» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 168 online users.
» 0 Member(s) | 138 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
Brick C++ application for KC868_M16v2
Posted by: bsarra - 12-12-2024, 09:02 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
I've made available via GitHub project a C++ project for the M16 board.  This application will read CT sensors on the Kincony KC868_M16v2 board and calculate power usage. It allows per sensor configuration and sensor correction algorithms. Periodic MQTT messages are emitted with various readings and configurations can be set via MQTT messages and saved into non-volatile memory.   It also includes an STL to allow you to print a rudimentary cover for the board which will allow it to be surface mounted via screws.
The code is too large to post here, along with the numerous class files, so I'd direct you to Github:  https://github.com/LouPaloma/KinconyM16-PUBLIC
The code is marked with a number of TODO/FIXME, so patches and pull requests are welcome, although I have limited ability to test since my own unit has been "deployed".
(Also, I have identified an issue with the SHT31 sensor, but I will open a separate thread for that.)
  Check about connections
Posted by: Bergoglio - 12-12-2024, 06:16 PM - Forum: KC868-A4S - Replies (2)
Good afternoon,
I want to control 2 different devices fans with 0-10v capabilities of one KC868-A4S but I'm not sure about wiring.
For the first fan from AFL Motors (file 122) these are the connections that I plan :
 - 0-10 VDC yellow on fan with AO1 on KC868-A4S
 - GND blue on fan with GND after AO1 on KC868-A4S
for the second fan from Aermec (file 22) these are the connections that I plan :
 - 0-10V IN V2 blue on Aermec with AO2 on KC868-A4S
 - 0V V1 grey on Aermec with GND after AO1 on KC868-A4S
Am I right or wrong ? If I'm wrong, what are the right connections ?
.pdf   122.pdf (Size: 122.57 KB / Downloads: 867)
.pdf   22.pdf (Size: 226.52 KB / Downloads: 735)
  ESP32 S3 set up issue
Posted by: omarzamudio - 12-12-2024, 05:35 PM - Forum: Extender module - Replies (10)
In a previous email I mentioned that I am using the SIM 7600 module with the ESP32 S3 WROOM 1U, however I can't use the serial monitor in order to receive information (I can't see data), I would like to know if you have any advice for the ESP32 S3 set up in Arduino firmware. See my below set up in tools menu:
[Image: 0?ui=2&ik=2d79881756&attid=0.1&permmsgid...j58g7e0&zw]
I followed you recommendation with ''USB CDC On Boot'' = ENABLE, and now I have below information in the Serial Monitor:
ELF file SHA256: 587cb4fa5
E (159) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
E (167) esp_core_dump_elf: Elf write init failed!
E (172) esp_core_dump_common: Core dump write failed with error=-1
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376f0d
SPIWP:0xee
modeBig GrinIO, clock div:1
load:0x3fce2810,len:0xfdc
load:0x403c8700,len:0x4
load:0x403c8704,len:0xabc
load:0x403cb700,len:0x2d40
entry 0x403c8890
E (113) quad_psram: PSRAM ID read error: 0x00ffffff, PSRAM chip not found or not supported, or wrong PSRAM line mode
E (116) spi_flash: Detected size(8192k) smaller than the size in the binary image header(16384k). Probe failed.
assert failed: __esp_system_init_fn_init_flash startup_funcs.c:95 (flash_ret == ESP_OK)
Backtrace: 0x4037654e:0x3fceb120 0x4037c65d:0x3fceb140 0x403830bd:0x3fceb160 0x4200a903:0x3fceb290 0x4200bd8b:0x3fceb2b0 0x4200bdc5:0x3fceb2d0 0x403768f5:0x3fceb300 0x403cc974:0x3fceb340 0x403ccd39:0x3fceb380 0x403c88fd:0x3fceb4b0 0x40045c01:0x3fceb570 0x40043ab6:0x3fceb6f0 0x40034c45:0x3fceb710
I think I need to change something else in the Tool config but I'm not sure.
Thanks.
  KC868-A8 Switch
Posted by: glorifiedg - 12-12-2024, 01:30 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hi!
I purchased some KC868-A8 to install in my new home and I'm now testing them.
I flashed one with ESPHome but the switches don't change relay state unless I program an automation in Home Assistant to do that (if input1 on/off change alternate relay state). Is it there anyway to configure this without HA? Should I use another firmware for this?
I also like to know if there any other device that can work with dimmable leds.
Photo no access to kcs
Posted by: philippe - 12-12-2024, 10:43 AM - Forum: KC868-A8 - Replies (5)
I received a new A8 board, downloaded KCS with  success, off/on the board. But I cant see the board on my net. Even with your tool udp scan. The board is on the same switch than my PC.
Udp scan can see my two other kincony board. I tried both kcs V2, the V1..no luck.
No problem with Tasmota, I have a wifi access to the board (but not via wire).
I remember , installing them last year was not esay for me, spending too much time.
I have 110 ish IP address on my Lan, many vendors, so far switches from shelly ,dingtian.
I added kincony for the 1wire support. But man, am I stupid for having so much problem with the K boards boards or is my english broken? I hope so and that you will point me to the solution.
Would be so easy for me, to have new board coming with kcs de facto.
Also, I tried to integarte it on HA. I thought it would be easy like the videos show : just copy and paste! . No way, I am fighting with the yaml syntax . I know I should learn the yaml syntax. But you could simplify my job by posting yaml files not text ( or it is hidden on the website?) . Yes I am dumb with yaml. But for newbies like me, we would be more enclined to buy kincony stuff.
Question:
When kcs starts for the first time, is dhcp activated? on wired lan first , right?
I posted my request by email, as you suggest when I contacted via ali. You reply that I should go to the forum. So please for new buyers, on ali , suggest to contact you on the forum.
Image(s)
  connecting the 868-A6 to the Raspberry via a cable
Posted by: Michal.T - 12-12-2024, 09:24 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
What are the options for connecting an A6 to a Raspberry Pi 5 with a cable, followed by integration with Home Assistant?
  433MHz sender and recievers
Posted by: Fleetz - 12-11-2024, 09:30 PM - Forum: KC868-A4 - Replies (1)
I already have these 433MHz sender and reciever modules are these suitable for the KC-868-A4?
Or are the sender and recievers that Kincony sell designed specifically to work only on the KC-868-A4 board?
  B16M Digital Input
Posted by: Dutchkiwi - 12-11-2024, 09:16 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (1)
I'm using a B16M to control a home automation project. It's using a 24V power supply and the B16M is switching a set of 24V relays that switch the 230V mains.
I can switch the relays via Home Assistant and via the ESPHome dashboard but I can't switch the relays using the digital inputs. If I ground a digital input pin I can see the state change on the Home Assistant and ESPHome dashboads but the relay dose not operate.
I am using the B16M ESPHome yaml for home assistant code from the forum which I haven't changed.
Regards
  KC868-H32B momentary switch self reset
Posted by: stybyk - 12-11-2024, 12:14 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
I am facing issue with KC868-H32B relay settings, when i enable relay momentary timer for more than 10 relays, entire settings reset.
Relay setting, password setting all gone.
Chip module is GD32F103
Firmware version H32B_V4.37
Any idea what could be the problem ?
  Set up KC868-A series board
Posted by: CEEGroup - 12-11-2024, 07:42 AM - Forum: KC868-A32/A32 Pro - Replies (1)
Hi dear,
Please give me link software of A32 Pro and M30 for installation with laptop and mobile phone.
If possible, you can support me by using team view as well.
Thank you!
Hang Phay Mr.
