» Members: 10,461
» Latest member: dnvje
» Forum threads: 4,327
» Forum posts: 21,317
There are currently 266 online users.
» 0 Member(s) | 252 Guest(s)
Amazonbot, Applebot, Bytespider, Crawl, Google, PetalBot, bot
Can the digital inputs ac...
Forum: KC868-A16S
7 hours ago
No AP appears
Yesterday, 12:38 AM
» Replies: 8
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
  AS voice assistant - Home Assistant - cannot install faster-whisper
Posted by: ZodInLynn - 12-31-2024, 11:19 PM - Forum: KinCony AS - Replies (2)
I have a new AS voice assistant, and am attempting to install it on Home Assistant (running on an 64 bit x86 under a bunch of Linux in virtualbox VM)
While attempting to install faster-whisper I continuously get installation errors, and faster whisper will not install.
--------error log from HA---------
Logger: homeassistant.util.package
Source: util/package.py:152
First occurred: 5:15:01 PM (3 occurrences)
Last logged: 5:15:04 PM
Unable to install package wyoming-faster-whisper==1.0.1: × No solution found when resolving dependencies: ╰─▶ Because only the following versions of ctranslate2 are available: ctranslate2<=3.17.0 ctranslate2==3.17.1 ctranslate2==3.18.0 ctranslate2==3.19.0 ctranslate2==3.20.0 ctranslate2==3.21.0 ctranslate2==3.22.0 ctranslate2==3.23.0 ctranslate2==3.24.0 ctranslate2>4 and ctranslate2>=3.17.0,<=3.24.0 has no wheels with a matching Python ABI tag, we can conclude that ctranslate2>=3.17.0,<3.17.1 cannot be used. And because wyoming-faster-whisper==1.0.1 depends on ctranslate2>=3.17,<4 and you require wyoming-faster-whisper==1.0.1, we can conclude that your requirements are unsatisfiable.
---------END ERROR LOG------
My question is, is there a workaround (already checked faster whisper GitHub for any solutions none there, and this issue has been around since 2023) or can another piece of software be substituted for faster whisper?
Thanks in advance....?
  PWM output
Posted by: TurSolution - 12-29-2024, 10:29 AM - Forum: B16M - Replies (3)
It is possible to do PWM to working with motor and PWM ,
If yes in which voltage?
If no what about the ads1115 it can be config as output or input it possible?
TurSolution
  screens automation with B16M and KCS
Posted by: WimVL - 12-29-2024, 01:00 AM - Forum: "KCS" v2 firmware system - Replies (7)
I testing a B16M controller for my home automation, running KCS v3.4.0 firmware
The screens in my house today work like this:
1 up button, 1 down button per screen with interlock.
Short press = Run for 10 seconds (up or down)
Long press = jogging (up or down)
Can this be implemented with KCS V3 firmware?
Thanks.
  "KCS" v2.2.10 firmware BIN file download
Posted by: admin - 12-29-2024, 12:54 AM - Forum: "KCS" v2 firmware system - Replies (30)
v2.2.10 improvement:
1. Fix the problem that multiple DI false configurations in ifttt cannot work well.
2. Fix the problem that ifttt processing will be blocked when mqtt is disconnected
.zip   KCS_KC868_A32_V2.2.10.zip (Size: 786.31 KB / Downloads: 1045)
.zip   KCS_KC868_A32M_V2.2.10.zip (Size: 804.31 KB / Downloads: 818)
.zip   KCS_KC868_A64_V2.2.10.zip (Size: 786.62 KB / Downloads: 944)
.zip   KCS_KC868_A128_V2.2.10.zip (Size: 786.19 KB / Downloads: 906)
.zip   KCS_KC868_AG_V2.2.10.zip (Size: 764.43 KB / Downloads: 965)
.zip   KCS_KC868_AI_V2.2.10.zip (Size: 789.12 KB / Downloads: 912)
.zip   KCS_KC868_AIO_V2.2.10.zip (Size: 806.16 KB / Downloads: 874)
.zip   KCS_KC868_AK_V2.2.10.zip (Size: 766.85 KB / Downloads: 878)
.zip   KCS_KC868_AM_V2.2.10.zip (Size: 781.85 KB / Downloads: 851)
.zip   KCS_KC868_AP_V2.2.10.zip (Size: 784.5 KB / Downloads: 840)
.zip   KCS_KC868_ASR_V2.2.10.zip (Size: 761.24 KB / Downloads: 903)
.zip   KCS_KC868_E16S_V2.2.10.zip (Size: 791.25 KB / Downloads: 875)
.zip   KCS_KC868_UAIR_V2.2.10.zip (Size: 767.77 KB / Downloads: 916)
.zip   KCS_KC868_A2_V2.2.10.zip (Size: 794.89 KB / Downloads: 889)
.zip   KCS_KC868_A4_V2.2.10.zip (Size: 781.89 KB / Downloads: 940)
.zip   KCS_KC868_A4S_V2.2.10.zip (Size: 805.4 KB / Downloads: 926)
.zip   KCS_KC868_A6_V2.2.10.zip (Size: 780.15 KB / Downloads: 1237)
.zip   KCS_KC868_A8_V2.2.10.zip (Size: 788.76 KB / Downloads: 998)
.zip   KCS_KC868_A8M_V2.2.10.zip (Size: 804.97 KB / Downloads: 887)
.zip   KCS_KC868_A8S_V2.2.10.zip (Size: 806.63 KB / Downloads: 894)
.zip   KCS_KC868_A16_V2.2.10.zip (Size: 796.35 KB / Downloads: 1403)
.zip   KCS_KC868_A16S_V2.2.10.zip (Size: 806.56 KB / Downloads: 908)
  A16 Digital Inputs
Posted by: plam09 - 12-28-2024, 10:21 PM - Forum: KC868-A16 - Replies (3)
I'm experimenting with Arduino IDE code (modbus server over TCP) with my A16 rev1.6 and I'm noticing something interesting.
The digital inputs do not latch to a value but constantly switch between 0 and the current value - 0 if they are grounded and 1 if they are not grounded.
Testing bench: I have inputs X01, X02 connected to the ground terminal - the rest are not connected to anything.
Those two inputs contansly stay at a value of 0 in the modbus coil. The rest however constantly hover between value of 0 and 1. I'm attaching a screenshot of a trend generated in the modbus simulator and the arduino code. I'm polling it at 100ms so 10 times a second so the graph is as real time as it gets.
What would be the cause of that? Polling time for the PCF8574 or just the I2C bus is switching between the 4 expanders and looses value while its talking to the rest?
Any tips are greatly appreciated!
.txt   PCF.txt (Size: 5.11 KB / Downloads: 619)
  AK KCS firmware - IFTTT multiple custom protocols to one input
Posted by: leliodm - 12-28-2024, 08:29 PM - Forum: "KCS" v2 firmware system - Replies (8)
Hi. I am on the latest KCS firmware on the AK. In the IFTTT menu I am trying to correspond an input to turn on several relays.
For instance, input 33 to turn on relays 17,18,20,21,23,25,26,28,29,7,4 without changing the status of the other relays.
I tried to add several rules in the IFTTT but it seems that it
1) only can use 6 (not a problem, I can have several commands), and
2) if I put multiple rules in the IFTTT window for input 33 it only executes the first one. in the attached picture it only executes rule "Custom Protocol 20"
PS: it seems that if I put a delay of 1 second between one protocol and the next one it executes all of them.
any solution for that ?
thanks
Also, can I get the link for the html protocol and serial protocol for the latest version of KCS?
  Firmware install too fast
Posted by: spentamanyu - 12-28-2024, 04:14 PM - Forum: KC868-A6 - Replies (7)
Hi!
I am new here and I am having some troubles.
my board is the KC868-A6-v1.3
the firmware I am trying to install is the KCS_KC868_A6_V2.2.8.bin
the flash tool version i s the 3.9.2
My problem is that it flashes it way too fast. In the youtube videos you can clearly see a progress bar and that it takes some time to upload the firmware.
Mine does not, it just go from START>SYNC>DOWNLOAD>FINISH  in two seconds. Meanwhile the background shell shows this
is stub and send flash finish
Uploading stub...
Running stub...
Stub running...
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
  but no progressbar or uploaded byte info. How can I be sure that the version has been uploaded properly? Might it be the reason why I don't find any AP after reseting it?
thanks!
  RS485 ON A16
Posted by: tom_elec - 12-28-2024, 09:56 AM - Forum: KC868-A16 - Replies (4)
Hello everyone,
I recently bought a Kincony A16 card with the aim of making it work in RS485 with this Waveshare gateway :
https://www.amazon.fr/dp/B09LQMH2S1?ref=...title&th=1
I control this gateway from a Loxone Miniserver, however I can't really understand the Kincony Modbus register table :
https://kincony.com/forum/attachment.php?aid=2240
The loxone page for modbus communication :
https://www.loxone.com/frfr/kb/communication-modbus/
RS485 transmission is enabled in the A16 and gateway parameters.
I need the I/O address and the register type.
Could someone tell me the requests to send to enable / disable an output and get state of digital / analog input on A16 please ?
Thanks in advance for your help, Tom
Question KC868 A16 mqtt temperature sensor - home assistant
Posted by: bonius - 12-27-2024, 07:21 PM - Forum: KC868-A16 - Replies (5)
My gear: KC868 A16, KCS
DS18B20 connected to chanel 1
I have one DS18B20 connected to chanel 1, and its working correct. I see that temperature is changing through kcs panel
Unfortunately looks like temperature value is not provided by mqtt. Through mqtt explorer i see there is only two threshold values provided by mqtt.
  coding support
Posted by: Salman - 12-27-2024, 07:09 PM - Forum: KC868-A4 - Replies (1)
greetings,
I would like to do the followings
3 digital input and one digital output
the trouble that digital input 3 should be permissive low to activiate relay 1.
then I would  the software while the relay 1 is activiated, to monitor digital input 3.
if it is remain high, keep relay 1
if it is switch to low , de activate relay 1
if ( digital input 1 == high and digital input 2 == high and digital input 3 ==  low ( this is will be permissive signal ) )
digital output 1 == high
if ( digital input 1 = low and digital input 2== low )
digital output 1 == low
if ( digital input 3 == low )
delay 1 minute
digital output 1 = low
