» Members: 10,451
» Latest member: ahmed-KC868-A6
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 702 online users.
» 0 Member(s) | 677 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  free sample
Posted by: suryaprakash - 07-09-2024, 04:28 AM - Forum: Apply for free sample product - No Replies
Dear Team,
I am a software engineer working in a Plastic recycling industry in India.
While googling for the Arduino automation I came across to the Kincony home automation server.
after going through the KinCony IoT channel on youtube it attracted my attention for the industrial automation.
I would like to start the new project on atomization of Extrusion project by extruder motor speed controlling using PWM and temperature zone with analog input and NO / NC replay output.
below is my details
Suryaprakash Sharma
VMS International
Plot no 66A, Govt Industrial Estate,
Village Masat, Silvassa, UT of Dadra and Nagar Haveli Daman and Diu - 396 230,
India
sharma.suryaprakash@gmail.com
Looking forward to hear from you.
Thanks & Regards
Surayprakash Sharma
  M30 Specifications
Posted by: Joshn - 07-09-2024, 04:21 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
I have a few questions regarding the specifications of the M30.
1. Is the PT (voltage) sensor connection mandatory? Can I connect CT only with NO connection of the PT 1,2 or 3?
2. What is the maximum current / amps that can be monitored for each CT channel? The schematic states Imax = 30A??...Can this unit monitor 50A on a single channel?
3. Can the CT's on bank 1-10 have a mix of phase 1 / 2 or 3?
  messed up deleted firmware
Posted by: QK-noliver - 07-08-2024, 09:18 PM - Forum: KC868-AI - Replies (3)
I thing i messed up with my board ive gone in with no knolage and installed esphome on the board from their web page but now the board is empty is there an recovery file for this? and is there also a simple gide to get it working with HA.
  MODBUS server- serial/TCP
Posted by: plam09 - 07-07-2024, 03:02 PM - Forum: KC868-A16 - Replies (1)
I'm looking at the KC868-A16 ESP32 board to buy one for a DIY project but from the description on the aliexpress page it only says 485 "Master".
My question is can I program the board to be a modbus server/slave and if yes on what interface - can the serial pins be used or is it just ethernet/modbus TCP?
Best regards!
  Reboot M30 Remotely
Posted by: WellsGoFar - 07-06-2024, 01:48 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Is there a way to reboot the M30 remotely?
Mine went offline and I had to got to the panel and unplug it. I would prefer to reboot it remotely. I can put it on a switched outlet, but thought I would ask here, too.
For instance, would restarting the esp32 cause a full board reboot?
https://esphome.io/components/button/restart.html
  automation and photovoltaic installation monitoring project
Posted by: zaki - 07-05-2024, 11:32 AM - Forum: Apply for free sample product - No Replies
Dear Kincony Team.
I am a web developer and server engineer. I came across your products on YouTube and I am in the process of developing a SAS for CMMS management of photovoltaic and thermal installations.
I would like to receive your product kits free of charge to integrate it into my automation and photovoltaic installation monitoring project.
These will allow me to become familiar with your products, use them on subsequent projects in the future and also market them to the customer as a better automation product.
Below is my detail
Zaki El-Ghassani Dharif
Tel and WhatsApp: +212666175852
zakidharif@gmail.com
I'm looking to hear from you. And also join your team
Sincerely
  ESP boad
Posted by: engr802@gmail.com - 07-04-2024, 12:29 PM - Forum: KC868-A16S - Replies (1)
please guide,  while programming A16s on arduino IDE, from which board to be select from many shown (ESP32 WROOM 32U not shown).
thanks
  Factory reset
Posted by: Chestie - 07-04-2024, 06:25 AM - Forum: KC868-E16T - Replies (1)
Hello team,
is there any way to factory reset the board?
I deactivated the wifi inside and my router is not able to assign an IP somehow when connected by ETH so I cannot interact with it.
Any ideas? Smile
  KC868-D16 - what's the max load(s)?
Posted by: andy - 07-03-2024, 10:03 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
Some questions about KC868-D16.
First one - what is the maximum load [Watt] per channel and max summary for module?
Second one - what's the dimming type? Phase-cut dimming, Pulse Width Modulation, Resistance dimming or some else?
And additional little out of topic - can this module work directly with Tuya, without any additional Kincony's controller/gateway/etc?
Regards.
  EnEnergy calculation on M30
Posted by: WellsGoFar - 07-03-2024, 09:35 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (3)
I am trying to ask good questions, but am unsure of the exact terminology to use here. Please be patient with me.
Do I need to have voltage lines in on all 3 of the M30 ports, or can I use the voltage in only one of the 3?
Do I need to make a change in the yaml file to use voltage line 1 with energy 2_1 computation?
For US Split Phase, does the voltage line in need to be the same circuit measured in the current lines in that bank?
