» Members: 10,451
» Latest member: ahmed-KC868-A6
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 537 online users.
» 0 Member(s) | 512 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bytespider, Crawl, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  which board and button
Posted by: Silver - 07-03-2024, 08:11 AM - Forum: DIY Project - Replies (3)
Translator
I would like to know whether the following project is possible and what people think about what I need to order:
I would like to control a rain sprinkler system via home assistant. I think I need a board that is controlled with Ethernet and can control 4-6 relays 24 volt "Hunter 24vac valves (magent coil)".
I would like to have an optional switch, for example
hhttps://shop.kincony.com/products/touch-switch-panel-dry-contact-signal?variant=43573355511973 or hhttps://shop.kincony.com/products/8-gang-wall-toggle-reset-switch-push-button-momentary-contact-for-smart-home-automation-diy
If necessary, you can control the release without a home assistant or an app.
Thank you
Dennis
  ESPHome DAC output DC 0-10V
Posted by: marek - 07-02-2024, 01:44 PM - Forum: KC868-A8M - Replies (1)
Is it possible to use outputs V-OUT1-8 to control a car charger that requires a control DAC output DC 0-10V?
If possible, I would need a KC868-A8M ESP32 I/O pin define.
I assume that the next work will be similar to the post for KC868-AP / ADR: https://www.kincony.com/forum/showthread.php?tid=2889
Heart A32 PRO Infrared
Posted by: thanassis - 07-01-2024, 11:43 AM - Forum: KC868-A32/A32 Pro - Replies (1)
Hi, How to implement infrared in A32 Pro in order to control Air Conditioner in hardware terms.
In a presentation of A32Pro I remember that a pre-cut hole on the right side of the module just below of the GSM antenta mentioned as for infrared module.Where are the pins to connect the I/R transcmitter?
My need is to control one unit of A/C.
  CT Clamp small for 25am
Posted by: kiloptero - 06-30-2024, 05:31 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (11)
any recommendation for a small clamp like the attached picture for 25amp or less for the M30?
  New Energy Board House
Posted by: kiloptero - 06-30-2024, 04:21 PM - Forum: KC868-A32/A32 Pro - Replies (1)
I would like some feedback on which system to buy. I am looking at the a32 and the m30. Apparently I am going to have more 32 circuits so it should have more than 32 connections like the a32 has. Any recommendations. My inspiration is the https://www.kincony.com/32ch-smart-distr...stant.html panel.
Best regards and thanks to all!
attached diagram
.zip   12062024 R0 CASA ROEPHERD.dwg.zip (Size: 1.14 MB / Downloads: 812)
  Lan problem
Posted by: Figge71 - 06-29-2024, 06:35 PM - Forum: KC868-A32M - Replies (2)
Hi! I'm having some problems with the Lan on my KC868-a32m.
When I receivedmy unit it worked fin, but now i can't get the Lan to connect.
Nether the Lan ligths on my switch or on my Kincony device lights up.
I would apriciate if you can guide me.
/Fredrik
  Kc868-AM and sensors
Posted by: fdcemb5 - 06-29-2024, 12:54 PM - Forum: KC868-AM - Replies (5)
My KC868-AM ports 14,13,5 is not working. I have connected several temperatures to these ports without success. Port 33 is working perfectly.
Is there any reason these ports are not responding
  V2.2.2 will not flash anymore
Posted by: Philadam - 06-29-2024, 05:08 AM - Forum: KC868-A16 - Replies (25)
I have an interesting problem.
After flashing my A16 with ESPHOME it will no longer flash KCS firmware v2.2.2.
I can flash my esphome bin many times without an issue.
I can flash v1.0.24 bin many times without an issue.
But when I try to flash v2.2.2, all appears normal, but the IP address I expect it at does not respond.
Scan tool does not detect it either.
I have also used esptool backup/resotre to flash and it still does not work.
Also does not show up as attached device in my router.
Any idea why v2.2.2 does not work anymore after flashing?
.txt   Flash Tool 3.9.2 90380CA3BE40.txt (Size: 747 bytes / Downloads: 598)
  1wire stopped working - KC868-A8
Posted by: deanfourie - 06-28-2024, 06:37 AM - Forum: KC868-A series and Uair Smart Controller - Replies (7)
Running esphome, lastest version, I have 4 of these board and only 1 has the issue.
No sensors found on the KC868-A8 on 1wire bus.
Any ideas?
Esphome config.
PHP Code:
one_wire:
  - platform: gpio
    pin
: GPIO14
sensor
  - platform: dallas_temp
    address
: 0x950121128170a628
    name
: "Temp"
The log,
PHP Code:
[18:36:35][C][logger:185]: Logger:
18:36:35][C][logger:186]:  Level: DEBUG
[18:36:35][C][logger:188]:  Log Baud Rate: 115200
[18:36:35][C][logger:189]:  Hardware UART: UART0
[18:36:35][C][i2c.arduino:071]: I2C Bus:
18:36:35][C][i2c.arduino:072]:  SDA Pin: GPIO4
[18:36:35][C][i2c.arduino:073]:  SCL Pin: GPIO5
[18:36:35][C][i2c.arduino:074]:  Frequency: 50000 Hz
[18:36:35][C][i2c.arduino:086]:  Recovery: bus successfully recovered
[18:36:35][I][i2c.arduino:096]: Results from i2c bus scan:
18:36:35][I][i2c.arduino:102]: Found i2c device at address 0x22
[18:36:35][I][i2c.arduino:102]: Found i2c device at address 0x24
[18:36:35][C][gpio.one_wire:020]: GPIO 1-wire bus:
18:36:35][C][gpio.one_wire:021]:  Pin: GPIO14
[18:36:35][W][gpio.one_wire:078]:  Found no devices!
  Technical consultation connection KC868-A16
Posted by: JulioVillamizar - 06-26-2024, 08:07 PM - Forum: KC868-A series and Uair Smart Controller - Replies (18)
Hello.
I am interested in purchasing a KC868-A16 board to connect the programmable outputs (PGM) of a DSC Neo Alarm Center to the digital inputs (dry contacts) of the KC868-A16.
My question stems from the fact that the PGM outputs of the DSC Neo deliver a negative referenced to the 12v positive of the same board.
And to connect this directly to the KC868-A16 I would have to put a relay in the middle but this is not feasible.
The other solution is to know if I can disconnect the 12v from the KC868-A16 in the input optocouplers and directly insert the 12 from the DSC Neo.
Could you confirm if this is viable at the board level?
