions are a bit unclear to me when they start using the ethernet cable and the A6 doesn't have one.
I've managed to connect to the board through its wifi and accessing http://192.168.4.1.
From here, I assume I need change the wifi mode to STA and set my home wifi ssid and password and after that the KC868-A6 will be discoverable through the scan device program, right?
My issue is that I can't move forward from this point, after changing it to STA it never connects to my wifi and I need to restart it through the flash program to make the board accessible again.
What am I missing? Did I understood something wrong? I've tried 2g and 5g with the same result.
  How to Use Single Click, Double Click, and Hold Click with KCS868-E16S in Home Assist
Posted by: engrezk - 12-23-2024, 06:28 AM - Forum: KC868-E16S/E16P - Replies (1)
I have a KC868-E16S and I am using KCS firmware. I can use single click, double click, and hold click. My question is, how can these clicks be used in Home Assistant? I want to use single click and double click to turn on and off some switches and lights that are controlled through Home Assistant
  Удлинение провода датчика температуры
Posted by: Dmitry razgulyaev - 12-22-2024, 04:38 PM - Forum: DIY Project - Replies (7)
Можно ли удлинитель провод датчика температуры на 40 метров проводом для интернета? И подойдет ли провод для интернета для выключателя, если выключатель находится за 40 метров?
  KC868-A16 need to power cycle
Posted by: soulmf - 12-22-2024, 10:39 AM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Hi there, i have just installed latest KCS firmware (V2.2.8) on my KC868-A16 and i noticed that besides the ntp time offset problem, after soft restarting the board the lan does not work. The only solution is to power cycle the board. On the wifi, connection re-establishes normally. I guess it's a software issue besause ESPHOME reboots and re-establishes on LAN successfully. Plz consider fixing in on next update. Thank you in advance![url=https://www.kincony.com/forum/showthread.php?tid=7077][/url]
  relay last state
Posted by: icemannz - 12-22-2024, 12:13 AM - Forum: DIY Project - Replies (2)
Hi, I would like to get a KC868-a6 board with the relays to run a home automation project.
The question I have is if it is possible to have the relays resume their last state if there is a power failure or similar.
So if they are reset, they would resume the last known state.
Is this possible and how would I accomplish this,
I have looked at using a MQTT system but I think it would be better if the KC868 board is able to store the state of the relays and then resume the state if reset.
  G1 firmware flash problems
Posted by: gal - 12-21-2024, 07:18 PM - Forum: G1 - Replies (1)
I have tried to flash firmware as shown in video sim7600e at comand...... and after flashing and repower the led display is blank and doesnt work tried many times same result.
  Manual Control Switches Not working
Posted by: Can - 12-21-2024, 04:30 PM - Forum: KC868-E16S/E16P - Replies (3)
Hello... I have a problem.
The manual control switches of my KCS_KC868_E16S are not working, they are not active.
my latest update is “KCS_KC868_E16S_V2.2.8.bin”
It was not working before the update.
I connect to the device via web. buttons work but manual switches are not active
[Image: image.png]
https://www.kincony.com/forum/showthread.php?tid=2241    ( #08-E16S-Ethernet_Web_server_code)
I installed the file on this page but it doesn't work, the ethernet lights don't come on. Only after installing the version update the ethernet lights come on and I can connect via web
  Kincony + Somfy LM100
Posted by: skench - 12-20-2024, 06:05 PM - Forum: F16 - Replies (5)
Good day, I recently bought a kincony f16 for myself. I want to control underfloor heating and electric curtain rods.
Please tell me if you can make a current video where using the new kincony f16 or f24 controllers you can control electric curtain rods via rs485.
For example, how to connect a somfy A-OK LM100 curtain rod.
Thanks in advance.
  Connecting Photoelectric (laser) meter
Posted by: Killi77 - 12-20-2024, 05:04 PM - Forum: KC868-A8 - Replies (3)
Hi, I'm looking for a solution connecting photo-electric (laser) distance meter to KC868-A8. Can I use ADC A1 or A2 port? I don't have the device yet so if you have any advice would be great otherwise I found the one in picture. Can I use this model with some resistor connected in serial to achieve 0-5V? Can you also provide ESP32 coding to configure those ports in Home Assistant please? Thank you.
